Request: Monitor recommendation for use with Macbook Pro 16
edited September 2020 in General
LES Team -
Looking for an external monitor recommendation to be used with a MacBook Pro 16 in my WFH setup (a standing desk setup).
Should be available or shippable to India.
Purpose: Work/Code. No gaming. Little design (app/mobile) work.
What is your view about 2K or 4K monitors? Any personal recommendations? What makes an ideal monitor size for work setup?
Is USB-C monitor worth? (I see that most USB-C monitors, which support power delivery only support upto 60/65W. Macbook Pro requires 96W)
I did look at rtings.com for recommendations. Most of them are expensive or unavailable in India.
Thanks in advance.
what is your ideal monitor setup?
  1. What do you recommend for a monitor setup?17 votes
    1. 4K/5K monitor
      41.18%
    2. 2K monitor
      35.29%
    3. Full HD (1080p)
      23.53%
  2. What is your ideal external monitor size?17 votes
    1. <= 24 inches
      17.65%
    2. 27" inches
      58.82%
    3. 32-34" inches
        5.88%
    4. >40" inches
      17.65%
