Static Websites
2»
  • If you want to use a CSS Framework I'd like to recommend TailwindCSS and you can use their purge method to remove unnecessary classes ( Tailwind Production Optimization )
    I would avoid using Site builder/Template since sometimes it just adds more unnecessary things to your script. If you familiar with Jamstack go with it. But basic HTML/CSS is not really that bad if just for the personal web.
    To host it, since its only simple HTML/CSS anywhere cheap/free is good enough
  • MichaelCeeMichaelCee ModeratorOGServices Provider
    @fragpic said: You did pay to get the footer removed right?
    No my friend, that's just a mistake in trying to integrate the footer colour with the link bar. I published again and it's back.
    Thanked by (2)Ympker AaronSS
    Michael
  • I've recently discovered that bunnycdn for this is actually excellent for this despite me initially shitting on them.
    Basically a FTP folder you drop your static stuff in there and it serves it with https...in a edge distributed manner. So its both fast and simple because there is no server per se.
    Not free, but the scaling & bang per buck looks insane. Best as I can tell whether I host 1 page of 5 big sites ends up at same cost.
    (Compulsory 10 USD per year recharge i.e. buy credit...not even month charge)
    Platform - I'm exploring Gatsby. Think it'll do what I need it to.
    Also looking at combining this with fly.io and the major cloud's serverless tech since it's a good fit but that can wait till I learn more.
    Thanked by (2)AaronSS willie
  • edited April 2021
    The former looks really nice! (in fact, so nice that it makes me wonder how long it'll last this way ^^')
    As for the latter, watch out for insane bandwidth pricing, and possibly consider using Cloudflare Workers as well!
  • @havoc said: (Compulsory 10 USD per year recharge i.e. buy credit...not even month charge)
    I thought minimum spend was $1 a month, which is why I've kept my stuff on cheap shared and vps plans so far. I do occasionally get higher amounts of traffic for which a cdn would be useful.
    Yeah 3x free ipv4 seems quite a lot
    True. TBH though it would mostly be for API calls for storage so shouldn't exceed 1gb free allowance. Depends on what you do I guess
    Their documentation is self contradictory. Says $1 min on front page and $10 recharge every 12 months in the docs
    https://support.bunny.net/hc/en-us/articles/360000235911-How-does-the-BunnyCDN-credit-and-billing-system-work#0
    I suspect the front page $1 is just a simplification. Given that I've got $11 credit hoping for a free year basically.
  • Push to github and cloudflare page/netlify
  • @havoc said: Their documentation is self contradictory. Says $1 min on front page and $10 recharge every 12 months in the docs
    Not contradictory. $1 min charge against your balance each month. $10 of actual $$ has to be paid in 1x a year.
  • Use w/e static site generator that matches your favorite language >.>
