2TB Storage - 2GB Ram - 1 Dedicated core - 4TB Transfer - USA €70 /year
in Offers
Phoenix Arizona USA.
KVM Storage VPS
- 1 CPU Core (dedicated)
- 2 GB Ram
- 2000 GB Disk space (Raid 6 + hardware cache)
- 4 TB Bandwidth @ 1 gbit (shared - unmetered inbound)
- 1IPv4 address
€70 /year
Order Link: https://clients.inceptionhosting.com/cart.php?a=add&pid=195
Coupon code: phxkvm2000
DC: Ioflood
Test file: http://148.163.68.178/1g.bin
10 Available.
Not an LESclusive?
Nope just generally available.
@Clouvider please get Ant a big storage node in UK
@AnthonySmith, do you allow private ISO seed on it?
Been discussed, they cannot even come close on price (not unexpected), so the UK storage offers will remain as they are I am afraid.
@AnthonySmith Any chance to get something similar in Germany in the future?
SoftwareArchitect, Projectmanager, Founder, Innovator and passionate admin in my free time.
I might need this. Which ISOs are available to custom install OS?
AMD EPYC powered Performance NVMe VPS - Los Angeles, Dallas, New York, Amsterdam, Singapore | Support | Status
Not impossible but only a thought in my head right now, obviously it would be Hetzner.
What ever you want.
ISO's? sure...
Really?
Why would I care about you seeding ISO's ?
Birthday boy specials are slowly coming..
Don't remind him.
when i see you always i check if its Thursday
-- i was trying to find an image and found this i had to add
Ordered a few to test things out (especially because it's my first time in IOFlood DC). Just in case I want more, how many coupon uses are left, and and does this expire?
Also, just curious, but what are the host machine specs like?
Sir,
I am not a seasonal bird! I shitpost everyday.
3 Coupon uses left now, although 1 person has not finished checkout so that may be returned to the pool.
New node is Dual E5-2660 based, 12 spinners in raid 6 + HW cache, basically the revamped spec with significantly better storage speeds than the older nodes.
I may be able to repeat this, not sure feel free to pop a ticket in when/if you want more I will have to make a call then.
I appreciate your order, regarding your order notes, you are on the fastest possible node right now, if you do want them moved to other nodes I can do that but I warn you they are significantly slower.
Doesn't "seeding" mean torrent seeding? (Which, IIRC, can be considered bad due to resource usage -- apart from whatever it is one is seeding.)
Well if he is seeding ISO's as long as he pre-allocates it should be fine.
