Really cheap San Jose VPS
Anyone have recommendations? Very tiny is fine - 128/256MB RAM, 5GB disk or less. Local cache for some JS/CSS. DDoS protection unnecessary but would be nice. Xen PV, Xen HVM, VMware, or KVM required.
Can pay with PP or BTC. Ideally less than 2-3ms to Internap SJC or Santa Clara.
  • WSSWSS Retired
    edited January 2020
    VIrmach?
    E: Oh. They won't let you do 256s in San Jose now likely due to abuse. Sucks.
    TinyKVMs' LA spot is about 8ms from if that's good enough.
  • No CC, unfortunately. Generally weird results.
    Thanked by (1)vpsgeek
  • If Fremont might be close enough then check with @freerangecloud
    HS4LIFE (+ (* 3 4) (* 5 6))
  • just checked to confirm - getting 2 sometimes 3 ms ping from freerangecloud in Fremont to Virmach in San Jose
    @freerangecloud will probably be your best bet for cheap mini deal (might be able to get something for $15 yearly)
    other options, not exactly cheap: AquaNX (San Jose) and Atlantic.net (Santa Clara)
  • WSSWSS Retired
    He doesn't want Virmach. He wants InterNap in San Jose.
    Thanked by (1)uptime
  • uptimeuptime OG
    edited January 2020
    @WSS - thanks, indeed I am suggesting freerangecloud - just using VirMach to test ping time from freerangecloud in Fremont.
    figuring if it can do 2 ms ping to Virmach in San Jose, chances are decent could see similar latency from freerangecloud in Fremont to InterNap in San Jose.
    That is all. :)
  • @WSS said: He doesn't want Virmach. He wants InterNap in San Jose.
    Virmach's US West locations seem to be very... random when it comes to performance. I assume because of the huge amount of VPN users running there.
    The destination for NFS/etc is Internap SJ. This VPS can be mostly anywhere close enough.
  • WSSWSS Retired
    I remember when InterNap came to ask us to use them and we were like PFFT we dual homed, we got a T1 and another T1. Whatchuu want bitch?
    Of course, that was 1999, so..
    Thanked by (1)skorous
  • I bought a Kamatera $9/m in Santa Clara. It looks like Cogent. Perf is kind of meh. Any others?
    edited January 2020
    Upcloud.
    Aff Signup link
    Aff signup for $25 credits.
    San Jose using Gold 6136, dont know where but it has IPv6 so definitely not CC
    Thanked by (2)uptime poisson
  • uptimeuptime OG
    edited January 2020
    vultr also has SJ location:
    http://sjo-ca-us-ping.vultr.com/
    Thanked by (1)cybertech
  • uptimeuptime OG
    edited January 2020
    @uptime said:
    derp. (double post)
  • freerangecloudfreerangecloud Hosting ProviderOG
    We do a $15/yr special, 512MB RAM, 15GB disk in Fremont (thanks for tagging us in @uptime). If you send me an IP I can ping it from our infra and let you know what the latency is. Alternatively, our looking glass is: http://fmt.lg.freerangecloud.com/
    https://freerangecloud.com - VPS, shared hosting, LIR services & more!
  • Is Seattle OK? FWIW, I live near San Jose and Cloudflare often routes via Seattle for me. MrVM has a location in Seattle, as does RamNode. Los Angeles might give you slightly better pings to the Bay Area though.
