@vyas maybe you could use code for formatting.. I am interested in those spec. How much bandwidth they provide?
I don't normally do these. But since @chocolateshirt requested it... ?
Liteserver.nl 's base-model Storage KVM-HDD-1G .
(1-2% overhead from LUKS full disk encryption)
They actually do deliver 500Gigs usable.
How did you set that up on a VPS?
Seems like you're able to boot a OS ISO with liteserver, so just using the default installer of your distribution I guess.
Browser issues while formatting. Deleted
I wish I could. In Vivaldi/chrome, the page keeps refreshing every time I format. Tried three times. Bot going to waste time again.
Yes, I think this bug happened when we do some post edit and trying to apply code format.
Code format used as below
< p r e >
< / p r e >
@chocolateshirt @vyas
On a test VPS in Bucharest, RO:
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # v2020-06-20 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed Aug 5 23:20:40 EDT 2020 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E3-1230 V2 @ 3.30GHz CPU cores : 1 @ 3300.022 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 985M Swap : 979M Disk : 502G fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 2.78 MB/s (696) | 34.85 MB/s (544) Write | 2.80 MB/s (700) | 35.21 MB/s (550) Total | 5.58 MB/s (1.3k) | 70.06 MB/s (1.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 101.87 MB/s (198) | 122.39 MB/s (119) Write | 107.28 MB/s (209) | 130.54 MB/s (127) Total | 209.16 MB/s (407) | 252.94 MB/s (246) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Bouygues Telecom | Paris, FR (10G) | 926 Mbits/sec | 926 Mbits/sec Online.net | Paris, FR (10G) | 930 Mbits/sec | 895 Mbits/sec WorldStream | The Netherlands (10G) | 930 Mbits/sec | 930 Mbits/sec wilhelm.tel | Hamburg, DE (10G) | 930 Mbits/sec | 911 Mbits/sec Biznet | Bogor, Indonesia (1G) | 278 Mbits/sec | 324 Mbits/sec Hostkey | Moscow, RU (1G) | 922 Mbits/sec | 838 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 850 Mbits/sec | 834 Mbits/sec Airstream Comms | Eau Claire, WI, US (10G) | 824 Mbits/sec | 712 Mbits/sec Hurricane Electric | Fremont, CA, US (10G) | 829 Mbits/sec | busy Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 690 Multi Core | 683 Full Test | https://browser.geekbench.com/v5/cpu/3188038Manchester, UK
Nice CPU!
Just debian-installer. (d-I)
MaxKVM
SKVM-4G
$12/mth
Singapore
EPYC 7302P
AES
Nested Virtualization
Those disk speeds are madness. How?
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-06-20 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Thu Aug 20 08:33:27 PDT 2020 Basic System Information: --------------------------------- Processor : AMD Ryzen 7 3700X 8-Core Processor CPU cores : 1 @ 3593.250 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 985M Swap : 1.0G Disk : 15G fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 316.37 MB/s (79.0k) | 3.34 GB/s (52.2k) Write | 317.20 MB/s (79.3k) | 3.35 GB/s (52.4k) Total | 633.57 MB/s (158.3k) | 6.70 GB/s (104.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 3.68 GB/s (7.2k) | 3.79 GB/s (3.7k) Write | 3.88 GB/s (7.5k) | 4.04 GB/s (3.9k) Total | 7.57 GB/s (14.7k) | 7.83 GB/s (7.6k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Online.net | Paris, FR (10G) | 935 Mbits/sec | 935 Mbits/sec WorldStream | The Netherlands (10G) | 934 Mbits/sec | 937 Mbits/sec Hurricane Electric | Fremont, CA, US (10G) | 376 Mbits/sec | 245 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1241 Multi Core | 1231 Full Test | https://browser.geekbench.com/v5/cpu/3355949Absolute madness. Looks like a Nexusbytes benchmark to me
AMD EPYC powered Performance NVMe VPS - Los Angeles, Dallas, New York, Amsterdam, Singapore | Support | Status
True. But I’ve got a decent collection of Nexusbytes VM’s and this has by far the highest disk speeds.
This is a Nexusbytes bench? @seriesn must be running a few Samsungs in RAID10 now. Nice!
That and
I try experimenting here and there so that kinda makes sense lol
. End of the day, numbers are just numbers. As long as the performance adds up to it
It looks good on benchmarks, I test some things on my VMs that prosper with fast disks. But I won’t notice the difference between 70K and 160K IOPS.
?. Spoken like a true human.
2K iops used to be real good, and 10K was the gold standards.
Guess this just means enough iops for every one and no longer the bottleneck in a shared server it used to be.
Will we ever be a happy family again?
i'm sure there will come one day boss
i came to Singapore for you, but yet you weren't there. Oh baby, only if you knew, how badly I want you
YABS thread needs a “comment cleanup in Aisle 9”...
So that we can get back to yabbing
Nexus Bites Singapore
@seriesn no Green Goblin stuff with the disk speeds
Thu Aug 20 18:51:36 CEST 2020 Basic System Information: --------------------------------- Processor : AMD Ryzen 9 3900X 12-Core Processor CPU cores : 1 @ 3792.872 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 981Mi Swap : 4.0Gi Disk : 20G fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 208.08 MB/s (52.0k) | 910.59 MB/s (14.2k) Write | 208.63 MB/s (52.1k) | 915.39 MB/s (14.3k) Total | 416.72 MB/s (104.1k) | 1.82 GB/s (28.5k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.12 GB/s (2.1k) | 1.22 GB/s (1.1k) Write | 1.18 GB/s (2.3k) | 1.30 GB/s (1.2k) Total | 2.30 GB/s (4.5k) | 2.52 GB/s (2.4k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Bouygues Telecom | Paris, FR (10G) | 368 Mbits/sec | 724 Mbits/sec Online.net | Paris, FR (10G) | 321 Mbits/sec | 634 Mbits/sec WorldStream | The Netherlands (10G) | 414 Mbits/sec | 830 Mbits/sec wilhelm.tel | Hamburg, DE (10G) | 349 Mbits/sec | 814 Mbits/sec Biznet | Bogor, Indonesia (1G) | 940 Mbits/sec | 923 Mbits/sec Hostkey | Moscow, RU (1G) | 368 Mbits/sec | 712 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 273 Mbits/sec | 614 Mbits/sec Airstream Comms | Eau Claire, WI, US (10G) | 370 Mbits/sec | 382 Mbits/sec Hurricane Electric | Fremont, CA, US (10G) | busy | busy Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 5481 Multi Core | 5403 Full Test | https://browser.geekbench.com/v4/cpu/15702905VPS reviews | | MicroLXC | English is my nth language.
@MaxKVM Singapore..
Fri Aug 21 03:35:06 UTC 2020 Basic System Information: --------------------------------- Processor : AMD EPYC 7302P 16-Core Processor CPU cores : 1 @ 2999.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 981Mi Swap : 2.0Gi Disk : 24G fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 249.53 MB/s (62.3k) | 2.40 GB/s (37.5k) Write | 250.19 MB/s (62.5k) | 2.41 GB/s (37.7k) Total | 499.73 MB/s (124.9k) | 4.81 GB/s (75.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.79 GB/s (5.4k) | 2.79 GB/s (2.7k) Write | 2.94 GB/s (5.7k) | 2.98 GB/s (2.9k) Total | 5.73 GB/s (11.2k) | 5.78 GB/s (5.6k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Bouygues Telecom | Paris, FR (10G) | 804 Mbits/sec | 383 Mbits/sec Online.net | Paris, FR (10G) | 806 Mbits/sec | 556 Mbits/sec WorldStream | The Netherlands (10G) | 788 Mbits/sec | 399 Mbits/sec wilhelm.tel | Hamburg, DE (10G) | 774 Mbits/sec | 238 Mbits/sec Biznet | Bogor, Indonesia (1G) | 919 Mbits/sec | 699 Mbits/sec Hostkey | Moscow, RU (1G) | 789 Mbits/sec | 579 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 715 Mbits/sec | 241 Mbits/sec Airstream Comms | Eau Claire, WI, US (10G) | 679 Mbits/sec | 169 Mbits/sec Hurricane Electric | Fremont, CA, US (10G) | busy | busy Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 968 Multi Core | 916 Full Test | https://browser.geekbench.com/v5/cpu/3362191geekbench 5 numbers are several dozen points lower than the YABS I had run a couple of weeks ago. (link)
Sir, that number don't add up. Can you please power your VPS off and on again from the managementpanel?
What is this green goblin gobledegook stuff?
'''''''wa fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 272.70 MB/s (68.1k) | 2.55 GB/s (39.8k) Write | 273.42 MB/s (68.3k) | 2.56 GB/s (40.0k) Total | 546.13 MB/s (136.5k) | 5.11 GB/s (79.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- **Read | 4.31 GB/s (8.4k) | 4.10 GB/s (4.0k) Write | 4.54 GB/s (8.8k) | 4.37 GB/s (4.2k) Total | 8.86 GB/s (17.3k) | 8.47 GB/s (8.2k) **Also
Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1257 Multi Core | 1254 Full Test | https://browser.geekbench.com/v5/cpu/3364455VPS reviews | | MicroLXC | English is my nth language.
This is Premium KVM VPS "VPS-1G" right??
