I've used Bootstrap Studio with success. Admittedly it's a bit clunky and seems to discourage any source code editing which is annoying. They had a good reason though, due to their software design.
so how about Dreamweaver ... old school, right ?
I don't know how to code JS, so the DW is still a great tool to code the simple HTML, ofcos need to read and edit the bootstrap manually!
Bootstrap Studio works fine.
@Unixfy Thanks! We keep running into each other =P
Pinegrow is nice and also supports Bootstrap
Mobirise does, too (kinda).
Like @Unixfy said, there's also Bootstrap studio. Didn't like it much, personally.
my fav is sublime editor, for txt processing, for programming and for simple note taking job.
Waikey
I use bootstrap studio demo (browser based). Unfortunately theres no easy way to export the html so I wrote a bookmarklet to make the html copy-able.
+1 Bootstrap Studio
