[Clearance Sale] NAT VPS at COST + 5 x 256MB NAT VPS Bundle @ $15 !!
hola!
We've had some unsold stock for NAT VPS, giving that away at cost price (or lower in some cases) at all locations, valid till end of this month.
VPS - NAT256 (available in Los Angeles, New York, Miami USA | Dronten, Netherlands & Zurich, Switzerland)
- 4GB NVMe SSD Disk
- 256MB DDR4 ECC RAM
- 1 vCPU (Fair Use)
- 1 x /112 IPv6 + 20 IPv4 ports
- 500GB transfer @ 1Gbps; then unlimited at reduced speed
$7 ** USD $3.99 / year** use coupon ClearNAT
Order in Los Angeles, USA
Order in New York, USA
Order in Miami, USA ==NEW LOCATION==
Order in Zurich, Switzerland ==NEW LOCATION==
Order in Dronten, Netherlands
Bundle Deal
Get 5 x 256MB location Bundle at just USD $15.5/year - that includes Los Angeles, New York, Miami, Dronten & Zurich locations>>>> Order now
APAC NAT VPS
Tokyo | Singapore | Mumbai |
4GB NVMe Disk | 4GB Disk | 4GB SSD Disk |
256MB DDR4 RAM | 256MB DDR4 RAM | 256MB DDR4 RAM |
1 x /112 IPv6 + 20 IPv4 ports | 1 x /112 IPv6 + 20 IPv4 ports | 1 x /112 IPv6 + 50 IPv4 ports |
250GB transfer @ 1Gbps; then reduced speed | 500GB transfer @ 1Gbps; then reduced speed | 250GB transfer @ 1Gbps; then reduced speed |
$12 $10 / year | $7 $5.8 / year | $12 $6.75 / year |
https://my.webhorizon.in/order/config/index/nat/?group_id=28&pricing_id=238&coupon=3vOiWfms | https://my.webhorizon.in/order/config/index/nat/?group_id=23&pricing_id=301&coupon=3vOiWfms | https://my.webhorizon.in/order/config/index/nat/?group_id=33&pricing_id=365&coupon=N7YVRdNc |
Bundle Deal
Order 3 x 256MB APAC location Bundle - Tokyo, Singapore & Mumbai - at $20/year
This is probably the lowest we have ever sell these.
Each VPS comes with a nice control panel which supports enabling tun/tap, NFS, Fuse, and PPP.
Full Netfilter support is enabled. Virtualization type is OVZ7.
OpenVPN supported.
Wireguard Supported.
You can reinstall the OS, options include Debian 9 & 10, Ubuntu 18 & 20, CentOS 7 & 8 now.
You can also upload your SSH key, so your VMs are set to use keys by default upon reinstall.
Support for Domain Forwarding - means you can have your domain served on port 80 & 443. SSL support letsencrypt certificates.
If you want to use them for VPN I highly recommend @Nyr 's script:
OpenVPN: https://github.com/Nyr/openvpn-install
Wireguard: https://github.com/Nyr/wireguard-install
Looking Glasses
Los Angeles - http://lax.lg.webhorizon.in
New York - http://nyc.lg.webhorizon.in
Zurich - http://zrh.lg.webhorizon.in
Dronten - http://dro.lg.webhorizon.in
Singapore - http://sgp3.lg.webhorizon.in
Tokyo - http://tyo.lg.webhorizon.in
Payment Methods
PayPal payments are available. We recommend using Cards via Stripe Payments.
Also BTC & XMR payments are supported.
Billing currencies: USD, EUR, GBP or INR.
For people living in India/having a card issued in India/billing address in India - Order using INR currency only - ORDER LINK
INR payment methods:
Razorpay(Cards, UPI, Netbanking, GooglePay etc), Stripe payments.
Thank you for reading.
I already enabled fuse but failed to mount remote drives.
mount helper error: fusermount: failed to open /dev/fuse: Operation not permitted
Fatal error: failed to mount FUSE fs: fusermount: exit status 1
can you guide me on this?
@Nyr wireguard script works awesome on these
Missing required permissions?
Aaron, You do not need another VPS...
But pricing is so good...
TRUE
Aaron, You do not need another VPS...USA
Aaron, You do not need another VPS..USA
Aaron, You do not need another VPS..EU
Are these the same nodes as the 4x128MB EPYC bundle you did in the past?
Alright, besides building a VPN, what are other uses for a NAT VPS?
Monitoring, hosting website, blah blah. Think of it as a glorified version of web hosting m, where you have almost root access
You're just jealous since you don't have NAT VPS.
Oh.
You actually do.
Damn.
Need a free NAT LXC? -> https://microlxc.net/
You can Nut on my Nat any time. It’s free ?
Order #603d962000260
Thank you. We have doubled your bandwidth.
But... you promised double RAM?
Please download your ram allocation here: https://downloadmoreram.com/
#StopGangViolance ?
Hola!
any looking glass for Miami location?
yes, http://mia.lg.webhorizon.in/
Hey, did you get it solved?
I think you will need to restart the vps after enabling fuse
after the migration, now all locations have one node each, except singapore & netherlands they got 2 nodes.
@Abdullah just wondering what the server specs are on the NAT bundle?
@Abdullah
i tried refresh it by reinstall, reenabled the options in panel, reboot, but got another error
mount helper error: fusermount: fuse device not found, try 'modprobe fuse' first
root@ubuntu:~# modprobe fuse
modprobe: FATAL: Module fuse not found in directory /lib/modules/3.10.0-1127.18.2.vz7.163.46
please create a ticket, so can look into your issue.
You mean each nat vps specs ?
Each vps will be:
I’m trying to understand if one can get 2x the $15.5 Bundle Deal and have the resources merged. So that one can have 512mb ram, etc, for each VPS.
I've replied your message
Can Adguard home run on this NAT VPS with default ports?
Is it possible to upgrade the old bundle to this?
Sorry, new orders only please.
It's a limited-time clearance sale, for the spare capacity we had which would otherwise be of no use.
Unfortunately no.
No, can't run a public adguard instance bcz. DNS port 53 is blocked. But a wayaround you can configure DNS-over-https, that should work.
Can also use a wireguard+adguard setup
I am pleasantly surprised by how well these NAT VPSs perform in first tests! Still have to find a good use case for them, but for the price I couldn't let these idlers escape.
