Looking for someone to code a plugin for vanilla (php)
 InceptionHosting
                    Hosting ProviderOG
InceptionHosting
                    Hosting ProviderOG
            Hi Folks,
I am looking for someone to code a plugin for vanilla that adds the 'reveal on post' functionality.
You have probably seen this on other forums but if not essentially what it does it gives the thread starter the option to only reveal the post content to those who have replied to the thread usually by adding <hide> or <hidden> tags which are only revealed upon adding a reply to the thread.
I don't mind how specifically it works as long as it achieves hiding the whole or some of the post until a reply has been made (not just through some css tricks that can be worked around in 5 seconds flat)
If you need a dummy vanilla forum setup for you to work on I can provide that.
Please post below or PM me your quote for doing this.
There will be some future work, I am reaching out to a few people to start doing paid dev work here but thought I would start off with what should be a fairly easy one as its a well-established forum function.
cheers.
Ant.
@AnthonySmith Have you got any response on this?
https://phpbackend.com/
Yes sorry, job booked
/thread
