NAT VPS, letsencrypt and so on
Searched this category and googled for some time but no cigar. The question: Is the some guide where I can learn how to host a website in a NAT VPS (using a domain name) and can use https with letsencrypt?
thanks in advance
You can use acme.sh for letsencrypt.
Listen to ipv6 or setup haproxy if your provider have one.
And go greyer than me in the process.
Use the IPv6 and port 80 for httpd.
Cloudflare provides IPv4 to IPv6 reverse proxy.
Copied from the other place.
If you get a NAT VPS from [mrvm.net] you can use the domain forwarding option to host both http and https site.
All you need to do is to handle the renewel of your Lets Encrypt Cert as you would on any regular IPv4 VPS.
https://clients.mrvm.net
Was there any hiccup in the beginning with the setup, https sites with Lets Encrypt Cert like broken cert ?
The only hiccup is when some customers try to use TCP or HTTP(s) forward to other ports then 80/443.
This could end up messing up the config file and then HAProxy fails to reload it.
Keeping the old config and that requires my hands to fix it.
use DNS record, do not use HTTP
https://letsencrypt.org/how-it-works/#domain-validation
https://github.com/acmesh-official/acme.sh/wiki/dnsapi
