Is anyone aware of anything that could be done to improve the server's performance? I hope the performance could be as good as possible. Thanks!
that point being smart was pretty much self-proclaimed. perhaps RaveX could shed some light since he has same thing running. the GB4 single core is pretty good.
also again, if there's a chance to compare kernel 5.11 Vs proxmox 5.4.....
@corbpie said:
Has 1500 been passed on GB5 single?
Out of curiosity I ran another YABS (GB5 only). Close to breaking the 4 minute mile record but not quite Roger Bannister.
Multi seems to have dropped too.
https://capnhatuudai.com/en/ - Personal blog sharing promotion information, Domain Name Coupons, Hosting, VPS / Server, WordPress and the latest experiences and news from service providers around the world.
Guys! I still don't understand why there should be such a big difference in single core performance, just under 1500 inside the container, versus just over 1700 outside, of the container. The test result difference of approximately 200 is greater than 10%. Why would using cgroups and namespaces cause a greater than 10% difference in the test performance? Thanks!
To match @vyas, I ran another yabs on the node to test the consistency of the single core score on the bare metal AX101.
The GB single core last time was 1719. This time 1710.
The other thing that was consistent on this particular test were the busy signals on the IPv4 iperf tests. Looks like Sunday evening in Mexico / early Monday morning in Europe might not be the best time for yabs iperf testing of IPv4 performance. IPv6 was wide open, though!
The above figure shows the graph for 66% load CPU utilization for Mixed load operation. 66% load is determined by op rate while running mixed load operation which stresses on 11GB data in the Cassandra cluster and 150 threads are given in the Cassandra stress command. The above graph shows the average values of CPU utilization for 10 iterations. It shows Cassandra utilizes more CPU usage on Linux Containers than Cassandra on bare metal in both 100% load and 66% load cases. Highest CPU usage on Linux Container is 88.93%. Highest CPU usage on bare metal is 71.77%.
That's a 17% difference in favor of LXC over bare metal on this test! So a lot depends on the test being used.
But I still would like to know more about why the Geekbench 5 disfavors LXC versus bare metal.
Apologies for possibly distracting the thread away from @Mason's lovely yabs. ⭐
@Not_Oles said: That's a 17% difference in favor of LXC over bare metal on this test!
Please correct me if I'm wrong, but doesn't the above indicate that the 17% CPU utilization difference is in favor of bare metal over LXC (the lower the CPU utilization, the better)? Basically the task uses 71.77% of the CPU on bare metal, but the same task uses 88.93% of the CPU when run in a container -- meaning the 17% difference is the CPU working harder (and having more overhead) within the container. At least that's how I'm interpreting the results.
Thank you! I was imagining it meant that LXC got more work done because it utilized the CPU for a longer time, i.e., higher CPU utilization and lower the idle time, the better.
@Abdullah said: @Not_Oles looks excellent already! can try set disk cache to writeback too.
Bad idea, unless your cache device is redundant and hopefully backed by some kind of battery sir.
yes...so do we should set it to writethrough ?
In proxmox, there is a 'writeback' & a 'writeback (unsafe)' option. I wonder if they are different, you have any idea @Not_Oles ?
I also read at another place virtualizor uses writeback in default cache option, with some 'optimizations'...not sure if they have a way to safely use writeback.
sorry to OP for being offtopic here, do you use virtualizor? can it work with kernel 5.11 in production?
hostvds
$1.59 per mth
don't be fooled by "data centers", only Russia available
performance wise, really crap bad throttled CPU (imagine virmach being virmached)
the score is GB4 not GB5!!!!!!
take hours to install simple webserver panel complete
Yabs inside a Proxmox KVM. Bare metal is running 5.4.98-1-pve. The kernel in the KVM was updated to the latest Proxmox-edge-kernel, 5.11.2-1-pve.
With 5.11.2-1-pve the KVM single core GB score was 1736.
Previously, on the bare metal, the GB single core score was 1719. That 1719 was with whatever kernel preceded the current stable Proxmox kernel, 5.4.98-1-pve.
It seems that the performance of the 5.11 kernel might be improved compared to 5.4. Unless I'm confused, which happens often. Luckily I have you guys to catch my mistakes!
^^^ the iperfs are looking impressively stable
1719
Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1483 Multi Core | 3519 Full Test | https://browser.geekbench.com/v5/cpu/6615273VPS reviews | | MicroLXC | English is my nth language.
drServer - Intel® Atom™ C2750 (4-Core, 2.4GHz) 8GB DDR3 1x 200GB SSD 13usd/m
root@sv:~# curl -sL yabs.sh | bash -s -- -9
# Yet-Another-Bench-Script #
# v2020-12-29 #
Sun 21 Feb 2021 01:34:55 AM EST Basic System Information: --------------------------------- Processor : Intel(R) Atom(TM) CPU C2750 @ 2.41GHz CPU cores : 4 @ 2449.889 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 7.7 GiB Swap : 977.0 MiB Disk : 181.4 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 15.32 MB/s (3.8k) | 58.55 MB/s (914) Write | 15.33 MB/s (3.8k) | 59.12 MB/s (923) Total | 30.66 MB/s (7.6k) | 117.68 MB/s (1.8k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 48.39 MB/s (94) | 75.66 MB/s (73) Write | 50.90 MB/s (99) | 80.70 MB/s (78) Total | 99.29 MB/s (193) | 156.36 MB/s (151) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | busy | busy Online.net | Paris, FR (10G) | 869 Mbits/sec | 223 Mbits/sec WorldStream | The Netherlands (10G) | 861 Mbits/sec | 227 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 404 Mbits/sec | 43.4 Mbits/sec Clouvider | NYC, NY, US (10G) | busy | busy Velocity Online | Tallahassee, FL, US (10G) | 927 Mbits/sec | 234 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | busy | busy Iveloz Telecom | Sao Paulo, BR (2G) | 822 Mbits/sec | 178 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 1276 Multi Core | 3952 Full Test | https://browser.geekbench.com/v4/cpu/16051854 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 260 Multi Core | 923 Full Test | https://browser.geekbench.com/v5/cpu/6616053https://capnhatuudai.com/en/ - Personal blog sharing promotion information, Domain Name Coupons, Hosting, VPS / Server, WordPress and the latest experiences and news from service providers around the world.
Abnormal disk speeds...
## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-12-29 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sun Feb 21 10:58:40 PST 2021 Basic System Information: --------------------------------- Processor : AMD Ryzen 9 3900X 12-Core Processor CPU cores : 1 @ 3792.874 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 985.4 MiB Swap : 0.0 KiB Disk : 14.7 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 475.88 MB/s (118.9k) | 3.93 GB/s (61.5k) Write | 477.14 MB/s (119.2k) | 3.95 GB/s (61.8k) Total | 953.03 MB/s (238.2k) | 7.89 GB/s (123.4k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 4.77 GB/s (9.3k) | 4.43 GB/s (4.3k) Write | 5.02 GB/s (9.8k) | 4.72 GB/s (4.6k) Total | 9.79 GB/s (19.1k) | 9.15 GB/s (8.9k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 924 Mbits/sec | 608 Mbits/sec Online.net | Paris, FR (10G) | 909 Mbits/sec | 444 Mbits/sec WorldStream | The Netherlands (10G) | 938 Mbits/sec | 936 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 355 Mbits/sec | 104 Mbits/sec Clouvider | NYC, NY, US (10G) | 676 Mbits/sec | 194 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 24.4 Mbits/sec | 127 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 344 Mbits/sec | 327 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 295 Mbits/sec | 146 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 375 Mbits/sec | 418 Mbits/sec Online.net | Paris, FR (10G) | 357 Mbits/sec | 459 Mbits/sec WorldStream | The Netherlands (10G) | 705 Mbits/sec | 838 Mbits/sec Clouvider | NYC, NY, US (10G) | 130 Mbits/sec | 243 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 139 Mbits/sec | 252 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1237 Multi Core | 1236 Full Test | https://browser.geekbench.com/v5/cpu/6625825Guys! I still don't understand why there should be such a big difference in single core performance, just under 1500 inside the container, versus just over 1700 outside, of the container. The test result difference of approximately 200 is greater than 10%. Why would using cgroups and namespaces cause a greater than 10% difference in the test performance? Thanks!
root@Proxmox-VE ~ # curl -sL yabs.sh | bash -s -- -9 # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-12-29 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon 22 Feb 2021 02:34:31 AM UTC Basic System Information: --------------------------------- Processor : AMD Ryzen 9 5950X 16-Core Processor CPU cores : 32 @ 2195.705 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 125.8 GiB Swap : 16.0 GiB Disk : 3.4 TiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 556.72 MB/s (139.1k) | 1.47 GB/s (22.9k) Write | 558.19 MB/s (139.5k) | 1.47 GB/s (23.1k) Total | 1.11 GB/s (278.7k) | 2.94 GB/s (46.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.50 GB/s (2.9k) | 1.50 GB/s (1.4k) Write | 1.59 GB/s (3.1k) | 1.60 GB/s (1.5k) Total | 3.10 GB/s (6.0k) | 3.11 GB/s (3.0k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | busy | busy Online.net | Paris, FR (10G) | busy | busy WorldStream | The Netherlands (10G) | busy | 914 Mbits/sec Biznet | Jakarta, Indonesia (1G) | busy | busy Clouvider | NYC, NY, US (10G) | busy | busy Velocity Online | Tallahassee, FL, US (10G) | busy | 39.1 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | busy | 279 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 919 Mbits/sec | 919 Mbits/sec Online.net | Paris, FR (10G) | 923 Mbits/sec | 924 Mbits/sec WorldStream | The Netherlands (10G) | 921 Mbits/sec | 923 Mbits/sec Clouvider | NYC, NY, US (10G) | 872 Mbits/sec | 426 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 818 Mbits/sec | 231 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 7283 Multi Core | 64571 Full Test | https://browser.geekbench.com/v4/cpu/16052962 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1710 Multi Core | 15316 Full Test | https://browser.geekbench.com/v5/cpu/6630343 root@Proxmox-VE ~ #Tom. 穆坦然. Not Oles. Happy New York City guy visiting Mexico! How is your 文言文?
Wow! In at least one test LXC actually beats bare metal! I wasn't expecting that!
Here is Figure 9 from Reventh Thiruvallur Vangeepuram's thesis, Performance Comparison of Cassandra in LXC and Bare metal:
@vyas
Humble janitor of LES
Proud papa of YABS
$7 256MB 5GB NAT Singapore
Tue Feb 23 08:07:37 IST 2021 Basic System Information: --------------------------------- Processor : Intel Core Processor (Broadwell, IBRS) CPU cores : 1 @ 3599.996 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 256.0 MiB Swap : 0.0 KiB Disk : 4.9 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 41.13 MB/s (10.2k) | 93.54 MB/s (1.4k) Write | 41.21 MB/s (10.3k) | 94.03 MB/s (1.4k) Total | 82.34 MB/s (20.5k) | 187.58 MB/s (2.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 41.95 MB/s (81) | 126.48 MB/s (123) Write | 44.37 MB/s (86) | 134.90 MB/s (131) Total | 86.33 MB/s (167) | 261.39 MB/s (254) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 760 Mbits/sec | 804 Mbits/sec Online.net | Paris, FR (10G) | 707 Mbits/sec | 665 Mbits/sec WorldStream | The Netherlands (10G) | busy | busy Biznet | Jakarta, Indonesia (1G) | 908 Mbits/sec | 901 Mbits/sec Clouvider | NYC, NY, US (10G) | 643 Mbits/sec | 645 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 623 Mbits/sec | 548 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 790 Mbits/sec | 255 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 63.7 Mbits/sec | 237 Mbits/sec Online.net | Paris, FR (10G) | 44.6 Mbits/sec | 282 Mbits/sec WorldStream | The Netherlands (10G) | 44.5 Mbits/sec | 430 Mbits/sec Clouvider | NYC, NY, US (10G) | 61.8 Mbits/sec | 278 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 50.5 Mbits/sec | 51.3 Mbits/sec@mikho
$7 512MB 7GB NAT Singapore
Tue Feb 23 00:05:46 IST 2021 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E3-1270 v6 @ 3.80GHz CPU cores : 1 @ 4005.725 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 512.0 MiB Swap : 0.0 KiB Disk : 6.9 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 1.02 MB/s (256) | 5.83 MB/s (91) Write | 1.05 MB/s (264) | 6.16 MB/s (96) Total | 2.08 MB/s (520) | 11.99 MB/s (187) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 17.09 MB/s (33) | 31.85 MB/s (31) Write | 18.41 MB/s (35) | 34.74 MB/s (33) Total | 35.50 MB/s (68) | 66.60 MB/s (64) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 369 Mbits/sec | 564 Mbits/sec Online.net | Paris, FR (10G) | 153 Mbits/sec | 722 Mbits/sec WorldStream | The Netherlands (10G) | busy | busy Biznet | Jakarta, Indonesia (1G) | 408 Mbits/sec | 248 Mbits/sec Clouvider | NYC, NY, US (10G) | 218 Mbits/sec | 144 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 241 Mbits/sec | 344 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 309 Mbits/sec | 1.60 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 371 Mbits/sec | 1.76 Mbits/sec Online.net | Paris, FR (10G) | 427 Mbits/sec | 823 Mbits/sec WorldStream | The Netherlands (10G) | busy | 1.65 Mbits/sec Clouvider | NYC, NY, US (10G) | 374 Mbits/sec | 1.59 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 420 Mbits/sec | 3.48 Mbits/sec@Abdullah
I use proxmox+virtualizor & kernel is 5.4
hostvds
$1.59 per mth
Cape Town ZappieHost
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-12-29 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Thu Feb 25 15:05:52 UTC 2021 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2620 v4 @ 2.10GHz CPU cores : 4 @ 2099.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 3.8 GiB Swap : 0.0 KiB Disk : 9.8 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 30.34 MB/s (7.5k) | 275.32 MB/s (4.3k) Write | 30.37 MB/s (7.5k) | 276.77 MB/s (4.3k) Total | 60.72 MB/s (15.1k) | 552.09 MB/s (8.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 350.76 MB/s (685) | 256.55 MB/s (250) Write | 369.40 MB/s (721) | 273.63 MB/s (267) Total | 720.17 MB/s (1.4k) | 530.18 MB/s (517) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 82.5 Mbits/sec | 83.1 Mbits/sec Online.net | Paris, FR (10G) | 83.9 Mbits/sec | 81.3 Mbits/sec WorldStream | The Netherlands (10G) | 81.1 Mbits/sec | 70.1 Mbits/sec Biznet | Jakarta, Indonesia (1G) | busy | busy Clouvider | NYC, NY, US (10G) | 77.5 Mbits/sec | 72.1 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 74.7 Mbits/sec | 58.9 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | busy | 58.0 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | 38.1 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 82.2 Mbits/sec | 82.0 Mbits/sec Online.net | Paris, FR (10G) | 80.1 Mbits/sec | 82.7 Mbits/sec WorldStream | The Netherlands (10G) | 79.2 Mbits/sec | 82.3 Mbits/sec Clouvider | NYC, NY, US (10G) | 76.9 Mbits/sec | 73.7 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | busy | 13.4 Mbits/sec Running GB5 benchmark test... *cue elevator music* Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 619 Multi Core | 2194 Full Test | https://browser.geekbench.com/v5/cpu/6686011Free NAT KVM | Free NAT LXC
Auckland ZappieHost
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-12-29 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Thu Feb 25 15:06:01 UTC 2021 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2650L v2 @ 1.70GHz CPU cores : 6 @ 1699.999 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 3.8 GiB Swap : 0.0 KiB Disk : 10.0 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 67.16 MB/s (16.7k) | 508.54 MB/s (7.9k) Write | 67.31 MB/s (16.8k) | 511.22 MB/s (7.9k) Total | 134.48 MB/s (33.6k) | 1.01 GB/s (15.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 748.30 MB/s (1.4k) | 801.25 MB/s (782) Write | 788.06 MB/s (1.5k) | 854.61 MB/s (834) Total | 1.53 GB/s (3.0k) | 1.65 GB/s (1.6k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 467 Mbits/sec | 70.2 Mbits/sec Online.net | Paris, FR (10G) | busy | 844 Kbits/sec WorldStream | The Netherlands (10G) | busy | 739 Kbits/sec Biznet | Jakarta, Indonesia (1G) | busy | busy Clouvider | NYC, NY, US (10G) | 371 Mbits/sec | 124 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 323 Mbits/sec | 93.3 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 576 Mbits/sec | 115 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 406 Mbits/sec | 96.8 Mbits/sec Online.net | Paris, FR (10G) | 416 Mbits/sec | 122 Mbits/sec WorldStream | The Netherlands (10G) | busy | 90.8 Mbits/sec Clouvider | NYC, NY, US (10G) | 531 Mbits/sec | 72.3 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 589 Mbits/sec | 21.6 Mbits/sec Running GB5 benchmark test... *cue elevator music* Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 432 Multi Core | 2383 Full Test | https://browser.geekbench.com/v5/cpu/6686038Free NAT KVM | Free NAT LXC
Nice CPU and network, but SAS is very low
... Netcup RS 2000 G8 SAS
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-12-29 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Thu Feb 25 17:54:09 WET 2021 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) Gold 6140 CPU @ 2.30GHz CPU cores : 4 @ 2294.598 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 15.5 GiB Swap : 2.0 GiB Disk : 458.6 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 1.66 MB/s (415) | 20.98 MB/s (327) Write | 1.69 MB/s (423) | 21.50 MB/s (336) Total | 3.35 MB/s (838) | 42.48 MB/s (663) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 85.21 MB/s (166) | 141.34 MB/s (138) Write | 89.73 MB/s (175) | 150.75 MB/s (147) Total | 174.95 MB/s (341) | 292.10 MB/s (285) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 811 Mbits/sec | 951 Mbits/sec Online.net | Paris, FR (10G) | 890 Mbits/sec | 945 Mbits/sec Clouvider | NYC, NY, US (10G) | 644 Mbits/sec | 600 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 877 Mbits/sec | 934 Mbits/sec Online.net | Paris, FR (10G) | 803 Mbits/sec | 659 Mbits/sec Clouvider | NYC, NY, US (10G) | 610 Mbits/sec | 644 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 651 Multi Core | 1865 Full Test | https://browser.geekbench.com/v5/cpu/6688056fio Disk Speed Tests 64k (IOPS) has doubled
Thu Feb 25 23:53:02 IST 2021 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz CPU cores : 2 @ 2397.222 MHz AES-NI : Enabled VM-x/AMD-V : Disabled RAM : 1.9 GiB Swap : 0.0 KiB Disk : 196.8 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 176.04 MB/s (44.0k) | 1.04 GB/s (16.3k) Write | 176.50 MB/s (44.1k) | 1.05 GB/s (16.4k) Total | 352.55 MB/s (88.1k) | 2.10 GB/s (32.8k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 975.12 MB/s (1.9k) | 1.10 GB/s (1.0k) Write | 1.02 GB/s (2.0k) | 1.18 GB/s (1.1k) Total | 2.00 GB/s (3.9k) | 2.28 GB/s (2.2k)Netcup RS1000G9
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-12-29 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Thu 25 Feb 2021 07:32:39 PM CET Basic System Information: --------------------------------- Processor : AMD EPYC 7702P 64-Core Processor CPU cores : 2 @ 1996.250 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 7.8 GiB Swap : 0.0 KiB Disk : 157.4 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 172.46 MB/s (43.1k) | 1.87 GB/s (29.3k) Write | 172.91 MB/s (43.2k) | 1.88 GB/s (29.4k) Total | 345.37 MB/s (86.3k) | 3.76 GB/s (58.8k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 3.63 GB/s (7.0k) | 3.63 GB/s (3.5k) Write | 3.82 GB/s (7.4k) | 3.87 GB/s (3.7k) Total | 7.46 GB/s (14.5k) | 7.50 GB/s (7.3k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 1.73 Gbits/sec | 2.37 Gbits/sec Online.net | Paris, FR (10G) | 1.69 Gbits/sec | 2.37 Gbits/sec Clouvider | NYC, NY, US (10G) | 735 Mbits/sec | 1.81 Gbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 1.36 Gbits/sec | 2.32 Gbits/sec Online.net | Paris, FR (10G) | 1.19 Gbits/sec | 2.32 Gbits/sec Clouvider | NYC, NY, US (10G) | 802 Mbits/sec | 1.56 Gbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1045 Multi Core | 2079 Full Test | https://browser.geekbench.com/v5/cpu/6688557Nexusbytes from new NL location.
It's too premium to keep for idling.
Basic System Information: --------------------------------- Processor : AMD Ryzen 9 3900X 12-Core Processor CPU cores : 1 @ 3792.874 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 981.2 MiB Swap : 0.0 KiB Disk : 19.6 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 501.40 MB/s (125.3k) | 4.08 GB/s (63.8k) Write | 502.73 MB/s (125.6k) | 4.10 GB/s (64.1k) Total | 1.00 GB/s (251.0k) | 8.19 GB/s (127.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 4.54 GB/s (8.8k) | 4.29 GB/s (4.1k) Write | 4.79 GB/s (9.3k) | 4.57 GB/s (4.4k) Total | 9.34 GB/s (18.2k) | 8.86 GB/s (8.6k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 934 Mbits/sec | 928 Mbits/sec Online.net | Paris, FR (10G) | 935 Mbits/sec | 903 Mbits/sec WorldStream | The Netherlands (10G) | 937 Mbits/sec | 935 Mbits/sec Biznet | Jakarta, Indonesia (1G) | busy | busy Clouvider | NYC, NY, US (10G) | 820 Mbits/sec | 516 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 677 Mbits/sec | 472 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 433 Mbits/sec | 327 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 401 Mbits/sec | 237 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 576 Mbits/sec | 902 Mbits/sec Online.net | Paris, FR (10G) | 607 Mbits/sec | 915 Mbits/sec WorldStream | The Netherlands (10G) | 847 Mbits/sec | 927 Mbits/sec Clouvider | NYC, NY, US (10G) | 334 Mbits/sec | 490 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 302 Mbits/sec | 404 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1233 Multi Core | 1219 Full Test | https://browser.geekbench.com/v5/cpu/6695833ApeWeb VM2
Fri 26 Feb 2021 06:33:34 PM CET Basic System Information: --------------------------------- Processor : AMD Ryzen 5 2600 Six-Core Processor CPU cores : 2 @ 3393.622 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 981.0 MiB Swap : 200.0 MiB Disk : 24.4 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 47.11 MB/s (11.7k) | 162.53 MB/s (2.5k) Write | 47.21 MB/s (11.8k) | 163.38 MB/s (2.5k) Total | 94.32 MB/s (23.5k) | 325.92 MB/s (5.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 547.39 MB/s (1.0k) | 618.39 MB/s (603) Write | 576.48 MB/s (1.1k) | 659.57 MB/s (644) Total | 1.12 GB/s (2.1k) | 1.27 GB/s (1.2k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 934 Mbits/sec | 869 Mbits/sec Online.net | Paris, FR (10G) | 929 Mbits/sec | busy WorldStream | The Netherlands (10G) | 925 Mbits/sec | 927 Mbits/sec Biznet | Jakarta, Indonesia (1G) | busy | busy Clouvider | NYC, NY, US (10G) | 883 Mbits/sec | 682 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 850 Mbits/sec | 496 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 782 Mbits/sec | 602 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy Geekbench 5 Benchmark Test: --------------------------------- Test | Value Single Core | 1077 Multi Core | 2049 Full Test | https://browser.geekbench.com/v5/cpu/6703280Nexus Bytes Ryzen Powered NVMe VPS | NYC|Miami|LA|London|Netherlands| Singapore|Tokyo
What else can I do as first command on my new VM? Oh yes, we will run a YABS of course! (It's also the last command it will run on that install!)
naranja.tech KVM-NVME-16GB - NEW YEAR OFFER
`# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #` `# Yet-Another-Bench-Script #` `# v2020-12-29 #` `# https://github.com/masonr/yet-another-bench-script #` `# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #` Fri 26 Feb 2021 09:09:47 PM CET Basic System Information: --------------------------------- Processor : AMD EPYC 7452 32-Core Processor CPU cores : 8 @ 2349.992 MHz AES-NI : ? Enabled VM-x/AMD-V : ? Disabled RAM : 15.6 GiB Swap : 255.0 MiB Disk : 236.0 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 263.51 MB/s (65.8k) | 3.35 GB/s (52.4k) Write | 264.20 MB/s (66.0k) | 3.37 GB/s (52.7k) Total | 527.71 MB/s (131.9k) | 6.73 GB/s (105.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 5.56 GB/s (10.8k) | 5.62 GB/s (5.4k) Write | 5.86 GB/s (11.4k) | 5.99 GB/s (5.8k) Total | 11.42 GB/s (22.3k) | 11.61 GB/s (11.3k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 923 Mbits/sec | 936 Mbits/sec Online.net | Paris, FR (10G) | 930 Mbits/sec | 916 Mbits/sec WorldStream | The Netherlands (10G) | 905 Mbits/sec | 939 Mbits/sec Biznet | Jakarta, Indonesia (1G) | busy | busy Clouvider | NYC, NY, US (10G) | 539 Mbits/sec | 160 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 609 Mbits/sec | 458 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 438 Mbits/sec | 180 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 370 Mbits/sec | 110 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 922 Mbits/sec | 915 Mbits/sec Online.net | Paris, FR (10G) | 920 Mbits/sec | 876 Mbits/sec WorldStream | The Netherlands (10G) | 901 Mbits/sec | 925 Mbits/sec Clouvider | NYC, NY, US (10G) | 722 Mbits/sec | 201 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 605 Mbits/sec | 220 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 4506 Multi Core | 28418 Full Test | https://browser.geekbench.com/v4/cpu/16059725 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1046 Multi Core | 7243 Full Test | https://browser.geekbench.com/v5/cpu/6705216Yabs inside a Proxmox KVM. Bare metal is running 5.4.98-1-pve. The kernel in the KVM was updated to the latest Proxmox-edge-kernel, 5.11.2-1-pve.
Maybe I am gonna try 5.11 on the bare metal node.
debian@debian-kvm:~$ cat /etc/debian_version 10.8 debian@debian-kvm:~$ uname -a Linux debian-kvm 5.11.2-1 #1 SMP 5.11.2-1 zen2 (Fri, 26 Feb 2021 16:42:01 +0000) x86_64 GNU/Linux debian@debian-kvm:~$ curl -sL yabs.sh | bash -s -- -9 # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-12-29 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sat 27 Feb 2021 12:38:18 AM UTC Basic System Information: --------------------------------- Processor : AMD Ryzen 9 5950X 16-Core Processor CPU cores : 4 @ 3393.624 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 3.8 GiB Swap : 975.0 MiB Disk : 97.0 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 401.14 MB/s (100.2k) | 1.47 GB/s (23.0k) Write | 402.20 MB/s (100.5k) | 1.48 GB/s (23.2k) Total | 803.35 MB/s (200.8k) | 2.96 GB/s (46.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.50 GB/s (2.9k) | 1.48 GB/s (1.4k) Write | 1.58 GB/s (3.0k) | 1.57 GB/s (1.5k) Total | 3.09 GB/s (6.0k) | 3.05 GB/s (2.9k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 950 Mbits/sec | 937 Mbits/sec Online.net | Paris, FR (10G) | busy | busy WorldStream | The Netherlands (10G) | busy | busy Biznet | Jakarta, Indonesia (1G) | busy | busy Clouvider | NYC, NY, US (10G) | 5.54 Mbits/sec | 304 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 861 Mbits/sec | 537 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 839 Mbits/sec | 398 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 7328 Multi Core | 22341 Full Test | https://browser.geekbench.com/v4/cpu/16059939 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1736 Multi Core | 5549 Full Test | https://browser.geekbench.com/v5/cpu/6707729 debian@debian-kvm:~$Tom. 穆坦然. Not Oles. Happy New York City guy visiting Mexico! How is your 文言文?
