Inception Hosting - NAT Bundle - 3 VPS (UK,NL,USA) for €5.10 p/year TOTAL!
2»
    greensysadmin said: (full Wireguard requires a host node kernel module to be active on OpenVZ/Virtuozzo, and it's not on any LES providers that I know of - if there are any be known :-)):
    Which one?
    Thanked by (1)greensysadmin
    Which one?
    https://wiki.openvz.org/VPN_using_Wireguard
    Looks like vzkernel-devel plus adding a yum repo and configging interfaces. Doesn't survive package updates, so totally appreciate all that combined is a headache when the userspace implementation gives good enough performance.
    edited November 2019
    Ah ok, yeah having read that doc that is not currently even close to being in any of the solusvm automation so your other method is the one to go for in VZ.
  • @sonic said:
    Hey @Nyr, I really love your OpenVPN script! Do you have plan to make WireGuard script also for NAT VPS?
    Probably, but when it is a bit more mature (for example, when packages are available in the main distributions, which will happen with the next Debian release or when there is a 1.0 release available).
    I am always very conservative with this stuff, so it will happen when it feels really ready for production everywhere, I don't want my installer to be the first, I want it to be the best.
  • h021kkh021kk OG
    edited December 2019
    @greensysadmin said:
    He might, but it's actually reasonably simple to setup the userspace wireguard-go binary yourself with this guide (full Wireguard requires a host node kernel module to be active on OpenVZ/Virtuozzo, and it's not on any LES providers that I know of - if there are any be known :-)):
    https://d.sb/2019/07/wireguard-on-openvz-lxc
    Notes from me:
    Thank you @greensysadmin for your tips and pointing attention. I am also big fan of Nyr & really appreciate his contribution. Also big thanks to Daniel who wrote guide on "WireGuard on OpenVZ/LXC" https://d.sb/2019/07/wireguard-on-openvz-lxc . I have tried & tested Daniel's guide and its even working on Debian OpenVZ6 & 7 NAT VPS
    OpenVZ6
    Debian 8.11 x64 - 128MB NAT VPS Kernal: 2.6.32-042stab130.1
    Debian 8.11 x64 - 256MB NAT VPS Kernal: 2.6.32-042stab140.1
    1. Only one client is working, tried to add multiple clients but still only one client worked
    2. IPv6 doesn't work
    3. Speed is faster than Openvpn
    4. low memory usage
    OpenVZ7
    Debian 9.11 x64 - 512MB NAT VPS - Kernal: 4.9.0
    1. Multiple clients working
    2. IPv6 working
    3. Speed is good
    4. low memory usage
    KVM
    Used installer of https://github.com/l-n-s/wireguard-install
    1. Automated installer for setup, adding clients & clients profile file.
    2. IPv6 worked when added manually in wg0.conf
    3. Speed is very good
    4. low memory usage
    Big Thanks to Daniel (https://d.sb/2019/07/wireguard-on-openvz-lxc). If anyone try to play, here are the details and commands. I have used Daniel's guide, please follow all steps, I added few commands as i got errors i.e apt install make and wg-quick up wg0 and wg-quick down wg0
    echo "deb http://deb.debian.org/debian/ unstable main" > /etc/apt/sources.list.d/unstable.list && printf 'Package: *\nPin: release a=unstable\nPin-Priority: 90\n' > /etc/apt/preferences.d/limit-unstable && apt update
    apt install wireguard-tools --no-install-recommends
    cd /tmp && wget https://dl.google.com/go/go1.13.4.linux-amd64.tar.gz && tar zvxf go1.13.4.linux-amd64.tar.gz && sudo mv go /opt/go1.13.4 && sudo ln -s /opt/go1.13.4/bin/go /usr/local/bin/go
    go version
    (have to install make, it wasn't install in my vps)
    apt install make
    cd /usr/local/src && wget https://git.zx2c4.com/wireguard-go/snapshot/wireguard-go-0.0.20191012.tar.xz && tar xvf wireguard-go-0.0.20191012.tar.xz && cd wireguard-go-0.0.20191012
    (set these variables if you are using VPS less than 256MB)
    nano device/queueconstants_default.go
    MaxSegmentSize = 1700
    PreallocatedBuffersPerPool = 1024
    (Run make command)
    make
    sudo cp wireguard-go /usr/local/bin
    wireguard-go --version
    (Create public & private keys for Server)
    wg genkey | tee private key | wg pubkey > publickey
    nano /lib/systemd/system/[email protected]
    add this line directly below
    Environment=WG_I_PREFER_BUGGY_USERSPACE_TO_POLISHED_KMOD=1
    (Perform these commands or wg0-quick will give error and wg0 interface won't come UP)
    wg-quick up wg0
    wg-quick down wg0
    Add following two lines in Server [Interface] /etc/wireguard/wg0.conf only if you using only IPv4
    PostUp = iptables -t nat -A POSTROUTING -o venet0 -j MASQUERADE
    PostDown = iptables -t nat -D POSTROUTING -o venet0 -j MASQUERADE)
    For IPv6, add these in /etc/wireguard/wg0.conf
    PostUp = iptables -t nat -A POSTROUTING -o venet0 -j MASQUERADE; ip6tables -t nat -A POSTROUTING -o venet0 -j MASQUERADE
    PostDown = iptables -t nat -D POSTROUTING -o venet0 -j MASQUERADE; ip6tables -t nat -D POSTROUTING -o venet0 -j MASQUERADE
    systemctl enable wg-quick@wg0
    systemctl start wg-quick@wg0
    wg
    (check wg running)
    Install Wireguard Client. I have used android and windows 10 client. Generate public and private keys in client software/App and set client "public key" in server wg0.conf on SERVER & set server "public key" in CLIENT
    thats it
    Following are my conf
    OpenVZ6 VPS
    Server Config /etc/wireguard/wg0.conf
    [Interface]
    Address = 10.66.66.1/24
    PrivateKey = PRIVATE KEY OF SERVER
    ListenPort = PORT
    SaveConfig = false
    [Peer]
    PublicKey = PUBLIC KEY OF CLIENT
    AllowedIPs = 10.66.66.3/24
    Client Config
    [Interface]
    PrivateKey = PRIVATE KEY OF CLIENT
    Address = 10.66.66.3/24
    DNS = 8.8.8.8, 8.8.4.4
    [Peer]
    PublicKey = PUBLIC KEY OF SERVER
    AllowedIPs = 0.0.0.0/0, ::/0
    Endpoint = SERVER IP:PORT
    PersistentKeepalive = 25
    Frequently used commands
    nano /etc/wireguard/wg0.conf
    systemctl status wg-quick@wg0
    systemctl stop wg-quick@wg0
    wg-quick up wg0
    wg-quick down wg0
    OpenVZ7
    [Interface]
    Address = 10.123.0.1/24,fd42:42:42::1/80
    ListenPort = PORT
    SaveConfig = false
    [Peer]
    PublicKey = PUBLIC KEY OF CLIENT1
    AllowedIPs = 10.123.0.3/32,fd42:42:42::3/128
    [Peer]
    PublicKey = PUBLIC KEY OF CLIENT2
    AllowedIPs = 10.123.0.4/32,fd42:42:42::4/128
    Client1 Config
    [Interface]
    PrivateKey = PRIVATE KEY OF CLIENT1
    Address = 10.123.0.3/24, fd42:42:42::3/80
    DNS = 8.8.8.8, 8.8.4.4, 2001:4860:4860::8888
    [Peer]
    Client2 Config
    [Interface]
    PrivateKey = PRIVATE KEY OF CLIENT2
    Address = 10.123.0.4/24, fd42:42:42::4/80
    [Peer]
    Thanked by (1)flips
