Introducing NOVOS BRICK cloud storage - 200 GB for just €1 (one-time only)
1235711
  • @martijnk said: And I couldn't offer her something similar.... omg
    Thank you! was wondering where to move my Google Photos! this is exactly what I need
  • alentoalento Hosting ProviderOGServices Provider
    edited January 2021
    @martijnk said:
    @alento said:
    @martijnk said:
    @ofit said:
    @martijnk activate Collabora Online please
    Hi Ofit,
    This is now active!
    I am certainly doing something wrong ... how do I access Collabra? I cannot find it anywhere. Please note, I am new to NextCloud so maybe I am not looking in the right place, but I have looked everywhere.
    Just create a new document or spreadsheet in a folder, then when you click it it will open.
    Uhmm, I wish my life were that simple. I created a new document. It did not open. I reread and saw that you said to create it in a folder so I did that ... same.
    Now, a few minutes later ... it works. Sigh
  • martijnkmartijnk Hosting Provider
    @alento said:
    @martijnk said:
    @alento said:
    @martijnk said:
    Hi Ofit,
    This is now active!
    You're not wrong. When I create a new document and click it, nothing happens. I have to go somewhere else, come back to files, then click it and it works.
    It's a bit bugged I guess...
  • Off topic - has anyone successfully mounted nextcloud using webdav?
    https://docs.nextcloud.com/server/20/user_manual/en/files/access_webdav.html#creating-webdav-mounts-on-the-linux-command-line
    I did as per above instructions and mount works fine, but when I reboot my box goes into emergency mode.
    I set a system-wide mount for WebDAV.
    All files would show up as owned by the ubuntu user that I use to login to the desktop.
    sudo apt install davfs2
    sudo mkdir -p /mnt/BRICK
    sudoedit /etc/davfs2/secrets
      /mnt/BRICK [email protected] 8e0e052e-7beb-4e35-bf8d-45e9d69aceaf
    sudoedit /etc/fstab
      https://brick.novos.be/remote.php/dav/files/[email protected]/ /mnt/BRICK davfs _netdev,user,uid=ubuntu,gid=ubuntu 0 0
    Thanked by (3)ferri Xenic name
  • Ordered one :)
    ?? :heart:
  • Managed to get one
    Good deal =)
  • IPv6 is disabled :scream:
    @martijnk
    @martijnk
    Yes I'm aware! It's on my list :)
  • @martijnk said:
    @martijnk
    Thanks my ?? friend.
    Greetings from Gummersbach, Germany,
    Malte / Xenic
  • thanks from indonesia <3
    Thanked by (1)youandri
    sudoedit /etc/fstab
    Thanks, I will try this. In the mean time, I tried rclone mount and it works perfectly.
    Thank you so much ?
  • Thanks, I got one.
  • gmsgms
    edited January 2021
    @martijnk Nice deal you got here, and thanks for the free 200GB. However, is there a way to enable file sharing with non-nextcloud users?
    Edit: Found the share option.
  • Could we have the "App Order" app installed pretty please? Maybe "Notes" and/or "Deck" too?
    I could but it seems the nextcloud app store is down right now. I will add them next time.
    Thanked by (1)Naix
    Ordered one, let's see how long it lasts :)
    https://canvay.io - A simple webhosting platform
    https://v6node.com - Affordable IPv6 only KVMs
    Sweet! I can see that you've installed them.
    Thanks a ton.
  • edited January 2021
    Got one.
    In total received 7 emails.
    Get some 405 errors randomly.
    Rclone command 'list' is disabled for WebDav.
  • How to mount it on a vps as an extra disk?
    sudoedit /etc/fstab
    sudoedit /etc/fstab
    Rclone
  • Maxmind fraud checks
    Interesting, I forget to disable NordVPN autoconnection but still order successfully.
    I think my order failed many times without VPN. Maybe because I am in Spain and billing address is german. Could try ordering via vpn but...
    Maybe IP from my shared flat here is blacklisted?
    edited January 2021
    just got onboard, the new nextcloud UI looks good! seems different than what I got from swizzin
    hope this BRICK will never get bricked!
    Thanked by (1)kkrajk
    It took me two days to upload all the photos (about 120GB) via davfs2+rsync.
    • davfs2 isn't working on my home router (GL-AR750) so I have to run it on a BeagleBone Black, then rsync from SAMBA mount to WebDAV mount.
    • rsync would only transfer 1 file at a time.
    • All the modify dates are messed up because WebDAV protocol doesn't allow setting modify dates.
    I wish I knew rclone ealier.
    With rclone sync command:
    • rclone can run on the home router directly, so the source HDD is local.
    • rclone can transfer 4 files in parallel.
    • Modify dates are set correctly.
    • There are fewer command line flags to remember than rsync.
    Currently, I'm using rclone to re-sync the photo directory.
    It wants to re-upload about 15% of the files, and takes a lot of CPU and RAM.
    Nevertheless, once I put it into nice, everything is progressing smoothly and should complete in less than a day.
    You can increase transfers from 4 by using --transfers=69 more here https://rclone.org/docs/
    Thanked by (1)lentro
    I passed with a Serbian address (and all the other data - like phone etc.), in spite of using a "foreign IP address" through a VPN.
    Maybe just lucky? :astonished:
    BikeGremlin I/O
    Mostly WordPress ™
  • vyasvyas OGContent Writer
    Maybe just lucky ? :astonished:
    Thanked by (2)bikegremlin Ympker
  • I am in too hopefully works well
