Wireguard Crashing
edited March 2021 in General
  • NAT VM from @mikho
  • Debian 10 minimal
  • Wireguard installed using @Nyr script.
  • Monitoring from @Andrei Hetrix Tools
It works for a couple of minutes, then the wg0 service crashes.
Any suggestings on how to start troubleshooting?
  • ehabehab Content Writer
    any debug logs?
    can you start wg0 in foreground with some verbosity?
  • Could be due to fair share limit or something. May be start from scratch, update OS and then install Nyr script again. Dont do any if the other stuff and see if wireguard is stable. I myself dont use wireguard as I find it to be slower than v2ray.
    Thanked by (1)ehab
    @xowxenxirix said:
    Thanks for v2ray mention. i will checkit out.
    One is layer 4 socks on top of TCP, another one is layer 3 VPN in the kernel. But I agree that a proxy is good enough in this use case. I actually think shadowsocks are more simple and beautiful.
  • edited March 2021
    You should make into a script ;)
    I'm lazy :p
    • Debian 10 minimal
    Logs? Enable debug logs and go from there.
    If its a OOM error (which would surprise me) or something else.
    Thanked by (2)AaronSS skorous
  • Update: I redid everything, and it seems to be working :)
  • Ping statistics for 172.217.12.174:
    Packets: Sent = 11301, Received = 11101, Lost = 200 (1% loss),
    Approximate round trip times in milli-seconds:
    Minimum = 21ms, Maximum = 2275ms, Average = 109ms
  • Strange after installing HetrixTools the problem came back :-/
    Perhaps Hetrix agent use too much resources (I don't know how), then the OS decide to nuke wg?
  • edited March 2021
    Hetrix is working on NAT or using php version ?
    Yes
    Thanked by (1)kuduku
    In that case, these two tools together very likely require more system memory than there is available.
    Most software does not gently handle the case of not being able to reserve more memory whenever they want and so the software just crashes instead. Sounds a lot to me that this is the case here too.
    Thanked by (1)skorous
    • Debian 10 minimal
    I do everything on 256mb SGP, works just fine.
  • @mikho said:
    Yes
    Thanks , let me test it out
    But i do face an issue on another NAT . It crashes everyday at 5.30 am . Only solution is to restart
    Any pointers by the member's what could be the issue . Peculiarity is the time . Every day somewhere around 5.30am
    @kuduku said:
    @mikho said:
    Yes
    sounds like a Windows problem, try calling Microsoft support.
    What crashes? On what node? You give very little information on your problem.
    I will not search thru all customers servers looking for your problem.
  • edited March 2021
    @mikho said:
    @kuduku said:
    @mikho said:
    Yes
    Relax its not yours . Yours are rocking . Not a single downtime or issue
    Just trying to understand the issue , that's why asked
    @kuduku said:
    @mikho said:
    @kuduku said:
    @mikho said:
    Yes
    You asked the question as it was a NAT service with me.
    And given the very little information provided, it is pure luck if given the correct solution.
    I am relaxed, as a parent of 3 kids can be. ;)
  • @mikho said:
    @kuduku said:
    @mikho said:
    @kuduku said:
    @mikho said:
    Yes
    Will make a separate thread with more details if cant resolve it . Will check the VPS for 2/3 days
  • @mikho said:
    Yes
    Thanks , Got my hetrix tools also working on your NAT
  • flipsflips OG
    edited March 2021
    FWIW: I'm running Wireguard and HetrixTools agent on multiple 128 MB NAT VPSes (on Debian 10), with no issues ... :)
    Thanked by (3)alwyzon AaronSS Naix
    So wonder what is issue is....
  • boringtun is very stable in my experience. With the information given, this is most likely an OOM issue.
    Thanked by (1)vimalware
  • @kuduku said: But i do face an issue on another NAT . It crashes everyday at 5.30 am . Only solution is to restart
    Run boringtun-upgrade in the affected server. Does it crash immediately after that?
    After completely removing HetrixTools (Sorry @Andrei :( ) it's been rock solid.
    No , wire-guard did not crash
    root@sg:~# boringtun-upgrade
    boringtun 0.3.0 is up to date
    Anything else to check ?
    Restarting wireguard services again make wireguard work properly
  • @kuduku said: Anything else to check ?
    Then I do not think that it is related to my installer, no idea on the root cause.
  • edited March 2021
    Seems to be working now =P
