NVMe SSD KVM - UK - DDOS Protected - Free DA || 50% OFF || Free 2nd IP or Double Disk.
InceptionHostingInceptionHosting Hosting ProviderOG
I have some space, thought I would do a promo :)
This promotion applies to any 2GB, 3GB, 4GB or 8GB VPS on a semi annual or annual basis.
Promotion code: ssdkvm2020
Plans below listed with double disk, open a ticket to choose double disk or 2nd IP after payment.
vCPU RAM DISK 6 Months yearly Order Link
2 x E31270v6 2GB DDR4 30GB €15 €30 ORDER
2 x E31270v6 3GB DDR4 40GB €22.50 €45 ORDER
2 x E31270v6 4GB DDR4 50GB €30 €60 ORDER
All UK SSD KVM plans benefit from:
  • Free Direct Admin licenses.
  • Free DDOS protection
  • @Clouvider 's excellent network
  • Daily full virtual disk image backup to a separate local raid array (DR Only)
Benchmarks:
 Benchmark started on 13-Jan-2020 08:00:51
 ## System Information
 OS Name     : Debian GNULinux 10 \ (64 bit)
 Kernel      : KVM / 4.19.0-5-amd64
 Hostname    : test9
 CPU Model   : Intel(R) Xeon(R) CPU E3-1270 v6 @ 3.80GHz
 CPU Cores   : 2 cores @  3792.008 MHz
 CPU Cache   : 16384 KB
 Total RAM   : 1995 MiB (Free 1812 MiB)
 Total SWAP  : 255 MiB (Free 255MiB)
 Total Space : 16GB (10% used)
 Running for : 38 minutes 56 seconds
 ## CDN Speedtest
 CacheFly :  92.59 MiB/s |  740.74 Mbps  | ping   1.176ms
 Gdrive   :       0 B/s |      N/A       | ping   1.808ms
 ## North America Speedtest
 Softlayer, Washington, USA :   1.38 MiB/s |   11.08 Mbps  | ping 131.512ms
 SoftLayer, San Jose, USA   : 954.86 KiB/s |    7.46 Mbps  | ping 144.266ms
 SoftLayer, Dallas, USA     :       0 B/s |      N/A       | ping error!
 Vultr, New Jersey, USA     :  24.71 MiB/s |  197.65 Mbps  | ping  71.224ms
 Vultr, Seattle, USA        :  13.05 MiB/s |  104.37 Mbps  | ping 127.839ms
 Vultr, Dallas, USA         :  13.61 MiB/s |  108.92 Mbps  | ping 108.305ms
 Vultr, Los Angeles, USA    :  12.09 MiB/s |   96.68 Mbps  | ping error!
 Ramnode, New York, USA     :  12.52 MiB/s |  100.15 Mbps  | ping 104.571ms
 Ramnode, Atlanta, USA      :   9.52 MiB/s |   76.16 Mbps  | ping  87.593ms
 OVH, Beauharnois, Canada   :   4.60 MiB/s |   36.83 Mbps  | ping  76.491ms
 ## Europe Speedtest
 Vultr, London, UK            : 107.53 MiB/s |  860.22 Mbps  | ping   1.372ms
 LeaseWeb, Frankfurt, Germany :  46.36 MiB/s |  370.90 Mbps  | ping  13.331ms
 Hetzner, Germany             :  30.05 MiB/s |  240.38 Mbps  | ping  22.289ms
 Ramnode, Alblasserdam, NL    :  80.28 MiB/s |  642.20 Mbps  | ping  15.591ms
 Vultr, Amsterdam, NL         :  88.50 MiB/s |  707.96 Mbps  | ping  10.770ms
 EDIS, Stockholm, Sweden      :   2.10 KiB/s |    0.02 Mbps  | ping  30.850ms
 OVH, Roubaix, France         :  92.76 MiB/s |  742.12 Mbps  | ping   4.759ms
 Online, France               :  98.01 MiB/s |  784.11 Mbps  | ping   9.503ms
 Prometeus, Milan, Italy      :     150 B/s |      N/A       | ping  25.688ms
 ## Exotic Speedtest
 Sydney, Australia     : 844.21 KiB/s |    6.60 Mbps  | ping 301.696ms
 Lagoon, New Caledonia :       0 B/s |      N/A       | ping error!
 Hosteasy, Moldova     :  10.12 MiB/s |   80.95 Mbps  | ping  54.183ms
 Prima, Argentina      : 380.76 KiB/s |    2.97 Mbps  | ping error!
 ## Asia Speedtest
 SoftLayer, Singapore :   1.24 MiB/s |    9.96 Mbps  | ping 156.671ms
 Linode, Tokyo, Japan :   5.74 MiB/s |   45.96 Mbps  | ping 217.234ms
 Linode, Singapore    :   6.13 MiB/s |   49.01 Mbps  | ping 153.564ms
 Vultr, Tokyo, Japan  :   3.18 MiB/s |   25.41 Mbps  | ping 213.080ms
 ## IO Test
 CPU Speed:
    bzip2 512MB -   302 MB/s
   sha256 512MB -   289 MB/s
   md5sum 512MB -   472 MB/s
 Disk Speed (512MB):
   I/O Speed  - 1.2 GB/s
   I/O Direct - 407 MB/s
 RAM Speed (1024MB):
   Avg. write - 3959.5 MB/s
   Avg. read  - 7304.5 MB/s
General Terms:
  1. No tor
  2. No torrenting
  3. CPU abuse policy is the very first thing in the terms, it is enforced when it impacts others.
  4. 48 hour refund window for promos, applies to your first service only.
  5. No open proxies.
  6. No bulk mail
  7. Any support is offered is free and low priority unless a paid support add-on is taken (optional)
  8. Outside of DR situations (full node) restores are charged at €10 and completed within 24 hours.
  9. Your data is called 'your data' for a reason, look after it!
Thanked by (2)beagle nullnothere
  • Hi @AnthonySmith - could you allocate a /64 IPv6 with the additional IPv4 (effectively the VPS will have 2 x IPv4 and 2 x /64 IPv6)?
    @nullnothere said: Hi @AnthonySmith - could you allocate a /64 IPv6 with the additional IPv4 (effectively the VPS will have 2 x IPv4 and 2 x /64 IPv6)?
    I can, curious as to the use case but I certainly don't mind doing that.
    Thanked by (1)nullnothere
    Seems like nested virt can effectively split 1 VPS into 2?
  • @AnthonySmith said: I can, curious as to the use case but I certainly don't mind doing that.
    It seems that in general, anything bad at the IPv6 level will pretty much effect the entire /64. So it's nice to have an extra /64 to avoid headaches and keep everything separate ala IPv4.
    @cybertech said: Seems like nested virt can effectively split 1 VPS into 2?
    I guess this could be a use case but I didn't really think of this at all. Depending on the RAM, this could also help but realistically a /80 or something like that could get equivalent functionality.
  • I have been in LE world since 2014 & InceptionHosting is one of the 3 providers who have been consistently top notch as evident from providers polls in the old world. Deals like this from Anthony should not be missed
    Thanked by (2)dahartigan uptime
  • evnixevnix OG
    edited January 2020
    @AnthonySmith said: No tor
    No torrenting
    No open proxies.
    No bulk mail
    Looks more like a threat rather than an offer but I do understand most of the above, but CPU is not something we as customers can control, lots of traffic or some malfunction in code can cause it.
    Usually I as a customer would expect hosts to throttle it on their side.
    if a host doesn't have the infrastructure to throttle it, being specific helps, like,
    CPU usage shouldn't be over 90% for more than a minute or something like that.
    Avg CPU usage shouldn't cross 50%
    If we know the specific thresholds, We as customers can write special programs that monitor such CPU usage and kill/restart programs that go over the specified threshold.
    Just venting my frustration because my server has been suspended for silly reasons by some providers just because some bot was trying to brute force SSH login into my VPS which caused a CPU spike on my VPS. I hope you understand the view from our side.
    @evnix said: Looks more like a threat rather than an offer but I do understand most of the above, but CPU is not something we as customers can control, lots of traffic or some malfunction in code can cause it.
    I assure you it is not a threat, it is being very transparent everything there is in the terms that 99/100 people will not read.
    It is a self managed service, you actually can control your own CPU use as a customer and you can most certainly monitor it, it is only enforced when it impacts others or when for example you have gone 5 days at 100% of a CPU core, this literally happens multiple times per day so I like to make sure people know this is not just a service that allows abuse, it is a shared resource environment, if you want dedicated CPU that you do not need to care about monitoring then you need a dedicated server not a VPS.
    I would say I am very liberal about it but I do expect you as a customer to take some responsibility, in fact I insist that you do :)
    Again, not a threat just not a hidden term.
    Thanked by (3)evnix vpsgeek dahartigan
  • @AnthonySmith said: It is a self managed service, you actually can control your own CPU use as a customer and you can most certainly monitor it, it is only enforced when it impacts others or when for example you have gone 5 days at 100% of a CPU core
    Thanks for clarifying this :smile:
  • sonicsonic OG
    edited January 2020
    Hi @AnthonySmith , is price be increased a little bit?
    @sonic the prices above are € EUR, you ordered in $ USD.
    Thanked by (1)sonic
    Thanks for the clarification <3
  • Had sent the link to a few friends to take advantage of the deal & one of them reported today that it is not working. Has it expired?
    edited February 2020
    Yep sorry was only valid for January :)
    I will put something new out this month when i have had a chance to asses things, lots of changes going on at the moment.
    Thanked by (1)vpsgeek
    Any plans for similar deals in February? :)
    I will take a look towards the middle of the month, lots going on right now with shutting down the old legacy xen service, removing the serversnv brand and UK VZ7 node migrations.
    You forgot this @AnthonySmith , any KVM deal soon?
    Thanked by (2)nhocconan benj0x
    Not so much forgot just still a lot going on.
  • But we want our unsustainable lower than low offers :(
    KVM wise I am pretty much full to the brim so only space at regular prices atm.
    As I understand it a tech preview of solus.io is coming very soon and I hope they also announce a target release date (or at least Year+Quarter) so I can start planning around that, seems pointless standing up new hardware right now if big changes are coming.
  • vyasvyas OGContent Writer
    Oh boy!
    @AnthonySmith
    Not a popular line on the other site... rather popular for the wrong reasons.
    Coming to the topic: fair to say that the coins may stay in the piggy bank till Mid- April?
    @vyas said: Not a popular line on the other site
    lol yeah, I should catch myself on before saying that.
    @vyas said: fair to say that the coins may stay in the piggy bank till Mid- April?
    Yep probably until summer tbh unless the right deal comes along from @funkywizard or @Clouvider that simply cant be turned down, I have some spare NVMe and sata drives at clouvider london so you never know.
    I am sorting out big changes this month and early march with the removal of serversnv and the legacy xen stuff which I need to focus on to do it right, then I will take a measure of what I have and what I need, the issue now is that I know everyone leaves it until last minute and I dont want to sell space that those coming from serversnv and xen may need.
    It has been a steady stream, a few customers per day, I will send out the final reminder this weekend and then lights go off on the 1st march, I am being pretty strict about it this time, I usually give people an extra 7 days after the deadline, this time its 24 hours as months of notice has been given already with multiple reminders.
    Anyway, rambling now but essentially, I expect to stand up new hardware with @clouvider at some point in march, not sure where that will be yet London or Amsterdam and I know IOflood are crunching numbers for me on the possibility of some AMD based servers so it just depends what is most appealing when its time to pull the trigger.
  • edited February 2020
    Was going for a KVM for my new project, But you have stopped me.
    some point in march
    oh, how can I not wait for that? How can we help you to make that "some point" as "first week"?
    please be London
    @PHP_Backend said: oh, how can I not wait for that? How can we help you to make that "some point" as "first week"?
    You cant :) it is more likely to be 2nd or 3rd.
