FATAL -> Failed to fork. (Ubuntu 18.04 / OVZ)
Hello, i rented from InceptionHosting some NAT VPSses and the one from London makes Problems right now. If i run "apt-get update" or "apt-get install ..." it will don't install the Package, it displays me directly after the normal process "FATAL -> Failed to fork.
" Have someone here also the Issue? I'm using Ubuntu 18.04.5 LTS
Thanks for Help,
Xenic
cat /proc/user_beancounters showes me the following issue,
resource held maxheld barrier limit failcnt
privvmpages 126086 178561 9223372036854775807 9223372036854775807 7
This usually happens when you run out of memory during the operation. What did you try to install?
I think I got 18.04 on at least one box as well and didn't run into a problem - it's a 256MB one.
I tryed to install traceroute over APT, but the progress don't need the full 128MB, it showed me circa 60MB of Ram Usage.
Your running out of ram, try installing some of the packages individually.
It may show you 60MB used but it means there is not even enough to allocate.
