JSlinux, Linux, Freedos, windows 2000 in your browser - surprisingly functional.
 InceptionHosting
                    Hosting ProviderOG
InceptionHosting
                    Hosting ProviderOG
                                  in Technical
                    Check it out: https://bellard.org/jslinux/
I don't know what else to sat about it, it is what it is.
Windows 2000 was the last Windows version that I used on a regular basis...
What a nice journey back in time.
And since then you have used Debian?
Which OS do you use for your laptop/desktop/workstation? Just curious
No, only for servers.
I use OSX (macOS) on workstations since leaving Windows behind.
Windows 10 is my daily driver. I don't feel good about it, but I have been upgrading and migrating this puppy since windows XP!
Man you made my day!
Now I can play solitaire on Windows2000 using my phone. Next step is install Lotus 1-2-3, grab some 5 1/4 floppy disks and connect to AOL.
Wonder if the old notepad (or was it wordpad) help escape to system level privilege command shell works?
will try tomorrow.
https://distrotest.net/
