@uptime said: since we've already got well over 1000 signups - we're probably getting pretty close to 1000 actual hooman members at some point real soon now
so that is going to be some legit cause for celebration I think (heads up @AnthonySmith!)
Currently 231 unconfirmed email/spam accounts.
I want to do a celebration but I want it to be legit I am keeping an eye out.
67915740063421897160415528047860811340195
867-5309
HS4LIFE (+ (* 3 4) (* 5 6))
5552861165372904
2008?
4
Obviously
0987654321
666
198237645
109148
3.141517
H̶m̶m̶,̶ ̶c̶a̶n̶'̶t̶ ̶f̶i̶n̶d̶ ̶t̶h̶e̶ ̶e̶x̶p̶l̶a̶n̶a̶t̶i̶o̶n̶ ̶t̶o̶ ̶w̶h̶y̶ ̶w̶e̶ ̶a̶r̶e̶ ̶p̶o̶s̶t̶i̶n̶g̶ ̶r̶a̶n̶d̶o̶m̶ ̶n̶u̶m̶b̶e̶r̶s̶ ̶- but why not.
S̶e̶e̶d̶ ̶c̶r̶e̶a̶t̶i̶o̶n̶ ̶I̶ ̶g̶u̶e̶s̶s̶?̶ ̶ Maybe I'm just blind.
29041901
This is my tiny contribution
1
156758
thanks errybuggy, good stuff, me like verry much!
@benz welcome to the numbers channel
@uptime your current Unix timestamp when you see this.
64723
Ok.
123345
@Iroshan464 I see what you did there ...
(digits 2 through 7 of the Hofstadter Q-sequence)
it's an older meme sir, but it checks out - I'll allow it!
I wonder what happens if I contribute:
17
Just came here for the first time and see this great thread
MetalVPS
I'm inclined to just parse it as
10
, unless you have some other suggestion?HS4LIFE (+ (* 3 4) (* 5 6))
11111111111111111111111111111111111111111111111111111111111111111111111111111
whoa. @vbloods went up to 11 ... and then just kept going. Well played sir.
welcome and congratulations on your first comment @quangthang
if you like numbers, here is some food for thought:
Who can name the bigger nuimber?
translated:
La course aux grands nombres
¿Quién puede nombrar el mayor número? (pdf)
谁能给出更大的数?
I have discovered a truly remarkable number which this comment field is too small to contain.
root@notty
7-up
7-11
777
