Host over 100 sites
--------------------------------------------------------------------------- Region: Global https://bench.monster v.1.5.0 2020-01-11 Usage : curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -Global --------------------------------------------------------------------------- OS : CloudLinux 7.7 (64 Bit) Virt/Kernel : OpenVZ / 3.10.0-962.3.2.lve1.5.27.el7.x86_64 CPU Model : AMD Ryzen 9 3900X 12-Core Processor CPU Cores : 12 @ 3792.874 MHz x86_64 512 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Enabled Load Average : 0.43, 0.49, 0.52 Total Space : 354G (92G ~26% used) Total RAM : 11851 MB (3735 MB + 7457 MB Buff in use) Total SWAP : 6143 MB (0 MB in use) Uptime : 20 days 23:20 --------------------------------------------------------------------------- ASN & ISP : AS23470, Nexus Bytes LLC Organization : NBL-74 Location : Los Angeles, United States / US Region : California --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 5241 (EXCELLENT) Multi Core : 30281 ## IO Test CPU Speed: bzip2 : 110 MB/s sha256 : 659 MB/s md5sum : 518 MB/s RAM Speed: Avg. write : 2457.6 MB/s Avg. read : 5017.6 MB/s Disk Speed: 1st run : 706 MB/s 2nd run : 725 MB/s 3rd run : 760 MB/s ----------------------- Average : 730.3 MB/s
@gtxr said: Host over 100 sites --------------------------------------------------------------------------- Region: Global https://bench.monster v.1.5.0 2020-01-11 Usage : curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -Global --------------------------------------------------------------------------- OS : CloudLinux 7.7 (64 Bit) Virt/Kernel : OpenVZ / 3.10.0-962.3.2.lve1.5.27.el7.x86_64 CPU Model : AMD Ryzen 9 3900X 12-Core Processor CPU Cores : 12 @ 3792.874 MHz x86_64 512 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Enabled Load Average : 0.43, 0.49, 0.52 Total Space : 354G (92G ~26% used) Total RAM : 11851 MB (3735 MB + 7457 MB Buff in use) Total SWAP : 6143 MB (0 MB in use) Uptime : 20 days 23:20 --------------------------------------------------------------------------- ASN & ISP : AS23470, Nexus Bytes LLC Organization : NBL-74 Location : Los Angeles, United States / US Region : California --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 5241 (EXCELLENT) Multi Core : 30281 ## IO Test CPU Speed: bzip2 : 110 MB/s sha256 : 659 MB/s md5sum : 518 MB/s RAM Speed: Avg. write : 2457.6 MB/s Avg. read : 5017.6 MB/s Disk Speed: 1st run : 706 MB/s 2nd run : 725 MB/s 3rd run : 760 MB/s ----------------------- Average : 730.3 MB/s
Boss, I hope you are happy and satisfied:). Thank you for being a member of the family
Nexus Bytes Ryzen Powered NVMe VPS | NYC|Miami|LA|London|Netherlands| Singapore|TokyoStorage VPS | LiteSpeed Powered Web Hosting + SSH access | Switcher Special |
@seriesn said: Boss, I hope you are happy and satisfied:). Thank you for being a member of the family
too much cpu idling ... load average less than 1 from 12 total cpu..more than happy
Can't go wrong with a NEB LEB.
Host over 100 sites
--------------------------------------------------------------------------- Region: Global https://bench.monster v.1.5.0 2020-01-11 Usage : curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -Global --------------------------------------------------------------------------- OS : CloudLinux 7.7 (64 Bit) Virt/Kernel : OpenVZ / 3.10.0-962.3.2.lve1.5.27.el7.x86_64 CPU Model : AMD Ryzen 9 3900X 12-Core Processor CPU Cores : 12 @ 3792.874 MHz x86_64 512 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Enabled Load Average : 0.43, 0.49, 0.52 Total Space : 354G (92G ~26% used) Total RAM : 11851 MB (3735 MB + 7457 MB Buff in use) Total SWAP : 6143 MB (0 MB in use) Uptime : 20 days 23:20 --------------------------------------------------------------------------- ASN & ISP : AS23470, Nexus Bytes LLC Organization : NBL-74 Location : Los Angeles, United States / US Region : California --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 5241 (EXCELLENT) Multi Core : 30281 ## IO Test CPU Speed: bzip2 : 110 MB/s sha256 : 659 MB/s md5sum : 518 MB/s RAM Speed: Avg. write : 2457.6 MB/s Avg. read : 5017.6 MB/s Disk Speed: 1st run : 706 MB/s 2nd run : 725 MB/s 3rd run : 760 MB/s ----------------------- Average : 730.3 MB/sBoss,
