UK KVM SSD - 2 x IP - 512MB Ram - 10GB Disk - 1000GB BW - DDOS Protected, Nightly backups, also...
InceptionHosting
Hosting ProviderOG
SPECIAL UPGRADED FOR MAY
- KVM
- 1 CPU Core (Equal Share - E3-1270v5/v6)
- 512 MB Ram (DDR4)
- 10 GB NVMe SSD Disk space (Samsung SSD 970 PRO)
- 1000 GB Bandwidth @ 1 gbit (shared, DDOS Protection Included)
- 2 x IPv4 address (rDNS available)
- 1 x /64 IPv6 (rDNS available)
- Full Nighly backup of your virtual disk image included to separate local raid array
€12 / 6 months
€24 / 12 months
Offer expires at the end of this month, not likely to be repeated.
Other offers still valid until the end of this month only
NAT Bundle
- OpenVZ 7 (Virtuozzo 7)
- 1 CPU Core (shared with FUP)
- 256mb Ram
- 3GB Disk Space
- 500 GB Transfer p/Month
- /64 IPv6 range
- 1 x NAT IPv4 (20 ports)
- Support is an optional extra
- Orders manually accepted within 24 hours, not instant setup
€9.99 /year for all 3. - Note: You need to add your hostname, password etc for each location and then it takes you to the next one.
USA OpenVZ 7 1GB - 2 IP4
- 2 vCPU Cores (shared with FUP)
- 1GB Ram
- 1GB vSWAP
- 40GB Disk
- 500 GB Bandwidth
- 2 x IPv4
€5.00 / 3 months or €17.50 /year
Phoenix USA or Rotterdam Netherlands OpenVZ 7 Special
- 1 vCPU Cores
- 512 MB Ram
- 512 MB vSWAP
- 15GB Disk
- 1000 GB Bandwidth
- 2 x External IPv4
- 1 x /64 IPv6 Subnet (NL Only)
€3.50 /3 months
NL Rotterdam Order Link
USA - Phoenix order Link
Terms TL;DR
- No Tor (AT ALL)
- No Torrents (yes that includes over a VPN)
- No open proxies
- No Cryptocurrency activities
Help me to understand. Guys what i can do with 2 ips? What service i can run with 2 ip? Thanks
Is the first offer OVZ(7)?
Edit: From the offer link it seems like KVM.
Need a free NAT LXC? -> https://microlxc.net/
I have been offering VZ7 since October 2019
It simply means if you have 2 services e.g. VPN, web server, proxy, mail server, game server, pihole, nameserver, (insert the limited amount of services out there here) you can have them on separate dedicated IP's
Also if you run docker or containers within the VPS you can have that on a dedicated IP instead of using NAT.
Actually what I meant was whether it’s OVZ or KVM, and it seems like it’s KVM
Ah sorry, yes top one is KVM, I have made that more clear now, thanks.
Such great use case!
... is the second IP promo finished? The item in the cart only seems to have one very lonely IP
Promo is still running, Ant comfirmed
Crazy good deal!
Thanks, available for the next 9 and a bit hours only!.
Aaand it happened again, I fell for the NAT bundle...damned! Let's see if I can find some use for them.
Short question out of curiosity: Can they be independently renewed?
yes.
All offers in this post have expired.
Thanks everyone.
