Here's my amateur attempt to answer some of your questions --
@Not_Oles said: (1) why should the single core score be better with LXC than without?
Based on your numbers posted, the inverse of that is true, as expected. Your first run on the host has the best single core score overall. Unless you're referring to the raw CPU frequency, in which case see my next answer below.
@Not_Oles said: (2) As between 32 and 1 core tests, why does the GB single core performance decrease when the processor speed increases?
I wouldn't pay too much attention to the CPU freq as that is just whatever speed the OS + CPU is reporting at the time that the stat is pulled (cat /proc/cpuinfo). The reported clock will always be somewhere between the min and max frequency (inclusive). The more cores it has, the more likely some of those cores are idling and awaiting work (therefore more chance of a lower frequency being reported). Those frequencies are likely hitting the max clock of the CPU (or burst clock, if available) when it's geekbench crunching time.
@Not_Oles said: (3) Does the GB single core score decrease with the "real core" count? 1 and 2 logical cores might run on one hardware core. 3 and 4 might run on a second "real core."
This I'm not so sure of. Ideally, the single core score should remain relatively the same no matter how many cores are allocated to the VM. For more concrete answers, I'd run more tests, as to me this looks to be within the margin of error to call all the single-core scores "somewhat equal".
@Not_Oles said: What's going on with the IPv4 Send Speed to Clouvider in NY?
I'll probably just be repeating what you already know here, but throughput of the network is bound to fluctuate depending on when exactly the tests are being run, how much traffic is going over the routes between your server and Clouvider's, how pegged Clouvider's speedtest server is at that moment in time, etc. Wouldn't surprise me if those cross-Atlantic links go from congested to free in just a few minute time window.
I find it interesting that the IPv6 speed tests to Clouvider's NYC location didn't suffer the same issues that the IPv4 test did that you noted above. Perhaps the different protocols are using separate routes between the two locations and the IPv4 route is defaulting to a more congested one (just a theory).
@Mason said: Unless you're referring to the raw CPU frequency, in which case see my next answer below.
You are right! I did intend to ask about the CPU frequency. I failed to write the question clearly! ?
Those clueless like me might imagine that yabs could be used to compare two different processors as well as to compare one processor in two different sets of circumstances. When comparing two different processors, knowing the maximum frequency might be useful. Clueless me imagined that the frequency yabs reported would be the maximum.
I want to learn about how the frequency report varies, both in general, and specifically how the 5950X speed report apparently increases from 2185 MHz to 2700 MHz just because of moving from bare metal to "inside" a "bare metal LXC container." I mean, since "the container has no walls," how would merely changing the cgroups and the namespaces increase the processor frequency significantly? There must be more to the story!
Got it!
I've seen this multiple times. I should do an mtr.
swap reported by yabs as 5.0 GiB
That's right about @Ympker being involved! Whenever anything truly great turns up, we can find him there!
The container used for the tests is still around, so I looked at the Proxmox web GUI to see how much space had been assigned for swap. Here's what I saw:
@Mason You are the best! Thanks for paying such careful attention to my questions! Also, thanks yet again for all your help previously -- both to me personally and to the LES community! ?
@Not_Oles said: The container used for the tests is still around, so I looked at the Proxmox web GUI to see how much space had been assigned for swap. Here's what I saw:
I've not done much with LXC but the swap in proxmox could be presented as a swap partition - that could still be added to via a swapfile on the disk itself which could top up the swap to 5gb.
For example on my desktop I have:
$ sudo swapon
NAME TYPE SIZE USED PRIO
/dev/sda3 partition 1.9G 696.5M -2
/swapfile file 8G 0B -3
You could disable CPU frequency scaling at a BIOS level which would keep the processor at max frequency, although not max boost frequency so you'd still possible see different results. I guess for fairness you could try and take CPU speed while running the geekbench test, but that would need a second yabs process I imagine.
root@test-container:~# swapon
none virtual 5G 0B 0
root@test-container:~# mount | grep swap
lxcfs on /proc/swaps type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
On the same node:
root@Proxmox-VE ~ # swapon
/dev/md0 partition 16G 0B -2
root@Proxmox-VE ~ # mount | grep swap
root@Proxmox-VE ~ # mount | grep md0
root@Proxmox-VE ~ #
@Mason@Mr_Tom Based on the above, it looks like yabs is reporting the same number that swapon reports for the size of the swap. The number reported by yabs and swapon apparently can seem different from the size configured in Proxmox's GUI LXC container creation dialog.
I didn't notice this before! ?
Not technically a VPS. KVM VM deployed on a home server. Was just curious to see how it compares.
Half of the cores assigned to VM. (PN50 Mini pc form factor zen 2 4700U / 64gig / nvme). About 500 bucks worth of gear. Unsure why AES and AMD-V is disabled. Single core sucks cause it's essentially a laptop cpu. Surprised at the weak disk though
Is anyone aware of anything that could be done to improve the server's performance? I hope the performance could be as good as possible. Thanks!
cat /proc/cpuinfo). The reported clock will always be somewhere between the min and max frequency (inclusive). The more cores it has, the more likely some of those cores are idling and awaiting work (therefore more chance of a lower frequency being reported). Those frequencies are likely hitting the max clock of the CPU (or burst clock, if available) when it's geekbench crunching time.This I'm not so sure of. Ideally, the single core score should remain relatively the same no matter how many cores are allocated to the VM. For more concrete answers, I'd run more tests, as to me this looks to be within the margin of error to call all the single-core scores "somewhat equal".
Likely is baked into the LXC template that you used. But, for now, I'll blame @Ympker, because why not?
Hope the above helps more than it hurts!
 Cheers!
Humble janitor of LES
Proud papa of YABS
It's good to hear from you, too, mate! Hope you and your loved ones are doing well in these times
 Take care!
As for the swap allocation: Ofc it was my doing. I like messing with ppl's swap
Got it!
@Mr_Tom
Same container:
On the same node:
Different container on a different node:
root@metalvps:~# swapon NAME TYPE SIZE USED PRIO none virtual 6G 24K 0 root@metalvps:~# mount | grep swap lxcfs on /proc/swaps type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other) root@metalvps:~# root@metalvps:~# curl -sL yabs.sh | bash -s -- -9 # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-12-29 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sat Feb 13 00:17:23 UTC 2021 Basic System Information: --------------------------------- Processor : AMD Ryzen 7 3700X 8-Core Processor CPU cores : 4 @ 2228.414 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 4.0 GiB Swap : 6.0 GiB Disk : 49.0 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 774.83 MB/s (193.7k) | 1.10 GB/s (17.3k) Write | 776.88 MB/s (194.2k) | 1.11 GB/s (17.4k) Total | 1.55 GB/s (387.9k) | 2.22 GB/s (34.7k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.33 GB/s (4.5k) | 2.35 GB/s (2.3k) Write | 2.45 GB/s (4.7k) | 2.51 GB/s (2.4k) Total | 4.78 GB/s (9.3k) | 4.87 GB/s (4.7k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 942 Mbits/sec | 918 Mbits/sec Online.net | Paris, FR (10G) | 936 Mbits/sec | 900 Mbits/sec WorldStream | The Netherlands (10G) | 922 Mbits/sec | 930 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 685 Mbits/sec | 181 Mbits/sec Clouvider | NYC, NY, US (10G) | 879 Mbits/sec | 473 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 851 Mbits/sec | 469 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 803 Mbits/sec | 363 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 920 Mbits/sec | 903 Mbits/sec Online.net | Paris, FR (10G) | 927 Mbits/sec | 850 Mbits/sec WorldStream | The Netherlands (10G) | 913 Mbits/sec | 915 Mbits/sec Clouvider | NYC, NY, US (10G) | 879 Mbits/sec | 538 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 818 Mbits/sec | 353 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 5546 Multi Core | 12949 Full Test | https://browser.geekbench.com/v4/cpu/16040291 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1208 Multi Core | 3165 Full Test | https://browser.geekbench.com/v5/cpu/6472459 root@metalvps:~#@Mason @Mr_Tom Based on the above, it looks like yabs is reporting the same number that swapon reports for the size of the swap. The number reported by yabs and swapon apparently can seem different from the size configured in Proxmox's GUI LXC container creation dialog.
Ok... that I can't answer
 lol
Racknerd 1GB KVM VPS LEB Special
Sat Feb 13 18:15:03 IST 2021
Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz CPU cores : 1 @ 2799.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 987.2 MiB Swap : 525.0 MiB Disk : 16.1 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 68.05 MB/s (17.0k) | 1.06 GB/s (16.6k) Write | 68.24 MB/s (17.0k) | 1.06 GB/s (16.7k) Total | 136.30 MB/s (34.0k) | 2.13 GB/s (33.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.57 GB/s (3.0k) | 1.45 GB/s (1.4k) Write | 1.65 GB/s (3.2k) | 1.55 GB/s (1.5k) Total | 3.23 GB/s (6.3k) | 3.01 GB/s (2.9k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 793 Mbits/sec | 800 Mbits/sec Online.net | Paris, FR (10G) | 790 Mbits/sec | 795 Mbits/sec WorldStream | The Netherlands (10G) | 794 Mbits/sec | 795 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 505 Mbits/sec | 193 Mbits/sec Clouvider | NYC, NY, US (10G) | 746 Mbits/sec | 757 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 592 Mbits/sec | 523 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 684 Mbits/sec | 408 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 394 Mbits/sec | 259 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 741 Multi Core | 738 Full Test | https://browser.geekbench.com/v5/cpu/6481050HosterLabs 2GB KVM IPV6 special
Sat 13 Feb 2021 06:37:43 PM IST
Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) E-2288G CPU @ 3.70GHz CPU cores : 1 @ 3696.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 1.9 GiB Swap : 1024.0 MiB Disk : 28.5 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 278.80 MB/s (69.7k) | 3.12 GB/s (48.8k) Write | 279.54 MB/s (69.8k) | 3.14 GB/s (49.1k) Total | 558.34 MB/s (139.5k) | 6.26 GB/s (97.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 4.02 GB/s (7.8k) | 3.81 GB/s (3.7k) Write | 4.24 GB/s (8.2k) | 4.06 GB/s (3.9k) Total | 8.27 GB/s (16.1k) | 7.88 GB/s (7.6k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 1.75 Gbits/sec | 2.26 Gbits/sec Online.net | Paris, FR (10G) | 1.78 Gbits/sec | 2.18 Gbits/sec WorldStream | The Netherlands (10G) | 1.75 Gbits/sec | 2.11 Gbits/sec Biznet | Jakarta, Indonesia (1G) | 542 Mbits/sec | 10.2 Mbits/sec Clouvider | NYC, NY, US (10G) | 1.92 Gbits/sec | 4.79 Gbits/sec Velocity Online | Tallahassee, FL, US (10G) | 1.72 Gbits/sec | 3.33 Gbits/sec Clouvider | Los Angeles, CA, US (10G) | 1.79 Gbits/sec | 2.53 Gbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 147 Mbits/sec | 630 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 1.67 Gbits/sec | 2.25 Gbits/sec Online.net | Paris, FR (10G) | 1.74 Gbits/sec | 2.19 Gbits/sec WorldStream | The Netherlands (10G) | 1.76 Gbits/sec | 2.08 Gbits/sec Clouvider | NYC, NY, US (10G) | 1.89 Gbits/sec | 4.67 Gbits/sec Clouvider | Los Angeles, CA, US (10G) | 1.76 Gbits/sec | 2.53 Gbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1231 Multi Core | 1227 Full Test | https://browser.geekbench.com/v5/cpu/6481455@hosterlabs
Hostsolution 2GB 200GB
#https://github.com/masonr/yet-another-bench-script
Sat Feb 13 18:48:52 IST 2021
Processor : Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz
CPU cores : 2 @ 2397.222 MHz
AES-NI : ✔ Enabled
RAM : 1.9 GiB
Swap : 0.0 KiB
Disk : 196.8 GiB
fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 131.24 MB/s (32.8k) | 883.29 MB/s (13.8k) Write | 131.59 MB/s (32.8k) | 887.94 MB/s (13.8k) Total | 262.83 MB/s (65.7k) | 1.77 GB/s (27.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.05 GB/s (2.0k) | 1.13 GB/s (1.1k) Write | 1.11 GB/s (2.1k) | 1.21 GB/s (1.1k) Total | 2.16 GB/s (4.2k) | 2.35 GB/s (2.2k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 218 Mbits/sec | 295 Mbits/sec Online.net | Paris, FR (10G) | 748 Mbits/sec | 360 Mbits/sec WorldStream | The Netherlands (10G) | 794 Mbits/sec | 427 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 529 Mbits/sec | 60.5 Mbits/sec Clouvider | NYC, NY, US (10G) | 734 Mbits/sec | 192 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 655 Mbits/sec | 162 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 198 Mbits/sec | 92.8 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 604 Multi Core | 1181 Full Test | https://browser.geekbench.com/v5/cpu/6481689@cociu
Inception 1GB 1TB
Sat 13 Feb 19:10:58 IST 2021
Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2660 0 @ 2.20GHz CPU cores : 1 @ 2199.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 987.2 MiB Swap : 0.0 KiB Disk : 984.2 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 4.13 MB/s (1.0k) | 52.72 MB/s (823) Write | 4.15 MB/s (1.0k) | 53.18 MB/s (831) Total | 8.28 MB/s (2.0k) | 105.91 MB/s (1.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 78.96 MB/s (154) | 102.80 MB/s (100) Write | 83.15 MB/s (162) | 109.65 MB/s (107) Total | 162.12 MB/s (316) | 212.45 MB/s (207) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | busy | 412 Mbits/sec Online.net | Paris, FR (10G) | 669 Mbits/sec | 151 Mbits/sec WorldStream | The Netherlands (10G) | 832 Mbits/sec | 310 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 628 Mbits/sec | 118 Mbits/sec Clouvider | NYC, NY, US (10G) | 836 Mbits/sec | 535 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 830 Mbits/sec | 592 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 883 Mbits/sec | 918 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 728 Mbits/sec | 306 Mbits/sec@AnthonySmith
vserver 1GB 5GB
Sat Feb 13 19:02:57 IST 2021
Basic System Information: --------------------------------- Processor : AMD Opteron(tm) Processor 6380 CPU cores : 1 @ 2500.012 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 987.2 MiB Swap : 349.0 MiB Disk : 4.5 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 9.39 MB/s (2.3k) | 26.32 MB/s (411) Write | 9.42 MB/s (2.3k) | 26.79 MB/s (418) Total | 18.81 MB/s (4.7k) | 53.12 MB/s (829) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 94.96 MB/s (185) | 112.48 MB/s (109) Write | 100.00 MB/s (195) | 119.97 MB/s (117) Total | 194.96 MB/s (380) | 232.46 MB/s (226) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 904 Mbits/sec | 308 Mbits/sec Online.net | Paris, FR (10G) | 893 Mbits/sec | 287 Mbits/sec WorldStream | The Netherlands (10G) | 867 Mbits/sec | 286 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 630 Mbits/sec | 85.9 Mbits/sec Clouvider | NYC, NY, US (10G) | 823 Mbits/sec | 163 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 702 Mbits/sec | 185 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 811 Mbits/sec | 114 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | busy | busy Online.net | Paris, FR (10G) | 882 Mbits/sec | 278 Mbits/sec WorldStream | The Netherlands (10G) | 781 Mbits/sec | 280 Mbits/sec Clouvider | NYC, NY, US (10G) | 642 Mbits/sec | 157 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 792 Mbits/sec | 113 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 353 Multi Core | 351 Full Test | https://browser.geekbench.com/v5/cpu/6481954@vserversite
Webhorizon 512MB 7GB
Sat Feb 13 19:04:45 IST 2021
Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) E-2276G CPU @ 3.80GHz CPU cores : 1 @ 3791.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 512.0 MiB Swap : 0.0 KiB Disk : 6.9 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 36.26 MB/s (9.0k) | 174.46 MB/s (2.7k) Write | 36.36 MB/s (9.0k) | 175.38 MB/s (2.7k) Total | 72.62 MB/s (18.1k) | 349.84 MB/s (5.4k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 142.68 MB/s (278) | 124.26 MB/s (121) Write | 150.27 MB/s (293) | 132.54 MB/s (129) Total | 292.95 MB/s (571) | 256.81 MB/s (250) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 475 Mbits/sec | 577 Mbits/sec Online.net | Paris, FR (10G) | 377 Mbits/sec | 351 Mbits/sec WorldStream | The Netherlands (10G) | 458 Mbits/sec | 499 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 877 Mbits/sec | 909 Mbits/sec Clouvider | NYC, NY, US (10G) | 407 Mbits/sec | 236 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 366 Mbits/sec | 327 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 481 Mbits/sec | 429 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | busy | 223 Mbits/sec Online.net | Paris, FR (10G) | busy | 236 Mbits/sec WorldStream | The Netherlands (10G) | busy | 220 Mbits/sec Clouvider | NYC, NY, US (10G) | busy | 201 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | busy | 203 Mbits/sec@Abdullah
Debian KVM on Hetzner Ax101
debian@debian-kvm:~$ date -u Sat 13 Feb 2021 08:36:08 PM UTC debian@debian-kvm:~$ curl -sL yabs.sh | bash -s -- -9 # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-12-29 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sat 13 Feb 2021 01:36:12 PM MST Basic System Information: --------------------------------- Processor : AMD Ryzen 9 5950X 16-Core Processor CPU cores : 4 @ 3393.624 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 3.9 GiB Swap : 975.0 MiB Disk : 194.9 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 360.72 MB/s (90.1k) | 1.46 GB/s (22.9k) Write | 361.68 MB/s (90.4k) | 1.47 GB/s (23.0k) Total | 722.40 MB/s (180.6k) | 2.94 GB/s (45.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.51 GB/s (2.9k) | 1.48 GB/s (1.4k) Write | 1.59 GB/s (3.1k) | 1.58 GB/s (1.5k) Total | 3.11 GB/s (6.0k) | 3.07 GB/s (3.0k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 942 Mbits/sec | busy Online.net | Paris, FR (10G) | 932 Mbits/sec | 933 Mbits/sec WorldStream | The Netherlands (10G) | 929 Mbits/sec | 937 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 720 Mbits/sec | 240 Mbits/sec Clouvider | NYC, NY, US (10G) | 78.7 Mbits/sec | 458 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 828 Mbits/sec | 500 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 670 Mbits/sec | 324 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 6479 Multi Core | 19697 Full Test | https://browser.geekbench.com/v4/cpu/16041450 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1471 Multi Core | 4834 Full Test | https://browser.geekbench.com/v5/cpu/6488317 debian@debian-kvm:~$Tom. 穆坦然. Not Oles. Happy New York City guy visiting Mexico! How is your 文言文?
Dedicated KVM Slice 512MB BuyVM Luxembourg Debian 10
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-12-29 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sun Feb 14 03:40:52 CET 2021 Basic System Information: --------------------------------- Processor : AMD Ryzen 9 3900X 12-Core Processor CPU cores : 1 @ 3792.872 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 483.2 MiB Swap : 512.0 MiB Disk : 9.3 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 122.57 MB/s (30.6k) | 390.67 MB/s (6.1k) Write | 122.90 MB/s (30.7k) | 392.72 MB/s (6.1k) Total | 245.48 MB/s (61.3k) | 783.39 MB/s (12.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 488.14 MB/s (953) | 514.72 MB/s (502) Write | 514.07 MB/s (1.0k) | 549.00 MB/s (536) Total | 1.00 GB/s (1.9k) | 1.06 GB/s (1.0k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 1.12 Gbits/sec | 586 Mbits/sec Online.net | Paris, FR (10G) | 1.12 Gbits/sec | 860 Mbits/sec WorldStream | The Netherlands (10G) | 1.12 Gbits/sec | 774 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 691 Mbits/sec | 382 Mbits/sec Clouvider | NYC, NY, US (10G) | 1.03 Gbits/sec | 205 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 336 Mbits/sec | 208 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 808 Mbits/sec | 231 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 63.5 Mbits/sec | 117 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 1.10 Gbits/sec | 320 Mbits/sec Online.net | Paris, FR (10G) | 1.11 Gbits/sec | 615 Mbits/sec WorldStream | The Netherlands (10G) | 1.02 Gbits/sec | 773 Mbits/sec Clouvider | NYC, NY, US (10G) | 45.7 Mbits/sec | 112 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 522 Kbits/sec | 21.4 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 983 Multi Core | 970 Full Test | https://browser.geekbench.com/v5/cpu/6492011taking Avoro Winter Deal 2019 for another spin, seems like it's time to put it back in production. less steal now than before:
Webhosting24 10x10x10 Special
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-12-29 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sun 14 Feb 2021 10:22:11 AM UTC Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz CPU cores : 1 @ 2399.996 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 981.2 MiB Swap : 0.0 KiB Disk : 9.8 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 263.14 MB/s (65.7k) | 2.72 GB/s (42.5k) Write | 263.84 MB/s (65.9k) | 2.73 GB/s (42.7k) Total | 526.98 MB/s (131.7k) | 5.46 GB/s (85.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 3.16 GB/s (6.1k) | 3.52 GB/s (3.4k) Write | 3.33 GB/s (6.5k) | 3.75 GB/s (3.6k) Total | 6.49 GB/s (12.6k) | 7.28 GB/s (7.1k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 838 Mbits/sec | 459 Mbits/sec Online.net | Paris, FR (10G) | 919 Mbits/sec | 437 Mbits/sec WorldStream | The Netherlands (10G) | 945 Mbits/sec | 509 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 291 Mbits/sec | 33.3 Mbits/sec Clouvider | NYC, NY, US (10G) | 342 Mbits/sec | 89.5 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 182 Mbits/sec | 71.5 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 358 Mbits/sec | 59.3 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | 69.7 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 390 Mbits/sec | 384 Mbits/sec Online.net | Paris, FR (10G) | 392 Mbits/sec | 460 Mbits/sec WorldStream | The Netherlands (10G) | 337 Mbits/sec | 491 Mbits/sec Clouvider | NYC, NY, US (10G) | 117 Mbits/sec | 77.3 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 94.9 Mbits/sec | 116 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 736 Multi Core | 732 Full Test | https://browser.geekbench.com/v5/cpu/6497422No matter how beautiful a bench looks, it can never beat nature for me.
Facts!!
The disk IO seems much lower than our other KVMs at Singapore, canyou create a ticket so I can look, or PM regd. email ?
ticket #7977790 made
and closed due to super fast response by @Abdullah
replied, seems like a confusion on my part. This is an OVZ NAT vps. sorry!
Dubai $5/m
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-12-29 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri Feb 19 01:19:37 +04 2021 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) Gold 6226R CPU @ 2.90GHz CPU cores : 1 @ 2893.200 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 990.9 MiB Swap : 2.0 GiB Disk : 19.6 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 417.79 MB/s (104.4k) | 3.73 GB/s (58.3k) Write | 418.89 MB/s (104.7k) | 3.75 GB/s (58.6k) Total | 836.68 MB/s (209.1k) | 7.48 GB/s (117.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 4.48 GB/s (8.7k) | 4.29 GB/s (4.1k) Write | 4.72 GB/s (9.2k) | 4.57 GB/s (4.4k) Total | 9.21 GB/s (18.0k) | 8.86 GB/s (8.6k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | busy | busy Online.net | Paris, FR (10G) | 868 Mbits/sec | 873 Mbits/sec WorldStream | The Netherlands (10G) | 847 Mbits/sec | 866 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 604 Mbits/sec | 87.9 Mbits/sec Clouvider | NYC, NY, US (10G) | busy | busy Velocity Online | Tallahassee, FL, US (10G) | 592 Mbits/sec | busy Clouvider | Los Angeles, CA, US (10G) | busy | busy Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 4179 Multi Core | 4100 Full Test | https://browser.geekbench.com/v4/cpu/16048612 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 955 Multi Core | 957 Full Test | https://browser.geekbench.com/v5/cpu/6575830TerraHost i3 BF 500gb HDD replaced with 2TB ssd
root@yeah:~# curl -sL yabs.sh | bash -s -- -9 # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-12-29 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri 19 Feb 2021 06:28:46 AM WIB Basic System Information: --------------------------------- Processor : Intel(R) Core(TM) i3-4130 CPU @ 3.40GHz CPU cores : 4 @ 2891.187 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 3.7 GiB Swap : 92.0 MiB Disk : 1.8 TiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 151.11 MB/s (37.7k) | 169.99 MB/s (2.6k) Write | 151.50 MB/s (37.8k) | 170.89 MB/s (2.6k) Total | 302.61 MB/s (75.6k) | 340.88 MB/s (5.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 217.58 MB/s (424) | 237.29 MB/s (231) Write | 229.14 MB/s (447) | 253.09 MB/s (247) Total | 446.72 MB/s (871) | 490.38 MB/s (478) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | busy | busy Online.net | Paris, FR (10G) | 914 Mbits/sec | 623 Mbits/sec WorldStream | The Netherlands (10G) | 921 Mbits/sec | 888 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 559 Mbits/sec | 22.3 Mbits/sec Clouvider | NYC, NY, US (10G) | busy | busy Velocity Online | Tallahassee, FL, US (10G) | 849 Mbits/sec | 346 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | busy | busy Iveloz Telecom | Sao Paulo, BR (2G) | 739 Mbits/sec | 156 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 3908 Multi Core | 7239 Full Test | https://browser.geekbench.com/v4/cpu/16048695 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 872 Multi Core | 1768 Full Test | https://browser.geekbench.com/v5/cpu/6576915After a lot of back and forth with @Not_Oles (for all good reasons!)
Sat Feb 20 06:04:39 UTC 2021 Basic System Information: --------------------------------- Processor : AMD Ryzen 9 5950X 16-Core Processor CPU cores : 4 @ 2192.292 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 4.0 GiB Swap : 4.5 GiB Disk : 97.9 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 945.54 MB/s (236.3k) | 2.54 GB/s (39.8k) Write | 948.04 MB/s (237.0k) | 2.56 GB/s (40.0k) Total | 1.89 GB/s (473.3k) | 5.10 GB/s (79.8k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 955.06 MB/s (1.8k) | 3.27 GB/s (3.2k) Write | 1.00 GB/s (1.9k) | 3.49 GB/s (3.4k) Total | 1.96 GB/s (3.8k) | 6.77 GB/s (6.6k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | busy | busy Online.net | Paris, FR (10G) | 947 Mbits/sec | 919 Mbits/sec Clouvider | NYC, NY, US (10G) | busy | busy iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | busy | busy Online.net | Paris, FR (10G) | 936 Mbits/sec | 924 Mbits/sec Clouvider | NYC, NY, US (10G) | busy | busy Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 6516 Multi Core | 19541 Full Test | https://browser.geekbench.com/v4/cpu/16050385 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1497 Multi Core | 4746 Full Test | https://browser.geekbench.com/v5/cpu/6597804VPS reviews | | MicroLXC | English is my nth language.
Shot in a ticket to have Clouvider check out their iperf servers.
Considering reducing the number of retries so when iperf servers aren't operational the script doesn't take forever to run
Proud papa of YABS
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-12-29 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sat 20 Feb 2021 02:13:15 PM UTC Basic System Information: --------------------------------- Processor : Common KVM processor CPU cores : 4 @ 1996.269 MHz AES-NI : ❌ Disabled VM-x/AMD-V : ❌ Disabled RAM : 3.9 GiB Swap : 0.0 KiB Disk : 9.8 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 123.27 MB/s (30.8k) | 518.63 MB/s (8.1k) Write | 123.59 MB/s (30.8k) | 521.36 MB/s (8.1k) Total | 246.86 MB/s (61.7k) | 1.04 GB/s (16.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 228.20 MB/s (445) | 217.90 MB/s (212) Write | 240.32 MB/s (469) | 232.41 MB/s (226) Total | 468.53 MB/s (914) | 450.32 MB/s (438) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | busy | busy Online.net | Paris, FR (10G) | 877 Mbits/sec | 695 Mbits/sec WorldStream | The Netherlands (10G) | 915 Mbits/sec | 688 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 291 Mbits/sec | 79.7 Mbits/sec Clouvider | NYC, NY, US (10G) | busy | busy Velocity Online | Tallahassee, FL, US (10G) | 826 Mbits/sec | 494 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | busy | busy Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | busy | busy Online.net | Paris, FR (10G) | 904 Mbits/sec | 591 Mbits/sec WorldStream | The Netherlands (10G) | 856 Mbits/sec | 690 Mbits/sec Clouvider | NYC, NY, US (10G) | busy | busy Clouvider | Los Angeles, CA, US (10G) | busy | busy Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 995 Multi Core | 3359pretty good actually for GB5
Yeah pretty happy with it. Low power (10W idle), 8 core & loads of mem makes it a good always on proxmox machine for gitlab, pihole etc
@vyas @cybertech @Mason @Everybody
