[NL] 1GB RAM KVM SSD VPS 12€/year & 4GB RAM KVM SSD VPS 48€/year Flash Sale
gleertgleert Hosting Provider
edited November 2020 in Offers
Flash Sale!
1 CPU Core
1GB RAM
20GB SSD
1TB Traffic
1Gbps port speed
1 IPv4
/64 IPv6
Quantity: 10
€12/yr
Promo code: QRRM502ZTI
Order Here
2 CPU Core
4 GB RAM
80 GB SSD
4 TB Traffic
1 Gbps port speed
1 IPv4
/64 IPv6
Quantity: 10
€48/yr
Promo code: 9JC6MMSA2V
Order Here
Our VPSes (ask for a recurring coupon code) Mailchannels low volume plans
Thanked by (1)ehab
  • ehabehab Content Writer
    u know that 4GB Ram are always welcome :)
  • gleertgleert Hosting Provider
    2 CPU Core
    4 GB RAM
    80 GB SSD
    4 TB Traffic
    1 Gbps port speed
    1 IPv4
    /64 IPv6
    Quantity: 10
    €48/yr
    Order Here
    Thanked by (1)ehab
  • Uh I’m on my mobile and this is impossible ?
    What is the issue?
  • @gleert said:
    What is the issue?
    Nothing, hate to see offers when I’m out on mobile ?
    @thedp said:
    @gleert said:
    What is the issue?
    Just ping me when you're back at you desktop and you can't get the offer anymore...
  • edited November 2020
    -snip out as it didn't really work-
    IPv6 didn't work out of the box in Debian 9, wrote this script to address it:
    # Put your gateway IP here
    GATEWAY_IPV6=1111:2222:3333:4444:0000:0000:0000:0001
    # Setup eth0 up/down hooks:
    cat > /etc/network/if-up.d/eth0_ipv6 <<EOF
    #!/bin/sh
    [ "\$IFACE" = "eth0" ] || exit 0
    /sbin/ip -r route add $GATEWAY_IPV6 dev eth0
    /sbin/ip -r route add default via $GATEWAY_IPV6
    EOF
    cat > /etc/network/if-down.d/eth0_ipv6 <<EOF
    #!/bin/sh
    /sbin/ip -r route del $GATEWAY_IPV6 dev eth0
    /sbin/ip -r route del default via $GATEWAY_IPV6
    EOF
    chown root:root /etc/network/if-up.d/eth0_ipv6 /etc/network/if-down.d/eth0_ipv6
    chmod 700 /etc/network/if-up.d/eth0_ipv6 /etc/network/if-down.d/eth0_ipv6
    Then comment out post-down section in /etc/network/interfaces and reboot... not sure why those post command defined in the file didn't work as expected :/
    Thanked by (1)ehab
    Looks like the IPv6 only works for a short period (~30 mins?) of time and then it decide to stop working... Delete and re-add those route will make it work again (route caching issue?).
    I'll upgrade to debian 10 and see if it fixes anything.
    Can you run:
    cat /etc/network/interfaces
    If netmask is 64, please change "netmask 64" to "netmask 48" in /etc/network/interfaces and reboot.
    Thanked by (1)jixun
  • That got IPv6 working for me. (well, the equivalent ip addr add MY_IPv6/48 dev MYDEV command did)
    Thanked by (1)gleert
    Can you run:
    I'll change it to 48 and reboot, thank you for the help! :D
    Looks like is working fine for now.
