Post some YABS bench here
1151618202170
  • MasonMason AdministratorOG
    edited February 2021
    Here's my amateur attempt to answer some of your questions --
    @Not_Oles said: (1) why should the single core score be better with LXC than without?
    Based on your numbers posted, the inverse of that is true, as expected. Your first run on the host has the best single core score overall. Unless you're referring to the raw CPU frequency, in which case see my next answer below.
    @Not_Oles said: (2) As between 32 and 1 core tests, why does the GB single core performance decrease when the processor speed increases?
    I wouldn't pay too much attention to the CPU freq as that is just whatever speed the OS + CPU is reporting at the time that the stat is pulled (cat /proc/cpuinfo). The reported clock will always be somewhere between the min and max frequency (inclusive). The more cores it has, the more likely some of those cores are idling and awaiting work (therefore more chance of a lower frequency being reported). Those frequencies are likely hitting the max clock of the CPU (or burst clock, if available) when it's geekbench crunching time.
    @Not_Oles said: (3) Does the GB single core score decrease with the "real core" count? 1 and 2 logical cores might run on one hardware core. 3 and 4 might run on a second "real core."
    This I'm not so sure of. Ideally, the single core score should remain relatively the same no matter how many cores are allocated to the VM. For more concrete answers, I'd run more tests, as to me this looks to be within the margin of error to call all the single-core scores "somewhat equal".
    @Not_Oles said: What's going on with the IPv4 Send Speed to Clouvider in NY?
    I'll probably just be repeating what you already know here, but throughput of the network is bound to fluctuate depending on when exactly the tests are being run, how much traffic is going over the routes between your server and Clouvider's, how pegged Clouvider's speedtest server is at that moment in time, etc. Wouldn't surprise me if those cross-Atlantic links go from congested to free in just a few minute time window.
    I find it interesting that the IPv6 speed tests to Clouvider's NYC location didn't suffer the same issues that the IPv4 test did that you noted above. Perhaps the different protocols are using separate routes between the two locations and the IPv4 route is defaulting to a more congested one (just a theory).
    @Not_Oles said: Who decided on those swap allocations?
    Likely is baked into the LXC template that you used. But, for now, I'll blame @Ympker, because why not?
    Hope the above helps more than it hurts! :) Cheers!
    Thanked by (3)Ympker Not_Oles saibal
    Humble janitor of LES
    Proud papa of YABS
    It's good to hear from you, too, mate! Hope you and your loved ones are doing well in these times :) Take care!
    As for the swap allocation: Ofc it was my doing. I like messing with ppl's swap :D
    Thanked by (2)Mason Not_Oles
  • @Mason said: Unless you're referring to the raw CPU frequency, in which case see my next answer below.
    You are right! I did intend to ask about the CPU frequency. I failed to write the question clearly! ?
    Those clueless like me might imagine that yabs could be used to compare two different processors as well as to compare one processor in two different sets of circumstances. When comparing two different processors, knowing the maximum frequency might be useful. Clueless me imagined that the frequency yabs reported would be the maximum.
    I want to learn about how the frequency report varies, both in general, and specifically how the 5950X speed report apparently increases from 2185 MHz to 2700 MHz just because of moving from bare metal to "inside" a "bare metal LXC container." I mean, since "the container has no walls," how would merely changing the cgroups and the namespaces increase the processor frequency significantly? There must be more to the story! :)
    Got it!
    I've seen this multiple times. I should do an mtr.
    swap reported by yabs as 5.0 GiB
    That's right about @Ympker being involved! Whenever anything truly great turns up, we can find him there!
    The container used for the tests is still around, so I looked at the Proxmox web GUI to see how much space had been assigned for swap. Here's what I saw:
    @Mason You are the best! Thanks for paying such careful attention to my questions! Also, thanks yet again for all your help previously -- both to me personally and to the LES community! ?
  • @Not_Oles said: The container used for the tests is still around, so I looked at the Proxmox web GUI to see how much space had been assigned for swap. Here's what I saw:
    I've not done much with LXC but the swap in proxmox could be presented as a swap partition - that could still be added to via a swapfile on the disk itself which could top up the swap to 5gb.
    For example on my desktop I have:
    $ sudo swapon
    NAME      TYPE      SIZE   USED PRIO
    /dev/sda3 partition 1.9G 696.5M   -2
    /swapfile file        8G     0B   -3
    You could disable CPU frequency scaling at a BIOS level which would keep the processor at max frequency, although not max boost frequency so you'd still possible see different results. I guess for fairness you could try and take CPU speed while running the geekbench test, but that would need a second yabs process I imagine.
  • Not_OlesNot_Oles Retired
    @Mr_Tom
    Same container:
    root@test-container:~# swapon
    none virtual   5G   0B    0
    root@test-container:~# mount | grep swap
    lxcfs on /proc/swaps type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
    On the same node:
    root@Proxmox-VE ~ # swapon
    /dev/md0 partition  16G   0B   -2
    root@Proxmox-VE ~ # mount | grep swap
    root@Proxmox-VE ~  # mount | grep md0
    root@Proxmox-VE ~ #
    Different container on a different node:
    root@metalvps:~# swapon
    none virtual   6G  24K    0
    root@metalvps:~# mount | grep swap
    root@metalvps:~#
    root@metalvps:~# curl -sL yabs.sh | bash -s -- -9
    #                     v2020-12-29                    #
    Sat Feb 13 00:17:23 UTC 2021
    Processor  : AMD Ryzen 7 3700X 8-Core Processor
    CPU cores  : 4 @ 2228.414 MHz
    RAM        : 4.0 GiB
    Swap       : 6.0 GiB
    Disk       : 49.0 GiB
    Read       | 774.83 MB/s (193.7k) | 1.10 GB/s    (17.3k)
    Write      | 776.88 MB/s (194.2k) | 1.11 GB/s    (17.4k)
    Total      | 1.55 GB/s   (387.9k) | 2.22 GB/s    (34.7k)
    Read       | 2.33 GB/s     (4.5k) | 2.35 GB/s     (2.3k)
    Write      | 2.45 GB/s     (4.7k) | 2.51 GB/s     (2.4k)
    Total      | 4.78 GB/s     (9.3k) | 4.87 GB/s     (4.7k)
    Clouvider       | London, UK (10G)          | 942 Mbits/sec   | 918 Mbits/sec
    Online.net      | Paris, FR (10G)           | 936 Mbits/sec   | 900 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 922 Mbits/sec   | 930 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 685 Mbits/sec   | 181 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 879 Mbits/sec   | 473 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 851 Mbits/sec   | 469 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 803 Mbits/sec   | 363 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | busy            | busy
    Clouvider       | London, UK (10G)          | 920 Mbits/sec   | 903 Mbits/sec
    Online.net      | Paris, FR (10G)           | 927 Mbits/sec   | 850 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 913 Mbits/sec   | 915 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 879 Mbits/sec   | 538 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 818 Mbits/sec   | 353 Mbits/sec
    Geekbench 4 Benchmark Test:
    Single Core     | 5546
    Multi Core      | 12949
    Full Test       | https://browser.geekbench.com/v4/cpu/16040291
    Geekbench 5 Benchmark Test:
    Single Core     | 1208
    Multi Core      | 3165
    Full Test       | https://browser.geekbench.com/v5/cpu/6472459
    root@metalvps:~#
    @Mason @Mr_Tom Based on the above, it looks like yabs is reporting the same number that swapon reports for the size of the swap. The number reported by yabs and swapon apparently can seem different from the size configured in Proxmox's GUI LXC container creation dialog.
    I didn't notice this before! ?
  • @Not_Oles said: I didn't notice this before!
    Ok... that I can't answer :/ lol
  • edited February 2021
    Racknerd 1GB KVM VPS LEB Special
    Sat Feb 13 18:15:03 IST 2021
    Processor  : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz
    CPU cores  : 1 @ 2799.998 MHz
    RAM        : 987.2 MiB
    Swap       : 525.0 MiB
    Disk       : 16.1 GiB
    Read       | 68.05 MB/s   (17.0k) | 1.06 GB/s    (16.6k)
    Write      | 68.24 MB/s   (17.0k) | 1.06 GB/s    (16.7k)
    Total      | 136.30 MB/s  (34.0k) | 2.13 GB/s    (33.3k)
    Read       | 1.57 GB/s     (3.0k) | 1.45 GB/s     (1.4k)
    Write      | 1.65 GB/s     (3.2k) | 1.55 GB/s     (1.5k)
    Total      | 3.23 GB/s     (6.3k) | 3.01 GB/s     (2.9k)
    Clouvider       | London, UK (10G)          | 793 Mbits/sec   | 800 Mbits/sec
    Online.net      | Paris, FR (10G)           | 790 Mbits/sec   | 795 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 794 Mbits/sec   | 795 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 505 Mbits/sec   | 193 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 746 Mbits/sec   | 757 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 592 Mbits/sec   | 523 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 684 Mbits/sec   | 408 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 394 Mbits/sec   | 259 Mbits/sec
    Single Core     | 741
    Multi Core      | 738
    Full Test       | https://browser.geekbench.com/v5/cpu/6481050
    Thanked by (1)cybertech
    HosterLabs 2GB KVM IPV6 special
    Sat 13 Feb 2021 06:37:43 PM IST
        Processor  : Intel(R) Xeon(R) E-2288G CPU @ 3.70GHz
        CPU cores  : 1 @ 3696.000 MHz
        VM-x/AMD-V : ❌ Disabled
        RAM        : 1.9 GiB
        Swap       : 1024.0 MiB
        Disk       : 28.5 GiB
        Read       | 278.80 MB/s  (69.7k) | 3.12 GB/s    (48.8k)
        Write      | 279.54 MB/s  (69.8k) | 3.14 GB/s    (49.1k)
        Total      | 558.34 MB/s (139.5k) | 6.26 GB/s    (97.9k)
        Read       | 4.02 GB/s     (7.8k) | 3.81 GB/s     (3.7k)
        Write      | 4.24 GB/s     (8.2k) | 4.06 GB/s     (3.9k)
        Total      | 8.27 GB/s    (16.1k) | 7.88 GB/s     (7.6k)
        Clouvider       | London, UK (10G)          | 1.75 Gbits/sec  | 2.26 Gbits/sec
        Online.net      | Paris, FR (10G)           | 1.78 Gbits/sec  | 2.18 Gbits/sec
        WorldStream     | The Netherlands (10G)     | 1.75 Gbits/sec  | 2.11 Gbits/sec
        Biznet          | Jakarta, Indonesia (1G)   | 542 Mbits/sec   | 10.2 Mbits/sec
        Clouvider       | NYC, NY, US (10G)         | 1.92 Gbits/sec  | 4.79 Gbits/sec
        Velocity Online | Tallahassee, FL, US (10G) | 1.72 Gbits/sec  | 3.33 Gbits/sec
        Clouvider       | Los Angeles, CA, US (10G) | 1.79 Gbits/sec  | 2.53 Gbits/sec
        Iveloz Telecom  | Sao Paulo, BR (2G)        | 147 Mbits/sec   | 630 Mbits/sec
        Clouvider       | London, UK (10G)          | 1.67 Gbits/sec  | 2.25 Gbits/sec
        Online.net      | Paris, FR (10G)           | 1.74 Gbits/sec  | 2.19 Gbits/sec
        WorldStream     | The Netherlands (10G)     | 1.76 Gbits/sec  | 2.08 Gbits/sec
        Clouvider       | NYC, NY, US (10G)         | 1.89 Gbits/sec  | 4.67 Gbits/sec
        Clouvider       | Los Angeles, CA, US (10G) | 1.76 Gbits/sec  | 2.53 Gbits/sec
        Single Core     | 1231
        Multi Core      | 1227
        Full Test       | https://browser.geekbench.com/v5/cpu/6481455
    @hosterlabs
    Thanked by (1)flips
    Hostsolution 2GB 200GB
    #https://github.com/masonr/yet-another-bench-script
    Sat Feb 13 18:48:52 IST 2021
    Processor : Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz
    CPU cores : 2 @ 2397.222 MHz
    AES-NI : ✔ Enabled
    RAM : 1.9 GiB
    Swap : 0.0 KiB
    Disk : 196.8 GiB
        Read       | 131.24 MB/s  (32.8k) | 883.29 MB/s  (13.8k)
        Write      | 131.59 MB/s  (32.8k) | 887.94 MB/s  (13.8k)
        Total      | 262.83 MB/s  (65.7k) | 1.77 GB/s    (27.6k)
        Read       | 1.05 GB/s     (2.0k) | 1.13 GB/s     (1.1k)
        Write      | 1.11 GB/s     (2.1k) | 1.21 GB/s     (1.1k)
        Total      | 2.16 GB/s     (4.2k) | 2.35 GB/s     (2.2k)
        Clouvider       | London, UK (10G)          | 218 Mbits/sec   | 295 Mbits/sec
        Online.net      | Paris, FR (10G)           | 748 Mbits/sec   | 360 Mbits/sec
        WorldStream     | The Netherlands (10G)     | 794 Mbits/sec   | 427 Mbits/sec
        Biznet          | Jakarta, Indonesia (1G)   | 529 Mbits/sec   | 60.5 Mbits/sec
        Clouvider       | NYC, NY, US (10G)         | 734 Mbits/sec   | 192 Mbits/sec
        Velocity Online | Tallahassee, FL, US (10G) | 655 Mbits/sec   | 162 Mbits/sec
        Clouvider       | Los Angeles, CA, US (10G) | 198 Mbits/sec   | 92.8 Mbits/sec
        Single Core     | 604
        Multi Core      | 1181
        Full Test       | https://browser.geekbench.com/v5/cpu/6481689
    @cociu
  • Inception 1GB 1TB
    Sat 13 Feb 19:10:58 IST 2021
        Processor  : Intel(R) Xeon(R) CPU E5-2660 0 @ 2.20GHz
        CPU cores  : 1 @ 2199.998 MHz
        RAM        : 987.2 MiB
        Swap       : 0.0 KiB
        Disk       : 984.2 GiB
        Read       | 4.13 MB/s     (1.0k) | 52.72 MB/s     (823)
        Write      | 4.15 MB/s     (1.0k) | 53.18 MB/s     (831)
        Total      | 8.28 MB/s     (2.0k) | 105.91 MB/s   (1.6k)
        Read       | 78.96 MB/s     (154) | 102.80 MB/s    (100)
        Write      | 83.15 MB/s     (162) | 109.65 MB/s    (107)
        Total      | 162.12 MB/s    (316) | 212.45 MB/s    (207)
        Clouvider       | London, UK (10G)          | busy            | 412 Mbits/sec
        Online.net      | Paris, FR (10G)           | 669 Mbits/sec   | 151 Mbits/sec
        WorldStream     | The Netherlands (10G)     | 832 Mbits/sec   | 310 Mbits/sec
        Biznet          | Jakarta, Indonesia (1G)   | 628 Mbits/sec   | 118 Mbits/sec
        Clouvider       | NYC, NY, US (10G)         | 836 Mbits/sec   | 535 Mbits/sec
        Velocity Online | Tallahassee, FL, US (10G) | 830 Mbits/sec   | 592 Mbits/sec
        Clouvider       | Los Angeles, CA, US (10G) | 883 Mbits/sec   | 918 Mbits/sec
        Iveloz Telecom  | Sao Paulo, BR (2G)        | 728 Mbits/sec   | 306 Mbits/sec
    @AnthonySmith
  • vserver 1GB 5GB
    Sat Feb 13 19:02:57 IST 2021
    Processor  : AMD Opteron(tm) Processor 6380
    CPU cores  : 1 @ 2500.012 MHz
    RAM        : 987.2 MiB
    Swap       : 349.0 MiB
    Disk       : 4.5 GiB
    Read       | 9.39 MB/s     (2.3k) | 26.32 MB/s     (411)
    Write      | 9.42 MB/s     (2.3k) | 26.79 MB/s     (418)
    Total      | 18.81 MB/s    (4.7k) | 53.12 MB/s     (829)
    Read       | 94.96 MB/s     (185) | 112.48 MB/s    (109)
    Write      | 100.00 MB/s    (195) | 119.97 MB/s    (117)
    Total      | 194.96 MB/s    (380) | 232.46 MB/s    (226)
    Clouvider       | London, UK (10G)          | 904 Mbits/sec   | 308 Mbits/sec
    Online.net      | Paris, FR (10G)           | 893 Mbits/sec   | 287 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 867 Mbits/sec   | 286 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 630 Mbits/sec   | 85.9 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 823 Mbits/sec   | 163 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 702 Mbits/sec   | 185 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 811 Mbits/sec   | 114 Mbits/sec
    Clouvider       | London, UK (10G)          | busy            | busy
    Online.net      | Paris, FR (10G)           | 882 Mbits/sec   | 278 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 781 Mbits/sec   | 280 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 642 Mbits/sec   | 157 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 792 Mbits/sec   | 113 Mbits/sec
    Single Core     | 353
    Multi Core      | 351
    Full Test       | https://browser.geekbench.com/v5/cpu/6481954
    @vserversite
  • Webhorizon 512MB 7GB
    Sat Feb 13 19:04:45 IST 2021
    Processor  : Intel(R) Xeon(R) E-2276G CPU @ 3.80GHz
    CPU cores  : 1 @ 3791.998 MHz
    RAM        : 512.0 MiB
    Swap       : 0.0 KiB
    Disk       : 6.9 GiB
    Read       | 36.26 MB/s    (9.0k) | 174.46 MB/s   (2.7k)
    Write      | 36.36 MB/s    (9.0k) | 175.38 MB/s   (2.7k)
    Total      | 72.62 MB/s   (18.1k) | 349.84 MB/s   (5.4k)
    Read       | 142.68 MB/s    (278) | 124.26 MB/s    (121)
    Write      | 150.27 MB/s    (293) | 132.54 MB/s    (129)
    Total      | 292.95 MB/s    (571) | 256.81 MB/s    (250)
    Clouvider       | London, UK (10G)          | 475 Mbits/sec   | 577 Mbits/sec
    Online.net      | Paris, FR (10G)           | 377 Mbits/sec   | 351 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 458 Mbits/sec   | 499 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 877 Mbits/sec   | 909 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 407 Mbits/sec   | 236 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 366 Mbits/sec   | 327 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 481 Mbits/sec   | 429 Mbits/sec
    Clouvider       | London, UK (10G)          | busy            | 223 Mbits/sec
    Online.net      | Paris, FR (10G)           | busy            | 236 Mbits/sec
    WorldStream     | The Netherlands (10G)     | busy            | 220 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | busy            | 201 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | busy            | 203 Mbits/sec
    @Abdullah
  • Debian KVM on Hetzner Ax101
    debian@debian-kvm:~$ date -u
    Sat 13 Feb 2021 08:36:08 PM UTC
    debian@debian-kvm:~$ curl -sL yabs.sh | bash -s -- -9
    #                     v2020-12-29                    #
    Sat 13 Feb 2021 01:36:12 PM MST
    CPU cores  : 4 @ 3393.624 MHz
    RAM        : 3.9 GiB
    Swap       : 975.0 MiB
    Disk       : 194.9 GiB
    Read       | 360.72 MB/s  (90.1k) | 1.46 GB/s    (22.9k)
    Write      | 361.68 MB/s  (90.4k) | 1.47 GB/s    (23.0k)
    Total      | 722.40 MB/s (180.6k) | 2.94 GB/s    (45.9k)
    Read       | 1.51 GB/s     (2.9k) | 1.48 GB/s     (1.4k)
    Write      | 1.59 GB/s     (3.1k) | 1.58 GB/s     (1.5k)
    Total      | 3.11 GB/s     (6.0k) | 3.07 GB/s     (3.0k)
    Clouvider       | London, UK (10G)          | 942 Mbits/sec   | busy
    Online.net      | Paris, FR (10G)           | 932 Mbits/sec   | 933 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 929 Mbits/sec   | 937 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 720 Mbits/sec   | 240 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 78.7 Mbits/sec  | 458 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 828 Mbits/sec   | 500 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 670 Mbits/sec   | 324 Mbits/sec
    Single Core     | 6479
    Multi Core      | 19697
    Full Test       | https://browser.geekbench.com/v4/cpu/16041450
    Single Core     | 1471
    Multi Core      | 4834
    Full Test       | https://browser.geekbench.com/v5/cpu/6488317
    Thanked by (2)kwaralala cybertech
    Dedicated KVM Slice 512MB BuyVM Luxembourg Debian 10
    #                     v2020-12-29                    #
    Sun Feb 14 03:40:52 CET 2021
    Processor  : AMD Ryzen 9 3900X 12-Core Processor
    CPU cores  : 1 @ 3792.872 MHz
    RAM        : 483.2 MiB
    Swap       : 512.0 MiB
    Disk       : 9.3 GiB
    Read       | 122.57 MB/s  (30.6k) | 390.67 MB/s   (6.1k)
    Write      | 122.90 MB/s  (30.7k) | 392.72 MB/s   (6.1k)
    Total      | 245.48 MB/s  (61.3k) | 783.39 MB/s  (12.2k)
    Read       | 488.14 MB/s    (953) | 514.72 MB/s    (502)
    Write      | 514.07 MB/s   (1.0k) | 549.00 MB/s    (536)
    Total      | 1.00 GB/s     (1.9k) | 1.06 GB/s     (1.0k)
    Clouvider       | London, UK (10G)          | 1.12 Gbits/sec  | 586 Mbits/sec
    Online.net      | Paris, FR (10G)           | 1.12 Gbits/sec  | 860 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 1.12 Gbits/sec  | 774 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 691 Mbits/sec   | 382 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 1.03 Gbits/sec  | 205 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 336 Mbits/sec   | 208 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 808 Mbits/sec   | 231 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 63.5 Mbits/sec  | 117 Mbits/sec
    Clouvider       | London, UK (10G)          | 1.10 Gbits/sec  | 320 Mbits/sec
    Online.net      | Paris, FR (10G)           | 1.11 Gbits/sec  | 615 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 1.02 Gbits/sec  | 773 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 45.7 Mbits/sec  | 112 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 522 Kbits/sec   | 21.4 Mbits/sec
    Single Core     | 983
    Multi Core      | 970
    Full Test       | https://browser.geekbench.com/v5/cpu/6492011
    taking Avoro Winter Deal 2019 for another spin, seems like it's time to put it back in production. less steal now than before:
    #                     v2020-12-29                    #
    Sun Feb 14 14:42:06 +08 2021
    Processor  : AMD EPYC 7352 24-Core Processor
    CPU cores  : 2 @ 2299.998 MHz
    RAM        : 5.8 GiB
    Swap       : 256.0 MiB
    Disk       : 29.7 GiB
    Read       | 146.74 MB/s  (36.6k) | 877.73 MB/s  (13.7k)
    Write      | 147.13 MB/s  (36.7k) | 882.35 MB/s  (13.7k)
    Total      | 293.88 MB/s  (73.4k) | 1.76 GB/s    (27.5k)
    Read       | 1.33 GB/s     (2.6k) | 1.31 GB/s     (1.2k)
    Write      | 1.40 GB/s     (2.7k) | 1.40 GB/s     (1.3k)
    Total      | 2.74 GB/s     (5.3k) | 2.71 GB/s     (2.6k)
    Clouvider       | London, UK (10G)          | 3.01 Gbits/sec  | 3.83 Gbits/sec
    Online.net      | Paris, FR (10G)           | 7.68 Gbits/sec  | 5.41 Gbits/sec
    WorldStream     | The Netherlands (10G)     | 7.13 Gbits/sec  | 1.11 Gbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 794 Mbits/sec   | 64.2 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 2.11 Gbits/sec  | 1.56 Gbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 1.66 Gbits/sec  | 1.25 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 1.02 Gbits/sec  | 27.3 Mbits/sec
    Clouvider       | London, UK (10G)          | 7.00 Gbits/sec  | 4.60 Gbits/sec
    Online.net      | Paris, FR (10G)           | 6.87 Gbits/sec  | 6.70 Gbits/sec
    WorldStream     | The Netherlands (10G)     | 6.53 Gbits/sec  | 4.61 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 2.12 Gbits/sec  | 1.28 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 1.08 Gbits/sec  | 1.02 Gbits/sec
    Single Core     | 3480
    Multi Core      | 5941
    Full Test       | https://browser.geekbench.com/v4/cpu/16041909
  • Webhosting24 10x10x10 Special
    #                     v2020-12-29                    #
    Sun 14 Feb 2021 10:22:11 AM UTC
    CPU cores  : 1 @ 2399.996 MHz
    RAM        : 981.2 MiB
    Swap       : 0.0 KiB
    Disk       : 9.8 GiB
    Read       | 263.14 MB/s  (65.7k) | 2.72 GB/s    (42.5k)
    Write      | 263.84 MB/s  (65.9k) | 2.73 GB/s    (42.7k)
    Total      | 526.98 MB/s (131.7k) | 5.46 GB/s    (85.3k)
    Read       | 3.16 GB/s     (6.1k) | 3.52 GB/s     (3.4k)
    Write      | 3.33 GB/s     (6.5k) | 3.75 GB/s     (3.6k)
    Total      | 6.49 GB/s    (12.6k) | 7.28 GB/s     (7.1k)
    Clouvider       | London, UK (10G)          | 838 Mbits/sec   | 459 Mbits/sec
    Online.net      | Paris, FR (10G)           | 919 Mbits/sec   | 437 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 945 Mbits/sec   | 509 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 291 Mbits/sec   | 33.3 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 342 Mbits/sec   | 89.5 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 182 Mbits/sec   | 71.5 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 358 Mbits/sec   | 59.3 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | busy            | 69.7 Mbits/sec
    Clouvider       | London, UK (10G)          | 390 Mbits/sec   | 384 Mbits/sec
    Online.net      | Paris, FR (10G)           | 392 Mbits/sec   | 460 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 337 Mbits/sec   | 491 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 117 Mbits/sec   | 77.3 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 94.9 Mbits/sec  | 116 Mbits/sec
    Single Core     | 736
    Multi Core      | 732
    Full Test       | https://browser.geekbench.com/v5/cpu/6497422
    Thanked by (2)cybertech tomazu
  • @seriesn said:
    Oh my!
    [root@test-1 ~]# curl -sL yabs.sh | bash -s -- -9
    #                     v2020-12-29                    #
    Thu Feb 11 23:16:29 EST 2021
    CPU cores  : 4 @ 3792.874 MHz
    RAM        : 3.7 GiB
    Swap       : 0.0 KiB
    Disk       : 59.0 GiB
    Read       | 382.67 MB/s  (95.6k) | 4.03 GB/s    (62.9k)
    Write      | 383.68 MB/s  (95.9k) | 4.05 GB/s    (63.3k)
    Total      | 766.36 MB/s (191.5k) | 8.08 GB/s   (126.2k)
    Read       | 4.85 GB/s     (9.4k) | 4.65 GB/s     (4.5k)
    Write      | 5.11 GB/s     (9.9k) | 4.96 GB/s     (4.8k)
    Total      | 9.96 GB/s    (19.4k) | 9.61 GB/s     (9.3k)
    Clouvider       | London, UK (10G)          | 760 Mbits/sec   | 930 Mbits/sec
    Online.net      | Paris, FR (10G)           | 754 Mbits/sec   | 921 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 834 Mbits/sec   | 941 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 386 Mbits/sec   | 169 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 476 Mbits/sec   | 807 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 374 Mbits/sec   | 588 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 334 Mbits/sec   | 306 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 232 Mbits/sec   | 162 Mbits/sec
    Clouvider       | London, UK (10G)          | 917 Mbits/sec   | 902 Mbits/sec
    Online.net      | Paris, FR (10G)           | 921 Mbits/sec   | 902 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 922 Mbits/sec   | 916 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 835 Mbits/sec   | 450 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 465 Mbits/sec   | 301 Mbits/sec
    Single Core     | 5865
    Multi Core      | 18710
    Full Test       | https://browser.geekbench.com/v4/cpu/16039136
    Single Core     | 1334
    Multi Core      | 4555
    Full Test       | https://browser.geekbench.com/v5/cpu/6456373
    No matter how beautiful a bench looks, it can never beat nature for me.
  • seriesnseriesn Hosting ProviderOG
    Facts!!
    MS said:
    @seriesn said:
    Oh my!
    #                     v2020-12-29                    #
    RAM        : 3.7 GiB
    Swap       : 0.0 KiB
    Disk       : 59.0 GiB
    Single Core     | 5865
    Multi Core      | 18710
    Single Core     | 1334
    Multi Core      | 4555
    Thanked by (1)_MS_
    AES-NI : ✔ Enabled
    RAM : 512.0 MiB
    Swap : 0.0 KiB
    Disk : 6.9 GiB
    @Abdullah
    The disk IO seems much lower than our other KVMs at Singapore, canyou create a ticket so I can look, or PM regd. email ? :)
    AES-NI : ✔ Enabled
    RAM : 512.0 MiB
    Swap : 0.0 KiB
    Disk : 6.9 GiB
    @Abdullah
    ticket #7977790 made
    and closed due to super fast response by @Abdullah :)
    Thanked by (1)Abdullah
    AES-NI : ✔ Enabled
    RAM : 512.0 MiB
    Swap : 0.0 KiB
    Disk : 6.9 GiB
    @Abdullah
    replied, seems like a confusion on my part. This is an OVZ NAT vps. sorry!
  • Dubai $5/m
    #                     v2020-12-29                    #
    Fri Feb 19 01:19:37 +04 2021
    Processor  : Intel(R) Xeon(R) Gold 6226R CPU @ 2.90GHz
    CPU cores  : 1 @ 2893.200 MHz
    RAM        : 990.9 MiB
    Swap       : 2.0 GiB
    Disk       : 19.6 GiB
    Read       | 417.79 MB/s (104.4k) | 3.73 GB/s    (58.3k)
    Write      | 418.89 MB/s (104.7k) | 3.75 GB/s    (58.6k)
    Total      | 836.68 MB/s (209.1k) | 7.48 GB/s   (117.0k)
    Read       | 4.48 GB/s     (8.7k) | 4.29 GB/s     (4.1k)
    Write      | 4.72 GB/s     (9.2k) | 4.57 GB/s     (4.4k)
    Total      | 9.21 GB/s    (18.0k) | 8.86 GB/s     (8.6k)
    Online.net      | Paris, FR (10G)           | 868 Mbits/sec   | 873 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 847 Mbits/sec   | 866 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 604 Mbits/sec   | 87.9 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | busy            | busy
    Velocity Online | Tallahassee, FL, US (10G) | 592 Mbits/sec   | busy
    Clouvider       | Los Angeles, CA, US (10G) | busy            | busy
    Single Core     | 4179
    Multi Core      | 4100
    Full Test       | https://browser.geekbench.com/v4/cpu/16048612
    Single Core     | 955
    Multi Core      | 957
    Full Test       | https://browser.geekbench.com/v5/cpu/6575830
    TerraHost i3 BF 500gb HDD replaced with 2TB ssd :joy:
    root@yeah:~# curl -sL yabs.sh | bash -s -- -9
    #                     v2020-12-29                    #
    Fri 19 Feb 2021 06:28:46 AM WIB
    Processor  : Intel(R) Core(TM) i3-4130 CPU @ 3.40GHz
    CPU cores  : 4 @ 2891.187 MHz
    RAM        : 3.7 GiB
    Swap       : 92.0 MiB
    Disk       : 1.8 TiB
    Read       | 151.11 MB/s  (37.7k) | 169.99 MB/s   (2.6k)
    Write      | 151.50 MB/s  (37.8k) | 170.89 MB/s   (2.6k)
    Total      | 302.61 MB/s  (75.6k) | 340.88 MB/s   (5.3k)
    Read       | 217.58 MB/s    (424) | 237.29 MB/s    (231)
    Write      | 229.14 MB/s    (447) | 253.09 MB/s    (247)
    Total      | 446.72 MB/s    (871) | 490.38 MB/s    (478)
    Online.net      | Paris, FR (10G)           | 914 Mbits/sec   | 623 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 921 Mbits/sec   | 888 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 559 Mbits/sec   | 22.3 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 849 Mbits/sec   | 346 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 739 Mbits/sec   | 156 Mbits/sec
    Single Core     | 3908
    Multi Core      | 7239
    Full Test       | https://browser.geekbench.com/v4/cpu/16048695
    Single Core     | 872
    Multi Core      | 1768
    Full Test       | https://browser.geekbench.com/v5/cpu/6576915
  • vyasvyas OGContent Writer
    After a lot of back and forth with @Not_Oles (for all good reasons!)
    Sat Feb 20 06:04:39 UTC 2021
    CPU cores  : 4 @ 2192.292 MHz
    RAM        : 4.0 GiB
    Swap       : 4.5 GiB
    Disk       : 97.9 GiB
    Read       | 945.54 MB/s (236.3k) | 2.54 GB/s    (39.8k)
    Write      | 948.04 MB/s (237.0k) | 2.56 GB/s    (40.0k)
    Total      | 1.89 GB/s   (473.3k) | 5.10 GB/s    (79.8k)
    Read       | 955.06 MB/s   (1.8k) | 3.27 GB/s     (3.2k)
    Write      | 1.00 GB/s     (1.9k) | 3.49 GB/s     (3.4k)
    Total      | 1.96 GB/s     (3.8k) | 6.77 GB/s     (6.6k)
    Online.net      | Paris, FR (10G)           | 947 Mbits/sec   | 919 Mbits/sec
    Online.net      | Paris, FR (10G)           | 936 Mbits/sec   | 924 Mbits/sec
    Single Core     | 6516
    Multi Core      | 19541
    Full Test       | https://browser.geekbench.com/v4/cpu/16050385
    Single Core     | 1497
    Multi Core      | 4746
    Full Test       | https://browser.geekbench.com/v5/cpu/6597804
    Thanked by (3)cybertech Mason Not_Oles
    Shot in a ticket to have Clouvider check out their iperf servers.
    Considering reducing the number of retries so when iperf servers aren't operational the script doesn't take forever to run
    Thanked by (2)vyas ariq01
    Proud papa of YABS
    RAM        : 4.0 GiB
    Swap       : 4.5 GiB
    Disk       : 97.9 GiB
    Single Core     | 6516
    Multi Core      | 19541
    Single Core     | 1497
    Multi Core      | 4746
  • Not technically a VPS. KVM VM deployed on a home server. Was just curious to see how it compares.
    Half of the cores assigned to VM. (PN50 Mini pc form factor zen 2 4700U / 64gig / nvme). About 500 bucks worth of gear. Unsure why AES and AMD-V is disabled. Single core sucks cause it's essentially a laptop cpu. Surprised at the weak disk though
    #                     v2020-12-29                    #
    Sat 20 Feb 2021 02:13:15 PM UTC
    Processor  : Common KVM processor
    CPU cores  : 4 @ 1996.269 MHz
    AES-NI     : ❌ Disabled
    RAM        : 3.9 GiB
    Swap       : 0.0 KiB
    Disk       : 9.8 GiB
    Read       | 123.27 MB/s  (30.8k) | 518.63 MB/s   (8.1k)
    Write      | 123.59 MB/s  (30.8k) | 521.36 MB/s   (8.1k)
    Total      | 246.86 MB/s  (61.7k) | 1.04 GB/s    (16.2k)
    Read       | 228.20 MB/s    (445) | 217.90 MB/s    (212)
    Write      | 240.32 MB/s    (469) | 232.41 MB/s    (226)
    Total      | 468.53 MB/s    (914) | 450.32 MB/s    (438)
    Online.net      | Paris, FR (10G)           | 877 Mbits/sec   | 695 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 915 Mbits/sec   | 688 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 291 Mbits/sec   | 79.7 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 826 Mbits/sec   | 494 Mbits/sec
    Online.net      | Paris, FR (10G)           | 904 Mbits/sec   | 591 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 856 Mbits/sec   | 690 Mbits/sec
    Single Core     | 995
    Multi Core      | 3359
    #                     v2020-12-29                    #
    AES-NI     : ❌ Disabled
    RAM        : 3.9 GiB
    Swap       : 0.0 KiB
    Disk       : 9.8 GiB
    Single Core     | 995
    Multi Core      | 3359
    pretty good actually for GB5
  • @cybertech said: pretty good actually for GB5
    Yeah pretty happy with it. Low power (10W idle), 8 core & loads of mem makes it a good always on proxmox machine for gitlab, pihole etc
    RAM        : 4.0 GiB
    Swap       : 4.5 GiB
    Disk       : 97.9 GiB
    Single Core     | 6516
    Multi Core      | 19541
    Single Core     | 1497
    Multi Core      | 4746
    @vyas @cybertech @Mason @Everybody
    Is anyone aware of anything that could be done to improve the server's performance? I hope the performance could be as good as possible. Thanks!
