@dahartigan said:
Have a look at Proxmox. You can get the best of both worlds, webui with console, easy to use, set up anything as a file backend etc etc all with LXC.
Is Proxmox works on VPS too, like netcup/hetzner cloud/vmware, the client base has unpredictable setup
Yes it works on any KVM VPS from any provider. You can install it on top of Debian 10 and it's quite lightweight.
That said, it might not be the best option but worth mentioning.
Thanks for the pointer, we will check them out later stage.. Just fiddling with lxc stuffs, storage pool, volume stuffs and cluster a while. Good to see a tons of features and options to scale.
Doesn't require nested virt for LXC?
