TeamSpeak 3 installer
mikhomikho AdministratorHosting ProviderOG
After a couple of tickets asking for TS3 install support I decided to fork an existing script and update it with some features like
  • Downloading the latest version
  • Working on both CentOS and Debian
I am not a coder by profession, I'll take all ideas, test-reports and feature requests as an opportunity to educate myself and learn something new.
https://github.com/mikho/TS3-Installer
I'm asking for this favor, please download, test install, let me know what you think.
Thanked by (3)Mason Ympker Pwner
  • WSSWSS Retired
    edited May 2020
    I don't like you putting that read in a loop. You should ony allow y/n/abort. I guarantee there's one moron who will bash on the keyboard for a week here.
    also:
    read -p 'Butts? [y/N]' boogerbrain
    case $boogerbrain in:
      y|Y) install ;;
     n|N) quit ;;
     *) abort ;;
    esac
    Also, holy shit, use lsb_release rather than assuming /etc/redhat-release and /etc/os-release are anything you can trust unless you parse them. Here's a silly code snippit based on CloudLinux' KernelCare installer script - I'd prefer to use lsb_release, but this /mostly/ works:
    if [ -e /etc/os-release ]; then
        distr=$(grep -w 'ID' /etc/os-release | cut -d'=' -f2|tr -d '"')
        if [ "$distr" == "debian" ] || [ "$distr" == "devuan" ] || [ "$distr" == "ubuntu" ]; then
            repo=${repo}-debian
            apt-get -y -q install curl
        else
            yum -y -q install curl
        fi
        #I really don't like their script design, but whatever.
        if [ "$distr" ==  "devuan" ]; then
            ver=$(grep -w 'PRETTY_NAME' /etc/os-release | cut -d' ' -f3 | grep -oE "[a-z]*")
            if [ "$ver" == "ascii" ]; then rel="9" pkg=${name}-9.deb
            else rel="8" pkg=${name}-8.deb
            fi
        else
            rel=$(grep -w 'VERSION_ID' /etc/os-release | cut -d'.' -f1 | grep -oE "[0-9]*")
        fi
        case $distr in
            "devuan")
                if [ "$rel" -ge "9" ]; then pkg=${name}-9.deb
                elif [ "$rel" -eq "8" ]; then pkg=${name}-8.deb
                else pkg=${name}-6.deb
                fi
            "debian")
                fi
            "ubuntu")
                if [ "$rel" -ge "14" ]; then pkg=${name}-8.deb
                fi
            "amzn")
                rel='7'
                pkg=${name}-${rel}.rpm
        esac
    elif [ -e /etc/system-release ]; then
        rel=$(cut -d'.' -f1 /etc/system-release | grep -oE "[0-9]")
    else
        rel=$(cut -d'.' -f1 /etc/redhat-release | grep -oE "[0-9]")
    fi
    Also, might want to learn to use ip a; since ifconfig is officially deprecated and isn't installed by default.
    Thanked by (2)mikho vimalware
  • I took a quick look, it looks good for someone who is learning Bash.
    Some observations:
    • If you install ca-certificates, don't use --no-check-certificate
    • Old init systems are irrelevant nowadays so I'd remove references to them and replace with systemd.
    • ifconfig is deprecated and not available everywhere. ip is available everywhere, and should be used instead. Take a look at my installers if you need help with regex.
  • @WSS said: Also, holy shit, use lsb_release rather than assuming /etc/redhat-release and /etc/os-release are anything you can trust.
    lsb_release isn't available everywhere, while /etc/*-release are.
    Thanked by (1)vimalware
  • WSSWSS Retired
    Fuck you, that's what.
    It is if you install it. Look at my revised 'not quite lsb_release' info above.
    Thanked by (1)comi
  • @Nyr said: Old init systems are irrelevant nowadays so I'd remove references to them and replace with systemd.
    Nooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo.
    Please.
    Thanked by (1)comi
  • I knew I was going to hurt some feelings.
  • WSSWSS Retired
    I'm happy for you, and Imma let you finish, but (sysv)init was and is still the standard of all time!
    @Nyr said:
    Some observations:
    One of two reasons, either I tested before I added ca-certificates to be installed.
    Or, it didn’t work without it.
    can’t remember which, I’ll check it out.
    I think I’ll keep it for now, still loads of old installations around that uses the old init system.
    Will take a look.
    Not that important though, only displaying the value in a text, not using it anywhere.
    @WSS : thanks for the input. I’ll consider lsb_release.
    In the templates I tried, lsb_release wasn’t available unless you installed it.
    Tried to keep number of packages needed to a minimum.
    Has even Red Hat stopped reading /etc/rc.local these days? :o
    Or is there a systemd unit parsing/sourcing it? :#
    I knew you did it on purpose! =D
  • I don't know anything about TeamSpeak.... is these ports are supposed to be accessible from outside?
    fport="30033"
    qport="10011"
    If so, I think you would need some kind of iptables/firewalld management.
  • @flips said: Or is there a systemd unit parsing/sourcing it?
    Indeed there is.
    Indeed there is.
    Awesome ... :p Then all those old articles explaining how you get old and unpatched stuff working by using tar, cp, chmod 777 and by adding a line or two to rc.local are still relevant ... ;):#
  • @flips said: Awesome ... :p Then all those old articles explaining how you get old and unpatched stuff working by using tar, cp, chmod 777 and by adding a line or two to rc.local are still relevant ... ;):#
    I was going to argue relevancy but since you specified "old and unpatched stuff" I figured learning the wrong way to do things was kinda on target. :P
    Thanked by (1)flips
    fport="30033"
    qport="10011"
    I think iptables is a bit out of the scope as not everyone is running it.
    I will however, make a note on adding a text telling the user to open the firewall on the selected ports.
