microLXC Public Test
2456710
  • @dev said:
    Wow, nanokvm and now this! Any plan to add more slot for test in Tokyo soon? I do not qualify with my les account but do with my baller account.
    At some point, yes, but no ETA.
    @foxone said:
    bf0f-83b1-4941-1ddb OwO
    Your request got stuck while in deployment, I did a reset.
    Please apply again.
    The location you want to deploy was under heavy packetloss at this time, which caused issues.
    Yet, the system does a rollback but does not cancel the pending request.
  • Kudos @Neoon looks like another great project. Keep up the good work
  • 26d7-d40a-f519-5e27 trying again
  • @verjin said:
    The fun part is LET is disabled :lol:
    Thanks to @FAT32 for the acceleration.
    But the Thread does not exist yet, but will soonTM.
    Thanked by (2)FAT32 verjin
  • foxonefoxone OG
    edited June 2020
    My vps still got stuck btw :(
    I see no error or anything stuck.
    You have to complete the request within 30 minutes or it gets deleted.
    I mean you posted a token right, so then you should enter a password for your account and if you do not do that within 30 minutes, the request gets cleaned up.
    It got stuck on "deploying" and never told me anything
  • NeoonNeoon OG
    edited June 2020
    Yea the first time, you deployed in Swiss, due to heavy packetloss the system failed to deploy.
    If your request is in deploy status, it won't get deleted, so if it would get stuck at some point, I can investigate it.
    But if your request, is still in verification or account setup, it will get deleted after 30 minutes, of inactivity.
    And since there is nothing stuck or a pending request in the database, your second request never reached deploy.
    The system scanned your post, I found the entry in the database, so you should be on the account setup.
    Request rejected
    Your request can get rejected for the following reasons:
    You provided an invalid account
    You do not meet the requirements
    Using a VPN or Proxy
    If you think there is an technical error,
    please let us know.
    Request rejected
    please let us know.
    You select Hostballs and the Account there does not exist, so the system rejected it.
  • b81d-82d9-c497-224f
    let's try
  • _MS__MS_ OG
    edited June 2020
    I entered correct LET username but the message says 'Invalid username.'.
  • @foxone said:
    let's try
    I changed the forum select, so there is not longer a default forum selected.
    Also, there is now a notification, about that the request will expire in 30 minutes.
    I updated the regex, so It will accept your username now.
    Besides, as I said before, as long the LET thread is not posted, it wont work if you go on the website and select Lowendtalk.
    Since you cannot post the token on LET.
  • Is this IPv6 only or will there be an NAT IPv4 in the future?
  • NeoonNeoon OG
    edited June 2020
    It's IPv6 + NAT IPv4.
    Thanked by (1)Pwner
    Awesome! I'll have to wait until the LET thread to apply then, my LES account doesn't qualify but I believe the LET account should.
  • @Neoon said: Since you cannot post the token on LET.
    Oh, I was gonna ask if the token could be posted here. I guess not, so I will wait for the post there.
  • NeoonNeoon OG
    edited June 2020
    The Request is bound to the forum, you requested it from.
    Otherwise, it would be exploitable aka someone could pick your username on LET and get a new account here to validate it.
    Thanked by (2)Ouji ralf
  • @Neoon said: The Request is bound to the forum, you requested it from.
    Although my username is taken here and there, I agree, that could work for other usernames of long standing users that are not yet registered here. I didn't thank of that. Thank you.
    OK, that's right.
  • AU and JP are OOS :(
  • BrendanBrendan Hosting ProviderOG
    @Neoon let me know if you want the specs for the AU PoP increased/another VM deployed.
    Thanked by (2)sonic dahartigan
  • NeoonNeoon OG
    edited June 2020
    Yes, I take the entire node, thx bay.
    Yes and there will be no restock until posted on LET.
    Thanked by (1)terrorgen
  • CH, AU restocked.
    NO added, with a special package.
    Please only pick that package if you really have a use for it.
    Thanked by (2)bdl flips
  • Anyone interested in HAProxy support?
    Thanked by (1)flips
  • Not in 128MB instance..
  • @Neoon said: Anyone interested in HAProxy support?
    That would be nice.
    Thanked by (1)flips
    Well, enough for a php script or html.
    No one said you need to run MariaDB.
  • Yep, Use full for what I'm trying to do with NAT VM's in general running a one file status page which checks all the servers and services I need to monitor and displays in a page.
    Also for some reason the my LXC JP is faster than my VM on Vultrs network so looking forward to it.
    StarryDNS has a decent network in jP; that could explain it.
