My Idlers - Self hosted web app for your servers, shared hosting and domains information
My Idlers is a web app for displaying, organizing and storing information about servers (VPS), shared hosting and domains.
Despite what the name infers this self-hosted web app isn't just for storing idling server information. By using a YABs output you can get disk & network speed values along with GeekBench 5 scores to do easier comparing and sorting.
Version 1.3 31st Jan 2021
Sample page (Add/Edit/Update/Delete disabled)
Features
Add servers Add shared hosting Add domains Auto suggest locations Auto suggest providers Auto get IP's from hostname Check up/down status Get YABs data from output Save & view YABs output Next due date system Multi currency compatibility Multi payment-term compatibility Pre-defined operating systems Assign tags Assign labels Assign server type (KVM, OVZ, LXC & dedi) Easy to edit values Order by table Search items Tally/stats card One-page design
Thanked by (37)dahartigan TheDP youandri localhost Neoon AC_Fan sahjanivishal Naix Asim donko _MS_ Brueggus mikho yokowasis ehab Bochi beagle alwyzon Falzo Ympker casadebamburojo PHP_Backend tridinebandim Mason lgsin elliotc bark Ganonk Abdullah lighter vimalware ferri alento Hirose verd Janevski bdl
Idling server management at its best.
It's cool.
Wow I'm impressed, Ima install this quick,
Really nice features
Sultan Muda - Amazon Store
Does it have a means to store YABs history? Add to that, it'll be great to have a way to compare different YABs results from different test times.
I have a (mostly) idle MXroute. Where do I put that?
Neat way to keep track of everything. Might have to give it a try. Good work!
Is there a way i can upvote this thread ?
this is a super tool, i will check it out.
Thank you very much.
looks awesome. already have a few more suggestions I'd love to see:
thanks for sharing and all the efforts you already put into that!
Looks awesome
Thanks!
Also: a way to back up or export to CSV or Excel format
Very neat! Great alternative for those using an Excel sheet for this.
Did you copy that nameserver field from whcms?
I like your subdomain naming!
User management would be overkill and any homemade user management is subject to attacks. For starters, it's very easy to make mistakes in how to store passwords.
An easier and more secure way is to deploy two separate webapps:
Then, the user can have the admin site listen on localhost and accessed via SSH tunnel, while the external site can either be open to everyone or placed behind Basic Auth configured in HTTP server.
Love the 'View YABS' feature
Layout/formatting could be better I suppose.
True. At first, I thought that was the Close button
. It's just the first release, and we might see changes in the future based on the feedback from the community.
Yeah.
Nevertheless, it's a piece of work ?
How to report bugs @corbpie , github issues?
Well done! Looks great
Humble janitor of LES
Proud papa of YABS
If I use a server to manage other servers, should I add the server itself to the list?
No, that server should go on a sticky note instead, stuck to your monitor or CPU
Just a couple of feature requests (if you are accepting them and they are within scope of the project):
This looks awesome and will likely replace my spreadsheet I have.
Unfortunately, in my country, sticky note and maker may count as weapon, I cannot use sticky note at will.
fragrant
https://microlxc.net/index.php?p=deploy
@corbpie
-You didn't used a framework so you are missing good security practices. Good thing you used PDO.
@everyone
-This project is not to be hosted publicly accessible. Basically there is zero user management, means no login, no secure sessions, no token etc. I guess is ok if you host it in your local computer where nobody can access it from the outside.
This is why you don't reinvent the wheel, instead you choose from one of the proven secure and stable PHP frameworks which already include best user management practices. User management is never overkill.
This is your opinion, but is not the year 1998.
Will work on that just for Disk & network speeds though.
Thank you, they're on the todo list.
Export & import would be great however these can only be done once it is settled on the final fields/inputs.
The NS1 and NS2? No, i was just cutting down on using "Name server"
Thanks, that is a nice idea and has been noted.
