Best IP Info website?
I normally use IPlookup.flagfox.net but lately it's database has not been updated that often. I'm struggling to find another IP info website that can be queried via URL (e.g. example com/IP=1.1.1.1), and displays ISP, ASN and location data (ideally with a map).
Anyone have any suggestions or hints of alternative sites that fit this use profile?
Try: https://ipinfo.io/
They have the usual limits blah blah blah for free use but it's been pretty decent for some simple use.
Yeah, I prefer ipinfo.io, they are simple and suppport curl & api
https://ipinfo.io/1.1.1.1
I use myip.ms and ipinfo.io
https://whatismyipaddress.com/ip/1.1.1.1
I usually use https://www.infobyip.com/ip-1.1.1.1.html
My favorite is https://bgp.he.net/
It has a clean interface and information about BGP peers.
However, there's no geolocation feature.
+1 for bgp.he.net
PeekaBoo at https://handyhost.net
(Not affiliated with the Russian Handyhost Website in any way.)
https://ipdata.co
Preferred over ipinfo because there is no query limit (to my knowledge).
AMD EPYC powered Performance NVMe VPS - Los Angeles, Dallas, New York, Amsterdam, Singapore | Support | Status
Good to know about another alternative out there.
Actually everyone has limits (and fine print).
ipinfo.io -> 50K / month (free usage, don't know if account is required)
ipdata.co -> 1500 / day free (again don't know if an account/key/whatever is required or if they track you by other means).
So far, I really like ipinfo.io - they do a good job and are generally pretty reliable (and decent/generous) with their limits for casual queries.
But it's always good to have a few extra options.
ifconfig.co and ifconfig.me
https://iplocation.io/ip/1.1.1.1
Use them occasionally, includes multiple sources. Don't know the limits (if any)
+1 for bgp.he.net as well. Also people saying it doesn't have Geolocation is not true, at least not from what I've seen.
I personally prefer Check-Host, and if I want to know more info about any IP or ASN, I use BGPView
AmirGT | AS207740
Yes, have backup options id always good.
I'm using also https://iplookup.flagfox.net & https://iplocation.net often, but i use more my self written discord certified bot
One major challenge with ipinfo.co is not being able to resolve IPs from website/A records. Any recommendations for one-step IP resolver + info sites?
