@yokowasis said: I can assure you it will end up ugly, unless you can selectively choose who you want to be your neighbor.
I am sorry, but I don't understand? The resources are dedicated, and your only talking about 2 - 4 people per server. What I am missing?
Yes, dedicated. But FBI will confiscate all the whole server. And hetzner in worst case scenario will suspend your account makes you lost your other server as well.
Being a provider isn't just be able to split the resouces.
In our scenario back in 2015, they took only the hard disks of the node where the customer's vps was created. And leaved all other 43 customers on the same node offline...
Was that on Hetzner, or somewhere else?
Actually it was in our DC in Albania... but if i remember correctly @seriesn (nexusbytes) have had the same situation in Germany-Hetzner recently, he said they took the disks.
It works for multi hard drive. In case 1 hard drive, it means the whole server are down.
Our server have had 4x1TB hdd raid10, and they took them all disks belong to that server, which mean whole server was offline. Because i'ts raid, and the data are striped around the disks.
wWw.AlbaHost.Net .AL domains, Dedicated Servers, VPS/VDS and Hosting Services. Geo Located in Albania and Kosovo.
I refer to the default hetzner AX LINE setup.
I have decided not to spit this up, and just transfer it to someone.
How much per month? Thanks!
I am ready to take it up.
ThemeForest Profile
is it done already ? I pm'ed you a few weeks ago
Received server transfer from @aaronstuder.
Thanks!
My apologies to anyone I missed :-( I tried my best
Please close this
You can update the subject to indicate it's sold.
