Tried setting up openvpn on the US and Bulgaria node and tun is not available, is it available at only certain locations or there is some configuration to enable tun that I missed out?
@mikho will be the only one to answer that.
Virtualizor is like trying to find a piece of hay in a hay stack, probably just a tick box for those locations would be my guess.
https://inceptionhosting.com Please do not use the PM system here for Inception Hosting support issues.
Check the box under ”VPS Configuration”. 1. Stop the VPS from the control panel, not from inside the VPS. 2. start VPS. 3. Good to go.
https://clients.mrvm.net
Got it working, thanks @mikho
2. start VPS.
3. Good to go.
