Pi-Hole New User
edited January 2021 in Help
Hola,
Hope some of LEB users use Pi-Hole here.
I just now installed Pi-Hole to one of my US Server. Ok everything runs ok.
But is there any point the A record to that Pi-Hole IP Address ?, I mean it is hard to remember the Ipv4 address.
And I would like to use a sub-domain as my DNS Server ( Pi-Hole server ), So Anyway to do that ?.
Is this possible ?
And want to use that sub-domain dns on private DNS setting
  • Well, you would then have a classic "chicken-and-egg" problem: whom would you ask for the IP of the entered A record? ;)
    Thanked by (1)deepak_leb
  • Please don't setup an open DNS resolver if you don't know what you're doing: https://blogs.infoblox.com/community/how-dangerous-can-an-open-dns-resolver-be-part-i/
    Especially Pi-hole is not meant to be setup as a public dns resolver. Instead it's designed to be used within a closed network, for example over VPN. Pi-hole does not feature any rate limiting and will happily answer ANY queries, which are notorious for being used in DNS amplification attacks.
    So please, restrict access to you pi-hole instance by using (for example) pi-VPN.
  • Change the listen interface to tun0/wg0 (openvpn/wireguard) and tunnel dns/all your traffic through the vpn.
    ^^This^^
    For extra cookie/brownie points setup Unbound as the upstream recursive DNS resolver. Follow this if you get stuck.
    ok noted
  • @saibal said:
    ^^This^^
    Will follow this
  • @deepak_leb said:
    @saibal said:
    ^^This^^
    Will follow this
    Also, (obviously) firewall off port 53 (DROP) on public interfaces using whatever layering of rules you prefer.
