SSD Caching a HDD RAID array
I am recently considering SSD caching a RAID-1 HDD array.
Looking up online, there are a few tools for SSD caching like lvmcache and bcache.
Does anyone have experience using these tools ? is it safe to cache a raid array ?
Being software solutions, will they work as expected? ![]()
These are some questions I had in mind.
Feel free to share any opinions/advice ![]()
thanks!
Do not cache storage unless it is a hardware based solution. Don't.
+1,000,000 times this
If it's a RAID1, you should cache it with a RAID1 of SSDs as well, else a failure of the single SSD will cause data loss.
Unless you use it in the write-through mode, which will not deliver nearly as much of the performance benefit.
@seriesn @rm_ thanks for the advice, that helps!
I was thinking of using write-through/around mode.
RAID1 HDD + NVMe for caching
SSD caching is pointless unless you are doing a lot of synchronous writes (i.e. database writes). But most people use asynchronous data only anyway which is already cached in memory before it's written to disk. If you then cache it on another device, SSD, you will only increase your write latency and your performance will probably go down.
Also I wonder why somebody would ever SSD cache a RAID-1 array, since that consists of 2 disks. Why not make a RAID1 of two SSD disks then? Much more efficent.
Hi @martijnk
thanks for your thoughts!
I was considering read caching (better read speeds for frequently accessed files), using one SSD and a raid-1 array of two HDDs.
in the old days SSDs were small and costly, while large spinning disks cheap and available :-)
Webhosting24: We are a Hoster, so You can be a Builder.® Build something today: 1 IPv4 & /48 IPv6 subnet always included
Munich Cloud Servers: NVMe RAID10 & Unmetered Bandwidth Singapore Launch Thread - Premium Connectivity, Ryzen CPU & NVMe RAID1
Well with RAID1 you already have read speed of 2 disks. Plus frequent accessed files will also be cached in mem, so more memory might be a better option.
It really all depends on your workload though. Let's say you are seeding 500 GB of torrents constantly and you cache those on a SSD it sure might help you out. I don't see a lot of other useful scenarios though. Because with SSD read caching it has to copy the data first from the slow hdd to the ssd which will probably take a lot of time as well.
But yeah it really all depends, you should probably test both setups. One with and one without SSD caching.
Yeah figured that might be the reason
What is the different between SSD cached and 2TB SSD as swap?
in the old days before internet life was simple and i enjoyed playing outside.
Thanks! that might be the best way to know.
