Introducing NOVOS BRICK cloud storage - 200 GB for just €1 (one-time only)
1246711
  • Ok, it seems like end to end didn't get turned on/applied to my account. I'm not seeing it in settings or when I right click folders. I changed my main password as well because when I was doing my instance it seemed that the private key was tied to that, but I just don't see anything on my account for that past the Server side encryption status on the dashboard.
  • @martijnk said:
    @lowendmeow said:
    So it still says in privacy that admin has access to my files but it also says that server side encryption is on. Not sure how to test the other encryption or if that applies when it's saying admin still has access
    If you run the nextcloud client, you can go to settings. There you can enable end-to-end encryption.
    Then right-click a folder and choose encrypt. Then only you will have the key and admin can't access the folder.
    Alternatively, if you're using rclone, you can use the crypt backend. (I believe rclone doesn't support NextCloud E2E.)
    sure, it's just nice to see the files in the UI as well for some things
  • martijnkmartijnk Hosting Provider
    Are you using the apple, android or windows client? it only works with those.
    I'm just doing the web client, not supported on there? Wasn't aware of that. I can check on android in a second
    Correct, it only works with the native clients :)
    Makes sense right because it's end-to-end and the website runs on our server, it needs to be your end ;)
    for sure! just seems like there should be some in browser encryption technology, I think mega.nz uses that, but as I understand Nextcloud is ramping up with the end to end.
  • Well seem that I now have a new addiction. At first it was idling server. Now I’ve added idling encrypted backup to that list. At least the chances of losing family picture are getting lower and lower....
  • Well done, greatings BE
    It s working in ios
    Isn't the backup storage supposed to be idle? As long as the primary doesn't break, you won't need the backup.
    I have 120GB of photos, since our first digital camera in 2002. All photos are in a 2TB USB HDD attached to the home router.
    Before that, I took 20 digital photos from 1998 at a computer summer camp, but the floppy disk containing those photos broke around 2000 and I lost them forever, except 2 photos printed.
    NOVOS would be my first off-site backup. With 200GB space, I would have enough for next 5~8 years.
    Now let's see whether the BRICK gets discontinued before that time comes.
    Thanked by (1)IV__
    Agree that backup are mostly idling once the initial upload is completed and until you need them...
    I had transip services before but since they are shutting down the free offer I've looked for a new home. I also have in house backup on an external drive connected to the router. But that does not protect for fire event, flood or even theft. So online storage is kind of a necessity. And I'm too lazy to manually do an offsite backup on an external drive.
  • Got one as well, thanks! Hope this works out long term
  • Hey @martijnk nice offer! ??
    Thanked by (1)martijnk
    Well we've reached 100 users so I added 100 more :)
    Also webdav had a 512MB file size limitation that was increased to 32 GB.
  • alentoalento Hosting ProviderOGServices Provider
    @martijnk
    As per the norm in my life, I have tripped MaxMind. :(
  • Excellent offer, thank you :)
    @alento said:
    @martijnk
    Yeah you're not alone, try now :)
    Thanked by (1)alento
    @ofit said:
    @martijnk activate Collabora Online please
    Hi Ofit,
    This is now active!
  • @martijnk said:
    Hi Ofit,
    This is now active!
    still not. You need config right Collabora Online server. When you config right it allow edit documents.
    @martijnk said:
    Hi Ofit,
    This is now active!
    I am certainly doing something wrong ... how do I access Collabra? I cannot find it anywhere. Please note, I am new to NextCloud so maybe I am not looking in the right place, but I have looked everywhere.
  • @martijnk said:
    Hi Ofit,
    This is now active!
    Now work ok.
    @ofit said:
    @martijnk said:
    Hi Ofit,
    This is now active!
    It works for me now:
    @alento said:
    @martijnk said:
    Hi Ofit,
    This is now active!
    Just create a new document or spreadsheet in a folder, then when you click it it will open.
    Thanked by (1)vimalware
  • guys how about talk plugin? do you use it?
    I had it disabled because it was leaking email of other users. Should be fixed now though.
  • Got one to play with.
    Great deal. Thanks!
  • edited January 2021
    Got this once http://prntscr.com/xszxbt . Probably need some database optimization?
    Another thing. Deleted file not going to trash.
    Yeah correct, I've seen that a couple of times. I'm still tweaking the values.
    I think the latter has to do with the first.
    Thanked by (1)Hakim
