LES newbie offer - 60% off on our yearly KVM SSD Linux VMs plans - Recurring!
We are new to LES, but have been in the hosting business since 2005.
Please check out our super fast pure SSD VMs.
THE OFFER:
For a limited time only, 60% off on our yearly KVM SSD Linux VMs plans (recurring)!
Orders include:
- IPv4 + IPv6
- SSD RAID 10
- KVM Virtualization
- Located in The Netherlands
- Looking Glass
Use coupon code: LES2020
Specs:
- Core(s) 1 - Ram 2GB - SSD Disk 40GB - 2TB BW - 30€/year (+vat if applicable) - Order Now
- Core(s) 2 - Ram 4GB - SSD Disk 80GB - 4TB BW - 60€/year (+vat if applicable) - Order Now
- MORE OPTIONS!
Kind Regards,
Naranjatech Team
Our VPSes (ask for a recurring coupon code) Mailchannels low volume plans
Sounds good! Is this NVMe or regular SSD (probably know the answer, but still)?
That's regular SSD, we also have NVMe nodes, but pricing is a bit different...
What is the host node cpu generation /model?
Nice offers
Dual AMD EPYC 7351
Any bench please
Found this bench at the other forum.
@debaser Found this bench at the other forum.
Waiting for YABS
Be the bench you want to see ....
HS4LIFE (+ (* 3 4) (* 5 6))
H/T to itlabs
Geekbench 4: https://browser.geekbench.com/v4/cpu/15261273
IPerf3 tests to Bouygues
How is the no-bench detox ?
@gleert You might want to check your support system/email setup. I tried contacting you with a pre-sales question from two different email addresses of which I am sure I never used to contact you or signup with, but they both bounce with this message:
Your email to our support system could not be accepted because it was not recognized as coming from an email address belonging to one of our customers. If you need assistance, please email from the address you registered with us that you use to login to our client area.
Damn, that AMD is tempting
Nice offer
If it helps:
WHMCS > Setup > General > Support > Untick the box above.
However, unless you are happy to set up some really good filtering I don't suggest any hosts accept email tickets from none customers directly to WHMCS as they have a history of being compromised through cleverly crafted emails.
It is common for people to set WHMCS securely as I suggested above but forget to disable the pre-sales form which WHMCS likes to re-enable for you and both cant exist with that security measure in place.
Hi Freek, could you try again?
Hi Freek, I see you're not a client... Support tickets only work for clients. Please send me a DM with your questions
Hi Gleert,
Thanks for your reply.
I'm not trying to send in a support ticket. I sent an email to the only email address listed on your webpage:
Kind regards,
Freek
Hi Freek, sorry for the hassle... Now it should work correct.
Hi Gleert. I just resent my question by email. It didn't bounce, so it seems to be working, although I didn't receive the usual WHMCS email confirmation message (yet). ** EDIT:** I've just received the WHMCS email confirmation message, so it's working. Thnx for fixing.
@Freek thanks for contracting! Please let me know how it's working out for you.
