Cloudflare open-sources Flan Scan, a network vulnerability scanner
Cloudflare open sourced Flan Scan, its in-house lightweight network vulnerability scanner.
Flan Scan is a lightweight network vulnerability scanner. With Flan Scan you can easily find open ports on your network, identify services and their version, and get a list of relevant CVEs affecting your network.
Flan Scan is a wrapper over Nmap and the vulners script which turns Nmap into a full-fledged network vulnerability scanner. Flan Scan makes it easy to deploy Nmap locally within a container, push results to the cloud, and deploy the scanner on Kubernetes.
Ref.: https://blog.cloudflare.com/introducing-flan-scan/
Ref.: https://github.com/cloudflare/flan
Do you use any vulnerability scanner in your daily activities? Which one performs better in your opinion?
Thanked by (1)Amitz
