the I/O performance has been miserable since my VPS was deployed. I checked twice yesterday and decided to wait for today to start setting things up. turns out the situation hadn't improved until this morning, so I decided to wait until the evening. well, nothing has changed...
yes. sadly I can confirm. started moving some backups from a nearby server... disk writes is about 5MB/s, iowait 40-50%.
it's either hundreds of users writing to spinning rust or abusers torrenting the shit out of it
@Falzo said:
I didn't bench again, but seeing only 5-6 MB/s still via iotop on transferring real data (archives) ... let's see, hopefully he get's it cleaned up.
I'm getting around 17 MB/s from my home connection (which maxes out at around 40MB/s). I guess it won't get much faster than this.
I can cofirm there is high IOwait, my rclone transfer only 2-5 MB/s with 3-6 CPU Load
@flips said:
I always wonder if we're considering Mbps vs MB/s correctly
at least I do ;-) :-P
PS: maybe there are troubles with the ZFS raid arrays already ... if some disk died and it runs around scrubbing all day, that obiosuly will f*ck up performance as well. I sincerely wish them good luck in figuring this out but seems it lacks a bit of planning or experience with that kind of product esp. when it comes to lowend audience ?♂️
Sorry for the delay in answering here
Was working fully on the new rack
for the performance what happened is a storm of users filling and testing their vms to the max which we have never seen before
the difference between here and last time is that
1- We got the same number of users that we usually get in 2 to 4 weeks of posting the offer in less than 12 hours
2- all past offers we had only 100mbps network which made filling the vps slower which helped in the first few days
to fix the issue we are currently moving some users to different nodes and we are suspending extreme abusers
as I said the performance should be back in few days and just in case we are extending refund window by another week so you have 2 weeks to ask for refund if you didn't like the performance
to fix this issue we have a plan for future offers but unfortunately it will not work for the restock in less than 2 weeks(too late to implement it)
@servarica_hani - I have won a prize from my participation in the draw on Low End Talk (thank you!). Please exclude me from the drawing here just in case I'm not automatically excluded.
PM the list to @vyas for accountability, tell me how many are on it and I will pick 5 numbers using a random number generator and post a screen capture of it.
PMed him
Thanks
Thanks @servarica_hani,
Confirming the receipt of the message.
@AnthonySmith It' s nearly 3 AM here but I can stay on for another half an hour or so if required for the draw.
PMed him
Thanks
Ok will have to be drawn tomorrow then, its 10pm here and I am old so going to bed, bit exhausted from staying up all night multiple days in a row over BF/CM. catching up on sleep.
@servarica_hani please let me know how many rows there are to pick from.
@servarica_hani@vyas for validation please as I don't have the list I only pick the numbers:
The winners are lines:
54
79
5
23
82
Screencap below compressed to a gif, the first number (number 3) is just what it loads on so ignore that as I had not expanded it to 101 lines initially
Registered for 2tb yearly waiting list.
Just getting around to catch up on the giveaways : Order #5186167037
Order #8152595252
Thanks
Want a Polar Bear.
Please set an exact schedule before releasing restocks.
Thank you
Order #2443392792
Thank you
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-11-20 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # lör 28 nov 2020 14:09:42 EST Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz CPU cores : 2 @ 2593.624 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 1.9 GiB Swap : 1.9 GiB Disk : 1.9 TiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 18.78 MB/s (4.6k) | 67.66 MB/s (1.0k) Write | 18.79 MB/s (4.6k) | 68.03 MB/s (1.0k) Total | 37.58 MB/s (9.3k) | 135.69 MB/s (2.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 26.60 MB/s (51) | 10.50 MB/s (10) Write | 28.45 MB/s (55) | 11.72 MB/s (11) Total | 55.05 MB/s (106) | 22.23 MB/s (21) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 948 Mbits/sec | 931 Mbits/sec Online.net | Paris, FR (10G) | 929 Mbits/sec | 925 Mbits/sec WorldStream | The Netherlands (10G) | 943 Mbits/sec | 927 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 492 Mbits/sec | 32.3 Mbits/sec Clouvider | NYC, NY, US (10G) | 1.01 Gbits/sec | 974 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 972 Mbits/sec | 959 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 909 Mbits/sec | 943 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 488 Multi Core | 929 Full Test | https://browser.geekbench.com/v5/cpu/5048180yes. sadly I can confirm. started moving some backups from a nearby server... disk writes is about 5MB/s, iowait 40-50%.
it seems @servarica_hani heard our complaints:
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-11-20 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # lör 28 nov 2020 17:47:55 EST Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz CPU cores : 2 @ 2593.624 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 1.9 GiB Swap : 1.9 GiB Disk : 1.9 TiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 22.74 MB/s (5.6k) | 149.06 MB/s (2.3k) Write | 22.75 MB/s (5.6k) | 149.84 MB/s (2.3k) Total | 45.49 MB/s (11.3k) | 298.90 MB/s (4.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 157.20 MB/s (307) | 158.67 MB/s (154) Write | 165.55 MB/s (323) | 169.23 MB/s (165) Total | 322.76 MB/s (630) | 327.90 MB/s (319)I didn't bench again, but seeing only 5-6 MB/s still via iotop on transferring real data (archives) ... let's see, hopefully he get's it cleaned up.
Didn't see a whole lot of giant storage offers...thanks for putting these out here!
Mine ofcourse correct.
Order #5607301752
thanks
My reliable providers : Ramnode : HostHatch : Serverica : InceptionHosting : AlphaVps : LittleCreekHosting : NexusBytes : Hostodo
good idea
GL getting people sorted!
will have the list of people who commented and their scores in less than 24 hours then will ask one of the admins to do the draw
Thanks
Tagging @FAT32 + @AnthonySmith as the administrators-at-the-moment.
@AnthonySmith do you want to do the draw ?
or we can ask @FAT32 if he is ok ?
I have the file ready
Thanks
PMed him
Thanks
@AnthonySmith
it is 101 lines
1 and 101 included
Thanks
Oops. Did not realize this was not shared across ogf...
Am I too late to make a post of my polar bear order? Order 3085116988
@servarica_hani @vyas for validation please as I don't have the list I only pick the numbers:
Congratz to the winners!
Nicely done @AnthonySmith , I learnt something new today.
Confirming 5 unique winners,
I will let you and @servarica_hani declare the names..
