Open source e-mail marketing platforms
What do you guys recommend for open source based email marketing like news letters and the like?
Thought Is a VPS with the platform connected via smtp to a reliable email solution sending out 50-150 emails an hour till the list is exhausted. Obviously with the ability to opt out via a link and analytics on those that do opt out or click through.
Check Mailtrain and Sendy out.
I'd go with the latter if you can spend a bit of money.
Thanks Sendy indeed looks pretty top notch but only locked to ses?
You can use SMTP in its settings, they just push the SES thing as a preference.
Hate radiates from the source. If you look around and see it everywhere, it's coming from you.
Never tried, but sendy + SES should be good
i second sendy. A friend, to who I recommended, has been using it successfully with 100K+ subscribers for the last 5 years.
I just did a larger mailing (3k) for a client using Mailtrain, on a Cloudron - Ubuntu 18.04 VPS from Time4VPS. It worked wonderfully well, for someone with zero experience with bulk mailing.
Not really a recommendation - just sharing my experience.
So while sendy is incredibly reasonably priced I kinda would prefer to first see if the news letters generate any meaningful traffic before investing any money into it. Mailtrain seems to be "free". Did you find it feature rich in terms of analytics or automation of sending?
Thanks
Again, email marketing / bulk email is not my thing, so I don't really know what I am doing in this area -- that said, as far as analytics, you can do both link click counting as well as using an embedded image for open counting. The reports that I have noticed are basically listing of who/when/where clicked the link or opened the email. It does have a report generator, but I have no idea how to utilize it nor a need to, so I can't comment.
As far as 'automation of sending' ... upload the email list, create the content, and click send. As I mentioned I used the Cloudron installed Mailtrain, so there was no real set up involved. Cloudron handles the integration very nicely as it has it's own MTA which I used.
My biggest frustration with it is that there is barely any documentation.
Any other questions feel free to ask, and I will try to answer.
Can you schedule out the sending from one list? For example send out 100 at 8am then 100 more at 12pm from one list. Or does it require you to make a different list for that? Ideally I would like to automate sending out different parts of the list instead of creating a bunch of lists and campaigns. This will also be my first go around for this so i actually appreciate that your also new to it.
Thanks!
From what I see there are two things at play. First what they call "List Segmentation"
List segmentation
Send messages only to list subscribers that match predefined segmentation rules. No need to create separate lists with small differences.
but I do not see how where one defines the 'segments'.
Second, when you create a campaign and it is unsent, you can add a delay in time for when it should send - I don't see any finer grained scheduling than that.
Gotcha appreciate the response.
Mailtrain - used it for the alumni association of the institute I completed my post-graduation from, even the non-technical student committee found it very easy to manage.
Artnet - Poland (Gdańsk) based instant setup express dedicated servers & cloud VPS
https://github.com/knadh/listmonk is another DIY open source solution.
Just a note that the readme states it is alpha software.
The best : Mautic
Nexa Racks - Reliable Web Hosting Company
