[VPSDime] Cage-free, Organic $1/month or $7/year VPS - 1 vCPU, 1GB RAM, 10GB SSD, 1TB Traffic
245
  • @imok said:
    Grabbed one but I'm not sure why.
    Thank you.
    Temped... Not sure why...
    Thanked by (1)serverian
  • Here is another interesting offer:
    -- Limited Offer --
    2vCPU, 2GB RAM, 20GB SSD for only $20/year
    Buy your Free-range, Organic VPS: https://vpsdime.com/SPECIAL2GB
    CentOS 8, Ubuntu 20.04, Debian 10 offered.
    Docker supported.
    Powered By OpenVZ 7.
  • Thank you for the deal, very appreciated...
  • FAT32FAT32 OG
    edited June 2020
    After 6 years you left LE_, are you considering to go back and see if things changed?
    I am asking this because I noticed this deal was shared to somewhere else earlier than LES where the abuse rate is relatively and statistically higher but it seems fine at the moment?
    "Humanity is f*cked up" - Jay
  • serverianserverian Hosting Provider
    Definitely considering. Could you please PM me that URL? I haven't posted this anywhere except Twitter and LES.
    Thanked by (1)FAT32
  • What is traffic generation? Are Web Crawlers (not shoe, not stresser, just regular search-engine crawling) okay?
  • MasonMason AdministratorOG
    Are your VPSes gluten-free?
    Humble janitor of LES
    Proud papa of YABS
    Crawlers are fine. Traffic generation means "liker bots", "page view generators", etc.
    Thanked by (1)vimalware
    100%. Also fair trade compliant. Vegan friendly.
    Thanked by (2)Mason vyas
  • No benchmark result yet?
  • imokimok OG
    edited June 2020
    @serverian said:
    @cybertech said:
    Stackable?
    Unfortunately, no. But got this offer as well from earlier: http://vpsdime.com/special2gb
    orale mijo!
    @serverian is it possible to buy additional disk space in the regular plans?
    @serverian said:
    @cybertech said:
    Stackable?
    orale mijo!
    Unfortunately, no.
  • I've resisted a few minutes... and failed :p
  • Ordered one ?
  • Welcome back @serverian - saw my old 512 plan got a bump as well :smile: Had that thing since 2014
    edited June 2020
    I'd be a crime to not bump it up!
    Thanked by (1)Harambe
     Region: Global  https://bench.monster v.1.5.0 2020-01-11
     Usage : curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -Global
     OS           : Ubuntu 18.04.2 LTS (64 Bit)
     Virt/Kernel  : OpenVZ / 4.15.0
     CPU Model    : Intel(R) Xeon(R) CPU E5-2697 v2 @ 2.70GHz
     CPU Cores    : 1 @ 2700.000 MHz x86_64 16384 KB Cache
     CPU Flags    : AES-NI Enabled & VM-x/AMD-V Disabled
     Load Average : 0.22, 0.07, 0.06
     Total Space  : 9.8G (716M ~8% used)
     Total RAM    : 1024 MB (21 MB + 373 MB Buff in use)
     Total SWAP   : 0 MB (0 MB in use)
     Uptime       : 0 days 3:50
     ASN & ISP    : AS394727, Nodisto IT, LLC
     Organization : Nodisto IT, LLC
     Region       : New Jersey
     ## Geekbench v4 CPU Benchmark:
      Single Core : 2890  (GOOD)
       Multi Core : 2726
     ## IO Test
     CPU Speed:
        bzip2     :  82.3 MB/s
       sha256     : 159 MB/s
       md5sum     : 411 MB/s
     RAM Speed:
       Avg. write : 599.7 MB/s
       Avg. read  : 2901.3 MB/s
     Disk Speed:
       1st run    : 367 MB/s
       2nd run    : 480 MB/s
       3rd run    : 544 MB/s
       Average    : 463.7 MB/s
     ## Global Speedtest
     Location                       Upload           Download         Ping
     Speedtest.net                  541.14 Mbit/s    870.35 Mbit/s    10.802 ms
     USA, Chicago (Windstream)      304.63 Mbit/s    1220.47 Mbit/s   21.153 ms
     USA, Dallas (Frontier)         900.01 Mbit/s    3006.18 Mbit/s    1.915 ms
     Timestamp   : 2020-06-17 16:46:28 GMT
  • CPU model : Intel(R) Xeon(R) CPU E5-2697 v2 @ 2.70GHz
    Number of cores : 1
    CPU frequency : 2700.000 MHz
    Total size of Disk : 9.8 GB (0.5 GB Used)
    Total amount of Mem : 1024 MB (19 MB Used)
    Total amount of Swap : 0 MB (0 MB Used)
    System uptime : 0 days, 0 hour 10 min
    Load average : 0.00, 0.01, 0.01
    Arch : x86_64 (64 Bit)
    Kernel : 4.15.0
    I/O speed(1st run) : 318 MB/s
    I/O speed(2nd run) : 416 MB/s
    I/O speed(3rd run) : 475 MB/s
    Average I/O speed : 403.0 MB/s
    Node Name IPv4 address Download Speed
    CacheFly 205.234.175.175 129MB/s
    Linode, Tokyo2, JP 139.162.65.37 11.1MB/s
    Linode, Singapore, SG 139.162.23.4 8.87MB/s
    Linode, London, UK 176.58.107.39 18.7MB/s
    Linode, Frankfurt, DE 139.162.130.8 13.5MB/s
    Linode, Fremont, CA 50.116.14.9 39.1MB/s
    Softlayer, Dallas, TX 173.192.68.18 90.9MB/s
    Softlayer, Seattle, WA 67.228.112.250 30.8MB/s
    Softlayer, Frankfurt, DE 159.122.69.4 5.48MB/s
    Softlayer, Singapore, SG 119.81.28.170 7.22MB/s
    Softlayer, HongKong, CN 119.81.130.170 6.36MB/s
  • Give it a week or two for everyone to let their VMs idle and not run 20 benches at the same time, speeds will be looking even better then :wink:
    Thanked by (2)uptime vimalware
    @FAT32 said: After 6 years you left LE_, are you considering to go back and see if things changed?
    Things 110% have not changed, they may be worse.
  • Thanks, picked one up
    PS. Go home DomainTools, you're drunk
  • @serverian , can't register without having a server? I am trying to refer a friend who might have a use of this one. :/
    Simply create an order with comments: "Cancel this order" and don't pay.
    Thanked by (1)PHP_Backend
    Why does that happen, I have a similar case with a client, I registered their domain myself, but it shows up for sale!? Man I did not list it anywhere. Someone has an idea?
  • I have absolutely no use for this but still need to resist the urge to buy.
    It was on sale previously, before it expired. If you are the current owner and bothered about it, you can delist it.
    Thanked by (2)serverian Abdullah
  • Feels good to see VPSDime deals on the forum again, and really nice to see an old friend and well respected member of the community be active on here.
    Do you plan on re-introducing the other subsidiaries of Nodisto as well?
  • Noice. Thanks - I bought one. Is the optional ipv6 address free?
  • @allendiggity said: Noice. Thanks - I bought one. Is the optional ipv6 address free?
    Yes, it is. Just click the "Request IPv6" button in the panel.
    Thanked by (2)allendiggity vimalware
