Free for life ! KVM storage 1tb hdd for the customer number 100-200-300-400-500-600-700-800-900-999!
1910121415
  • The magic concatenated crowdsourced digits are: 2562852951896884411038506926702020752420420242042018472438753189
    The hash is: 85f6281b34035fe6dc33a920d1fbea5e08d3a207b2a7227693220ad20286ca33
    The lucky winner is @pascal (member #389) - and as luck would have it, it seems that @pascal is indeed active here.
    Assuming they respond to my PM within the next 72 hours to claim the fine fine superfine free for life 1 TB KVM storage prize, then it's a done deal!
    (Otherwise we'll move on to the backup selection #584 and after that if necessary #239 ...)
    Congratulations @pascal! And thanks @cociu for the generous prize!
    Also big ups to all the people who contributed their very best pseudorandom digits to facilitate a fair selection process :)
    I'll start the magic numbers for the next selection for signup #900: 389584239
    plus a secret to be revealed before the next selection, after signup #900
    the secret hashes to: dd4a7df5114bcc9c0c8b506923637e48fb2d5b94a01512c4a11b24758d1ca1b8
    Please add your favorite magic numbers to the mix!
    notes:
          import random
    random.seed(0x85f6281b34035fe6dc33a920d1fbea5e08d3a207b2a7227693220ad20286ca33)
    random.randint(1,800) 389 random.randint(1,800) 584 random.randint(1,800) 239
    echo -n "2562852951896884411038506926702020752420420242042018472438753189" | sha256sum
    @uptime said: I'll start with 256285295189 followed by a secret salt sequence.
    The secret salt will be revealed before the next hash/seed is generated, after the 800th signup.
    The secret salt hashes to f704239842f4001e8d47210e9b818af1e1ea345c3e4743d2a3a92f722a8ed36b
    teh secret salt revealed: 68844110385069
    echo -n "68844110385069"
    68844110385069df@re:~$ echo -n "68844110385069" | sha256sum
    @souen said: 2670 - from the latest Joy of Tech comic
    @Rahul said: 2020
    @IV said: 752, provided by google random number generator
    @dahartigan said: 420420
    @terrorgen said: 2^420420 + 1
    ah ... that's going to be like 10 pages of tl;dr digits, so let's just call it 24204201 mkay? :smiley:
    @flips said: 8472 (Ref. Star Trek Voyager)
    @deepak_leb said: 4387
    @MS said: 53189
    Thanked by (1)pascal
    HS4LIFE (+ (* 3 4) (* 5 6))
  • Oh my! That is awesome, thanks @uptime and @cociu. I’ll try to be a little more active around these parts, though I am indeed excellent at lurking around... :-)
    Thanked by (1)uptime
  • Well played @pascal, well played indeed.
    Lurkers are legit <3
  • 131026 for next draw
  • £2.50
  • ~$3.50
  • WSSWSS Retired
    Butts.
  • 8008135
    Thanked by (2)WSS dahartigan
  • Thanks to @cociu for the VPS!
    Here are some benchmarks:
    nench.sh v2019.07.20 -- https://git.io/nench.sh
    benchmark timestamp: 2020-01-25 20:57:03 UTC
    Processor: Common KVM processor
    CPU cores: 1
    Frequency: 1795.672 MHz
    RAM: 990M
    Swap: 819M
    Kernel: Linux 3.10.0-1062.1.1.el7.x86_64 x86_64
    Disks:
    sda 1T HDD
    CPU: SHA256-hashing 500 MB
    7.711 seconds
    CPU: bzip2-compressing 500 MB
    CPU: AES-encrypting 500 MB
    8.973 seconds
    ioping: seek rate
    min/avg/max/mdev = 170.8 us / 356.7 us / 29.0 ms / 855.0 us
    ioping: sequential read speed
    generated 9.10 k requests in 5.00 s, 2.22 GiB, 1.82 k iops, 455.1 MiB/s
    dd: sequential write speed
    1st run: 177.38 MiB/s
    2nd run: 348.09 MiB/s
    3rd run: 313.76 MiB/s
    average: 279.74 MiB/s
    IPv4 speedtests
    your IPv4: 193.148.71.xxxx
    Cachefly CDN:         39.01 MiB/s
    Leaseweb (NL):        0.24 MiB/s
    Softlayer DAL (US):   3.41 MiB/s
    Online.net (FR):      5.56 MiB/s
    OVH BHS (CA):         4.07 MiB/s
    I am unsure what I'll use the instance for... But I'll find a use :smiley:
  • 2^80, then take first 10 digits if longer than 10
  • uptimeuptime OG
    edited January 2020
    As you wish:
    python -c 'print(str(2**80)[:10])'
    1208925819
    EDIT: by the way, 2^420420 + 1 is (probably) not prime :)
  • Congrats
  • 11001101 10011101 11101111 11100110
  • Here we go again
    69
  • 6881
    2915
    62925
    13278
    Either treat them as one or as four.
  • 97087
  • 8305
  • 46156
  • 84225
  • souensouen OG
    edited January 2020
  • uptimeuptime OG
    edited January 2020
    Thanks @beagle and @souen for freshening up our prem pseuodrando digits
    Llooks like we just got to the 900th signup a few hours ago: https://talk.lowendspirit.com/profile/900/name
    which was after the 84225 from @beagle - but before the 20090526 from @souen (so we'll end the current string for hashing with 84225, and begin the next one with 20090526)
    and I shall commence to gather the spoons to do the needful hashery for the current selection shortly :)
    Thanked by (3)beagle Kyle_ souen
  • secret was 3594351797809761419
    crowsourced digits: 389584239359435179780976141913102625035080081351208925819110011011001110111101111111001106691456881291562925132789708783054615684225
    first three selections: 600, 235, 23
    https://talk.lowendspirit.com/profile/600/name
    https://talk.lowendspirit.com/profile/235/name
    https://talk.lowendspirit.com/profile/23/name
    of which I see the first @Baris (#600) looks to be bogus (that is to say, "unconfirmed" since December 2019) - let's not waste time waiting to hear back from that one.
    so ... next up is @Piso91 (#235) - who has indeed made a few visits ... last active January 1st. Alrighty then! I'll send them a PM and hope for response within 72 hours
    And after that will move on to a true OG (#23) ... omg it's @ITLabs
    Notes:
    echo -n 3594351797809761419 | sha256sum
    echo -n "389584239359435179780976141913102625035080081351208925819110011011001110111101111111001106691456881291562925132789708783054615684225" | sha256sum
    5cd16c7be8e777dea9fa08e6feb1d01cace344401233ba74437e8fa1ff6df094
    python3
    Python 3.6.9 (default, Nov  7 2019, 10:44:02)
    [GCC 8.3.0] on linux
    Type "help", "copyright", "credits" or "license" for more information.
          import random
    random.seed(0x5cd16c7be8e777dea9fa08e6feb1d01cace344401233ba74437e8fa1ff6df094)
    random.randint(1,900) 600 random.randint(1,900) 235 random.randint(1,900) 23 random.randint(1,900) 134 random.randint(1,900) 746
    the secret is: 3594351797809761419
    @beagle said: 131026 for next draw
    @uhu said: £2.50
    @dahartigan said: ~$3.50
    @WSS said: Butts.
    @uptime said: 8008135
    @terrorgen said: 2^80, then take first 10 digits if longer than 10
    1208925819
    @flips said: 11001101 10011101 11101111 11100110
    @Rahul said: 669
    @Iroshan464 said: 145
    @debaser said:
    6881
    2915
    62925
    13278
    @beagle said: 97087
    @MS said: 8305
    @dosai said: 46156
    @beagle said: 84225
  • 02022020
  • 123
  • 88888888
  • 30321
    45512
    11713
    82314
    35315
  • hmmmm ... I've got some catching up to do here.
    Apologies for the delay - I got a bit drunk last night and ummmmm ... found myself challenged to muster the required attention to detail for this very important business.
    (shit's getting real here yo!)
    no response from @Piso91, so ... next up is OG @ITLabs (!) - I will take some time to compose a proper "hey what's up" PM and then come back to do the needful for SELECTION #999 and beyond ...! :scream:
    Thanked by (1)Kyle_
  • 96937
  • we actually hit signup #999 yesterday: https://talk.lowendspirit.com/profile/999/name
    and 1000 ... and ... and ...
    as I type, it looks like we are up to https://talk.lowendspirit.com/profile/1024/name aka @StopForumSpam
    but let's just take a moment to celebrate all the friends we've made along the way!
    with an extra special shout out to @xraycreampie and @maskedmilfdp
    (it's times like these I ask myself: "What Would Nekki Do?" ... Okay, just keep calm and carry on I guess!)
    tl;dr: we've been moving just a wee bit faster than originally anticipated, but damn the spammers - full speed ahead! :scream:
    @uptime said: we'll end the current string for hashing with 84225, and begin the next one with 20090526
    the secret is: there was no secret! The only digits submitted before #999 were the 20090526 from @souen
    hahahahahaha deal with it! :sunglasses:
    echo -n "20090526" | sha256sum
    6240f41f843aa0ea74ed613bb0ba050ca02f3451e7df58f79772941a2b5de70b
    python3
          import random
    random.seed(0x6240f41f843aa0ea74ed613bb0ba050ca02f3451e7df58f79772941a2b5de70b)
    random.randint(1,999) 18 random.randint(1,999) 319 random.randint(1,999) 410 random.randint(1,999) 510 random.randint(1,999) 155
    and (drumroll ...) https://talk.lowendspirit.com/profile/18/name is ...
    [spoiler]
    @HostDoc
    [/spoiler]
    alrighty then - will send a PM and let's see what's up, doc!
    some backup selections, if we go a few days (aka 72 hours) without hearing back:
    https://talk.lowendspirit.com/profile/319/name
    https://talk.lowendspirit.com/profile/410/name
    https://talk.lowendspirit.com/profile/510/name
    :smiley:
    Also, I sent a PM to @ITLabs (backup for previous draw) a few hours ago - really hoping to hear back by the end of the week, let's see what happens.
    As for the drawings for #1000 and beyond - we're going to open a new thread for those. Maybe we can take a little time to gather our wits and see if any adjustment to our ... process ... might be warranted.
    (I'm thinking mainly about how to account for the recently increasing number of spam accounts - though that particular issue may have been resolved at this point.)
    Questions, suggestions, and of course moar rando digits welcome
    Thanked by (3)poisson ouvoun beagle
