Some hints to set up a ad free VPN on a nat vps.
Here is a super simple guide to set up a ad free vpn that come with a adguard interface on a nat vpn. The reason why I write this is because I see some others suffering with pi-hole on a nat vps.
This guide should be unreadable since I am bad in all Language. I just hope my experience worth 2 cents.
What is AdguardHome?
AdguardHome is a alternative of pi hole. If you dont know what is pi-hole, google it.
What is OpenVPN?
Openvpn is a VPN
My server: 256MB from @mrvm
- install AdguardHome, too simple,skip. Hints : I use [ipv6]:3000 to complete the install process
- Encryption settings for AdguadHome. Hints : you can get a let's encrypt cert very easy with acme.sh
config Adguardhome's Adguardhome.yaml (127.0.0.1 -> your internal IP address), Like that
dns:
bind_host: your internal IP addressset up proxy from mrvm clients panel. (That domain forwarding bottom),this action give you a Adguard Home control panel
- install openvpn or any other vpns then point the dns to your internal IP
my suggestion is bash a script
Now, you get a ad-free VPN and a DNS over https.
Is it too short?
Will try and get you back shortly
You can replace openvpn with wireguard. Faster and efficient.
It is openvz
. I know I can use wireguard-go but OpenVPN is not bad either.
I just set this up on 128 mb NAT vps. Totally worth the $2 per annum I've paid for the service. Thanks for the tutorial
FWIW, Wireguard is actually quite a bit faster on slow CPUs than OpenVZ. Haven't done audits of it, but several places are embracing WireGuard, including writing their own implementation.
... than OpenVPN, I assume?
Uhm, yeah.
Wireguard howto. It works! I have had it running on several NAT vps for over 12 months now.
https://d.sb/2019/07/wireguard-on-openvz-lxc
https://github.com/rodeodomino/algo-pihole/blob/add-adguard-012020-02/README.md
I actually using wireguard now but not on a nat openvz box. Personal VPN don't eat many server resources so that I host it with my other little things.
Spend time researching how to install wireguard on openvz is too wasteful.
Research done.
Next
