If you're from AU or NZ, you can use -au or -nz curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -au curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -nz
India is under development curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -in
HostHatch 1 Gb/s 1TB/m for $27/y
OS : Debian GNU/Linux 10 (64 Bit)
Virt/Kernel : KVM / 4.19.0-13-amd64
CPU Model : Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz
CPU Cores : 2 @ 3000.000 MHz x86_64 16384 KB Cache
CPU Flags : AES-NI Enabled & VM-x/AMD-V Disabled
Load Average : 0.00, 0.00, 0.00
Total Space : 39G (2.7G ~8% used)
Total RAM : 7978 MB (313 MB + 1803 MB Buff in use)
Total SWAP : 1023 MB (0 MB in use)
Uptime : 1 days 1:2
ASN & ISP : AS63473, HostHatch
Organization : HostHatch, LLC
Region : New South Wales
## Geekbench v4 CPU Benchmark:
Single Core : 2932 (GOOD)
Multi Core : 5540
## IO Test
CPU Speed:
bzip2 : 107 MB/s
sha256 : 188 MB/s
md5sum : 486 MB/s
RAM Speed:
Avg. write : 2491.7 MB/s
Avg. read : 6280.5 MB/s
Disk Speed:
1st run : 994 MB/s
2nd run : 983 MB/s
3rd run : 904 MB/s
Average : 960.3 MB/s
## Australia & New Zealand Speedtest.net
Location Upload Download Ping
Nearby 928.25 Mbit/s 931.40 Mbit/s 2.774 ms
Australia, Sydney (Optus) 924.65 Mbit/s 925.61 Mbit/s 1.398 ms
Australia, Melbourne (Telstra) 728.49 Mbit/s 771.84 Mbit/s 11.810 ms
Australia, Brisbane (Telstra) 684.49 Mbit/s 736.52 Mbit/s 15.475 ms
Australia, Adelaide (AARNet) 570.53 Mbit/s 403.54 Mbit/s 18.767 ms
Australia, Hobart (Optus) 714.02 Mbit/s 791.39 Mbit/s 12.773 ms
Australia, Darwin (AARNet) 191.05 Mbit/s 241.82 Mbit/s 58.152 ms
Australia, Perth (Telstra) 272.60 Mbit/s 316.28 Mbit/s 50.890 ms
NZ, Auckland (MyRepublic) 271.19 Mbit/s 350.51 Mbit/s 50.901 ms
NZ, Wellington (Spark) 407.58 Mbit/s 433.75 Mbit/s 34.470 ms
NZ, Christchurch (Vodafone) 329.00 Mbit/s 543.16 Mbit/s 39.123 ms
Finished in : 6 min 36 sec
Timestamp : 2020-12-10 21:36:19 GMT
Saved in : /root/speedtest.log
Share results:
- https://www.speedtest.net/result/10568020115.png
- https://browser.geekbench.com/v4/cpu/15931962
- https://clbin.com/iB828
OVH 100 Mb/s (an old VPS promo plan for $2.5/m)
Region: AU-NZ https://bench.monster v.1.5.5 2020-12-10
Usage : curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -AU-NZ
OS : CentOS 7.9.2009 (64 Bit)
Virt/Kernel : KVM / 3.10.0-1160.6.1.el7.x86_64
CPU Model : Intel Core Processor (Haswell, no TSX)
CPU Cores : 1 @ 3504.000 MHz x86_64 16384 KB Cache
CPU Flags : AES-NI Enabled & VM-x/AMD-V Enabled
Load Average : 0.26, 0.12, 0.08
Total Space : 30G (5.4G ~20% used)
Total RAM : 966 MB (349 MB + 451 MB Buff in use)
Total SWAP : 1023 MB (391 MB in use)
Uptime : 20 days 2:27
ASN & ISP : AS16276, OVH SAS
Organization : OVH Australia PTY LTD
Single Core : 4378 (EXCELLENT)
Multi Core : 4137
## IO Test
CPU Speed:
bzip2 : 126 MB/s
sha256 : 394 MB/s
md5sum : 564 MB/s
RAM Speed:
Avg. write : 3925.3 MB/s
Avg. read : 7714.1 MB/s
Disk Speed:
1st run : 368 MB/s
2nd run : 365 MB/s
3rd run : 356 MB/s
Average : 363.0 MB/s
Nearby 98.45 Mbit/s 97.59 Mbit/s 2.965 ms
Australia, Sydney (Optus) 99.59 Mbit/s 97.36 Mbit/s 1.223 ms
Australia, Melbourne (Telstra) 98.26 Mbit/s 97.27 Mbit/s 11.807 ms
Australia, Brisbane (Telstra) 99.30 Mbit/s 96.86 Mbit/s 14.998 ms
Australia, Adelaide (AARNet) 98.96 Mbit/s 96.82 Mbit/s 18.514 ms
Australia, Hobart (Optus) 98.80 Mbit/s 97.08 Mbit/s 12.297 ms
Australia, Darwin (AARNet) 87.48 Mbit/s 90.69 Mbit/s 59.915 ms
Australia, Perth (Telstra) 92.00 Mbit/s 86.99 Mbit/s 50.855 ms
NZ, Auckland (MyRepublic) 90.34 Mbit/s 90.99 Mbit/s 50.727 ms
NZ, Wellington (Spark) 96.41 Mbit/s 95.65 Mbit/s 34.934 ms
NZ, Christchurch (Vodafone) 93.00 Mbit/s 95.25 Mbit/s 39.298 ms
Finished in : 8 min 18 sec
Timestamp : 2020-12-10 22:18:30 GMT
Share results:
- https://www.speedtest.net/result/10568175619.png
- https://browser.geekbench.com/v4/cpu/15932019
- https://clbin.com/M8hSX
Singapore 1 Gb/s (inferno.name $2.5/m)
OS : CentOS 8.3.2011 (64 Bit)
Virt/Kernel : KVM / 4.18.0-193.28.1.el8_2.x86_64
CPU Model : Intel(R) Xeon(R) CPU E5-2699 v4 @ 2.20GHz
CPU Cores : 1 @ 2199.906 MHz x86_64 16384 KB Cache
Load Average : 0.13, 0.32, 0.17
Total Space : 20G (6.2G ~33% used)
Total RAM : 979 MB (182 MB + 186 MB Buff in use)
Total SWAP : 2048 MB (162 MB in use)
Uptime : 10 days 11:25
ASN & ISP : AS9009, ISPIRIA Networks Ltd
Organization : ISPIRIA Networks Ltd
Region :
Single Core : 3688 (VERY GOOD)
Multi Core : 3275
## IO Test
CPU Speed:
bzip2 : 99.7 MB/s
sha256 : 296 MB/s
md5sum : 454 MB/s
RAM Speed:
Avg. write : 1774.9 MB/s
Avg. read : 4232.5 MB/s
Disk Speed:
1st run : 1.1 GB/s
2nd run : 1.1 GB/s
3rd run : 1.2 GB/s
Average : 1160.5 MB/s
Nearby 872.03 Mbit/s 918.48 Mbit/s 2.161 ms
Australia, Sydney (Optus) 148.54 Mbit/s 430.12 Mbit/s 119.909 ms
Australia, Melbourne (Telstra) 19.81 Mbit/s 85.74 Mbit/s 276.653 ms
Australia, Brisbane (Telstra) 19.73 Mbit/s 80.34 Mbit/s 276.130 ms
Australia, Adelaide (AARNet) 179.92 Mbit/s 510.35 Mbit/s 91.128 ms
Australia, Hobart (Optus) 129.63 Mbit/s 394.05 Mbit/s 132.014 ms
Australia, Darwin (AARNet) 137.34 Mbit/s 344.05 Mbit/s 153.140 ms
Australia, Perth (Telstra) 17.36 Mbit/s 52.69 Mbit/s 315.717 ms
NZ, Auckland (MyRepublic) 16.91 Mbit/s 53.00 Mbit/s 315.878 ms
NZ, Wellington (Spark) 67.17 Mbit/s 159.06 Mbit/s 215.844 ms
NZ, Christchurch (Vodafone) 58.55 Mbit/s 147.74 Mbit/s 227.401 ms
Finished in : 7 min 56 sec
Timestamp : 2020-12-10 22:24:35 GMT
Share results:
- https://www.speedtest.net/result/10568197720.png
- https://browser.geekbench.com/v4/cpu/15932028
- https://clbin.com/34tG2
OS : Ubuntu 20.04.2 LTS (64 Bit)
Virt/Kernel : Dedicated / 5.4.0-65-generic
CPU Model : AMD Ryzen 9 3900XT 12-Core Processor
CPU Cores : 2 @ 3792.872 MHz x86_64 512 KB Cache
Load Average : 0.00, 0.02, 0.02
Total Space : 2.0T (6.4G ~1% used)
Total RAM : 3936 MB (412 MB + 1997 MB Buff in use)
Total SWAP : 2047 MB (0 MB in use)
Uptime : 7 days 22:4
ASN & ISP : AS42160, lcp nv
Organization : Novos Lease
Region : Flanders
Single Core : 5642 (EXCELLENT)
Multi Core : 10101
## IO Test
CPU Speed:
bzip2 : 139 MB/s
sha256 : 280 MB/s
md5sum : 637 MB/s
RAM Speed:
Avg. write : 3413.3 MB/s
Avg. read : 10854.4 MB/s
Disk Speed:
1st run : 1.1 GB/s
2nd run : 960 MB/s
3rd run : 1.1 GB/s
Average : 1070.9 MB/s
## Global Speedtest.net
Nearby 468.72 Mbit/s 507.36 Mbit/s 8.978 ms
USA, New York (Optimum) 183.87 Mbit/s 211.12 Mbit/s 91.917 ms
USA, Chicago (Windstream) 178.71 Mbit/s 42.24 Mbit/s 101.491 ms
USA, Dallas (Frontier) 151.98 Mbit/s 115.03 Mbit/s 120.890 ms
USA, Miami (Frontier) 156.15 Mbit/s 93.45 Mbit/s 116.896 ms
USA, Los Angeles (Windstream) 121.35 Mbit/s 63.39 Mbit/s 154.967 ms
UK, London (toob Ltd) 389.51 Mbit/s 536.73 Mbit/s 13.309 ms
France, Lyon (SFR) 426.84 Mbit/s 433.09 Mbit/s 27.697 ms
Germany, Berlin (DNS:NET) 386.85 Mbit/s 340.36 Mbit/s 32.875 ms
Spain, Madrid (MasMovil) 384.73 Mbit/s 454.63 Mbit/s 34.917 ms
Italy, Rome (Unidata) 372.08 Mbit/s 383.71 Mbit/s 38.359 ms
Russia, Moscow (Rostelecom) 283.06 Mbit/s 215.36 Mbit/s 54.275 ms
Israel, Haifa (013Netvision) 210.82 Mbit/s 186.38 Mbit/s 75.092 ms
India, New Delhi (GIGATEL) 119.21 Mbit/s 104.87 Mbit/s 143.711 ms
Singapore (FirstMedia) 52.40 Mbit/s 33.89 Mbit/s 191.220 ms
Japan, Tsukuba (SoftEther) 45.05 Mbit/s 59.63 Mbit/s 226.047 ms
Australia, Sydney (Optus) 19.53 Mbit/s 46.83 Mbit/s 295.509 ms
RSA, Randburg (Cool Ideas) 103.65 Mbit/s 210.15 Mbit/s 166.912 ms
Brazil, Sao Paulo (Criare) 30.14 Mbit/s 100.90 Mbit/s 217.579 ms
Finished in : 9 min 24 sec
Timestamp : 2021-02-05 12:08:43 GMT
Share results:
- https://www.speedtest.net/result/10876737411.png
- https://browser.geekbench.com/v4/cpu/16028170
- https://clbin.com/ipXNm
https://capnhatuudai.com/en/ - Personal blog sharing promotion information, Domain Name Coupons, Hosting, VPS / Server, WordPress and the latest experiences and news from service providers around the world.
drServer - Intel® Atom™ C2750 (4-Core, 2.4GHz) 8GB DDR3 1x 200GB SSD 13usd/m
CPU Model : Intel(R) Atom(TM) CPU C2750 @ 2.41GHz
CPU Cores : 4 @ 2528.036 MHz x86_64 1024 KB Cache
Load Average : 0.25, 0.20, 0.21
Total Space : 182G (2.2G ~2% used)
Total RAM : 7918 MB (119 MB + 479 MB Buff in use)
Total SWAP : 976 MB (0 MB in use)
Uptime : 0 days 2:43
ASN & ISP : AS396881, drServer International
Organization : FranTech Solutions
Region : Delaware
Single Core : 1274 (POOR)
Multi Core : 3962
## IO Test
CPU Speed:
bzip2 : 50.4 MB/s
sha256 : 72.8 MB/s
md5sum : 325 MB/s
RAM Speed:
Avg. write : 1024.0 MB/s
Avg. read : 2560.0 MB/s
Disk Speed:
1st run : 85.2 MB/s
2nd run : 84.6 MB/s
3rd run : 46.4 MB/s
Average : 72.1 MB/s
Nearby 683.43 Mbit/s 231.70 Mbit/s 9.651 ms
USA, New York (Optimum) 397.42 Mbit/s 208.64 Mbit/s 42.517 ms
USA, Chicago (Windstream) 494.71 Mbit/s 219.61 Mbit/s 26.294 ms
USA, Dallas (Frontier) 899.06 Mbit/s 239.46 Mbit/s 1.210 ms
USA, Miami (Frontier) 440.83 Mbit/s 226.77 Mbit/s 31.740 ms
USA, Los Angeles (Windstream) 440.86 Mbit/s 208.72 Mbit/s 29.355 ms
UK, London (toob Ltd) 50.86 Mbit/s 121.92 Mbit/s 106.467 ms
France, Lyon (SFR) 118.59 Mbit/s 78.48 Mbit/s 119.473 ms
Germany, Berlin (DNS:NET) 161.20 Mbit/s 42.15 Mbit/s 125.500 ms
Spain, Madrid (MasMovil) 183.47 Mbit/s 117.17 Mbit/s 109.802 ms
Italy, Rome (Unidata) 142.45 Mbit/s 84.77 Mbit/s 138.087 ms
Russia, Moscow (Rostelecom) 136.65 Mbit/s 96.93 Mbit/s 150.942 ms
Israel, Haifa (013Netvision) 113.92 Mbit/s 96.96 Mbit/s 180.728 ms
India, New Delhi (GIGATEL) 23.73 Mbit/s 46.66 Mbit/s 250.831 ms
Singapore (FirstMedia) 32.51 Mbit/s 31.62 Mbit/s 206.748 ms
Japan, Tsukuba (SoftEther) 135.32 Mbit/s 68.89 Mbit/s 145.760 ms
Australia, Sydney (Optus) 111.73 Mbit/s 81.39 Mbit/s 188.487 ms
RSA, Randburg (Cool Ideas) 27.23 Mbit/s 51.98 Mbit/s 270.439 ms
Brazil, Sao Paulo (Criare) 110.41 Mbit/s 70.35 Mbit/s 138.262 ms
Finished in : 13 min 15 sec
Timestamp : 2021-02-21 06:24:40 GMT
Share results:
- https://www.speedtest.net/result/10966816036.png
- https://browser.geekbench.com/v4/cpu/16051821
- https://clbin.com/Rp0t7
Racknerd 11.11 Special with additional 1 core upgrade.
Region: USA https://bench.monster v.1.5.5 2020-12-10
Usage : curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -USA
CPU Model : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz
CPU Cores : 4 @ 2799.998 MHz x86_64 16384 KB Cache
Load Average : 0.04, 0.04, 0.05
Total Space : 55G (23G ~44% used)
Total RAM : 2845 MB (561 MB + 1492 MB Buff in use)
Uptime : 0 days 23:59
ASN & ISP : AS36352, ColoCrossing
Organization : NYC Metro
Region : District of Columbia
Single Core : 2215 (FAIR)
Multi Core : 5731
## IO Test
CPU Speed:
bzip2 : 59.4 MB/s
sha256 : 133 MB/s
md5sum : 349 MB/s
RAM Speed:
Avg. write : 1051.3 MB/s
Avg. read : 2867.2 MB/s
Disk Speed:
1st run : 665 MB/s
2nd run : 505 MB/s
3rd run : 544 MB/s
Average : 571.3 MB/s
## USA Speedtest.net
Nearby 279.60 Mbit/s 364.93 Mbit/s 43.052 ms
USA, New York (Optimum) 417.28 Mbit/s 755.45 Mbit/s 7.512 ms
USA, Boston (Starry, Inc.) 469.17 Mbit/s 647.34 Mbit/s 12.500 ms
USA, Washington, DC (Sprint) 603.12 Mbit/s 791.53 Mbit/s 1.890 ms
USA, Charlotte, NC (Windstream) 404.33 Mbit/s 540.53 Mbit/s 14.991 ms
USA, Atlanta (Frontier) 204.95 Mbit/s 648.75 Mbit/s 31.872 ms
USA, Miami (Frontier) 149.33 Mbit/s 635.74 Mbit/s 50.819 ms
USA, Nashville (Sprint) 360.73 Mbit/s 584.19 Mbit/s 16.774 ms
USA, Indianapolis (Metronet) 113.48 Mbit/s 470.39 Mbit/s 31.883 ms
USA, Cleveland (CenturyLink) 374.71 Mbit/s 619.87 Mbit/s 20.612 ms
USA, Chicago (Windstream) 263.94 Mbit/s 598.29 Mbit/s 23.170 ms
USA, St. Louis (Elite Fiber) 359.28 Mbit/s 381.70 Mbit/s 29.117 ms
USA, Minneapolis (US Internet) 376.42 Mbit/s 727.76 Mbit/s 24.279 ms
USA, Kansas City (UPNfiber) 276.76 Mbit/s 525.16 Mbit/s 39.291 ms
USA, Oklahoma City (OneNet) 150.39 Mbit/s 365.01 Mbit/s 34.610 ms
USA, Dallas (Windstream) 230.07 Mbit/s 434.64 Mbit/s 29.248 ms
USA, San Antonio, TX (Sprint) 212.89 Mbit/s 470.58 Mbit/s 33.502 ms
USA, Denver (Vistabeam) 109.38 Mbit/s 146.14 Mbit/s 59.639 ms
USA, Albuquerque (Plateau Tel) 149.31 Mbit/s 490.05 Mbit/s 58.392 ms
USA, Phoenix (Cox) 224.65 Mbit/s 287.64 Mbit/s 71.475 ms
USA, Salt Lake City (UTOPIA) 217.79 Mbit/s 225.53 Mbit/s 69.603 ms
USA, Helena, MT (The Fusion) 212.85 Mbit/s 420.58 Mbit/s 48.273 ms
USA, Las Vegas (LV.Net) 179.04 Mbit/s 239.32 Mbit/s 66.194 ms
USA, Seattle (Bluespan) 146.12 Mbit/s 440.43 Mbit/s 75.077 ms
USA, San Francisco (Wiline) 196.15 Mbit/s 252.33 Mbit/s 67.784 ms
USA, Los Angeles (Windstream) 154.73 Mbit/s 314.94 Mbit/s 66.622 ms
USA, Anchorage (Alaska Com) 148.91 Mbit/s 371.42 Mbit/s 115.077 ms
USA, Honolulu (Hawaiian Telcom) 150.08 Mbit/s 121.29 Mbit/s 130.923 ms
Finished in : 12 min 34 sec
Timestamp : 2021-03-25 02:24:21 GMT
Share results:
- https://www.speedtest.net/result/11151722443.png
- https://browser.geekbench.com/v4/cpu/16098770
- https://clbin.com/sKGzK
Virt/Kernel : KVM / 5.4.0-70-generic
CPU Model : AMD Ryzen 9 3900X 12-Core Processor
CPU Cores : 1 @ 3792.874 MHz x86_64 512 KB Cache
Load Average : 0.10, 0.04, 0.01
Total Space : 19G (3.1G ~18% used)
Total RAM : 1483 MB (240 MB + 1049 MB Buff in use)
Total SWAP : 1535 MB (0 MB in use)
Uptime : 1 days 3:15
Organization : RackNerd LLC
Region : New York
Single Core : 4860 (EXCELLENT)
Multi Core : 4699
## IO Test
CPU Speed:
bzip2 : 127 MB/s
sha256 : 240 MB/s
md5sum : 555 MB/s
RAM Speed:
Avg. write : 2184.5 MB/s
Avg. read : 7782.4 MB/s
Disk Speed:
1st run : 1.2 GB/s
2nd run : 1.2 GB/s
3rd run : 1.2 GB/s
Average : 1228.8 MB/s
Nearby 342.58 Mbit/s 125.29 Mbit/s * 82.838 ms
USA, New York (Optimum) 597.37 Mbit/s 381.84 Mbit/s 11.352 ms
USA, Boston (Starry, Inc.) 335.63 Mbit/s 428.04 Mbit/s 15.995 ms
USA, Washington, DC (Sprint) 455.90 Mbit/s 602.22 Mbit/s 17.548 ms
USA, Charlotte, NC (Windstream) 434.81 Mbit/s 320.28 Mbit/s 27.219 ms
USA, Atlanta (Frontier) 332.23 Mbit/s 281.06 Mbit/s 36.765 ms
USA, Miami (Frontier) 188.95 Mbit/s 351.63 Mbit/s 41.692 ms
USA, Nashville (Sprint) 247.70 Mbit/s 436.73 Mbit/s 29.891 ms
USA, Indianapolis (Metronet) 490.59 Mbit/s 574.79 Mbit/s 17.647 ms
USA, Cleveland (CenturyLink) 432.98 Mbit/s 320.84 Mbit/s 22.064 ms
USA, Chicago (Windstream) 571.09 Mbit/s 617.87 Mbit/s 10.625 ms
USA, St. Louis (Elite Fiber) 475.77 Mbit/s 604.67 Mbit/s 19.793 ms
USA, Minneapolis (US Internet) 468.76 Mbit/s 368.04 Mbit/s 22.184 ms
USA, Kansas City (UPNfiber) 204.79 Mbit/s 140.89 Mbit/s 24.626 ms
USA, Oklahoma City (OneNet) 237.13 Mbit/s 320.32 Mbit/s 36.224 ms
USA, Dallas (Windstream) 304.45 Mbit/s 329.96 Mbit/s 36.103 ms
USA, San Antonio, TX (Sprint) 180.90 Mbit/s 404.20 Mbit/s 40.841 ms
USA, Denver (Vistabeam) 325.56 Mbit/s 272.08 Mbit/s 35.555 ms
USA, Albuquerque (Plateau Tel) 242.76 Mbit/s 226.12 Mbit/s 43.417 ms
USA, Phoenix (Cox) 171.06 Mbit/s 231.80 Mbit/s 80.111 ms
USA, Salt Lake City (UTOPIA) 144.25 Mbit/s 99.05 Mbit/s 50.526 ms
USA, Helena, MT (The Fusion) 220.76 Mbit/s 330.58 Mbit/s 42.031 ms
USA, Las Vegas (LV.Net) 168.44 Mbit/s 212.91 Mbit/s 75.821 ms
USA, Seattle (Bluespan) 153.05 Mbit/s 500.05 Mbit/s 65.382 ms
USA, San Francisco (Wiline) 184.88 Mbit/s 223.73 Mbit/s 70.749 ms
USA, Los Angeles (Windstream) 207.45 Mbit/s 313.78 Mbit/s 55.833 ms
USA, Anchorage (Alaska Com) 144.92 Mbit/s 102.36 Mbit/s 88.701 ms
USA, Honolulu (Hawaiian Telcom) 95.75 Mbit/s 98.65 Mbit/s 140.709 ms
Finished in : 11 min 28 sec
Timestamp : 2021-04-03 10:06:50 GMT
Share results:
- https://www.speedtest.net/result/11203306855.png
- https://browser.geekbench.com/v4/cpu/16111686
- https://clbin.com/baSab
curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -aucurl -LsO bench.monster/speedtest.sh; bash speedtest.sh -nzIndia is under development
curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -inHostHatch 1 Gb/s 1TB/m for $27/y
--------------------------------------------------------------------------- OS : Debian GNU/Linux 10 (64 Bit) Virt/Kernel : KVM / 4.19.0-13-amd64 CPU Model : Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz CPU Cores : 2 @ 3000.000 MHz x86_64 16384 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Disabled Load Average : 0.00, 0.00, 0.00 Total Space : 39G (2.7G ~8% used) Total RAM : 7978 MB (313 MB + 1803 MB Buff in use) Total SWAP : 1023 MB (0 MB in use) Uptime : 1 days 1:2 --------------------------------------------------------------------------- ASN & ISP : AS63473, HostHatch Organization : HostHatch, LLC Location : Sydney, Australia / AU Region : New South Wales --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 2932 (GOOD) Multi Core : 5540 ## IO Test CPU Speed: bzip2 : 107 MB/s sha256 : 188 MB/s md5sum : 486 MB/s RAM Speed: Avg. write : 2491.7 MB/s Avg. read : 6280.5 MB/s Disk Speed: 1st run : 994 MB/s 2nd run : 983 MB/s 3rd run : 904 MB/s ----------------------- Average : 960.3 MB/s ## Australia & New Zealand Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 928.25 Mbit/s 931.40 Mbit/s 2.774 ms --------------------------------------------------------------------------- Australia, Sydney (Optus) 924.65 Mbit/s 925.61 Mbit/s 1.398 ms Australia, Melbourne (Telstra) 728.49 Mbit/s 771.84 Mbit/s 11.810 ms Australia, Brisbane (Telstra) 684.49 Mbit/s 736.52 Mbit/s 15.475 ms Australia, Adelaide (AARNet) 570.53 Mbit/s 403.54 Mbit/s 18.767 ms Australia, Hobart (Optus) 714.02 Mbit/s 791.39 Mbit/s 12.773 ms Australia, Darwin (AARNet) 191.05 Mbit/s 241.82 Mbit/s 58.152 ms Australia, Perth (Telstra) 272.60 Mbit/s 316.28 Mbit/s 50.890 ms NZ, Auckland (MyRepublic) 271.19 Mbit/s 350.51 Mbit/s 50.901 ms NZ, Wellington (Spark) 407.58 Mbit/s 433.75 Mbit/s 34.470 ms NZ, Christchurch (Vodafone) 329.00 Mbit/s 543.16 Mbit/s 39.123 ms --------------------------------------------------------------------------- Finished in : 6 min 36 sec Timestamp : 2020-12-10 21:36:19 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/10568020115.png - https://browser.geekbench.com/v4/cpu/15931962 - https://clbin.com/iB828OVH 100 Mb/s (an old VPS promo plan for $2.5/m)
--------------------------------------------------------------------------- Region: AU-NZ https://bench.monster v.1.5.5 2020-12-10 Usage : curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -AU-NZ --------------------------------------------------------------------------- OS : CentOS 7.9.2009 (64 Bit) Virt/Kernel : KVM / 3.10.0-1160.6.1.el7.x86_64 CPU Model : Intel Core Processor (Haswell, no TSX) CPU Cores : 1 @ 3504.000 MHz x86_64 16384 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Enabled Load Average : 0.26, 0.12, 0.08 Total Space : 30G (5.4G ~20% used) Total RAM : 966 MB (349 MB + 451 MB Buff in use) Total SWAP : 1023 MB (391 MB in use) Uptime : 20 days 2:27 --------------------------------------------------------------------------- ASN & ISP : AS16276, OVH SAS Organization : OVH Australia PTY LTD Location : Sydney, Australia / AU Region : New South Wales --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 4378 (EXCELLENT) Multi Core : 4137 ## IO Test CPU Speed: bzip2 : 126 MB/s sha256 : 394 MB/s md5sum : 564 MB/s RAM Speed: Avg. write : 3925.3 MB/s Avg. read : 7714.1 MB/s Disk Speed: 1st run : 368 MB/s 2nd run : 365 MB/s 3rd run : 356 MB/s ----------------------- Average : 363.0 MB/s ## Australia & New Zealand Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 98.45 Mbit/s 97.59 Mbit/s 2.965 ms --------------------------------------------------------------------------- Australia, Sydney (Optus) 99.59 Mbit/s 97.36 Mbit/s 1.223 ms Australia, Melbourne (Telstra) 98.26 Mbit/s 97.27 Mbit/s 11.807 ms Australia, Brisbane (Telstra) 99.30 Mbit/s 96.86 Mbit/s 14.998 ms Australia, Adelaide (AARNet) 98.96 Mbit/s 96.82 Mbit/s 18.514 ms Australia, Hobart (Optus) 98.80 Mbit/s 97.08 Mbit/s 12.297 ms Australia, Darwin (AARNet) 87.48 Mbit/s 90.69 Mbit/s 59.915 ms Australia, Perth (Telstra) 92.00 Mbit/s 86.99 Mbit/s 50.855 ms NZ, Auckland (MyRepublic) 90.34 Mbit/s 90.99 Mbit/s 50.727 ms NZ, Wellington (Spark) 96.41 Mbit/s 95.65 Mbit/s 34.934 ms NZ, Christchurch (Vodafone) 93.00 Mbit/s 95.25 Mbit/s 39.298 ms --------------------------------------------------------------------------- Finished in : 8 min 18 sec Timestamp : 2020-12-10 22:18:30 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/10568175619.png - https://browser.geekbench.com/v4/cpu/15932019 - https://clbin.com/M8hSXSingapore 1 Gb/s (inferno.name $2.5/m)
--------------------------------------------------------------------------- Region: AU-NZ https://bench.monster v.1.5.5 2020-12-10 Usage : curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -AU-NZ --------------------------------------------------------------------------- OS : CentOS 8.3.2011 (64 Bit) Virt/Kernel : KVM / 4.18.0-193.28.1.el8_2.x86_64 CPU Model : Intel(R) Xeon(R) CPU E5-2699 v4 @ 2.20GHz CPU Cores : 1 @ 2199.906 MHz x86_64 16384 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Enabled Load Average : 0.13, 0.32, 0.17 Total Space : 20G (6.2G ~33% used) Total RAM : 979 MB (182 MB + 186 MB Buff in use) Total SWAP : 2048 MB (162 MB in use) Uptime : 10 days 11:25 --------------------------------------------------------------------------- ASN & ISP : AS9009, ISPIRIA Networks Ltd Organization : ISPIRIA Networks Ltd Location : Singapore, Singapore / SG Region : --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 3688 (VERY GOOD) Multi Core : 3275 ## IO Test CPU Speed: bzip2 : 99.7 MB/s sha256 : 296 MB/s md5sum : 454 MB/s RAM Speed: Avg. write : 1774.9 MB/s Avg. read : 4232.5 MB/s Disk Speed: 1st run : 1.1 GB/s 2nd run : 1.1 GB/s 3rd run : 1.2 GB/s ----------------------- Average : 1160.5 MB/s ## Australia & New Zealand Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 872.03 Mbit/s 918.48 Mbit/s 2.161 ms --------------------------------------------------------------------------- Australia, Sydney (Optus) 148.54 Mbit/s 430.12 Mbit/s 119.909 ms Australia, Melbourne (Telstra) 19.81 Mbit/s 85.74 Mbit/s 276.653 ms Australia, Brisbane (Telstra) 19.73 Mbit/s 80.34 Mbit/s 276.130 ms Australia, Adelaide (AARNet) 179.92 Mbit/s 510.35 Mbit/s 91.128 ms Australia, Hobart (Optus) 129.63 Mbit/s 394.05 Mbit/s 132.014 ms Australia, Darwin (AARNet) 137.34 Mbit/s 344.05 Mbit/s 153.140 ms Australia, Perth (Telstra) 17.36 Mbit/s 52.69 Mbit/s 315.717 ms NZ, Auckland (MyRepublic) 16.91 Mbit/s 53.00 Mbit/s 315.878 ms NZ, Wellington (Spark) 67.17 Mbit/s 159.06 Mbit/s 215.844 ms NZ, Christchurch (Vodafone) 58.55 Mbit/s 147.74 Mbit/s 227.401 ms --------------------------------------------------------------------------- Finished in : 7 min 56 sec Timestamp : 2020-12-10 22:24:35 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/10568197720.png - https://browser.geekbench.com/v4/cpu/15932028 - https://clbin.com/34tG2Virmach BF special
refer to YABS thread for VPS description
--------------------------------------------------------------------------- OS : CentOS 8.3.2011 (64 Bit) Virt/Kernel : KVM / 5.10.2-1.el8.elrepo.x86_64 CPU Model : Intel(R) Xeon(R) CPU E5-2660 0 @ 2.20GHz CPU Cores : 2 @ 2199.998 MHz x86_64 4096 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Disabled Load Average : 0.55, 0.31, 0.14 Total Space : 15G (1.9G ~13% used) Total RAM : 4176 MB (154 MB + 307 MB Buff in use) Total SWAP : 255 MB (0 MB in use) Uptime : 0 days 0:4 --------------------------------------------------------------------------- ASN & ISP : AS36352, ColoCrossing Organization : Virtual Machine Solutions LLC Location : Los Angeles, United States / US Region : California --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 1639 (POOR) Multi Core : 3043 ## IO Test CPU Speed: bzip2 : 59.6 MB/s sha256 : 151 MB/s md5sum : 304 MB/s RAM Speed: Avg. write : 1570.1 MB/s Avg. read : 3003.7 MB/s Disk Speed: 1st run : 142 MB/s 2nd run : 559 MB/s 3rd run : 536 MB/s ----------------------- Average : 412.3 MB/s ## Global Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 774.37 Mbit/s 869.79 Mbit/s 4.079 ms --------------------------------------------------------------------------- USA, New York (Optimum) 264.01 Mbit/s 202.98 Mbit/s 64.508 ms USA, Chicago (Windstream) 249.28 Mbit/s 345.39 Mbit/s 51.326 ms USA, Dallas (Frontier) 437.38 Mbit/s 357.82 Mbit/s 29.892 ms USA, Miami (Frontier) 284.45 Mbit/s 250.28 Mbit/s 60.076 ms USA, Los Angeles (Windstream) 786.91 Mbit/s 828.48 Mbit/s 0.703 ms UK, London (toob Ltd) 19.87 Mbit/s 130.86 Mbit/s 139.240 ms France, Lyon (SFR) 72.26 Mbit/s 110.60 Mbit/s 145.258 ms Germany, Berlin (DNS:NET) 115.02 Mbit/s 125.83 Mbit/s 160.156 ms Spain, Madrid (MasMovil) 115.81 Mbit/s 18.83 Mbit/s 170.179 ms Italy, Rome (Unidata) 110.93 Mbit/s 110.05 Mbit/s 162.098 ms Russia, Moscow (Rostelecom) 40.86 Mbit/s 46.33 Mbit/s 168.576 ms Israel, Haifa (013Netvision) 66.43 Mbit/s 84.07 Mbit/s 207.484 ms India, New Delhi (GIGATEL) 21.15 Mbit/s 90.43 Mbit/s 281.996 ms Singapore (FirstMedia) 75.60 Mbit/s 45.49 Mbit/s 158.410 ms Japan, Tsukuba (SoftEther) 157.81 Mbit/s 126.24 Mbit/s 110.771 ms Australia, Sydney (Optus) 118.14 Mbit/s 137.93 Mbit/s 147.110 ms RSA, Randburg (Cool Ideas) 19.30 Mbit/s 84.92 Mbit/s 295.257 ms Brazil, Sao Paulo (Criare) 69.04 Mbit/s 133.77 Mbit/s 176.282 ms --------------------------------------------------------------------------- Finished in : 12 min 6 sec Timestamp : 2020-12-22 03:35:07 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/10629716368.png - https://browser.geekbench.com/v4/cpu/15951523 - https://clbin.com/IfzRM [root@cybertech ~]#I bench YABS 24/7/365 unless it's a leap year.
Virmach BF special
--------------------------------------------------------------------------- OS : CentOS 8.3.2011 (64 Bit) Virt/Kernel : KVM / 5.10.2-1.el8.elrepo.x86_64 CPU Model : Intel(R) Xeon(R) CPU E5-2670 v2 @ 2.50GHz CPU Cores : 2 @ 2499.998 MHz x86_64 4096 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Disabled Load Average : 0.14, 0.03, 0.01 Total Space : 25G (1.9G ~8% used) Total RAM : 1981 MB (150 MB + 285 MB Buff in use) Total SWAP : 255 MB (0 MB in use) Uptime : 0 days 18:27 --------------------------------------------------------------------------- ASN & ISP : AS36352, ColoCrossing Organization : Virtual Machine Solutions LLC Location : Los Angeles, United States / US Region : California --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 1865 (FAIR) Multi Core : 3306 ## IO Test CPU Speed: bzip2 : 55.5 MB/s sha256 : 157 MB/s md5sum : 352 MB/s RAM Speed: Avg. write : 1262.9 MB/s Avg. read : 2833.1 MB/s Disk Speed: 1st run : 778 MB/s 2nd run : 877 MB/s 3rd run : 876 MB/s ----------------------- Average : 843.7 MB/s ## Global Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 328.26 Mbit/s 201.30 Mbit/s * 52.85 ms --------------------------------------------------------------------------- USA, New York (Optimum) 232.35 Mbit/s 200.90 Mbit/s 64.977 ms USA, Chicago (Windstream) 257.98 Mbit/s 312.86 Mbit/s 49.626 ms USA, Dallas (Frontier) 139.84 Mbit/s 509.93 Mbit/s 29.821 ms USA, Miami (Frontier) 184.39 Mbit/s 416.15 Mbit/s 60.101 ms USA, Los Angeles (Windstream) 513.55 Mbit/s 805.35 Mbit/s 0.803 ms UK, London (toob Ltd) 19.25 Mbit/s 84.01 Mbit/s 143.876 ms France, Lyon (SFR) 55.43 Mbit/s 55.74 Mbit/s 155.496 ms Germany, Berlin (DNS:NET) 80.58 Mbit/s 79.89 Mbit/s 163.949 ms Spain, Madrid (MasMovil) 73.00 Mbit/s 17.62 Mbit/s 160.311 ms Italy, Rome (Unidata) 67.39 Mbit/s 44.98 Mbit/s 176.861 ms Russia, Moscow (Rostelecom) 4.31 Mbit/s 2.87 Mbit/s 175.936 ms Israel, Haifa (013Netvision) 43.25 Mbit/s 31.50 Mbit/s 205.942 ms India, New Delhi (GIGATEL) 19.93 Mbit/s 31.92 Mbit/s 285.896 ms Singapore (FirstMedia) 42.55 Mbit/s 24.81 Mbit/s 162.016 ms Japan, Tsukuba (SoftEther) 127.21 Mbit/s 67.70 Mbit/s 111.732 ms Australia, Sydney (Optus) 97.75 Mbit/s 261.53 Mbit/s 146.896 ms RSA, Randburg (Cool Ideas) 18.84 Mbit/s 64.68 Mbit/s 294.877 ms Brazil, Sao Paulo (Criare) 42.20 Mbit/s 70.36 Mbit/s 183.667 ms --------------------------------------------------------------------------- Finished in : 12 min 33 sec Timestamp : 2020-12-22 03:31:55 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/10629706934.png - https://browser.geekbench.com/v4/cpu/15951517 - https://clbin.com/R3wLC [root@cybertech ~]#I bench YABS 24/7/365 unless it's a leap year.
anynode
product description in YAB thread
--------------------------------------------------------------------------- OS : CentOS 8.3.2011 (64 Bit) Virt/Kernel : KVM / 5.10.4-1.el8.elrepo.x86_64 CPU Model : Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz CPU Cores : 1 @ 2599.998 MHz x86_64 20480 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Disabled Load Average : 0.24, 0.25, 0.23 Total Space : 30G (2.6G ~9% used) Total RAM : 1981 MB (132 MB + 314 MB Buff in use) Total SWAP : 255 MB (0 MB in use) Uptime : 0 days 0:26 --------------------------------------------------------------------------- ASN & ISP : AS20150, High Speed Web/Genesis 2 Networks Organization : CPH Inc Location : Philadelphia, United States / US Region : Pennsylvania --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 2305 (GOOD) Multi Core : 2286 ## IO Test CPU Speed: bzip2 : 85.0 MB/s sha256 : 205 MB/s md5sum : 395 MB/s RAM Speed: Avg. write : 1877.3 MB/s Avg. read : 4608.0 MB/s Disk Speed: 1st run : 493 MB/s 2nd run : 500 MB/s 3rd run : 493 MB/s ----------------------- Average : 495.3 MB/s ## Global Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 197.46 Mbit/s 307.12 Mbit/s 42.369 ms --------------------------------------------------------------------------- USA, New York (Optimum) 174.71 Mbit/s 238.21 Mbit/s 64.553 ms USA, Chicago (Windstream) 51.65 Mbit/s 122.63 Mbit/s 210.147 ms USA, Dallas (Frontier) 117.33 Mbit/s 295.51 Mbit/s 40.164 ms USA, Miami (Frontier) 172.49 Mbit/s 272.96 Mbit/s 64.573 ms USA, Los Angeles (Windstream) 277.95 Mbit/s 313.87 Mbit/s 17.185 ms UK, London (toob Ltd) 88.09 Mbit/s 136.70 Mbit/s 124.903 ms France, Lyon (SFR) 108.55 Mbit/s 90.99 Mbit/s 153.943 ms Germany, Berlin (DNS:NET) 57.27 Mbit/s 102.99 Mbit/s 145.562 ms Spain, Madrid (MasMovil) 106.58 Mbit/s 93.00 Mbit/s 137.660 ms Italy, Rome (Unidata) 87.55 Mbit/s 89.77 Mbit/s 159.456 ms Russia, Moscow (Rostelecom) 20.11 Mbit/s 52.56 Mbit/s 186.286 ms Israel, Haifa (013Netvision) 27.08 Mbit/s 57.47 Mbit/s 206.195 ms India, New Delhi (GIGATEL) 21.72 Mbit/s 30.62 Mbit/s 270.092 ms Singapore (FirstMedia) 15.71 Mbit/s 26.52 Mbit/s 194.245 ms Japan, Tsukuba (SoftEther) 98.02 Mbit/s 95.67 Mbit/s 128.370 ms Australia, Sydney (Optus) 83.17 Mbit/s 146.40 Mbit/s 155.699 ms RSA, Randburg (Cool Ideas) 21.38 Mbit/s 26.46 Mbit/s 281.815 ms Brazil, Sao Paulo (Criare) 84.90 Mbit/s 121.13 Mbit/s 182.489 ms --------------------------------------------------------------------------- Finished in : 11 min 54 sec Timestamp : 2021-01-02 07:34:19 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/10681428114.png - https://browser.geekbench.com/v4/cpu/15969992 - https://clbin.com/9XN3yI bench YABS 24/7/365 unless it's a leap year.
hosterlabs
--------------------------------------------------------------------------- OS : CentOS 8.3.2011 (64 Bit) Virt/Kernel : KVM / 5.10.7-1.el8.elrepo.x86_64 CPU Model : AMD Ryzen 5 3600 6-Core Processor CPU Cores : 2 @ 3593.234 MHz x86_64 512 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Disabled Load Average : 0.10, 0.03, 0.01 Total Space : 15G (2.3G ~16% used) Total RAM : 1981 MB (126 MB + 211 MB Buff in use) Total SWAP : 0 MB (0 MB in use) Uptime : 0 days 4:43 --------------------------------------------------------------------------- ASN & ISP : AS24940, Hetzner Online GmbH Organization : Location : Falkenstein, Germany / DE Region : Saxony --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 5241 (EXCELLENT) Multi Core : 9053 ## IO Test CPU Speed: bzip2 : 130 MB/s sha256 : 1.3 GB/s md5sum : 663 MB/s RAM Speed: Avg. write : 3276.8 MB/s Avg. read : 9659.7 MB/s Disk Speed: 1st run : 982 MB/s 2nd run : 2.2 GB/s 3rd run : 2.4 GB/s ----------------------- Average : 1897.5 MB/s ## Global Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 361.98 Mbit/s 336.56 Mbit/s 20.854 ms --------------------------------------------------------------------------- USA, New York (Optimum) 217.94 Mbit/s 269.11 Mbit/s 83.624 ms USA, Chicago (Windstream) 189.31 Mbit/s 98.86 Mbit/s 97.965 ms USA, Dallas (Frontier) 151.75 Mbit/s 95.46 Mbit/s 126.476 ms USA, Miami (Frontier) 165.13 Mbit/s 215.37 Mbit/s 117.214 ms USA, Los Angeles (Windstream) 138.49 Mbit/s 98.95 Mbit/s 141.999 ms UK, London (toob Ltd) 136.82 Mbit/s 474.46 Mbit/s 24.415 ms France, Lyon (SFR) 532.25 Mbit/s 621.62 Mbit/s 20.923 ms Germany, Berlin (DNS:NET) 611.49 Mbit/s 674.53 Mbit/s 15.731 ms Spain, Madrid (MasMovil) 475.59 Mbit/s 562.23 Mbit/s 29.586 ms Italy, Rome (Unidata) 367.48 Mbit/s 470.66 Mbit/s 42.438 ms Russia, Moscow (Rostelecom) 345.10 Mbit/s 239.70 Mbit/s 42.833 ms Israel, Haifa (013Netvision) 290.11 Mbit/s 171.70 Mbit/s 59.556 ms India, New Delhi (GIGATEL) 119.60 Mbit/s 223.11 Mbit/s 152.505 ms Singapore (FirstMedia) 59.36 Mbit/s 21.88 Mbit/s 180.950 ms Japan, Tsukuba (SoftEther) 21.56 Mbit/s 51.36 Mbit/s 258.765 ms Australia, Sydney (Optus) 16.28 Mbit/s 50.45 Mbit/s 298.780 ms RSA, Randburg (Cool Ideas) 73.80 Mbit/s 238.94 Mbit/s 179.387 ms Brazil, Sao Paulo (Criare) 72.18 Mbit/s 121.84 Mbit/s 190.514 ms --------------------------------------------------------------------------- Finished in : 9 min 5 sec Timestamp : 2021-01-18 12:40:19 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/10769831460.png - https://browser.geekbench.com/v4/cpu/15998214 - https://clbin.com/8FPTOI bench YABS 24/7/365 unless it's a leap year.
racknerd
San Jose (premium Colon)
--------------------------------------------------------------------------- OS : CentOS 8 (64 Bit) Virt/Kernel : KVM / 5.10.12-1.el8.elrepo.x86_64 CPU Model : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz CPU Cores : 3 @ 2799.998 MHz x86_64 16384 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Enabled Load Average : 0.23, 0.17, 0.08 Total Space : 39G (2.1G ~6% used) Total RAM : 2482 MB (157 MB + 316 MB Buff in use) Total SWAP : 1023 MB (0 MB in use) Uptime : 0 days 17:55 --------------------------------------------------------------------------- ASN & ISP : AS36352, ColoCrossing Organization : HLM Location : San Jose, United States / US Region : California --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 2766 (GOOD) Multi Core : 7550 ## IO Test CPU Speed: bzip2 : 99.8 MB/s sha256 : 255 MB/s md5sum : 504 MB/s RAM Speed: Avg. write : 2184.5 MB/s Avg. read : 4949.3 MB/s Disk Speed: 1st run : 1.7 GB/s 2nd run : 1.8 GB/s 3rd run : 1.7 GB/s ----------------------- Average : 1774.9 MB/s ## Global Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 665.64 Mbit/s 683.87 Mbit/s 11.485 ms --------------------------------------------------------------------------- USA, New York (Optimum) 226.20 Mbit/s 320.92 Mbit/s 70.653 ms USA, Chicago (Windstream) 315.62 Mbit/s 169.83 Mbit/s 47.965 ms USA, Dallas (Frontier) 294.53 Mbit/s 318.30 Mbit/s 37.390 ms USA, Miami (Frontier) 229.29 Mbit/s 143.31 Mbit/s 71.266 ms USA, Los Angeles (Windstream) 537.91 Mbit/s 638.19 Mbit/s 7.666 ms UK, London (toob Ltd) 20.09 Mbit/s 134.99 Mbit/s 133.788 ms France, Lyon (SFR) 86.44 Mbit/s 107.43 Mbit/s 145.118 ms Germany, Berlin (DNS:NET) 110.38 Mbit/s 27.75 Mbit/s 165.349 ms Spain, Madrid (MasMovil) 20.73 Mbit/s 57.51 Mbit/s 161.942 ms Italy, Rome (Unidata) 100.35 Mbit/s 118.71 Mbit/s 166.583 ms Russia, Moscow (Rostelecom) 80.84 Mbit/s 59.84 Mbit/s 194.468 ms Israel, Haifa (013Netvision) 66.56 Mbit/s 24.01 Mbit/s 204.217 ms India, New Delhi (GIGATEL) 25.82 Mbit/s 93.74 Mbit/s 261.200 ms Singapore (FirstMedia) 59.64 Mbit/s 31.29 Mbit/s 171.421 ms Japan, Tsukuba (SoftEther) 151.19 Mbit/s 159.28 Mbit/s 108.904 ms Australia, Sydney (Optus) 115.92 Mbit/s 167.22 Mbit/s 162.049 ms RSA, Randburg (Cool Ideas) 19.02 Mbit/s 51.15 Mbit/s 304.137 ms Brazil, Sao Paulo (Criare) 66.93 Mbit/s 74.65 Mbit/s 176.102 ms --------------------------------------------------------------------------- Finished in : 25 min 56 sec Timestamp : 2021-02-03 03:25:16 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/10861726869.png - https://browser.geekbench.com/v4/cpu/16024304 - https://clbin.com/yfWWFI bench YABS 24/7/365 unless it's a leap year.
ServersGalore $16 AUD p/m Melbourne:
OS : Ubuntu 20.04.1 LTS (64 Bit) Virt/Kernel : Dedicated / 5.4.0-64-generic CPU Model : AMD EPYC Processor (with IBPB) CPU Cores : 4 @ 3593.248 MHz x86_64 512 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Disabled Load Average : 0.00, 0.00, 0.00 Total Space : 69G (29G ~44% used) Total RAM : 5945 MB (463 MB + 5270 MB Buff in use) Total SWAP : 511 MB (14 MB in use) Uptime : 10 days 22:50 --------------------------------------------------------------------------- ASN & ISP : AS136557, HostRoyale AU Network Organization : Location : Melbourne, Australia / AU Region : Victoria --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 5675 (EXCELLENT) Multi Core : 17753 ## IO Test CPU Speed: bzip2 : 136 MB/s sha256 : 271 MB/s md5sum : 537 MB/s RAM Speed: Avg. write : 3140.3 MB/s Avg. read : 8226.1 MB/s Disk Speed: 1st run : 710 MB/s 2nd run : 701 MB/s 3rd run : 713 MB/s ----------------------- Average : 708.0 MB/s ## Australia & New Zealand Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 924.67 Mbit/s 939.75 Mbit/s 1.223 ms --------------------------------------------------------------------------- Australia, Sydney (Optus) 711.98 Mbit/s 845.45 Mbit/s 11.809 ms Australia, Melbourne (Telstra) 913.29 Mbit/s 926.94 Mbit/s 0.610 ms Australia, Brisbane (Telstra) 551.59 Mbit/s 626.05 Mbit/s 24.241 ms Australia, Adelaide (AARNet) 761.57 Mbit/s 846.40 Mbit/s 10.215 ms Australia, Hobart (Optus) 901.12 Mbit/s 938.47 Mbit/s 0.867 ms Australia, Darwin (AARNet) 198.81 Mbit/s 342.85 Mbit/s 70.968 ms Australia, Perth (Telstra) 341.85 Mbit/s 470.08 Mbit/s 42.066 ms NZ, Auckland (MyRepublic) 322.91 Mbit/s 482.62 Mbit/s 41.701 ms NZ, Christchurch (Vodafone) 146.77 Mbit/s 359.71 Mbit/s 49.480 ms --------------------------------------------------------------------------- Finished in : 6 min 2 sec Timestamp : 2021-02-03 03:51:02 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/10861867517.png - https://browser.geekbench.com/v4/cpu/16024416 - https://clbin.com/P0IJCHetzner AX101
https://pastebin.com/GRhvmWtD
Just moved to Singapore location
MaxKVM SKVM-4G
an old test from @cybertech https://talk.lowendspirit.com/discussion/comment/37100/#Comment_37100
Region: Asia https://bench.monster v.1.5.5 2020-12-10 Usage : curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -Asia --------------------------------------------------------------------------- OS : CentOS 7.9.2009 (64 Bit) Virt/Kernel : KVM / 3.10.0-1160.11.1.el7.x86_64 CPU Model : AMD EPYC 7302P 16-Core Processor CPU Cores : 2 @ 3000.000 MHz x86_64 512 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Enabled Load Average : 0.05, 0.06, 0.04 Total Space : 73G (1.7G ~3% used) Total RAM : 3789 MB (214 MB + 303 MB Buff in use) Total SWAP : 1023 MB (0 MB in use) Uptime : 0 days 0:4 --------------------------------------------------------------------------- ASN & ISP : AS29802, HIVELOCITY, Inc. Organization : Sin1 Location : Singapore, Singapore / SG Region : --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 4478 (EXCELLENT) Multi Core : 7591 ## IO Test CPU Speed: bzip2 : 120 MB/s sha256 : 923 MB/s md5sum : 521 MB/s RAM Speed: Avg. write : 2833.1 MB/s Avg. read : 8635.7 MB/s Disk Speed: 1st run : 911 MB/s 2nd run : 971 MB/s 3rd run : 928 MB/s ----------------------- Average : 936.7 MB/s ## Asia Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 834.40 Mbit/s 910.82 Mbit/s 1.974 ms --------------------------------------------------------------------------- India, New Delhi (GIGATEL) 141.90 Mbit/s 443.33 Mbit/s 83.571 ms India, Mumbai (SevenStar) 146.70 Mbit/s 443.54 Mbit/s 60.755 ms India, Bengaluru (I-ON) 267.18 Mbit/s 475.43 Mbit/s 41.496 ms Sri Lanka, Colombo (Telecom PLC) 56.63 Mbit/s 543.12 Mbit/s 41.307 ms Pakistan, Islamabad (Telenor) 57.72 Mbit/s 233.20 Mbit/s 196.611 ms Mongolia, Ulaanbaatar (Mobicom) 50.09 Mbit/s 53.46 Mbit/s 196.755 ms Bangladesh, Dhaka (Skytel) 100.98 Mbit/s 47.04 Mbit/s 64.848 ms Bhutan, Thimphu (Bhutan Telecom) 143.10 Mbit/s 392.68 Mbit/s 75.804 ms Myanmar, Mandalay (Ooredoo) 184.83 Mbit/s 405.81 Mbit/s 52.972 ms Laos, Vientaine (Mangkone) 436.91 Mbit/s 542.86 Mbit/s 34.558 ms Thailand, Bangkok (CAT Telecom) 292.16 Mbit/s 479.42 Mbit/s 33.718 ms Cambodia, Phnom Penh (Smart) 444.41 Mbit/s 214.97 Mbit/s 21.887 ms Vietnam, Hanoi (Viettel) 271.27 Mbit/s 335.54 Mbit/s 52.930 ms Malaysia, Kuala Lumpur (Extreme) 38.24 Mbit/s 397.44 Mbit/s 40.596 ms Singapore (PT FirstMedia) 769.93 Mbit/s 909.21 Mbit/s 1.340 ms Indonesia, Jakarta (Desnet) 83.24 Mbit/s 125.36 Mbit/s 13.104 ms Philippines, Manila (Globe Tel) 153.65 Mbit/s 346.72 Mbit/s 51.056 ms Hong Kong (fdcservers) 68.83 Mbit/s 61.53 Mbit/s 85.704 ms Taiwan, Taipei (TAIFO) 61.42 Mbit/s 47.69 Mbit/s 92.497 ms Japan, Tsukuba (SoftEther) 112.39 Mbit/s 132.63 Mbit/s 78.717 ms --------------------------------------------------------------------------- Timestamp : 2021-02-03 14:31:09 GMT - https://browser.geekbench.com/v4/cpu/16025107hostsolutions @cociu
--------------------------------------------------------------------------- OS : CentOS 8 (64 Bit) Virt/Kernel : KVM / 5.10.12-1.el8.elrepo.x86_64 CPU Model : Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz CPU Cores : 2 @ 2397.222 MHz x86_64 16384 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Disabled Load Average : 0.32, 0.12, 0.12 Total Space : 49G (2.1G ~5% used) Total RAM : 1981 MB (151 MB + 299 MB Buff in use) Total SWAP : 1023 MB (0 MB in use) Uptime : 0 days 1:9 --------------------------------------------------------------------------- ASN & ISP : AS44220, Parfumuri Femei.com SRL Organization : SC NETSILVANIA NETWORK SRL Location : Bucharest, Romania / RO Region : Bucharest --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 3246 (VERY GOOD) Multi Core : 6171 ## IO Test CPU Speed: bzip2 : 95.0 MB/s sha256 : 291 MB/s md5sum : 411 MB/s RAM Speed: Avg. write : 1551.5 MB/s Avg. read : 3857.1 MB/s Disk Speed: 1st run : 1.6 GB/s 2nd run : 1.6 GB/s 3rd run : 1.5 GB/s ----------------------- Average : 1604.3 MB/s ## Global Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 761.73 Mbit/s 785.33 Mbit/s 4.932 ms --------------------------------------------------------------------------- USA, New York (Optimum) 175.37 Mbit/s 43.13 Mbit/s 110.637 ms USA, Chicago (Windstream) 144.87 Mbit/s 375.30 Mbit/s 124.287 ms USA, Dallas (Frontier) 89.85 Mbit/s 139.38 Mbit/s 158.155 ms USA, Miami (Frontier) 112.69 Mbit/s 212.89 Mbit/s 160.921 ms USA, Los Angeles (Windstream) 110.98 Mbit/s 223.42 Mbit/s 178.945 ms UK, London (toob Ltd) 195.74 Mbit/s 1014.62 Mbit/s 36.096 ms France, Lyon (SFR) 407.51 Mbit/s 664.84 Mbit/s 44.278 ms Germany, Berlin (DNS:NET) 314.88 Mbit/s 638.08 Mbit/s 35.648 ms Spain, Madrid (MasMovil) 251.62 Mbit/s 697.70 Mbit/s 67.260 ms Italy, Rome (Unidata) 275.46 Mbit/s 855.73 Mbit/s 51.915 ms Russia, Moscow (Rostelecom) 227.80 Mbit/s 625.31 Mbit/s 80.862 ms Israel, Haifa (013Netvision) 181.87 Mbit/s 149.83 Mbit/s 91.206 ms India, New Delhi (GIGATEL) 91.98 Mbit/s 224.64 Mbit/s 160.545 ms Singapore (FirstMedia) 54.61 Mbit/s 41.74 Mbit/s 188.795 ms Japan, Tsukuba (SoftEther) 26.96 Mbit/s 26.65 Mbit/s 261.871 ms Australia, Sydney (Optus) 7.65 Mbit/s 50.72 Mbit/s 329.393 ms RSA, Randburg (Cool Ideas) 71.63 Mbit/s 51.33 Mbit/s 199.838 ms Brazil, Sao Paulo (Criare) 39.28 Mbit/s 129.02 Mbit/s 243.680 ms --------------------------------------------------------------------------- Finished in : 9 min 54 sec Timestamp : 2021-02-04 02:52:18 GMTI bench YABS 24/7/365 unless it's a leap year.
Hosthatch 8NVMe post re-installation of Debian 10
https://clbin.com/ZHWe3
--------------------------------------------------------------------------- OS : Debian GNU/Linux 10 (64 Bit) Virt/Kernel : KVM / 4.19.0-14-amd64 CPU Model : Intel(R) Xeon(R) CPU E5-2690 0 @ 2.90GHz CPU Cores : 2 @ 2899.998 MHz x86_64 20480 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Disabled Load Average : 0.20, 0.08, 0.08 Total Space : 39G (5.4G ~15% used) Total RAM : 7978 MB (753 MB + 4741 MB Buff in use) Total SWAP : 974 MB (0 MB in use) Uptime : 0 days 21:0 --------------------------------------------------------------------------- ASN & ISP : AS63473, HostHatch Organization : HostHatch LLC Location : Amsterdam, Netherlands / NL Region : North Holland --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 2771 (GOOD) Multi Core : 4979 ## IO Test CPU Speed: bzip2 : 84.8 MB/s sha256 : 140 MB/s md5sum : 423 MB/s RAM Speed: Avg. write : 2423.5 MB/s Avg. read : 5768.5 MB/s Disk Speed: 1st run : 934 MB/s 2nd run : 998 MB/s 3rd run : 971 MB/s ----------------------- Average : 967.7 MB/s ## India Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 1555.62 Mbit/s 920.64 Mbit/s 3.108 ms --------------------------------------------------------------------------- India, New Delhi (GIGATEL) 70.78 Mbit/s 207.25 Mbit/s 182.717 ms India, New Delhi (Weebo) 13.64 Mbit/s 190.04 Mbit/s 142.121 ms India, Mumbai (SevenStar) 96.74 Mbit/s 34.95 Mbit/s 166.289 ms India, Mumbai (OneBroadband) 115.49 Mbit/s 158.29 Mbit/s 115.194 ms India, Mumbai (SevenStar) 95.20 Mbit/s 33.92 Mbit/s 166.280 ms India, Bengaluru (I-ON) 64.98 Mbit/s 55.18 Mbit/s 170.057 ms India, Bengaluru (Activline) 100.62 Mbit/s 112.78 Mbit/s ping error! --------------------------------------------------------------------------- Finished in : 7 min 22 sec Timestamp : 2021-02-04 07:21:48 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/10869097900.png - https://browser.geekbench.com/v4/cpu/16026193Novos's EPYC
--------------------------------------------------------------------------- OS : Ubuntu 20.04.2 LTS (64 Bit) Virt/Kernel : KVM / 5.4.0-65-generic CPU Model : AMD EPYC 7451 24-Core Processor CPU Cores : 2 @ 2295.554 MHz x86_64 512 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Enabled Load Average : 0.18, 0.05, 0.01 Total Space : 39G (7.8G ~20% used) Total RAM : 3936 MB (1203 MB + 2538 MB Buff in use) Total SWAP : 0 MB (0 MB in use) Uptime : 5 days 1:6 --------------------------------------------------------------------------- ASN & ISP : AS42160, lcp nv Organization : Novos Lease Location : Antwerp, Belgium / BE Region : Flanders --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 3083 (VERY GOOD) Multi Core : 5544 ## IO Test CPU Speed: bzip2 : 89.5 MB/s sha256 : 175 MB/s md5sum : 432 MB/s RAM Speed: Avg. write : 1589.4 MB/s Avg. read : 4983.5 MB/s Disk Speed: 1st run : 665 MB/s 2nd run : 790 MB/s 3rd run : 717 MB/s ----------------------- Average : 724.0 MB/s ## Global Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 455.53 Mbit/s 138.41 Mbit/s 12.391 ms --------------------------------------------------------------------------- USA, New York (Optimum) 25.71 Mbit/s 19.06 Mbit/s 80.585 ms USA, Chicago (Windstream) 4.60 Mbit/s 7.68 Mbit/s 101.662 ms USA, Dallas (Frontier) 155.44 Mbit/s 19.00 Mbit/s 124.068 ms USA, Miami (Frontier) 28.94 Mbit/s 2.63 Mbit/s 144.125 ms USA, Los Angeles (Windstream) 75.73 Mbit/s 6.22 Mbit/s 154.929 ms UK, London (toob Ltd) 38.49 Mbit/s 41.23 Mbit/s 13.259 ms France, Lyon (SFR) 150.65 Mbit/s 8.88 Mbit/s 27.823 ms Germany, Berlin (DNS:NET) 245.96 Mbit/s 85.58 Mbit/s 33.293 ms Spain, Madrid (MasMovil) 194.18 Mbit/s 61.99 Mbit/s 37.733 ms Italy, Rome (Unidata) 392.40 Mbit/s 313.04 Mbit/s 39.680 ms Russia, Moscow (Rostelecom) 147.67 Mbit/s 22.92 Mbit/s 54.361 ms Israel, Haifa (013Netvision) 111.12 Mbit/s 12.32 Mbit/s 82.780 ms India, New Delhi (GIGATEL) 127.58 Mbit/s 9.13 Mbit/s 138.871 ms Singapore (FirstMedia) 9.40 Mbit/s 11.81 Mbit/s 190.272 ms Japan, Tsukuba (SoftEther) 43.89 Mbit/s 45.70 Mbit/s 227.482 ms Australia, Sydney (Optus) 19.11 Mbit/s 7.77 Mbit/s 296.223 ms RSA, Randburg (Cool Ideas) 56.89 Mbit/s 4.79 Mbit/s 166.947 ms Brazil, Sao Paulo (Criare) 67.06 Mbit/s 94.34 Mbit/s 201.465 ms --------------------------------------------------------------------------- Finished in : 11 min 45 sec Timestamp : 2021-02-04 07:30:54 GMT Share results: - https://www.speedtest.net/result/10869116378.png - https://browser.geekbench.com/v4/cpu/16026199 - https://clbin.com/9lT9ANovos - Ryzen 9 3900XT
--------------------------------------------------------------------------- OS : Ubuntu 20.04.2 LTS (64 Bit) Virt/Kernel : Dedicated / 5.4.0-65-generic CPU Model : AMD Ryzen 9 3900XT 12-Core Processor CPU Cores : 2 @ 3792.872 MHz x86_64 512 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Enabled Load Average : 0.00, 0.02, 0.02 Total Space : 2.0T (6.4G ~1% used) Total RAM : 3936 MB (412 MB + 1997 MB Buff in use) Total SWAP : 2047 MB (0 MB in use) Uptime : 7 days 22:4 --------------------------------------------------------------------------- ASN & ISP : AS42160, lcp nv Organization : Novos Lease Location : Antwerp, Belgium / BE Region : Flanders --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 5642 (EXCELLENT) Multi Core : 10101 ## IO Test CPU Speed: bzip2 : 139 MB/s sha256 : 280 MB/s md5sum : 637 MB/s RAM Speed: Avg. write : 3413.3 MB/s Avg. read : 10854.4 MB/s Disk Speed: 1st run : 1.1 GB/s 2nd run : 960 MB/s 3rd run : 1.1 GB/s ----------------------- Average : 1070.9 MB/s ## Global Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 468.72 Mbit/s 507.36 Mbit/s 8.978 ms --------------------------------------------------------------------------- USA, New York (Optimum) 183.87 Mbit/s 211.12 Mbit/s 91.917 ms USA, Chicago (Windstream) 178.71 Mbit/s 42.24 Mbit/s 101.491 ms USA, Dallas (Frontier) 151.98 Mbit/s 115.03 Mbit/s 120.890 ms USA, Miami (Frontier) 156.15 Mbit/s 93.45 Mbit/s 116.896 ms USA, Los Angeles (Windstream) 121.35 Mbit/s 63.39 Mbit/s 154.967 ms UK, London (toob Ltd) 389.51 Mbit/s 536.73 Mbit/s 13.309 ms France, Lyon (SFR) 426.84 Mbit/s 433.09 Mbit/s 27.697 ms Germany, Berlin (DNS:NET) 386.85 Mbit/s 340.36 Mbit/s 32.875 ms Spain, Madrid (MasMovil) 384.73 Mbit/s 454.63 Mbit/s 34.917 ms Italy, Rome (Unidata) 372.08 Mbit/s 383.71 Mbit/s 38.359 ms Russia, Moscow (Rostelecom) 283.06 Mbit/s 215.36 Mbit/s 54.275 ms Israel, Haifa (013Netvision) 210.82 Mbit/s 186.38 Mbit/s 75.092 ms India, New Delhi (GIGATEL) 119.21 Mbit/s 104.87 Mbit/s 143.711 ms Singapore (FirstMedia) 52.40 Mbit/s 33.89 Mbit/s 191.220 ms Japan, Tsukuba (SoftEther) 45.05 Mbit/s 59.63 Mbit/s 226.047 ms Australia, Sydney (Optus) 19.53 Mbit/s 46.83 Mbit/s 295.509 ms RSA, Randburg (Cool Ideas) 103.65 Mbit/s 210.15 Mbit/s 166.912 ms Brazil, Sao Paulo (Criare) 30.14 Mbit/s 100.90 Mbit/s 217.579 ms --------------------------------------------------------------------------- Finished in : 9 min 24 sec Timestamp : 2021-02-05 12:08:43 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/10876737411.png - https://browser.geekbench.com/v4/cpu/16028170 - https://clbin.com/ipXNmhttps://capnhatuudai.com/en/ - Personal blog sharing promotion information, Domain Name Coupons, Hosting, VPS / Server, WordPress and the latest experiences and news from service providers around the world.
revisit to AlphaVPS after BF.
lookatdat ram speeeeeed.
--------------------------------------------------------------------------- OS : CentOS 8.3.2011 (64 Bit) Virt/Kernel : KVM / 5.10.13-1.el8.elrepo.x86_64 CPU Model : AMD Ryzen 9 3900X 12-Core Processor CPU Cores : 4 @ 3792.874 MHz x86_64 512 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Disabled Load Average : 0.00, 0.00, 0.00 Total Space : 45G (8.7G ~20% used) Total RAM : 2985 MB (592 MB + 275 MB Buff in use) Total SWAP : 255 MB (0 MB in use) Uptime : 0 days 0:39 --------------------------------------------------------------------------- ASN & ISP : AS18450, WebNX, Inc. Organization : DA International Group Ltd Location : Los Angeles, United States / US Region : California --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 5493 (EXCELLENT) Multi Core : 16849 ## IO Test CPU Speed: bzip2 : 138 MB/s sha256 : 1.4 GB/s md5sum : 722 MB/s RAM Speed: Avg. write : 3276.8 MB/s Avg. read : 10001.1 MB/s Disk Speed: 1st run : 2.2 GB/s 2nd run : 2.2 GB/s 3rd run : 2.2 GB/s ----------------------- Average : 2252.8 MB/s ## Global Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 890.38 Mbit/s 935.17 Mbit/s 1.581 ms --------------------------------------------------------------------------- USA, New York (Optimum) 278.23 Mbit/s 334.35 Mbit/s 67.109 ms USA, Chicago (Windstream) 335.57 Mbit/s 474.54 Mbit/s 61.523 ms USA, Dallas (Frontier) 395.63 Mbit/s 408.26 Mbit/s 39.419 ms USA, Miami (Frontier) 255.22 Mbit/s 333.37 Mbit/s 68.624 ms USA, Los Angeles (Windstream) 855.32 Mbit/s 919.99 Mbit/s 1.016 ms UK, London (toob Ltd) 23.67 Mbit/s 144.93 Mbit/s 137.236 ms France, Lyon (SFR) 76.30 Mbit/s 241.25 Mbit/s 155.525 ms Germany, Berlin (DNS:NET) 123.46 Mbit/s 241.65 Mbit/s 164.134 ms Spain, Madrid (MasMovil) 117.46 Mbit/s 240.43 Mbit/s 167.152 ms Italy, Rome (Unidata) 120.86 Mbit/s 197.24 Mbit/s 171.241 ms Russia, Moscow (Rostelecom) 113.17 Mbit/s 246.76 Mbit/s 175.116 ms Israel, Haifa (013Netvision) 66.13 Mbit/s 149.78 Mbit/s 217.593 ms India, New Delhi (GIGATEL) 20.10 Mbit/s 63.40 Mbit/s 291.023 ms Singapore (FirstMedia) 66.16 Mbit/s 29.88 Mbit/s 168.511 ms Japan, Tsukuba (SoftEther) 166.77 Mbit/s 238.21 Mbit/s 123.930 ms Australia, Sydney (Optus) 88.79 Mbit/s 324.40 Mbit/s 150.966 ms RSA, Randburg (Cool Ideas) 19.39 Mbit/s 57.26 Mbit/s 297.732 ms Brazil, Sao Paulo (Criare) 86.98 Mbit/s 131.10 Mbit/s 172.387 ms --------------------------------------------------------------------------- Finished in : 10 min 38 sec Timestamp : 2021-02-07 04:57:25 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/10886537303.png - https://browser.geekbench.com/v4/cpu/16031074 - https://clbin.com/FzmyVI bench YABS 24/7/365 unless it's a leap year.
My idling Letbox's 3TB Ryzen on BF
--------------------------------------------------------------------------- OS : Debian GNU/Linux 10 (64 Bit) Virt/Kernel : KVM / 5.9.0-0.bpo.5-amd64 CPU Model : AMD Ryzen 9 3900X 12-Core Processor CPU Cores : 1 @ 3792.870 MHz x86_64 512 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Enabled Load Average : 0.11, 0.09, 0.03 Total Space : 2.8T (3.8G ~1% used) Total RAM : 1989 MB (213 MB + 400 MB Buff in use) Total SWAP : 2044 MB (0 MB in use) Uptime : 0 days 0:1 --------------------------------------------------------------------------- ASN & ISP : AS13789, Internap Holding LLC Organization : LetBox NJ Helms Deep Location : New York, United States / US Region : New York --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 5320 (EXCELLENT) Multi Core : 5129 ## IO Test CPU Speed: bzip2 : 141 MB/s sha256 : 269 MB/s md5sum : 597 MB/s RAM Speed: Avg. write : 3140.3 MB/s Avg. read : 9728.0 MB/s Disk Speed: 1st run : 1.8 GB/s 2nd run : 1.6 GB/s 3rd run : 1.8 GB/s ----------------------- Average : 1774.9 MB/s ## Global Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 191.17 Mbit/s 92.78 Mbit/s * 75.884 ms --------------------------------------------------------------------------- USA, New York (Optimum) 378.07 Mbit/s 554.75 Mbit/s 5.060 ms USA, Chicago (Windstream) 197.79 Mbit/s 323.69 Mbit/s 22.450 ms USA, Dallas (Frontier) 167.39 Mbit/s 320.60 Mbit/s 43.659 ms USA, Miami (Frontier) 159.14 Mbit/s 318.34 Mbit/s 48.690 ms USA, Los Angeles (Windstream) 107.15 Mbit/s 179.42 Mbit/s 77.995 ms UK, London (toob Ltd) 108.80 Mbit/s 182.89 Mbit/s 67.498 ms France, Lyon (SFR) 126.45 Mbit/s 152.89 Mbit/s 85.384 ms Germany, Berlin (DNS:NET) 167.66 Mbit/s 232.67 Mbit/s 90.782 ms Spain, Madrid (MasMovil) 158.81 Mbit/s 18.40 Mbit/s 94.446 ms Italy, Rome (Unidata) 146.21 Mbit/s 127.20 Mbit/s 100.018 ms Russia, Moscow (Rostelecom) 108.39 Mbit/s 100.35 Mbit/s 114.869 ms Israel, Haifa (013Netvision) 111.61 Mbit/s 163.79 Mbit/s 138.995 ms India, New Delhi (GIGATEL) 66.28 Mbit/s 132.15 Mbit/s 226.802 ms Singapore (FirstMedia) 20.51 Mbit/s 39.84 Mbit/s 248.884 ms Japan, Tsukuba (SoftEther) 56.01 Mbit/s 78.08 Mbit/s 157.895 ms Australia, Sydney (Optus) 53.78 Mbit/s 89.93 Mbit/s 225.371 ms RSA, Randburg (Cool Ideas) 19.11 Mbit/s 152.34 Mbit/s 232.827 ms Brazil, Sao Paulo (Criare) 51.78 Mbit/s 51.14 Mbit/s 180.168 ms --------------------------------------------------------------------------- Finished in : 10 min 13 sec Timestamp : 2021-02-08 03:48:25 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/10891216206.png - https://browser.geekbench.com/v4/cpu/16032741 - https://clbin.com/99LJyDubai $5/m
--------------------------------------------------------------------------- Region: Middle-East https://bench.monster v.1.5.5 2020-12-10 Usage : curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -Middle-East --------------------------------------------------------------------------- OS : CentOS 7.9.2009 (64 Bit) Virt/Kernel : KVM / 3.10.0-1160.el7.x86_64 CPU Model : Intel(R) Xeon(R) Gold 6226R CPU @ 2.90GHz CPU Cores : 1 @ 2893.200 MHz x86_64 16384 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Enabled Load Average : 0.02, 0.10, 0.12 Total Space : 20G (1.2G ~7% used) Total RAM : 990 MB (83 MB + 144 MB Buff in use) Total SWAP : 0 MB (0 MB in use) Uptime : 0 days 0:44 --------------------------------------------------------------------------- ASN & ISP : AS9009, 3nt solutions LLP Organization : 3nt solutions LLP Location : Fitzrovia, United Kingdom / GB Region : England --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 4436 (EXCELLENT) Multi Core : 4230 ## IO Test CPU Speed: bzip2 : 133 MB/s sha256 : 421 MB/s md5sum : 588 MB/s RAM Speed: Avg. write : 3037.9 MB/s Avg. read : 5973.3 MB/s Disk Speed: 1st run : 1.7 GB/s 2nd run : 1.7 GB/s 3rd run : 1.7 GB/s ----------------------- Average : 1740.8 MB/s ## Middle East Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 133.10 Mbit/s 12.84 Mbit/s * 220.73 ms --------------------------------------------------------------------------- Cyprus, Limassol (DragonNET) 95.01 Mbit/s 6.60 Mbit/s 180.592 ms Israel, Haifa (013Netvision) 89.61 Mbit/s 7.71 Mbit/s 180.966 ms Egypt, Cairo (Vodafone) 89.29 Mbit/s 12.18 Mbit/s 174.243 ms Lebanon, Tripoli (BItarNet) 2.78 Mbit/s 6.82 Mbit/s 164.927 ms UAE, Dubai (Orixcom) 31.07 Mbit/s 6.88 Mbit/s 0.339 ms Qatar, Doha (Vodafone) 127.17 Mbit/s 150.10 Mbit/s 11.763 ms SA, Riyadh (GO) 403.19 Mbit/s 51.02 Mbit/s 24.958 ms Bahrain, Manama (Zain) 380.61 Mbit/s 807.66 Mbit/s 13.971 ms Iran, Tehran (Fanap Telecom) 2.64 Mbit/s 32.27 Mbit/s 266.108 ms --------------------------------------------------------------------------- Finished in : 18 min 54 sec Timestamp : 2021-02-17 18:02:55 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/10946887025.png - https://browser.geekbench.com/v4/cpu/16046877 - https://clbin.com/mFFmfdrServer - Intel® Atom™ C2750 (4-Core, 2.4GHz) 8GB DDR3 1x 200GB SSD 13usd/m
Region : Delaware
## Geekbench v4 CPU Benchmark: Single Core : 1274 (POOR) Multi Core : 3962 ## IO Test CPU Speed: bzip2 : 50.4 MB/s sha256 : 72.8 MB/s md5sum : 325 MB/s RAM Speed: Avg. write : 1024.0 MB/s Avg. read : 2560.0 MB/s Disk Speed: 1st run : 85.2 MB/s 2nd run : 84.6 MB/s 3rd run : 46.4 MB/s ----------------------- Average : 72.1 MB/s ## Global Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 683.43 Mbit/s 231.70 Mbit/s 9.651 ms --------------------------------------------------------------------------- USA, New York (Optimum) 397.42 Mbit/s 208.64 Mbit/s 42.517 ms USA, Chicago (Windstream) 494.71 Mbit/s 219.61 Mbit/s 26.294 ms USA, Dallas (Frontier) 899.06 Mbit/s 239.46 Mbit/s 1.210 ms USA, Miami (Frontier) 440.83 Mbit/s 226.77 Mbit/s 31.740 ms USA, Los Angeles (Windstream) 440.86 Mbit/s 208.72 Mbit/s 29.355 ms UK, London (toob Ltd) 50.86 Mbit/s 121.92 Mbit/s 106.467 ms France, Lyon (SFR) 118.59 Mbit/s 78.48 Mbit/s 119.473 ms Germany, Berlin (DNS:NET) 161.20 Mbit/s 42.15 Mbit/s 125.500 ms Spain, Madrid (MasMovil) 183.47 Mbit/s 117.17 Mbit/s 109.802 ms Italy, Rome (Unidata) 142.45 Mbit/s 84.77 Mbit/s 138.087 ms Russia, Moscow (Rostelecom) 136.65 Mbit/s 96.93 Mbit/s 150.942 ms Israel, Haifa (013Netvision) 113.92 Mbit/s 96.96 Mbit/s 180.728 ms India, New Delhi (GIGATEL) 23.73 Mbit/s 46.66 Mbit/s 250.831 ms Singapore (FirstMedia) 32.51 Mbit/s 31.62 Mbit/s 206.748 ms Japan, Tsukuba (SoftEther) 135.32 Mbit/s 68.89 Mbit/s 145.760 ms Australia, Sydney (Optus) 111.73 Mbit/s 81.39 Mbit/s 188.487 ms RSA, Randburg (Cool Ideas) 27.23 Mbit/s 51.98 Mbit/s 270.439 ms Brazil, Sao Paulo (Criare) 110.41 Mbit/s 70.35 Mbit/s 138.262 ms --------------------------------------------------------------------------- Finished in : 13 min 15 sec Timestamp : 2021-02-21 06:24:40 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/10966816036.png - https://browser.geekbench.com/v4/cpu/16051821 - https://clbin.com/Rp0t7https://capnhatuudai.com/en/ - Personal blog sharing promotion information, Domain Name Coupons, Hosting, VPS / Server, WordPress and the latest experiences and news from service providers around the world.
Is the difference b/w Bench Monster and YABS basically Geekbench V4 vs V5 and iperf vs speedtest.net?
something like that. YABS can choose GB v4/v5 or both in the same test.
monster can choose either v4/v5 as well.
monster has RAM speed test.
Wiredblade. description in YABS thread.
https://talk.lowendspirit.com/discussion/comment/58378/#Comment_58378
--------------------------------------------------------------------------- OS : CentOS 8.3.2011 (64 Bit) Virt/Kernel : KVM / 5.11.3-1.el8.elrepo.x86_64 CPU Model : Intel(R) Xeon(R) CPU E5-2697 v2 @ 2.70GHz CPU Cores : 2 @ 2699.998 MHz x86_64 16384 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Disabled Load Average : 0.11, 0.10, 0.09 Total Space : 40G (2.1G ~6% used) Total RAM : 3929 MB (158 MB + 396 MB Buff in use) Total SWAP : 255 MB (0 MB in use) Uptime : 0 days 12:13 --------------------------------------------------------------------------- ASN & ISP : AS398019, Dynu Systems Incorporated Organization : Dynu Systems Incorporated Location : Chandler, United States / US Region : Arizona --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 2714 (GOOD) Multi Core : 5253 ## IO Test CPU Speed: bzip2 : 95.2 MB/s sha256 : 257 MB/s md5sum : 451 MB/s RAM Speed: Avg. write : 907.5 MB/s Avg. read : 2730.7 MB/s Disk Speed: 1st run : 569 MB/s 2nd run : 664 MB/s 3rd run : 447 MB/s ----------------------- Average : 560.0 MB/s ## Global Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 807.91 Mbit/s 1417.55 Mbit/s 14.591 ms --------------------------------------------------------------------------- USA, New York (Optimum) 269.26 Mbit/s 623.60 Mbit/s 65.403 ms USA, Chicago (Windstream) 343.40 Mbit/s 916.51 Mbit/s 50.026 ms USA, Dallas (Frontier) 471.62 Mbit/s 1366.54 Mbit/s 31.424 ms USA, Miami (Frontier) 319.25 Mbit/s 829.94 Mbit/s 58.959 ms USA, Los Angeles (Windstream) 410.33 Mbit/s 772.38 Mbit/s 46.924 ms UK, London (toob Ltd) 40.01 Mbit/s 340.07 Mbit/s 121.200 ms France, Lyon (SFR) 64.83 Mbit/s 328.43 Mbit/s 145.930 ms Germany, Berlin (DNS:NET) 124.47 Mbit/s 301.41 Mbit/s 152.583 ms Spain, Madrid (MasMovil) 126.33 Mbit/s 313.68 Mbit/s 153.910 ms Italy, Rome (Unidata) 116.18 Mbit/s 220.50 Mbit/s 170.895 ms Russia, Moscow (Rostelecom) 112.81 Mbit/s 260.75 Mbit/s 173.111 ms Israel, Haifa (013Netvision) 68.77 Mbit/s 157.58 Mbit/s 205.610 ms India, New Delhi (GIGATEL) 22.10 Mbit/s 87.71 Mbit/s 246.951 ms Singapore (FirstMedia) 68.72 Mbit/s 41.25 Mbit/s 168.307 ms Japan, Tsukuba (SoftEther) 144.04 Mbit/s 275.34 Mbit/s 134.070 ms Australia, Sydney (Optus) 114.73 Mbit/s 279.26 Mbit/s 174.584 ms RSA, Randburg (Cool Ideas) 20.02 Mbit/s 120.49 Mbit/s 294.916 ms Brazil, Sao Paulo (Criare) 110.61 Mbit/s 159.27 Mbit/s 175.364 ms --------------------------------------------------------------------------- Finished in : 15 min 12 sec Timestamp : 2021-03-08 05:28:32 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/11052781716.png - https://browser.geekbench.com/v4/cpu/16073860 - https://clbin.com/8UuuHI bench YABS 24/7/365 unless it's a leap year.
naranjatech
KVM-NVME-2GB
2 GB RAM
1 CPU Core
30 GB NVMe
5 TB Traffic
1 Gbps port speed
1 IPv4
/64 IPv6
mindblown
--------------------------------------------------------------------------- OS : CentOS 8.3.2011 (64 Bit) Virt/Kernel : KVM / 5.11.4-1.el8.elrepo.x86_64 CPU Model : AMD EPYC 7452 32-Core Processor CPU Cores : 1 @ 2349.992 MHz x86_64 512 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Disabled Load Average : 0.15, 0.06, 0.07 Total Space : 30G (1.9G ~7% used) Total RAM : 1981 MB (149 MB + 291 MB Buff in use) Total SWAP : 255 MB (0 MB in use) Uptime : 0 days 2:39 --------------------------------------------------------------------------- ASN & ISP : AS41608, NextGenWebs Organization : Location : Amsterdam, Netherlands / NL Region : North Holland --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 4668 (EXCELLENT) Multi Core : 4499 ## IO Test CPU Speed: bzip2 : 130 MB/s sha256 : 1.0 GB/s md5sum : 535 MB/s RAM Speed: Avg. write : 3072.0 MB/s Avg. read : 8396.8 MB/s Disk Speed: 1st run : 2.3 GB/s 2nd run : 2.4 GB/s 3rd run : 2.4 GB/s ----------------------- Average : 2423.5 MB/s ## Global Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 384.61 Mbit/s 436.61 Mbit/s 36.384 ms --------------------------------------------------------------------------- USA, New York (Optimum) 231.09 Mbit/s 119.80 Mbit/s 76.041 ms USA, Chicago (Windstream) 195.60 Mbit/s 207.05 Mbit/s 89.136 ms USA, Dallas (Frontier) 144.39 Mbit/s 191.01 Mbit/s 113.208 ms USA, Miami (Frontier) 157.97 Mbit/s 156.74 Mbit/s 104.528 ms USA, Los Angeles (Windstream) 137.95 Mbit/s 110.99 Mbit/s 134.939 ms UK, London (toob Ltd) 512.61 Mbit/s 698.19 Mbit/s 9.323 ms France, Lyon (SFR) 503.32 Mbit/s 425.52 Mbit/s 20.238 ms Germany, Berlin (DNS:NET) 480.75 Mbit/s 469.46 Mbit/s 21.839 ms Spain, Madrid (MasMovil) 462.58 Mbit/s 254.07 Mbit/s 27.318 ms Italy, Rome (Unidata) 412.42 Mbit/s 325.28 Mbit/s 33.773 ms Russia, Moscow (Rostelecom) 356.56 Mbit/s 319.25 Mbit/s 40.527 ms Israel, Haifa (013Netvision) 207.46 Mbit/s 196.78 Mbit/s 80.772 ms India, New Delhi (GIGATEL) 103.48 Mbit/s 184.51 Mbit/s 151.962 ms Singapore (FirstMedia) 2.56 Mbit/s 17.62 Mbit/s 197.918 ms Japan, Tsukuba (SoftEther) 66.68 Mbit/s 32.52 Mbit/s 197.113 ms Australia, Sydney (Optus) 18.97 Mbit/s 43.91 Mbit/s 281.191 ms RSA, Randburg (Cool Ideas) 110.22 Mbit/s 221.45 Mbit/s 173.886 ms Brazil, Sao Paulo (Criare) 88.37 Mbit/s 159.03 Mbit/s 183.587 ms --------------------------------------------------------------------------- Finished in : 9 min 22 sec Timestamp : 2021-03-08 12:13:20 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/11054322944.png - https://browser.geekbench.com/v4/cpu/16074366 - https://clbin.com/X ~]# --------------------------------------------------------------------------- OS : CentOS 8.3.2011 (64 Bit) Virt/Kernel : KVM / 5.11.4-1.el8.elrepo.x86_64 CPU Model : AMD EPYC 7452 32-Core Processor CPU Cores : 1 @ 2349.992 MHz x86_64 512 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Disabled Load Average : 0.15, 0.06, 0.07 Total Space : 30G (1.9G ~7% used) Total RAM : 1981 MB (149 MB + 291 MB Buff in use) Total SWAP : 255 MB (0 MB in use) Uptime : 0 days 2:39 --------------------------------------------------------------------------- ASN & ISP : AS41608, NextGenWebs Organization : Location : Amsterdam, Netherlands / NL Region : North Holland --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 4668 (EXCELLENT) Multi Core : 4499 ## IO Test CPU Speed: bzip2 : 130 MB/s sha256 : 1.0 GB/s md5sum : 535 MB/s RAM Speed: Avg. write : 3072.0 MB/s Avg. read : 8396.8 MB/s Disk Speed: 1st run : 2.3 GB/s 2nd run : 2.4 GB/s 3rd run : 2.4 GB/s ----------------------- Average : 2423.5 MB/s ## Global Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 384.61 Mbit/s 436.61 Mbit/s 36.384 ms --------------------------------------------------------------------------- USA, New York (Optimum) 231.09 Mbit/s 119.80 Mbit/s 76.041 ms USA, Chicago (Windstream) 195.60 Mbit/s 207.05 Mbit/s 89.136 ms USA, Dallas (Frontier) 144.39 Mbit/s 191.01 Mbit/s 113.208 ms USA, Miami (Frontier) 157.97 Mbit/s 156.74 Mbit/s 104.528 ms USA, Los Angeles (Windstream) 137.95 Mbit/s 110.99 Mbit/s 134.939 ms UK, London (toob Ltd) 512.61 Mbit/s 698.19 Mbit/s 9.323 ms France, Lyon (SFR) 503.32 Mbit/s 425.52 Mbit/s 20.238 ms Germany, Berlin (DNS:NET) 480.75 Mbit/s 469.46 Mbit/s 21.839 ms Spain, Madrid (MasMovil) 462.58 Mbit/s 254.07 Mbit/s 27.318 ms Italy, Rome (Unidata) 412.42 Mbit/s 325.28 Mbit/s 33.773 ms Russia, Moscow (Rostelecom) 356.56 Mbit/s 319.25 Mbit/s 40.527 ms Israel, Haifa (013Netvision) 207.46 Mbit/s 196.78 Mbit/s 80.772 ms India, New Delhi (GIGATEL) 103.48 Mbit/s 184.51 Mbit/s 151.962 ms Singapore (FirstMedia) 2.56 Mbit/s 17.62 Mbit/s 197.918 ms Japan, Tsukuba (SoftEther) 66.68 Mbit/s 32.52 Mbit/s 197.113 ms Australia, Sydney (Optus) 18.97 Mbit/s 43.91 Mbit/s 281.191 ms RSA, Randburg (Cool Ideas) 110.22 Mbit/s 221.45 Mbit/s 173.886 ms Brazil, Sao Paulo (Criare) 88.37 Mbit/s 159.03 Mbit/s 183.587 ms --------------------------------------------------------------------------- Finished in : 9 min 22 sec Timestamp : 2021-03-08 12:13:20 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/11054322944.png - https://browser.geekbench.com/v4/cpu/16074366 - https://clbin.com/Xrk3CI bench YABS 24/7/365 unless it's a leap year.
Racknerd 11.11 Special with additional 1 core upgrade.
--------------------------------------------------------------------------- Region: USA https://bench.monster v.1.5.5 2020-12-10 Usage : curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -USA --------------------------------------------------------------------------- OS : CentOS 7.9.2009 (64 Bit) Virt/Kernel : KVM / 3.10.0-1160.6.1.el7.x86_64 CPU Model : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz CPU Cores : 4 @ 2799.998 MHz x86_64 16384 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Disabled Load Average : 0.04, 0.04, 0.05 Total Space : 55G (23G ~44% used) Total RAM : 2845 MB (561 MB + 1492 MB Buff in use) Total SWAP : 2047 MB (0 MB in use) Uptime : 0 days 23:59 --------------------------------------------------------------------------- ASN & ISP : AS36352, ColoCrossing Organization : NYC Metro Location : Washington, United States / US Region : District of Columbia --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 2215 (FAIR) Multi Core : 5731 ## IO Test CPU Speed: bzip2 : 59.4 MB/s sha256 : 133 MB/s md5sum : 349 MB/s RAM Speed: Avg. write : 1051.3 MB/s Avg. read : 2867.2 MB/s Disk Speed: 1st run : 665 MB/s 2nd run : 505 MB/s 3rd run : 544 MB/s ----------------------- Average : 571.3 MB/s ## USA Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 279.60 Mbit/s 364.93 Mbit/s 43.052 ms --------------------------------------------------------------------------- USA, New York (Optimum) 417.28 Mbit/s 755.45 Mbit/s 7.512 ms USA, Boston (Starry, Inc.) 469.17 Mbit/s 647.34 Mbit/s 12.500 ms USA, Washington, DC (Sprint) 603.12 Mbit/s 791.53 Mbit/s 1.890 ms USA, Charlotte, NC (Windstream) 404.33 Mbit/s 540.53 Mbit/s 14.991 ms USA, Atlanta (Frontier) 204.95 Mbit/s 648.75 Mbit/s 31.872 ms USA, Miami (Frontier) 149.33 Mbit/s 635.74 Mbit/s 50.819 ms USA, Nashville (Sprint) 360.73 Mbit/s 584.19 Mbit/s 16.774 ms USA, Indianapolis (Metronet) 113.48 Mbit/s 470.39 Mbit/s 31.883 ms USA, Cleveland (CenturyLink) 374.71 Mbit/s 619.87 Mbit/s 20.612 ms USA, Chicago (Windstream) 263.94 Mbit/s 598.29 Mbit/s 23.170 ms USA, St. Louis (Elite Fiber) 359.28 Mbit/s 381.70 Mbit/s 29.117 ms USA, Minneapolis (US Internet) 376.42 Mbit/s 727.76 Mbit/s 24.279 ms USA, Kansas City (UPNfiber) 276.76 Mbit/s 525.16 Mbit/s 39.291 ms USA, Oklahoma City (OneNet) 150.39 Mbit/s 365.01 Mbit/s 34.610 ms USA, Dallas (Windstream) 230.07 Mbit/s 434.64 Mbit/s 29.248 ms USA, San Antonio, TX (Sprint) 212.89 Mbit/s 470.58 Mbit/s 33.502 ms USA, Denver (Vistabeam) 109.38 Mbit/s 146.14 Mbit/s 59.639 ms USA, Albuquerque (Plateau Tel) 149.31 Mbit/s 490.05 Mbit/s 58.392 ms USA, Phoenix (Cox) 224.65 Mbit/s 287.64 Mbit/s 71.475 ms USA, Salt Lake City (UTOPIA) 217.79 Mbit/s 225.53 Mbit/s 69.603 ms USA, Helena, MT (The Fusion) 212.85 Mbit/s 420.58 Mbit/s 48.273 ms USA, Las Vegas (LV.Net) 179.04 Mbit/s 239.32 Mbit/s 66.194 ms USA, Seattle (Bluespan) 146.12 Mbit/s 440.43 Mbit/s 75.077 ms USA, San Francisco (Wiline) 196.15 Mbit/s 252.33 Mbit/s 67.784 ms USA, Los Angeles (Windstream) 154.73 Mbit/s 314.94 Mbit/s 66.622 ms USA, Anchorage (Alaska Com) 148.91 Mbit/s 371.42 Mbit/s 115.077 ms USA, Honolulu (Hawaiian Telcom) 150.08 Mbit/s 121.29 Mbit/s 130.923 ms --------------------------------------------------------------------------- Finished in : 12 min 34 sec Timestamp : 2021-03-25 02:24:21 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/11151722443.png - https://browser.geekbench.com/v4/cpu/16098770 - https://clbin.com/sKGzKHosterlabs Germany AMD 5
Any Austrians here? Look at that (barely existing) latency towards Magenta/DTAG network!
--------------------------------------------------------------------------- OS : Debian GNU/Linux 10 (64 Bit) Virt/Kernel : KVM / 4.19.0-14-amd64 CPU Model : Intel(R) Xeon(R) E-2174G CPU @ 3.80GHz CPU Cores : 1 @ 3792.038 MHz x86_64 16384 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Disabled Load Average : 0.19, 0.23, 0.13 Total Space : 197G (1.4G ~1% used) Total RAM : 3946 MB (62 MB + 320 MB Buff in use) Total SWAP : 0 MB (0 MB in use) Uptime : 0 days 0:17 --------------------------------------------------------------------------- ASN & ISP : AS40994, Alwyzon Organization : Hohl IT e.U. Location : Vienna, Austria / AT Region : Vienna --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 5869 (EXCELLENT) Multi Core : 5622 ## IO Test CPU Speed: bzip2 : 153 MB/s sha256 : 261 MB/s md5sum : 708 MB/s RAM Speed: Avg. write : 5870.9 MB/s Avg. read : 12185.6 MB/s Disk Speed: 1st run : 1.5 GB/s 2nd run : 1.4 GB/s 3rd run : 1.3 GB/s ----------------------- Average : 1433.6 MB/s ## Europe Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 876.17 Mbit/s 889.93 Mbit/s 1.509 ms --------------------------------------------------------------------------- UK, London (toob Ltd) 375.87 Mbit/s 757.72 Mbit/s 24.740 ms Netherlands, Amsterdam (MaxiTEL) 568.98 Mbit/s 789.23 Mbit/s 18.962 ms Germany, Berlin (DNS:NET) 571.36 Mbit/s 714.48 Mbit/s 22.011 ms Germany, Munich (InterNetX) 580.43 Mbit/s 807.81 Mbit/s 16.974 ms Denmark, Copenhagen (Fiberby) 526.87 Mbit/s 689.94 Mbit/s 17.079 ms Sweden, Stockholm (SUNET) 275.77 Mbit/s 440.46 Mbit/s 43.931 ms Norway, Oslo (NextGenTel) 360.22 Mbit/s 606.75 Mbit/s 34.325 ms France, Lyon (SFR) 420.89 Mbit/s 720.12 Mbit/s 35.942 ms Spain, Madrid (MasMovil) 397.93 Mbit/s 544.63 Mbit/s 35.785 ms Italy, Rome (Unidata) 244.37 Mbit/s 355.54 Mbit/s 64.980 ms Czechia, Prague (Dial Telecom) 817.41 Mbit/s 918.18 Mbit/s 5.168 ms Austria, Vienna (Magenta) 891.49 Mbit/s 926.09 Mbit/s 0.882 ms Poland, Warsaw (Orange) 392.94 Mbit/s 512.22 Mbit/s 21.023 ms Ukraine, Kyiv (KyivStar) 364.41 Mbit/s 511.92 Mbit/s 40.147 ms Latvia, Riga (Bite) 327.51 Mbit/s 544.90 Mbit/s 37.038 ms Russia, Moscow (Rostelecom) 251.36 Mbit/s 396.94 Mbit/s 60.101 ms Greece, Athens (GRNET) 468.78 Mbit/s 638.24 Mbit/s 27.216 ms Turkey, Istanbul (Radore) 305.73 Mbit/s 669.54 Mbit/s 49.761 ms --------------------------------------------------------------------------- Finished in : 7 min 9 sec Timestamp : 2021-03-20 08:16:14 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/11124712732.png - https://browser.geekbench.com/v4/cpu/16090964 - https://clbin.com/u69utNow, if only Magenta would finally improve the latency of their own last mile…
Contabo VPS L SSD
--------------------------------------------------------------------------- OS : Debian GNU/Linux 10 (64 Bit) Virt/Kernel : Dedicated / 4.19.0-13-amd64 CPU Model : AMD EPYC 7282 16-Core Processor CPU Cores : 8 @ 2800.000 MHz x86_64 512 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Disabled Load Average : 0.82, 1.15, 1.03 Total Space : 815G (257G ~33% used) Total RAM : 30153 MB (12304 MB + 3228 MB Buff in use) Total SWAP : 4200 MB (2057 MB in use) Uptime : 103 days 10:27 --------------------------------------------------------------------------- ASN & ISP : AS51167, Contabo GmbH Organization : Contabo GmbH Location : Nuremberg, Germany / DE Region : Bavaria --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 4085 (EXCELLENT) Multi Core : 18115 ## IO Test CPU Speed: bzip2 : 89.3 MB/s sha256 : 196 MB/s md5sum : 400 MB/s RAM Speed: Avg. write : 1543.9 MB/s Avg. read : 4778.7 MB/s Disk Speed: 1st run : 584 MB/s 2nd run : 562 MB/s 3rd run : 562 MB/s ----------------------- Average : 569.3 MB/s ## Europe Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 165.14 Mbit/s 580.46 Mbit/s 1.53 ms --------------------------------------------------------------------------- UK, London (toob Ltd) 34.98 Mbit/s 346.17 Mbit/s 22.876 ms Netherlands, Amsterdam (MaxiTEL) 397.54 Mbit/s 189.18 Mbit/s 16.224 ms Germany, Berlin (DNS:NET) 429.52 Mbit/s 239.32 Mbit/s 16.235 ms Germany, Munich (InterNetX) 459.32 Mbit/s 540.60 Mbit/s 11.698 ms Denmark, Copenhagen (Fiberby) 266.10 Mbit/s 85.90 Mbit/s 11.687 ms Sweden, Stockholm (SUNET) 135.67 Mbit/s 71.56 Mbit/s 35.077 ms Norway, Oslo (NextGenTel) 392.06 Mbit/s 315.06 Mbit/s 26.926 ms France, Lyon (SFR) 421.72 Mbit/s 182.56 Mbit/s 22.635 ms Spain, Madrid (MasMovil) 338.39 Mbit/s 178.12 Mbit/s 40.645 ms Italy, Rome (Unidata) 422.40 Mbit/s 320.70 Mbit/s 20.539 ms Czechia, Prague (Dial Telecom) 135.12 Mbit/s 244.67 Mbit/s 16.155 ms Austria, Vienna (Magenta) 224.81 Mbit/s 94.36 Mbit/s 20.608 ms Poland, Warsaw (Orange) 143.03 Mbit/s 228.41 Mbit/s 36.179 ms Ukraine, Kyiv (KyivStar) 131.43 Mbit/s 267.81 Mbit/s 37.944 ms Latvia, Riga (Bite) 266.31 Mbit/s 131.39 Mbit/s 47.314 ms Russia, Moscow (Rostelecom) 294.71 Mbit/s 97.15 Mbit/s 52.962 ms Greece, Athens (GRNET) 37.21 Mbit/s 47.27 Mbit/s 89.827 ms Turkey, Istanbul (Radore) 246.16 Mbit/s 134.46 Mbit/s 62.025 ms --------------------------------------------------------------------------- Finished in : 12 min 0 sec Timestamp : 2021-03-25 07:34:59 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/11152695909.png - https://browser.geekbench.com/v4/cpu/16099014 - https://clbin.com/BmHk8Hostsolutions 1TB Storage VPS
--------------------------------------------------------------------------- OS : Debian GNU/Linux 10 (64 Bit) Virt/Kernel : KVM / 4.19.0-14-amd64 CPU Model : Intel(R) Xeon(R) CPU E5-2450L 0 @ 1.80GHz CPU Cores : 1 @ 1795.672 MHz x86_64 16384 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Disabled Load Average : 0.97, 0.46, 0.68 Total Space : 1008G (452G ~47% used) Total RAM : 987 MB (204 MB + 157 MB Buff in use) q Total SWAP : 8191 MB (630 MB in use) Uptime : 7 days 0:40 --------------------------------------------------------------------------- ASN & ISP : AS44220, Parfumuri Femei.com SRL Organization : SC NETSILVANIA NETWORK SRL Location : Bucharest, Romania / RO Region : Bucharest --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 1532 (POOR) Multi Core : 1486 ## IO Test CPU Speed: bzip2 : 42.1 MB/s sha256 : 63.2 MB/s md5sum : 226 MB/s RAM Speed: Avg. write : 749.0 MB/s Avg. read : 1735.6 MB/s Disk Speed: 1st run : 245 MB/s 2nd run : 140 MB/s 3rd run : 145 MB/s ----------------------- Average : 176.7 MB/s ## Europe Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 99.34 Mbit/s 169.92 Mbit/s 23.654 ms --------------------------------------------------------------------------- UK, London (toob Ltd) 77.44 Mbit/s 134.44 Mbit/s 49.673 ms Netherlands, Amsterdam (MaxiTEL) 80.13 Mbit/s 86.95 Mbit/s 41.897 ms Germany, Berlin (DNS:NET) 80.11 Mbit/s 148.08 Mbit/s 46.874 ms Germany, Munich (InterNetX) 104.05 Mbit/s 254.98 Mbit/s 24.197 ms Denmark, Copenhagen (Fiberby) 105.86 Mbit/s 199.48 Mbit/s 24.280 ms Sweden, Stockholm (SUNET) 81.43 Mbit/s 106.93 Mbit/s 54.129 ms Norway, Oslo (NextGenTel) 89.56 Mbit/s 188.39 Mbit/s 49.705 ms France, Lyon (SFR) 91.63 Mbit/s 181.05 Mbit/s 43.164 ms Spain, Madrid (MasMovil) 86.74 Mbit/s 141.61 Mbit/s 67.213 ms Italy, Rome (Unidata) 96.79 Mbit/s 196.23 Mbit/s 46.979 ms Czechia, Prague (Dial Telecom) 101.34 Mbit/s 222.62 Mbit/s 23.142 ms Austria, Vienna (Magenta) 83.29 Mbit/s 192.25 Mbit/s 23.831 ms Poland, Warsaw (Orange) 72.78 Mbit/s 173.41 Mbit/s 37.032 ms Ukraine, Kyiv (KyivStar) 67.88 Mbit/s 147.61 Mbit/s 43.553 ms Latvia, Riga (Bite) 72.99 Mbit/s 120.13 Mbit/s 70.771 ms Russia, Moscow (Rostelecom) 68.87 Mbit/s 82.95 Mbit/s 68.657 ms Greece, Athens (GRNET) 97.86 Mbit/s 173.30 Mbit/s 46.011 ms Turkey, Istanbul (Radore) 95.63 Mbit/s 228.78 Mbit/s 26.076 ms --------------------------------------------------------------------------- Finished in : 15 min 16 sec Timestamp : 2021-03-25 07:53:19 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/11152761369.png - https://browser.geekbench.com/v4/cpu/16099025 - https://clbin.com/ATm4cWEbhosting24- SIngapore 2 GB. Ran it witi -in flag for India specific network speeds.
OS : Ubuntu 20.04 LTS (64 Bit) Virt/Kernel : KVM / 5.4.0-29-generic CPU Model : AMD Ryzen 9 3900X 12-Core Processor CPU Cores : 1 @ 3792.872 MHz x86_64 512 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Enabled Load Average : 0.07, 0.02, 0.00 Total Space : 30G (2.1G ~8% used) Total RAM : 1987 MB (90 MB + 297 MB Buff in use) Total SWAP : 0 MB (0 MB in use) Uptime : 0 days 0:30 --------------------------------------------------------------------------- ASN & ISP : AS34081, incubatec network Organization : Impulsiva Location : Urtijëi, Italy / IT Region : Trentino-Alto Adige --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 5538 (EXCELLENT) Multi Core : 5341 ## IO Test CPU Speed: bzip2 : 140 MB/s sha256 : 172 MB/s md5sum : 665 MB/s RAM Speed: Avg. write : 3481.6 MB/s Avg. read : 10752.0 MB/s Disk Speed: 1st run : 754 MB/s 2nd run : 767 MB/s 3rd run : 754 MB/s ----------------------- Average : 758.3 MB/s ## India Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 779.09 Mbit/s 855.76 Mbit/s 2.59 ms --------------------------------------------------------------------------- India, New Delhi (Weebo) 231.20 Mbit/s 599.79 Mbit/s 69.916 ms India, Mumbai (SevenStar) 151.99 Mbit/s 498.54 Mbit/s 68.381 ms India, Mumbai (OneBroadband) 216.33 Mbit/s 355.37 Mbit/s 62.954 ms India, Mumbai (SevenStar) 131.98 Mbit/s 533.23 Mbit/s 68.399 ms India, Bengaluru (I-ON) 316.67 Mbit/s 422.59 Mbit/s 39.531 ms India, Bengaluru (Activline) 265.48 Mbit/s 159.04 Mbit/s 39.510 ms --------------------------------------------------------------------------- Finished in : 6 min 7 sec Timestamp : 2021-04-03 03:47:13 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/11202207780.png - https://browser.geekbench.com/v4/cpu/16111360 - https://clbin.com/Zi8JHFor Asia:
Racknerd 1.5 GB Ryzen KVM VPS (USA Speedtest)
--------------------------------------------------------------------------- OS : Ubuntu 20.04.2 LTS (64 Bit) Virt/Kernel : KVM / 5.4.0-70-generic CPU Model : AMD Ryzen 9 3900X 12-Core Processor CPU Cores : 1 @ 3792.874 MHz x86_64 512 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Enabled Load Average : 0.10, 0.04, 0.01 Total Space : 19G (3.1G ~18% used) Total RAM : 1483 MB (240 MB + 1049 MB Buff in use) Total SWAP : 1535 MB (0 MB in use) Uptime : 1 days 3:15 --------------------------------------------------------------------------- ASN & ISP : AS36352, ColoCrossing Organization : RackNerd LLC Location : Buffalo, United States / US Region : New York --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 4860 (EXCELLENT) Multi Core : 4699 ## IO Test CPU Speed: bzip2 : 127 MB/s sha256 : 240 MB/s md5sum : 555 MB/s RAM Speed: Avg. write : 2184.5 MB/s Avg. read : 7782.4 MB/s Disk Speed: 1st run : 1.2 GB/s 2nd run : 1.2 GB/s 3rd run : 1.2 GB/s ----------------------- Average : 1228.8 MB/s ## USA Speedtest.net Location Upload Download Ping --------------------------------------------------------------------------- Nearby 342.58 Mbit/s 125.29 Mbit/s * 82.838 ms --------------------------------------------------------------------------- USA, New York (Optimum) 597.37 Mbit/s 381.84 Mbit/s 11.352 ms USA, Boston (Starry, Inc.) 335.63 Mbit/s 428.04 Mbit/s 15.995 ms USA, Washington, DC (Sprint) 455.90 Mbit/s 602.22 Mbit/s 17.548 ms USA, Charlotte, NC (Windstream) 434.81 Mbit/s 320.28 Mbit/s 27.219 ms USA, Atlanta (Frontier) 332.23 Mbit/s 281.06 Mbit/s 36.765 ms USA, Miami (Frontier) 188.95 Mbit/s 351.63 Mbit/s 41.692 ms USA, Nashville (Sprint) 247.70 Mbit/s 436.73 Mbit/s 29.891 ms USA, Indianapolis (Metronet) 490.59 Mbit/s 574.79 Mbit/s 17.647 ms USA, Cleveland (CenturyLink) 432.98 Mbit/s 320.84 Mbit/s 22.064 ms USA, Chicago (Windstream) 571.09 Mbit/s 617.87 Mbit/s 10.625 ms USA, St. Louis (Elite Fiber) 475.77 Mbit/s 604.67 Mbit/s 19.793 ms USA, Minneapolis (US Internet) 468.76 Mbit/s 368.04 Mbit/s 22.184 ms USA, Kansas City (UPNfiber) 204.79 Mbit/s 140.89 Mbit/s 24.626 ms USA, Oklahoma City (OneNet) 237.13 Mbit/s 320.32 Mbit/s 36.224 ms USA, Dallas (Windstream) 304.45 Mbit/s 329.96 Mbit/s 36.103 ms USA, San Antonio, TX (Sprint) 180.90 Mbit/s 404.20 Mbit/s 40.841 ms USA, Denver (Vistabeam) 325.56 Mbit/s 272.08 Mbit/s 35.555 ms USA, Albuquerque (Plateau Tel) 242.76 Mbit/s 226.12 Mbit/s 43.417 ms USA, Phoenix (Cox) 171.06 Mbit/s 231.80 Mbit/s 80.111 ms USA, Salt Lake City (UTOPIA) 144.25 Mbit/s 99.05 Mbit/s 50.526 ms USA, Helena, MT (The Fusion) 220.76 Mbit/s 330.58 Mbit/s 42.031 ms USA, Las Vegas (LV.Net) 168.44 Mbit/s 212.91 Mbit/s 75.821 ms USA, Seattle (Bluespan) 153.05 Mbit/s 500.05 Mbit/s 65.382 ms USA, San Francisco (Wiline) 184.88 Mbit/s 223.73 Mbit/s 70.749 ms USA, Los Angeles (Windstream) 207.45 Mbit/s 313.78 Mbit/s 55.833 ms USA, Anchorage (Alaska Com) 144.92 Mbit/s 102.36 Mbit/s 88.701 ms USA, Honolulu (Hawaiian Telcom) 95.75 Mbit/s 98.65 Mbit/s 140.709 ms --------------------------------------------------------------------------- Finished in : 11 min 28 sec Timestamp : 2021-04-03 10:06:50 GMT Saved in : /root/speedtest.log Share results: - https://www.speedtest.net/result/11203306855.png - https://browser.geekbench.com/v4/cpu/16111686 - https://clbin.com/baSabWebhosting24 - Munich
Click to view
(gif screencapture)
Edit: click to view. See comment below
mate I can't see the results I wonder if my internet is slow
The file is 81.6 MB in size. An 81.6 MB GIF.
