Could be due to fair share limit or something. May be start from scratch, update OS and then install Nyr script again. Dont do any if the other stuff and see if wireguard is stable. I myself dont use wireguard as I find it to be slower than v2ray.
One is layer 4 socks on top of TCP, another one is layer 3 VPN in the kernel. But I agree that a proxy is good enough in this use case. I actually think shadowsocks are more simple and beautiful.
Ping statistics for 172.217.12.174:
Packets: Sent = 11301, Received = 11101, Lost = 200 (1% loss),
Approximate round trip times in milli-seconds:
Minimum = 21ms, Maximum = 2275ms, Average = 109ms
@Aaron said:
Strange after installing HetrixTools the problem came back :-/
In that case, these two tools together very likely require more system memory than there is available.
Most software does not gently handle the case of not being able to reserve more memory whenever they want and so the software just crashes instead. Sounds a lot to me that this is the case here too.
Hetrix is working on NAT or using php version ?
Yes
Thanks , let me test it out
But i do face an issue on another NAT . It crashes everyday at 5.30 am . Only solution is to restart
Any pointers by the member's what could be the issue . Peculiarity is the time . Every day somewhere around 5.30am
Yes
sounds like a Windows problem, try calling Microsoft support.
What crashes? On what node? You give very little information on your problem.
I will not search thru all customers servers looking for your problem.
Yes
Relax its not yours . Yours are rocking . Not a single downtime or issue
Just trying to understand the issue , that's why asked
Yes
You asked the question as it was a NAT service with me.
And given the very little information provided, it is pure luck if given the correct solution.
Yes
I am relaxed, as a parent of 3 kids can be.
Will make a separate thread with more details if cant resolve it . Will check the VPS for 2/3 days
any debug logs?
can you start wg0 in foreground with some verbosity?
Thanks for v2ray mention. i will checkit out.
incase you decide using v2ray https://talk.lowendspirit.com/discussion/1564/personal-proxy-on-ipv6-nat-ipv4-server
You should make into a script
I'm lazy
Logs? Enable debug logs and go from there.
If its a OOM error (which would surprise me) or something else.
https://clients.mrvm.net
Update: I redid everything, and it seems to be working
Perhaps Hetrix agent use too much resources (I don't know how), then the OS decide to nuke wg?
Github
Yes
I do everything on 256mb SGP, works just fine.
Thanks , Got my hetrix tools also working on your NAT
FWIW: I'm running Wireguard and HetrixTools agent on multiple 128 MB NAT VPSes (on Debian 10), with no issues ...
So wonder what is issue is....
boringtun is very stable in my experience. With the information given, this is most likely an OOM issue.
Run
boringtun-upgrade
in the affected server. Does it crash immediately after that?OpenVPN installer | WireGuard installer
After completely removing HetrixTools (Sorry @Andrei ) it's been rock solid.
No , wire-guard did not crash
root@sg:~# boringtun-upgrade
boringtun 0.3.0 is up to date
Anything else to check ?
Restarting wireguard services again make wireguard work properly
Then I do not think that it is related to my installer, no idea on the root cause.
Seems to be working now =P
