Tiny LXC box
I have one of these that doesn't permit a TUN interface, which kind of nixes the VPN idea I had in mind.
Net speeds are actually pretty impressive for such a small unit, albeit IPv6 only.
Apart from web hosting or a DNS server, what other uses could I put this thing to?
TYIA
`iperf3 Network Speed Tests (IPv6):
Bouygues Telecom | Paris, FR (10G) | busy | 902 Mbits/sec
Online.net | Paris, FR (10G) | busy | 922 Mbits/sec
WorldStream | The Netherlands (10G) | busy | 924 Mbits/sec
wilhelm.tel | Hamburg, DE (10G) | busy | 925 Mbits/sec
Airstream Comms | Eau Claire, WI, US (10G) | 719 Mbits/sec | 355 Mbits/sec
Hurricane Electric | Fremont, CA, US (10G) | 728 Mbits/sec | 236 Mbits/sec `
Proxy server
You can try squid proxy server,
Nice network speed.
Whoops, I've ran into a problem here:
ssh root@<IPv6 address assigned>
port 22: Network is unreachable
Any suggestions...?
This is an IPv6-only box, whereas my other IPv4 instance connects just fine.
TYIA
Is it listening on port 22?
Does your internet provider give you access to the IPV6 internet (or are you using some method to get from IPV4 to 6)?
What happens if you
Ask for TUN/TAP to be enabled.
Asked already...and declined...
PING 2606:4700:4700::1111(2606:4700:4700::1111) 56 data bytes 64 bytes from 2606:4700:4700::1111: icmp_seq=1 ttl=57 time=250 ms 64 bytes from 2606:4700:4700::1111: icmp_seq=2 ttl=57 time=250 ms 64 bytes from 2606:4700:4700::1111: icmp_seq=3 ttl=57 time=249 ms 64 bytes from 2606:4700:4700::1111: icmp_seq=4 ttl=57 time=250 ms
No problem with IPv6, once I have an IPv4 connection set up through OpenVPN...
Close that VPN connection and guess what...?
$ ping6 2606:4700:4700::1111 connect: Network is unreachable
Supplied by the provider:
Primary IP 192.168.52.22
My initial thinking is that the network interface initialisation, client side, might be the primary issue....
@anteck - I'm all confused here.
Do you have IPv6 connectivity? Otherwise I'm not surprised that you're unable to SSH to the IPv6 box. That also explains why once you enable OpenVPN things work (likely you have all external connectivity routed via the OpenVPN tunnel).
I guess I don't have independent IPv6 connectivity at all.
Just like you say, only when OpenVPN is up and running...
I guess that explains it then.
You should check if there is a IPv4 NAT for the LXC box which will allow you to use a custom port to SSH via IPv4.
Otherwise, if you want to reach the IPv6 only box you should look at a
ProxyCommand
and/orProxyJump
options for SSH (assuming a recent enough version of SSH).You could use it as a honeypot to combat malicious online activity.
Oh dear, back to the old drawing board...
I'll take a look into the SSH proxy options available.
Thanks to all for your help...!
