LES Wiki - work in progress.
InceptionHosting
Hosting ProviderOG
The LES wiki is going to be very much a work in progress and will take over all 'list posts' in time, I have made it visible for now with a top bar link.
Eventually, when I move talk.lowendspirit.com to lowendspirit.com it may replace the current 'blog' based on grav completely, that is still under consideration though.
Suggestions on content for the wiki are welcome please ![]()
Thanks @AnthonySmith for doing this
@AnthonySmith
FREE Blesta licenses by BuyVM and NexusBytes
FREE Softaculous Premium by BuyVM
@Francisco and @seriesn , please correct If I get it wrong
That sounds Great @AnthonySmith _/_
For Wiki Suggestions, something like Installing Selfhosted Open Source stuff on LowendVPS providers
"how to"s lots of "how to"s
vpn, proxy, dns, torrent, xamp, wp scripts, media server installs, hosting scripts installs, proxmox , ipv6 only proxmox, proxmox ha?.....
Well, I don't think it is the right format to have the actual guides in but it will be great to link to them when they are written
A Self-Hosted Category.
You're gonna take a mega SEO hit on that if I'm not mistaken. Subdomains are scored separately so basically start from zero
Users can contribute (write) to the wiki as usual?
Github
A 301 Cloudflare Page Rule should take care of passing the Link Juice in sometime
Great job @AnthonySmith
How can we contribute?
nope, at least not directly, I can't afford the time to moderate the spam and dead stuff.
That was what I was hoping, but the place is only a year old I can live with the 'hit'
I guess the only way I can think of right now is to make a wiki contributions category when it gets approval I will take the content and push it into the wiki.
Sounds great
Just some ideas:
Self-Hosting
Backups
DNS
Security Hardening/Tips
https://cyberhost.uk
if anyone has any scripts or configs they use and want to share that would be great, I am not talking about self-made software suites but more like backups scirpts, one liners to do xyz, nginx/mysqld conf's etc etc
Noticed that only Nexusbytes is listed under hosts giving free Blesta, but according to their website BuyVM also does so.
Thanks, yes, it will take a while and good people like you to help get that info on the site, I am seemingly incapable of keeping all of these things in my head these days
good job I am making a directory eh!
LXD, LXC Idiots Guide complete
Wireguard Idiots Guide complete
VXLAN between LES VPS, NAT VPS, network and port forwarding.. I shall test with InceptionHosting then expand to Cam and MrVm NATs.
docker for idlers: a concies guide (install, configure,use, backup, delete, f*ck up, recover, try to keep it running)
Will I be able to add a definition for male PMS?
It's a common occurrence in low end world.
In regards to how-to guides to install generic xx service or program, don't see a need for them here as there are already 1000's of same guides already available with a google search. If anything, more vps specific how-to's such as Anthony already mentioned : "backups scripts, one liners to do xyz, nginx/mysqld conf's etc etc.
One liner to break OpenVZ 7 so bad that it would require a reinstall:
I found this when I'm trying to stop SolusVM from overwriting my config. Apparently this breaks the container and it will never boot again.
One liner to stop SolusVM from messing up the config:
Tested on Gullo's Hosting Canada.
No rm -rf jokes, please.
@Not_Oles already lost his hair on this, lets see who next.
i would settle in installing k3s master on proxmox-LXC.
I spent like five minutes. All I did was run virt-host-validate.
Today I have a new customer who wants Stripe. I can imagine Stripe being harder than running KVM inside LXC.
Any tips on Stripe?
yep, that can do the trick however I would suggest that if you need to edit the network config, you probably should not be cheeping out on OpenVZ anyway.
no experience on strip at all - sorry about that.
The top bar text entries now break at my very high level of zoom.
I will have a look later I may have some bash scripts lying around. Maybe not the most actual ones but still working I hope.
Grab your vmWare toblerone today.
How about some
dd if=/dev/zero of=/dev/yourdriveor some malformedmkfscommands?Sorry
not a lot I can do about that, at least it is not a functional change.
