Share some Monster Benches
1568101114
  • edited December 2020
    If you're from AU or NZ, you can use -au or -nz
    curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -au
    curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -nz
    India is under development
    curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -in
    HostHatch 1 Gb/s 1TB/m for $27/y
     OS           : Debian GNU/Linux 10 (64 Bit)
     Virt/Kernel  : KVM / 4.19.0-13-amd64
     CPU Model    : Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz
     CPU Cores    : 2 @ 3000.000 MHz x86_64 16384 KB Cache
     CPU Flags    : AES-NI Enabled & VM-x/AMD-V Disabled
     Load Average : 0.00, 0.00, 0.00
     Total Space  : 39G (2.7G ~8% used)
     Total RAM    : 7978 MB (313 MB + 1803 MB Buff in use)
     Total SWAP   : 1023 MB (0 MB in use)
     Uptime       : 1 days 1:2
     ASN & ISP    : AS63473, HostHatch
     Organization : HostHatch, LLC
     Region       : New South Wales
     ## Geekbench v4 CPU Benchmark:
      Single Core : 2932  (GOOD)
       Multi Core : 5540
     ## IO Test
     CPU Speed:
        bzip2     : 107 MB/s
       sha256     : 188 MB/s
       md5sum     : 486 MB/s
     RAM Speed:
       Avg. write : 2491.7 MB/s
       Avg. read  : 6280.5 MB/s
     Disk Speed:
       1st run    : 994 MB/s
       2nd run    : 983 MB/s
       3rd run    : 904 MB/s
       Average    : 960.3 MB/s
     ## Australia & New Zealand Speedtest.net
     Location                       Upload           Download         Ping
     Nearby                         928.25 Mbit/s    931.40 Mbit/s    2.774 ms
     Australia, Sydney (Optus)      924.65 Mbit/s    925.61 Mbit/s     1.398 ms
     Australia, Melbourne (Telstra) 728.49 Mbit/s    771.84 Mbit/s    11.810 ms
     Australia, Brisbane (Telstra)  684.49 Mbit/s    736.52 Mbit/s    15.475 ms
     Australia, Adelaide (AARNet)   570.53 Mbit/s    403.54 Mbit/s    18.767 ms
     Australia, Hobart (Optus)      714.02 Mbit/s    791.39 Mbit/s    12.773 ms
     Australia, Darwin (AARNet)     191.05 Mbit/s    241.82 Mbit/s    58.152 ms
     Australia, Perth (Telstra)     272.60 Mbit/s    316.28 Mbit/s    50.890 ms
     NZ, Auckland (MyRepublic)      271.19 Mbit/s    350.51 Mbit/s    50.901 ms
     NZ, Wellington (Spark)         407.58 Mbit/s    433.75 Mbit/s    34.470 ms
     NZ, Christchurch (Vodafone)    329.00 Mbit/s    543.16 Mbit/s    39.123 ms
     Finished in : 6 min 36 sec
     Timestamp   : 2020-12-10 21:36:19 GMT
     Saved in    : /root/speedtest.log
     Share results:
     - https://www.speedtest.net/result/10568020115.png
     - https://browser.geekbench.com/v4/cpu/15931962
     - https://clbin.com/iB828
    OVH 100 Mb/s (an old VPS promo plan for $2.5/m)
     Region: AU-NZ  https://bench.monster v.1.5.5 2020-12-10
     Usage : curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -AU-NZ
     OS           : CentOS 7.9.2009 (64 Bit)
     Virt/Kernel  : KVM / 3.10.0-1160.6.1.el7.x86_64
     CPU Model    : Intel Core Processor (Haswell, no TSX)
     CPU Cores    : 1 @ 3504.000 MHz x86_64 16384 KB Cache
     CPU Flags    : AES-NI Enabled & VM-x/AMD-V Enabled
     Load Average : 0.26, 0.12, 0.08
     Total Space  : 30G (5.4G ~20% used)
     Total RAM    : 966 MB (349 MB + 451 MB Buff in use)
     Total SWAP   : 1023 MB (391 MB in use)
     Uptime       : 20 days 2:27
     ASN & ISP    : AS16276, OVH SAS
     Organization : OVH Australia PTY LTD
      Single Core : 4378  (EXCELLENT)
       Multi Core : 4137
     ## IO Test
     CPU Speed:
        bzip2     : 126 MB/s
       sha256     : 394 MB/s
       md5sum     : 564 MB/s
     RAM Speed:
       Avg. write : 3925.3 MB/s
       Avg. read  : 7714.1 MB/s
     Disk Speed:
       1st run    : 368 MB/s
       2nd run    : 365 MB/s
       3rd run    : 356 MB/s
       Average    : 363.0 MB/s
     Nearby                         98.45 Mbit/s     97.59 Mbit/s     2.965 ms
     Australia, Sydney (Optus)      99.59 Mbit/s     97.36 Mbit/s      1.223 ms
     Australia, Melbourne (Telstra) 98.26 Mbit/s     97.27 Mbit/s     11.807 ms
     Australia, Brisbane (Telstra)  99.30 Mbit/s     96.86 Mbit/s     14.998 ms
     Australia, Adelaide (AARNet)   98.96 Mbit/s     96.82 Mbit/s     18.514 ms
     Australia, Hobart (Optus)      98.80 Mbit/s     97.08 Mbit/s     12.297 ms
     Australia, Darwin (AARNet)     87.48 Mbit/s     90.69 Mbit/s     59.915 ms
     Australia, Perth (Telstra)     92.00 Mbit/s     86.99 Mbit/s     50.855 ms
     NZ, Auckland (MyRepublic)      90.34 Mbit/s     90.99 Mbit/s     50.727 ms
     NZ, Wellington (Spark)         96.41 Mbit/s     95.65 Mbit/s     34.934 ms
     NZ, Christchurch (Vodafone)    93.00 Mbit/s     95.25 Mbit/s     39.298 ms
     Finished in : 8 min 18 sec
     Timestamp   : 2020-12-10 22:18:30 GMT
     Share results:
     - https://www.speedtest.net/result/10568175619.png
     - https://browser.geekbench.com/v4/cpu/15932019
     - https://clbin.com/M8hSX
    Singapore 1 Gb/s (inferno.name $2.5/m)
     OS           : CentOS 8.3.2011 (64 Bit)
     Virt/Kernel  : KVM / 4.18.0-193.28.1.el8_2.x86_64
     CPU Model    : Intel(R) Xeon(R) CPU E5-2699 v4 @ 2.20GHz
     CPU Cores    : 1 @ 2199.906 MHz x86_64 16384 KB Cache
     Load Average : 0.13, 0.32, 0.17
     Total Space  : 20G (6.2G ~33% used)
     Total RAM    : 979 MB (182 MB + 186 MB Buff in use)
     Total SWAP   : 2048 MB (162 MB in use)
     Uptime       : 10 days 11:25
     ASN & ISP    : AS9009, ISPIRIA Networks Ltd
     Organization : ISPIRIA Networks Ltd
     Region       :
      Single Core : 3688  (VERY GOOD)
       Multi Core : 3275
     ## IO Test
     CPU Speed:
        bzip2     :  99.7 MB/s
       sha256     : 296 MB/s
       md5sum     : 454 MB/s
     RAM Speed:
       Avg. write : 1774.9 MB/s
       Avg. read  : 4232.5 MB/s
     Disk Speed:
       1st run    : 1.1 GB/s
       2nd run    : 1.1 GB/s
       3rd run    : 1.2 GB/s
       Average    : 1160.5 MB/s
     Nearby                         872.03 Mbit/s    918.48 Mbit/s    2.161 ms
     Australia, Sydney (Optus)      148.54 Mbit/s    430.12 Mbit/s   119.909 ms
     Australia, Melbourne (Telstra) 19.81 Mbit/s     85.74 Mbit/s    276.653 ms
     Australia, Brisbane (Telstra)  19.73 Mbit/s     80.34 Mbit/s    276.130 ms
     Australia, Adelaide (AARNet)   179.92 Mbit/s    510.35 Mbit/s    91.128 ms
     Australia, Hobart (Optus)      129.63 Mbit/s    394.05 Mbit/s   132.014 ms
     Australia, Darwin (AARNet)     137.34 Mbit/s    344.05 Mbit/s   153.140 ms
     Australia, Perth (Telstra)     17.36 Mbit/s     52.69 Mbit/s    315.717 ms
     NZ, Auckland (MyRepublic)      16.91 Mbit/s     53.00 Mbit/s    315.878 ms
     NZ, Wellington (Spark)         67.17 Mbit/s     159.06 Mbit/s   215.844 ms
     NZ, Christchurch (Vodafone)    58.55 Mbit/s     147.74 Mbit/s   227.401 ms
     Finished in : 7 min 56 sec
     Timestamp   : 2020-12-10 22:24:35 GMT
     Share results:
     - https://www.speedtest.net/result/10568197720.png
     - https://browser.geekbench.com/v4/cpu/15932028
     - https://clbin.com/34tG2
    Thanked by (1)cybertech
    Virmach BF special
    refer to YABS thread for VPS description
     Virt/Kernel  : KVM / 5.10.2-1.el8.elrepo.x86_64
     CPU Model    : Intel(R) Xeon(R) CPU E5-2660 0 @ 2.20GHz
    CPU Cores    : 2 @ 2199.998 MHz x86_64 4096 KB Cache
     Load Average : 0.55, 0.31, 0.14
     Total Space  : 15G (1.9G ~13% used)
     Total RAM    : 4176 MB (154 MB + 307 MB Buff in use)
     Total SWAP   : 255 MB (0 MB in use)
     Uptime       : 0 days 0:4
     ASN & ISP    : AS36352, ColoCrossing
     Organization : Virtual Machine Solutions LLC
     Region       : California
      Single Core : 1639  (POOR)
       Multi Core : 3043
     ## IO Test
     CPU Speed:
        bzip2     :  59.6 MB/s
       sha256     : 151 MB/s
       md5sum     : 304 MB/s
     RAM Speed:
       Avg. write : 1570.1 MB/s
       Avg. read  : 3003.7 MB/s
     Disk Speed:
       1st run    : 142 MB/s
       2nd run    : 559 MB/s
       3rd run    : 536 MB/s
       Average    : 412.3 MB/s
     ## Global Speedtest.net
     Nearby                         774.37 Mbit/s    869.79 Mbit/s    4.079 ms
     USA, New York (Optimum)        264.01 Mbit/s    202.98 Mbit/s    64.508 ms
     USA, Chicago (Windstream)      249.28 Mbit/s    345.39 Mbit/s    51.326 ms
     USA, Dallas (Frontier)         437.38 Mbit/s    357.82 Mbit/s    29.892 ms
     USA, Miami (Frontier)          284.45 Mbit/s    250.28 Mbit/s    60.076 ms
     USA, Los Angeles (Windstream)  786.91 Mbit/s    828.48 Mbit/s     0.703 ms
     UK, London (toob Ltd)          19.87 Mbit/s     130.86 Mbit/s   139.240 ms
     France, Lyon (SFR)             72.26 Mbit/s     110.60 Mbit/s   145.258 ms
     Germany, Berlin (DNS:NET)      115.02 Mbit/s    125.83 Mbit/s   160.156 ms
     Spain, Madrid (MasMovil)       115.81 Mbit/s    18.83 Mbit/s    170.179 ms
     Italy, Rome (Unidata)          110.93 Mbit/s    110.05 Mbit/s   162.098 ms
     Russia, Moscow (Rostelecom)    40.86 Mbit/s     46.33 Mbit/s    168.576 ms
     Israel, Haifa (013Netvision)   66.43 Mbit/s     84.07 Mbit/s    207.484 ms
     India, New Delhi (GIGATEL)     21.15 Mbit/s     90.43 Mbit/s    281.996 ms
     Singapore (FirstMedia)         75.60 Mbit/s     45.49 Mbit/s    158.410 ms
     Japan, Tsukuba (SoftEther)     157.81 Mbit/s    126.24 Mbit/s   110.771 ms
     Australia, Sydney (Optus)      118.14 Mbit/s    137.93 Mbit/s   147.110 ms
     RSA, Randburg (Cool Ideas)     19.30 Mbit/s     84.92 Mbit/s    295.257 ms
     Brazil, Sao Paulo (Criare)     69.04 Mbit/s     133.77 Mbit/s   176.282 ms
     Finished in : 12 min 6 sec
     Timestamp   : 2020-12-22 03:35:07 GMT
     Share results:
     - https://www.speedtest.net/result/10629716368.png
     - https://browser.geekbench.com/v4/cpu/15951523
     - https://clbin.com/IfzRM
    [root@cybertech ~]#
    Virmach BF special
     CPU Model    : Intel(R) Xeon(R) CPU E5-2670 v2 @ 2.50GHz
     CPU Cores    : 2 @ 2499.998 MHz x86_64 4096 KB Cache
     Load Average : 0.14, 0.03, 0.01
     Total Space  : 25G (1.9G ~8% used)
     Total RAM    : 1981 MB (150 MB + 285 MB Buff in use)
     Uptime       : 0 days 18:27
     Region       : California
      Single Core : 1865  (FAIR)
       Multi Core : 3306
     ## IO Test
     CPU Speed:
        bzip2     :  55.5 MB/s
       sha256     : 157 MB/s
       md5sum     : 352 MB/s
     RAM Speed:
       Avg. write : 1262.9 MB/s
       Avg. read  : 2833.1 MB/s
     Disk Speed:
       1st run    : 778 MB/s
       2nd run    : 877 MB/s
       3rd run    : 876 MB/s
       Average    : 843.7 MB/s
     Nearby                         328.26 Mbit/s    201.30 Mbit/s   * 52.85 ms
     USA, New York (Optimum)        232.35 Mbit/s    200.90 Mbit/s    64.977 ms
     USA, Chicago (Windstream)      257.98 Mbit/s    312.86 Mbit/s    49.626 ms
     USA, Dallas (Frontier)         139.84 Mbit/s    509.93 Mbit/s    29.821 ms
     USA, Miami (Frontier)          184.39 Mbit/s    416.15 Mbit/s    60.101 ms
     USA, Los Angeles (Windstream)  513.55 Mbit/s    805.35 Mbit/s     0.803 ms
     UK, London (toob Ltd)          19.25 Mbit/s     84.01 Mbit/s    143.876 ms
     France, Lyon (SFR)             55.43 Mbit/s     55.74 Mbit/s    155.496 ms
     Germany, Berlin (DNS:NET)      80.58 Mbit/s     79.89 Mbit/s    163.949 ms
     Spain, Madrid (MasMovil)       73.00 Mbit/s     17.62 Mbit/s    160.311 ms
     Italy, Rome (Unidata)          67.39 Mbit/s     44.98 Mbit/s    176.861 ms
     Russia, Moscow (Rostelecom)    4.31 Mbit/s      2.87 Mbit/s     175.936 ms
     Israel, Haifa (013Netvision)   43.25 Mbit/s     31.50 Mbit/s    205.942 ms
     India, New Delhi (GIGATEL)     19.93 Mbit/s     31.92 Mbit/s    285.896 ms
     Singapore (FirstMedia)         42.55 Mbit/s     24.81 Mbit/s    162.016 ms
     Japan, Tsukuba (SoftEther)     127.21 Mbit/s    67.70 Mbit/s    111.732 ms
     Australia, Sydney (Optus)      97.75 Mbit/s     261.53 Mbit/s   146.896 ms
     RSA, Randburg (Cool Ideas)     18.84 Mbit/s     64.68 Mbit/s    294.877 ms
     Brazil, Sao Paulo (Criare)     42.20 Mbit/s     70.36 Mbit/s    183.667 ms
     Finished in : 12 min 33 sec
     Timestamp   : 2020-12-22 03:31:55 GMT
     Share results:
     - https://www.speedtest.net/result/10629706934.png
     - https://browser.geekbench.com/v4/cpu/15951517
     - https://clbin.com/R3wLC
    [root@cybertech ~]#
    anynode
    product description in YAB thread
     Virt/Kernel  : KVM / 5.10.4-1.el8.elrepo.x86_64
     CPU Model    : Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz
     CPU Cores    : 1 @ 2599.998 MHz x86_64 20480 KB Cache
     Load Average : 0.24, 0.25, 0.23
     Total Space  : 30G (2.6G ~9% used)
     Total RAM    : 1981 MB (132 MB + 314 MB Buff in use)
     Uptime       : 0 days 0:26
     ASN & ISP    : AS20150, High Speed Web/Genesis 2 Networks
     Organization : CPH Inc
     Region       : Pennsylvania
      Single Core : 2305  (GOOD)
       Multi Core : 2286
     ## IO Test
     CPU Speed:
        bzip2     :  85.0 MB/s
       sha256     : 205 MB/s
       md5sum     : 395 MB/s
     RAM Speed:
       Avg. write : 1877.3 MB/s
       Avg. read  : 4608.0 MB/s
     Disk Speed:
       1st run    : 493 MB/s
       2nd run    : 500 MB/s
       3rd run    : 493 MB/s
       Average    : 495.3 MB/s
     Nearby                         197.46 Mbit/s    307.12 Mbit/s    42.369 ms
     USA, New York (Optimum)        174.71 Mbit/s    238.21 Mbit/s    64.553 ms
     USA, Chicago (Windstream)      51.65 Mbit/s     122.63 Mbit/s   210.147 ms
     USA, Dallas (Frontier)         117.33 Mbit/s    295.51 Mbit/s    40.164 ms
     USA, Miami (Frontier)          172.49 Mbit/s    272.96 Mbit/s    64.573 ms
     USA, Los Angeles (Windstream)  277.95 Mbit/s    313.87 Mbit/s    17.185 ms
     UK, London (toob Ltd)          88.09 Mbit/s     136.70 Mbit/s   124.903 ms
     France, Lyon (SFR)             108.55 Mbit/s    90.99 Mbit/s    153.943 ms
     Germany, Berlin (DNS:NET)      57.27 Mbit/s     102.99 Mbit/s   145.562 ms
     Spain, Madrid (MasMovil)       106.58 Mbit/s    93.00 Mbit/s    137.660 ms
     Italy, Rome (Unidata)          87.55 Mbit/s     89.77 Mbit/s    159.456 ms
     Russia, Moscow (Rostelecom)    20.11 Mbit/s     52.56 Mbit/s    186.286 ms
     Israel, Haifa (013Netvision)   27.08 Mbit/s     57.47 Mbit/s    206.195 ms
     India, New Delhi (GIGATEL)     21.72 Mbit/s     30.62 Mbit/s    270.092 ms
     Singapore (FirstMedia)         15.71 Mbit/s     26.52 Mbit/s    194.245 ms
     Japan, Tsukuba (SoftEther)     98.02 Mbit/s     95.67 Mbit/s    128.370 ms
     Australia, Sydney (Optus)      83.17 Mbit/s     146.40 Mbit/s   155.699 ms
     RSA, Randburg (Cool Ideas)     21.38 Mbit/s     26.46 Mbit/s    281.815 ms
     Brazil, Sao Paulo (Criare)     84.90 Mbit/s     121.13 Mbit/s   182.489 ms
     Finished in : 11 min 54 sec
     Timestamp   : 2021-01-02 07:34:19 GMT
     Share results:
     - https://www.speedtest.net/result/10681428114.png
     - https://browser.geekbench.com/v4/cpu/15969992
     - https://clbin.com/9XN3y
    hosterlabs
     Virt/Kernel  : KVM / 5.10.7-1.el8.elrepo.x86_64
    CPU Model    : AMD Ryzen 5 3600 6-Core Processor
     CPU Cores    : 2 @ 3593.234 MHz x86_64 512 KB Cache
     Load Average : 0.10, 0.03, 0.01
     Total Space  : 15G (2.3G ~16% used)
     Total RAM    : 1981 MB (126 MB + 211 MB Buff in use)
     Total SWAP   : 0 MB (0 MB in use)
     Uptime       : 0 days 4:43
     ASN & ISP    : AS24940, Hetzner Online GmbH
     Organization :
     Region       : Saxony
      Single Core : 5241  (EXCELLENT)
       Multi Core : 9053
     ## IO Test
     CPU Speed:
        bzip2     : 130 MB/s
       sha256     :   1.3 GB/s
       md5sum     : 663 MB/s
     RAM Speed:
       Avg. write : 3276.8 MB/s
       Avg. read  : 9659.7 MB/s
     Disk Speed:
       1st run    : 982 MB/s
       2nd run    : 2.2 GB/s
       3rd run    : 2.4 GB/s
       Average    : 1897.5 MB/s
     Nearby                         361.98 Mbit/s    336.56 Mbit/s    20.854 ms
     USA, New York (Optimum)        217.94 Mbit/s    269.11 Mbit/s    83.624 ms
     USA, Chicago (Windstream)      189.31 Mbit/s    98.86 Mbit/s     97.965 ms
     USA, Dallas (Frontier)         151.75 Mbit/s    95.46 Mbit/s    126.476 ms
     USA, Miami (Frontier)          165.13 Mbit/s    215.37 Mbit/s   117.214 ms
     USA, Los Angeles (Windstream)  138.49 Mbit/s    98.95 Mbit/s    141.999 ms
     UK, London (toob Ltd)          136.82 Mbit/s    474.46 Mbit/s    24.415 ms
     France, Lyon (SFR)             532.25 Mbit/s    621.62 Mbit/s    20.923 ms
     Germany, Berlin (DNS:NET)      611.49 Mbit/s    674.53 Mbit/s    15.731 ms
     Spain, Madrid (MasMovil)       475.59 Mbit/s    562.23 Mbit/s    29.586 ms
     Italy, Rome (Unidata)          367.48 Mbit/s    470.66 Mbit/s    42.438 ms
     Russia, Moscow (Rostelecom)    345.10 Mbit/s    239.70 Mbit/s    42.833 ms
     Israel, Haifa (013Netvision)   290.11 Mbit/s    171.70 Mbit/s    59.556 ms
     India, New Delhi (GIGATEL)     119.60 Mbit/s    223.11 Mbit/s   152.505 ms
     Singapore (FirstMedia)         59.36 Mbit/s     21.88 Mbit/s    180.950 ms
     Japan, Tsukuba (SoftEther)     21.56 Mbit/s     51.36 Mbit/s    258.765 ms
     Australia, Sydney (Optus)      16.28 Mbit/s     50.45 Mbit/s    298.780 ms
     RSA, Randburg (Cool Ideas)     73.80 Mbit/s     238.94 Mbit/s   179.387 ms
     Brazil, Sao Paulo (Criare)     72.18 Mbit/s     121.84 Mbit/s   190.514 ms
     Finished in : 9 min 5 sec
     Timestamp   : 2021-01-18 12:40:19 GMT
     Share results:
     - https://www.speedtest.net/result/10769831460.png
     - https://browser.geekbench.com/v4/cpu/15998214
     - https://clbin.com/8FPTO
    racknerd
    San Jose (premium Colon)
     OS           : CentOS 8 (64 Bit)
     Virt/Kernel  : KVM / 5.10.12-1.el8.elrepo.x86_64
     CPU Model    : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz
     CPU Cores    : 3 @ 2799.998 MHz x86_64 16384 KB Cache
     Load Average : 0.23, 0.17, 0.08
     Total Space  : 39G (2.1G ~6% used)
     Total RAM    : 2482 MB (157 MB + 316 MB Buff in use)
     Uptime       : 0 days 17:55
     Organization : HLM
     Region       : California
      Single Core : 2766  (GOOD)
       Multi Core : 7550
     ## IO Test
     CPU Speed:
        bzip2     :  99.8 MB/s
       sha256     : 255 MB/s
       md5sum     : 504 MB/s
     RAM Speed:
       Avg. write : 2184.5 MB/s
       Avg. read  : 4949.3 MB/s
     Disk Speed:
       1st run    : 1.7 GB/s
       2nd run    : 1.8 GB/s
       3rd run    : 1.7 GB/s
       Average    : 1774.9 MB/s
     Nearby                         665.64 Mbit/s    683.87 Mbit/s    11.485 ms
     USA, New York (Optimum)        226.20 Mbit/s    320.92 Mbit/s    70.653 ms
     USA, Chicago (Windstream)      315.62 Mbit/s    169.83 Mbit/s    47.965 ms
     USA, Dallas (Frontier)         294.53 Mbit/s    318.30 Mbit/s    37.390 ms
     USA, Miami (Frontier)          229.29 Mbit/s    143.31 Mbit/s    71.266 ms
     USA, Los Angeles (Windstream)  537.91 Mbit/s    638.19 Mbit/s     7.666 ms
     UK, London (toob Ltd)          20.09 Mbit/s     134.99 Mbit/s   133.788 ms
     France, Lyon (SFR)             86.44 Mbit/s     107.43 Mbit/s   145.118 ms
     Germany, Berlin (DNS:NET)      110.38 Mbit/s    27.75 Mbit/s    165.349 ms
     Spain, Madrid (MasMovil)       20.73 Mbit/s     57.51 Mbit/s    161.942 ms
     Italy, Rome (Unidata)          100.35 Mbit/s    118.71 Mbit/s   166.583 ms
     Russia, Moscow (Rostelecom)    80.84 Mbit/s     59.84 Mbit/s    194.468 ms
     Israel, Haifa (013Netvision)   66.56 Mbit/s     24.01 Mbit/s    204.217 ms
     India, New Delhi (GIGATEL)     25.82 Mbit/s     93.74 Mbit/s    261.200 ms
     Singapore (FirstMedia)         59.64 Mbit/s     31.29 Mbit/s    171.421 ms
     Japan, Tsukuba (SoftEther)     151.19 Mbit/s    159.28 Mbit/s   108.904 ms
     Australia, Sydney (Optus)      115.92 Mbit/s    167.22 Mbit/s   162.049 ms
     RSA, Randburg (Cool Ideas)     19.02 Mbit/s     51.15 Mbit/s    304.137 ms
     Brazil, Sao Paulo (Criare)     66.93 Mbit/s     74.65 Mbit/s    176.102 ms
     Finished in : 25 min 56 sec
     Timestamp   : 2021-02-03 03:25:16 GMT
     Share results:
     - https://www.speedtest.net/result/10861726869.png
     - https://browser.geekbench.com/v4/cpu/16024304
     - https://clbin.com/yfWWF
  • ServersGalore $16 AUD p/m Melbourne:
     OS           : Ubuntu 20.04.1 LTS (64 Bit)
     Virt/Kernel  : Dedicated / 5.4.0-64-generic
     CPU Model    : AMD EPYC Processor (with IBPB)
     CPU Cores    : 4 @ 3593.248 MHz x86_64 512 KB Cache
     Total Space  : 69G (29G ~44% used)
     Total RAM    : 5945 MB (463 MB + 5270 MB Buff in use)
     Total SWAP   : 511 MB (14 MB in use)
     Uptime       : 10 days 22:50
     ASN & ISP    : AS136557, HostRoyale AU Network
     Organization :
     Region       : Victoria
      Single Core : 5675  (EXCELLENT)
       Multi Core : 17753
     ## IO Test
     CPU Speed:
        bzip2     : 136 MB/s
       sha256     : 271 MB/s
       md5sum     : 537 MB/s
     RAM Speed:
       Avg. write : 3140.3 MB/s
       Avg. read  : 8226.1 MB/s
     Disk Speed:
       1st run    : 710 MB/s
       2nd run    : 701 MB/s
       3rd run    : 713 MB/s
       Average    : 708.0 MB/s
     Nearby                         924.67 Mbit/s    939.75 Mbit/s    1.223 ms
     Australia, Sydney (Optus)      711.98 Mbit/s    845.45 Mbit/s    11.809 ms
     Australia, Melbourne (Telstra) 913.29 Mbit/s    926.94 Mbit/s     0.610 ms
     Australia, Brisbane (Telstra)  551.59 Mbit/s    626.05 Mbit/s    24.241 ms
     Australia, Adelaide (AARNet)   761.57 Mbit/s    846.40 Mbit/s    10.215 ms
     Australia, Hobart (Optus)      901.12 Mbit/s    938.47 Mbit/s     0.867 ms
     Australia, Darwin (AARNet)     198.81 Mbit/s    342.85 Mbit/s    70.968 ms
     Australia, Perth (Telstra)     341.85 Mbit/s    470.08 Mbit/s    42.066 ms
     NZ, Auckland (MyRepublic)      322.91 Mbit/s    482.62 Mbit/s    41.701 ms
     NZ, Christchurch (Vodafone)    146.77 Mbit/s    359.71 Mbit/s    49.480 ms
     Finished in : 6 min 2 sec
     Timestamp   : 2021-02-03 03:51:02 GMT
     Share results:
     - https://www.speedtest.net/result/10861867517.png
     - https://browser.geekbench.com/v4/cpu/16024416
     - https://clbin.com/P0IJC
  • Just moved to Singapore location
    MaxKVM SKVM-4G
    an old test from @cybertech https://talk.lowendspirit.com/discussion/comment/37100/#Comment_37100
     Region: Asia  https://bench.monster v.1.5.5 2020-12-10
     Usage : curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -Asia
     Virt/Kernel  : KVM / 3.10.0-1160.11.1.el7.x86_64
     CPU Model    : AMD EPYC 7302P 16-Core Processor
     CPU Cores    : 2 @ 3000.000 MHz x86_64 512 KB Cache
     Load Average : 0.05, 0.06, 0.04
     Total Space  : 73G (1.7G ~3% used)
     Total RAM    : 3789 MB (214 MB + 303 MB Buff in use)
     Uptime       : 0 days 0:4
     ASN & ISP    : AS29802, HIVELOCITY, Inc.
     Organization : Sin1
     Region       :
      Single Core : 4478  (EXCELLENT)
       Multi Core : 7591
     ## IO Test
     CPU Speed:
        bzip2     : 120 MB/s
       sha256     : 923 MB/s
       md5sum     : 521 MB/s
     RAM Speed:
       Avg. write : 2833.1 MB/s
       Avg. read  : 8635.7 MB/s
     Disk Speed:
       1st run    : 911 MB/s
       2nd run    : 971 MB/s
       3rd run    : 928 MB/s
       Average    : 936.7 MB/s
     ## Asia Speedtest.net
     Nearby                           834.40 Mbit/s    910.82 Mbit/s    1.974 ms
     India, New Delhi (GIGATEL)       141.90 Mbit/s    443.33 Mbit/s    83.571 ms
     India, Mumbai (SevenStar)        146.70 Mbit/s    443.54 Mbit/s    60.755 ms
     India, Bengaluru (I-ON)          267.18 Mbit/s    475.43 Mbit/s    41.496 ms
     Sri Lanka, Colombo (Telecom PLC) 56.63 Mbit/s     543.12 Mbit/s    41.307 ms
     Pakistan, Islamabad (Telenor)    57.72 Mbit/s     233.20 Mbit/s   196.611 ms
     Mongolia, Ulaanbaatar (Mobicom)  50.09 Mbit/s     53.46 Mbit/s    196.755 ms
     Bangladesh, Dhaka (Skytel)       100.98 Mbit/s    47.04 Mbit/s     64.848 ms
     Bhutan, Thimphu (Bhutan Telecom) 143.10 Mbit/s    392.68 Mbit/s    75.804 ms
     Myanmar, Mandalay (Ooredoo)      184.83 Mbit/s    405.81 Mbit/s    52.972 ms
     Laos, Vientaine (Mangkone)       436.91 Mbit/s    542.86 Mbit/s    34.558 ms
     Thailand, Bangkok (CAT Telecom)  292.16 Mbit/s    479.42 Mbit/s    33.718 ms
     Cambodia, Phnom Penh (Smart)     444.41 Mbit/s    214.97 Mbit/s    21.887 ms
     Vietnam, Hanoi (Viettel)         271.27 Mbit/s    335.54 Mbit/s    52.930 ms
     Malaysia, Kuala Lumpur (Extreme) 38.24 Mbit/s     397.44 Mbit/s    40.596 ms
     Singapore (PT FirstMedia)        769.93 Mbit/s    909.21 Mbit/s     1.340 ms
     Indonesia, Jakarta (Desnet)      83.24 Mbit/s     125.36 Mbit/s    13.104 ms
     Philippines, Manila (Globe Tel)  153.65 Mbit/s    346.72 Mbit/s    51.056 ms
     Hong Kong (fdcservers)           68.83 Mbit/s     61.53 Mbit/s     85.704 ms
     Taiwan, Taipei (TAIFO)           61.42 Mbit/s     47.69 Mbit/s     92.497 ms
     Japan, Tsukuba (SoftEther)       112.39 Mbit/s    132.63 Mbit/s    78.717 ms
     Timestamp   : 2021-02-03 14:31:09 GMT
     - https://browser.geekbench.com/v4/cpu/16025107
    hostsolutions @cociu
     CPU Model    : Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz
     CPU Cores    : 2 @ 2397.222 MHz x86_64 16384 KB Cache
     Load Average : 0.32, 0.12, 0.12
     Total Space  : 49G (2.1G ~5% used)
     Total RAM    : 1981 MB (151 MB + 299 MB Buff in use)
     Uptime       : 0 days 1:9
     ASN & ISP    : AS44220, Parfumuri Femei.com SRL
     Organization : SC NETSILVANIA NETWORK SRL
     Region       : Bucharest
      Single Core : 3246  (VERY GOOD)
       Multi Core : 6171
     ## IO Test
     CPU Speed:
        bzip2     :  95.0 MB/s
       sha256     : 291 MB/s
       md5sum     : 411 MB/s
     RAM Speed:
       Avg. write : 1551.5 MB/s
       Avg. read  : 3857.1 MB/s
     Disk Speed:
       1st run    : 1.6 GB/s
       2nd run    : 1.6 GB/s
       3rd run    : 1.5 GB/s
       Average    : 1604.3 MB/s
     Nearby                         761.73 Mbit/s    785.33 Mbit/s    4.932 ms
     USA, New York (Optimum)        175.37 Mbit/s    43.13 Mbit/s    110.637 ms
     USA, Chicago (Windstream)      144.87 Mbit/s    375.30 Mbit/s   124.287 ms
     USA, Dallas (Frontier)         89.85 Mbit/s     139.38 Mbit/s   158.155 ms
     USA, Miami (Frontier)          112.69 Mbit/s    212.89 Mbit/s   160.921 ms
     USA, Los Angeles (Windstream)  110.98 Mbit/s    223.42 Mbit/s   178.945 ms
     UK, London (toob Ltd)          195.74 Mbit/s    1014.62 Mbit/s   36.096 ms
     France, Lyon (SFR)             407.51 Mbit/s    664.84 Mbit/s    44.278 ms
     Germany, Berlin (DNS:NET)      314.88 Mbit/s    638.08 Mbit/s    35.648 ms
     Spain, Madrid (MasMovil)       251.62 Mbit/s    697.70 Mbit/s    67.260 ms
     Italy, Rome (Unidata)          275.46 Mbit/s    855.73 Mbit/s    51.915 ms
     Russia, Moscow (Rostelecom)    227.80 Mbit/s    625.31 Mbit/s    80.862 ms
     Israel, Haifa (013Netvision)   181.87 Mbit/s    149.83 Mbit/s    91.206 ms
     India, New Delhi (GIGATEL)     91.98 Mbit/s     224.64 Mbit/s   160.545 ms
     Singapore (FirstMedia)         54.61 Mbit/s     41.74 Mbit/s    188.795 ms
     Japan, Tsukuba (SoftEther)     26.96 Mbit/s     26.65 Mbit/s    261.871 ms
     Australia, Sydney (Optus)      7.65 Mbit/s      50.72 Mbit/s    329.393 ms
     RSA, Randburg (Cool Ideas)     71.63 Mbit/s     51.33 Mbit/s    199.838 ms
     Brazil, Sao Paulo (Criare)     39.28 Mbit/s     129.02 Mbit/s   243.680 ms
     Finished in : 9 min 54 sec
     Timestamp   : 2021-02-04 02:52:18 GMT
  • Hosthatch 8NVMe post re-installation of Debian 10
    https://clbin.com/ZHWe3
     Virt/Kernel  : KVM / 4.19.0-14-amd64
     CPU Model    : Intel(R) Xeon(R) CPU E5-2690 0 @ 2.90GHz
     CPU Cores    : 2 @ 2899.998 MHz x86_64 20480 KB Cache
     Load Average : 0.20, 0.08, 0.08
     Total Space  : 39G (5.4G ~15% used)
     Total RAM    : 7978 MB (753 MB + 4741 MB Buff in use)
     Total SWAP   : 974 MB (0 MB in use)
     Uptime       : 0 days 21:0
     Organization : HostHatch LLC
     Region       : North Holland
      Single Core : 2771  (GOOD)
       Multi Core : 4979
     ## IO Test
     CPU Speed:
        bzip2     :  84.8 MB/s
       sha256     : 140 MB/s
       md5sum     : 423 MB/s
     RAM Speed:
       Avg. write : 2423.5 MB/s
       Avg. read  : 5768.5 MB/s
     Disk Speed:
       1st run    : 934 MB/s
       2nd run    : 998 MB/s
       3rd run    : 971 MB/s
       Average    : 967.7 MB/s
     ## India Speedtest.net
     Nearby                          1555.62 Mbit/s   920.64 Mbit/s    3.108 ms
     India, New Delhi (GIGATEL)      70.78 Mbit/s     207.25 Mbit/s   182.717 ms
     India, New Delhi (Weebo)        13.64 Mbit/s     190.04 Mbit/s   142.121 ms
     India, Mumbai (SevenStar)       96.74 Mbit/s     34.95 Mbit/s    166.289 ms
     India, Mumbai (OneBroadband)    115.49 Mbit/s    158.29 Mbit/s   115.194 ms
     India, Mumbai (SevenStar)       95.20 Mbit/s     33.92 Mbit/s    166.280 ms
     India, Bengaluru (I-ON)         64.98 Mbit/s     55.18 Mbit/s    170.057 ms
     India, Bengaluru (Activline)    100.62 Mbit/s    112.78 Mbit/s   ping error!
     Finished in : 7 min 22 sec
     Timestamp   : 2021-02-04 07:21:48 GMT
     Share results:
     - https://www.speedtest.net/result/10869097900.png
     - https://browser.geekbench.com/v4/cpu/16026193
  • edited February 2021
    Novos's EPYC
     OS           : Ubuntu 20.04.2 LTS (64 Bit)
     Virt/Kernel  : KVM / 5.4.0-65-generic
     CPU Model    : AMD EPYC 7451 24-Core Processor
     CPU Cores    : 2 @ 2295.554 MHz x86_64 512 KB Cache
     Load Average : 0.18, 0.05, 0.01
     Total Space  : 39G (7.8G ~20% used)
     Total RAM    : 3936 MB (1203 MB + 2538 MB Buff in use)
     Uptime       : 5 days 1:6
     ASN & ISP    : AS42160, lcp nv
     Organization : Novos Lease
     Region       : Flanders
      Single Core : 3083  (VERY GOOD)
       Multi Core : 5544
     ## IO Test
     CPU Speed:
        bzip2     :  89.5 MB/s
       sha256     : 175 MB/s
       md5sum     : 432 MB/s
     RAM Speed:
       Avg. write : 1589.4 MB/s
       Avg. read  : 4983.5 MB/s
     Disk Speed:
       1st run    : 665 MB/s
       2nd run    : 790 MB/s
       3rd run    : 717 MB/s
       Average    : 724.0 MB/s
     Nearby                         455.53 Mbit/s    138.41 Mbit/s    12.391 ms
     USA, New York (Optimum)        25.71 Mbit/s     19.06 Mbit/s     80.585 ms
     USA, Chicago (Windstream)      4.60 Mbit/s      7.68 Mbit/s     101.662 ms
     USA, Dallas (Frontier)         155.44 Mbit/s    19.00 Mbit/s    124.068 ms
     USA, Miami (Frontier)          28.94 Mbit/s     2.63 Mbit/s     144.125 ms
     USA, Los Angeles (Windstream)  75.73 Mbit/s     6.22 Mbit/s     154.929 ms
     UK, London (toob Ltd)          38.49 Mbit/s     41.23 Mbit/s     13.259 ms
     France, Lyon (SFR)             150.65 Mbit/s    8.88 Mbit/s      27.823 ms
     Germany, Berlin (DNS:NET)      245.96 Mbit/s    85.58 Mbit/s     33.293 ms
     Spain, Madrid (MasMovil)       194.18 Mbit/s    61.99 Mbit/s     37.733 ms
     Italy, Rome (Unidata)          392.40 Mbit/s    313.04 Mbit/s    39.680 ms
     Russia, Moscow (Rostelecom)    147.67 Mbit/s    22.92 Mbit/s     54.361 ms
     Israel, Haifa (013Netvision)   111.12 Mbit/s    12.32 Mbit/s     82.780 ms
     India, New Delhi (GIGATEL)     127.58 Mbit/s    9.13 Mbit/s     138.871        ms
     Singapore (FirstMedia)         9.40 Mbit/s      11.81 Mbit/s    190.272 ms
     Japan, Tsukuba (SoftEther)     43.89 Mbit/s     45.70 Mbit/s    227.482 ms
     Australia, Sydney (Optus)      19.11 Mbit/s     7.77 Mbit/s     296.223 ms
     RSA, Randburg (Cool Ideas)     56.89 Mbit/s     4.79 Mbit/s     166.947 ms
     Brazil, Sao Paulo (Criare)     67.06 Mbit/s     94.34 Mbit/s    201.465 ms
     Finished in : 11 min 45 sec
     Timestamp   : 2021-02-04 07:30:54 GMT
     Share results:
     - https://www.speedtest.net/result/10869116378.png
     - https://browser.geekbench.com/v4/cpu/16026199
     - https://clbin.com/9lT9A
  • Novos - Ryzen 9 3900XT
     Virt/Kernel  : Dedicated / 5.4.0-65-generic
     CPU Model    : AMD Ryzen 9 3900XT 12-Core Processor
     CPU Cores    : 2 @ 3792.872 MHz x86_64 512 KB Cache
     Load Average : 0.00, 0.02, 0.02
     Total Space  : 2.0T (6.4G ~1% used)
     Total RAM    : 3936 MB (412 MB + 1997 MB Buff in use)
     Total SWAP   : 2047 MB (0 MB in use)
     Uptime       : 7 days 22:4
     Region       : Flanders
      Single Core : 5642  (EXCELLENT)
       Multi Core : 10101
     ## IO Test
     CPU Speed:
        bzip2     : 139 MB/s
       sha256     : 280 MB/s
       md5sum     : 637 MB/s
     RAM Speed:
       Avg. write : 3413.3 MB/s
       Avg. read  : 10854.4 MB/s
     Disk Speed:
       1st run    : 1.1 GB/s
       2nd run    : 960 MB/s
       3rd run    : 1.1 GB/s
       Average    : 1070.9 MB/s
     Nearby                         468.72 Mbit/s    507.36 Mbit/s    8.978 ms
     USA, New York (Optimum)        183.87 Mbit/s    211.12 Mbit/s    91.917 ms
     USA, Chicago (Windstream)      178.71 Mbit/s    42.24 Mbit/s    101.491 ms
     USA, Dallas (Frontier)         151.98 Mbit/s    115.03 Mbit/s   120.890 ms
     USA, Miami (Frontier)          156.15 Mbit/s    93.45 Mbit/s    116.896 ms
     USA, Los Angeles (Windstream)  121.35 Mbit/s    63.39 Mbit/s    154.967 ms
     UK, London (toob Ltd)          389.51 Mbit/s    536.73 Mbit/s    13.309 ms
     France, Lyon (SFR)             426.84 Mbit/s    433.09 Mbit/s    27.697 ms
     Germany, Berlin (DNS:NET)      386.85 Mbit/s    340.36 Mbit/s    32.875 ms
     Spain, Madrid (MasMovil)       384.73 Mbit/s    454.63 Mbit/s    34.917 ms
     Italy, Rome (Unidata)          372.08 Mbit/s    383.71 Mbit/s    38.359 ms
     Russia, Moscow (Rostelecom)    283.06 Mbit/s    215.36 Mbit/s    54.275 ms
     Israel, Haifa (013Netvision)   210.82 Mbit/s    186.38 Mbit/s    75.092 ms
     India, New Delhi (GIGATEL)     119.21 Mbit/s    104.87 Mbit/s   143.711 ms
     Singapore (FirstMedia)         52.40 Mbit/s     33.89 Mbit/s    191.220 ms
     Japan, Tsukuba (SoftEther)     45.05 Mbit/s     59.63 Mbit/s    226.047 ms
     Australia, Sydney (Optus)      19.53 Mbit/s     46.83 Mbit/s    295.509 ms
     RSA, Randburg (Cool Ideas)     103.65 Mbit/s    210.15 Mbit/s   166.912 ms
     Brazil, Sao Paulo (Criare)     30.14 Mbit/s     100.90 Mbit/s   217.579 ms
     Finished in : 9 min 24 sec
     Timestamp   : 2021-02-05 12:08:43 GMT
     Share results:
     - https://www.speedtest.net/result/10876737411.png
     - https://browser.geekbench.com/v4/cpu/16028170
     - https://clbin.com/ipXNm
    https://capnhatuudai.com/en/ - Personal blog sharing promotion information, Domain Name Coupons, Hosting, VPS / Server, WordPress and the latest experiences and news from service providers around the world.
    revisit to AlphaVPS after BF.
    lookatdat ram speeeeeed.
     Virt/Kernel  : KVM / 5.10.13-1.el8.elrepo.x86_64
     CPU Model    : AMD Ryzen 9 3900X 12-Core Processor
     CPU Cores    : 4 @ 3792.874 MHz x86_64 512 KB Cache
     Total Space  : 45G (8.7G ~20% used)
     Total RAM    : 2985 MB (592 MB + 275 MB Buff in use)
     Uptime       : 0 days 0:39
     ASN & ISP    : AS18450, WebNX, Inc.
     Organization : DA International Group Ltd
     Region       : California
      Single Core : 5493  (EXCELLENT)
       Multi Core : 16849
     ## IO Test
     CPU Speed:
        bzip2     : 138 MB/s
       sha256     :   1.4 GB/s
       md5sum     : 722 MB/s
     RAM Speed:
       Avg. read  : 10001.1 MB/s
     Disk Speed:
       1st run    : 2.2 GB/s
       2nd run    : 2.2 GB/s
       3rd run    : 2.2 GB/s
       Average    : 2252.8 MB/s
     Nearby                         890.38 Mbit/s    935.17 Mbit/s    1.581 ms
     USA, New York (Optimum)        278.23 Mbit/s    334.35 Mbit/s    67.109 ms
     USA, Chicago (Windstream)      335.57 Mbit/s    474.54 Mbit/s    61.523 ms
     USA, Dallas (Frontier)         395.63 Mbit/s    408.26 Mbit/s    39.419 ms
     USA, Miami (Frontier)          255.22 Mbit/s    333.37 Mbit/s    68.624 ms
     USA, Los Angeles (Windstream)  855.32 Mbit/s    919.99 Mbit/s     1.016 ms
     UK, London (toob Ltd)          23.67 Mbit/s     144.93 Mbit/s   137.236 ms
     France, Lyon (SFR)             76.30 Mbit/s     241.25 Mbit/s   155.525 ms
     Germany, Berlin (DNS:NET)      123.46 Mbit/s    241.65 Mbit/s   164.134 ms
     Spain, Madrid (MasMovil)       117.46 Mbit/s    240.43 Mbit/s   167.152 ms
     Italy, Rome (Unidata)          120.86 Mbit/s    197.24 Mbit/s   171.241 ms
     Russia, Moscow (Rostelecom)    113.17 Mbit/s    246.76 Mbit/s   175.116 ms
     Israel, Haifa (013Netvision)   66.13 Mbit/s     149.78 Mbit/s   217.593 ms
     India, New Delhi (GIGATEL)     20.10 Mbit/s     63.40 Mbit/s    291.023 ms
     Singapore (FirstMedia)         66.16 Mbit/s     29.88 Mbit/s    168.511 ms
     Japan, Tsukuba (SoftEther)     166.77 Mbit/s    238.21 Mbit/s   123.930 ms
     Australia, Sydney (Optus)      88.79 Mbit/s     324.40 Mbit/s   150.966 ms
     RSA, Randburg (Cool Ideas)     19.39 Mbit/s     57.26 Mbit/s    297.732 ms
     Brazil, Sao Paulo (Criare)     86.98 Mbit/s     131.10 Mbit/s   172.387 ms
     Finished in : 10 min 38 sec
     Timestamp   : 2021-02-07 04:57:25 GMT
     Share results:
     - https://www.speedtest.net/result/10886537303.png
     - https://browser.geekbench.com/v4/cpu/16031074
     - https://clbin.com/FzmyV
  • My idling Letbox's 3TB Ryzen on BF
     Virt/Kernel  : KVM / 5.9.0-0.bpo.5-amd64
     CPU Cores    : 1 @ 3792.870 MHz x86_64 512 KB Cache
     Load Average : 0.11, 0.09, 0.03
     Total Space  : 2.8T (3.8G ~1% used)
     Total RAM    : 1989 MB (213 MB + 400 MB Buff in use)
     Total SWAP   : 2044 MB (0 MB in use)
     Uptime       : 0 days 0:1
     ASN & ISP    : AS13789, Internap Holding LLC
     Organization : LetBox NJ Helms Deep
     Region       : New York
      Single Core : 5320  (EXCELLENT)
       Multi Core : 5129
     ## IO Test
     CPU Speed:
        bzip2     : 141 MB/s
       sha256     : 269 MB/s
       md5sum     : 597 MB/s
     RAM Speed:
       Avg. read  : 9728.0 MB/s
     Disk Speed:
       1st run    : 1.8 GB/s
       2nd run    : 1.6 GB/s
       3rd run    : 1.8 GB/s
     Nearby                         191.17 Mbit/s    92.78 Mbit/s    * 75.884 ms
     USA, New York (Optimum)        378.07 Mbit/s    554.75 Mbit/s     5.060 ms
     USA, Chicago (Windstream)      197.79 Mbit/s    323.69 Mbit/s    22.450 ms
     USA, Dallas (Frontier)         167.39 Mbit/s    320.60 Mbit/s    43.659 ms
     USA, Miami (Frontier)          159.14 Mbit/s    318.34 Mbit/s    48.690 ms
     USA, Los Angeles (Windstream)  107.15 Mbit/s    179.42 Mbit/s    77.995 ms
     UK, London (toob Ltd)          108.80 Mbit/s    182.89 Mbit/s    67.498 ms
     France, Lyon (SFR)             126.45 Mbit/s    152.89 Mbit/s    85.384 ms
     Germany, Berlin (DNS:NET)      167.66 Mbit/s    232.67 Mbit/s    90.782 ms
     Spain, Madrid (MasMovil)       158.81 Mbit/s    18.40 Mbit/s     94.446 ms
     Italy, Rome (Unidata)          146.21 Mbit/s    127.20 Mbit/s   100.018 ms
     Russia, Moscow (Rostelecom)    108.39 Mbit/s    100.35 Mbit/s   114.869 ms
     Israel, Haifa (013Netvision)   111.61 Mbit/s    163.79 Mbit/s   138.995 ms
     India, New Delhi (GIGATEL)     66.28 Mbit/s     132.15 Mbit/s   226.802 ms
     Singapore (FirstMedia)         20.51 Mbit/s     39.84 Mbit/s    248.884 ms
     Japan, Tsukuba (SoftEther)     56.01 Mbit/s     78.08 Mbit/s    157.895 ms
     Australia, Sydney (Optus)      53.78 Mbit/s     89.93 Mbit/s    225.371 ms
     RSA, Randburg (Cool Ideas)     19.11 Mbit/s     152.34 Mbit/s   232.827 ms
     Brazil, Sao Paulo (Criare)     51.78 Mbit/s     51.14 Mbit/s    180.168 ms
     Finished in : 10 min 13 sec
     Timestamp   : 2021-02-08 03:48:25 GMT
     Share results:
     - https://www.speedtest.net/result/10891216206.png
     - https://browser.geekbench.com/v4/cpu/16032741
     - https://clbin.com/99LJy
  • Dubai $5/m
     Region: Middle-East  https://bench.monster v.1.5.5 2020-12-10
     Usage : curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -Middle-East
     Virt/Kernel  : KVM / 3.10.0-1160.el7.x86_64
     CPU Model    : Intel(R) Xeon(R) Gold 6226R CPU @ 2.90GHz
     CPU Cores    : 1 @ 2893.200 MHz x86_64 16384 KB Cache
     Load Average : 0.02, 0.10, 0.12
     Total Space  : 20G (1.2G ~7% used)
     Total RAM    : 990 MB (83 MB + 144 MB Buff in use)
     Uptime       : 0 days 0:44
     ASN & ISP    : AS9009, 3nt solutions LLP
     Organization : 3nt solutions LLP
     Region       : England
      Single Core : 4436  (EXCELLENT)
       Multi Core : 4230
     ## IO Test
     CPU Speed:
        bzip2     : 133 MB/s
       sha256     : 421 MB/s
       md5sum     : 588 MB/s
     RAM Speed:
       Avg. write : 3037.9 MB/s
       Avg. read  : 5973.3 MB/s
     Disk Speed:
       1st run    : 1.7 GB/s
       2nd run    : 1.7 GB/s
       3rd run    : 1.7 GB/s
       Average    : 1740.8 MB/s
     ## Middle East Speedtest.net
     Nearby                       133.10 Mbit/s    12.84 Mbit/s    * 220.73 ms
     Cyprus, Limassol (DragonNET) 95.01 Mbit/s     6.60 Mbit/s     180.592 ms
     Israel, Haifa (013Netvision) 89.61 Mbit/s     7.71 Mbit/s     180.966 ms
     Egypt, Cairo (Vodafone)      89.29 Mbit/s     12.18 Mbit/s    174.243 ms
     Lebanon, Tripoli (BItarNet)  2.78 Mbit/s      6.82 Mbit/s     164.927 ms
     UAE, Dubai (Orixcom)         31.07 Mbit/s     6.88 Mbit/s       0.339 ms
     Qatar, Doha (Vodafone)       127.17 Mbit/s    150.10 Mbit/s    11.763 ms
     SA, Riyadh (GO)              403.19 Mbit/s    51.02 Mbit/s     24.958 ms
     Bahrain, Manama (Zain)       380.61 Mbit/s    807.66 Mbit/s    13.971 ms
     Iran, Tehran (Fanap Telecom) 2.64 Mbit/s      32.27 Mbit/s    266.108 ms
     Finished in : 18 min 54 sec
     Timestamp   : 2021-02-17 18:02:55 GMT
     Share results:
     - https://www.speedtest.net/result/10946887025.png
     - https://browser.geekbench.com/v4/cpu/16046877
     - https://clbin.com/mFFmf
  • drServer - Intel® Atom™ C2750 (4-Core, 2.4GHz) 8GB DDR3 1x 200GB SSD 13usd/m
    CPU Model : Intel(R) Atom(TM) CPU C2750 @ 2.41GHz
    CPU Cores : 4 @ 2528.036 MHz x86_64 1024 KB Cache
    Load Average : 0.25, 0.20, 0.21
    Total Space : 182G (2.2G ~2% used)
    Total RAM : 7918 MB (119 MB + 479 MB Buff in use)
    Total SWAP : 976 MB (0 MB in use)
    Uptime : 0 days 2:43
    ASN & ISP : AS396881, drServer International
    Organization : FranTech Solutions
    Region : Delaware
              Single Core : 1274  (POOR)
               Multi Core : 3962
             ## IO Test
             CPU Speed:
                bzip2     :  50.4 MB/s
               sha256     :  72.8 MB/s
               md5sum     : 325 MB/s
             RAM Speed:
               Avg. write : 1024.0 MB/s
               Avg. read  : 2560.0 MB/s
             Disk Speed:
               1st run    : 85.2 MB/s
               2nd run    : 84.6 MB/s
               3rd run    : 46.4 MB/s
               Average    : 72.1 MB/s
         Nearby                         683.43 Mbit/s    231.70 Mbit/s    9.651 ms
         USA, New York (Optimum)        397.42 Mbit/s    208.64 Mbit/s    42.517 ms
         USA, Chicago (Windstream)      494.71 Mbit/s    219.61 Mbit/s    26.294 ms
         USA, Dallas (Frontier)         899.06 Mbit/s    239.46 Mbit/s     1.210 ms
         USA, Miami (Frontier)          440.83 Mbit/s    226.77 Mbit/s    31.740 ms
         USA, Los Angeles (Windstream)  440.86 Mbit/s    208.72 Mbit/s    29.355 ms
         UK, London (toob Ltd)          50.86 Mbit/s     121.92 Mbit/s   106.467 ms
         France, Lyon (SFR)             118.59 Mbit/s    78.48 Mbit/s    119.473 ms
         Germany, Berlin (DNS:NET)      161.20 Mbit/s    42.15 Mbit/s    125.500 ms
         Spain, Madrid (MasMovil)       183.47 Mbit/s    117.17 Mbit/s   109.802 ms
         Italy, Rome (Unidata)          142.45 Mbit/s    84.77 Mbit/s    138.087 ms
         Russia, Moscow (Rostelecom)    136.65 Mbit/s    96.93 Mbit/s    150.942 ms
         Israel, Haifa (013Netvision)   113.92 Mbit/s    96.96 Mbit/s    180.728 ms
         India, New Delhi (GIGATEL)     23.73 Mbit/s     46.66 Mbit/s    250.831 ms
         Singapore (FirstMedia)         32.51 Mbit/s     31.62 Mbit/s    206.748 ms
         Japan, Tsukuba (SoftEther)     135.32 Mbit/s    68.89 Mbit/s    145.760 ms
         Australia, Sydney (Optus)      111.73 Mbit/s    81.39 Mbit/s    188.487 ms
         RSA, Randburg (Cool Ideas)     27.23 Mbit/s     51.98 Mbit/s    270.439 ms
         Brazil, Sao Paulo (Criare)     110.41 Mbit/s    70.35 Mbit/s    138.262 ms
         Finished in : 13 min 15 sec
         Timestamp   : 2021-02-21 06:24:40 GMT
         Share results:
         - https://www.speedtest.net/result/10966816036.png
         - https://browser.geekbench.com/v4/cpu/16051821
         - https://clbin.com/Rp0t7
    Is the difference b/w Bench Monster and YABS basically Geekbench V4 vs V5 and iperf vs speedtest.net?
    edited March 2021
    something like that. YABS can choose GB v4/v5 or both in the same test.
    monster can choose either v4/v5 as well.
    monster has RAM speed test.
    Wiredblade. description in YABS thread.
    https://talk.lowendspirit.com/discussion/comment/58378/#Comment_58378
     Virt/Kernel  : KVM / 5.11.3-1.el8.elrepo.x86_64
     CPU Model    : Intel(R) Xeon(R) CPU E5-2697 v2 @ 2.70GHz
     CPU Cores    : 2 @ 2699.998 MHz x86_64 16384 KB Cache
     Load Average : 0.11, 0.10, 0.09
     Total Space  : 40G (2.1G ~6% used)
     Total RAM    : 3929 MB (158 MB + 396 MB Buff in use)
     Uptime       : 0 days 12:13
     ASN & ISP    : AS398019, Dynu Systems Incorporated
     Organization : Dynu Systems Incorporated
     Region       : Arizona
      Single Core : 2714  (GOOD)
       Multi Core : 5253
     ## IO Test
     CPU Speed:
        bzip2     :  95.2 MB/s
       sha256     : 257 MB/s
       md5sum     : 451 MB/s
     RAM Speed:
       Avg. write : 907.5 MB/s
       Avg. read  : 2730.7 MB/s
     Disk Speed:
       1st run    : 569 MB/s
       2nd run    : 664 MB/s
       3rd run    : 447 MB/s
       Average    : 560.0 MB/s
     Nearby                         807.91 Mbit/s    1417.55 Mbit/s   14.591 ms
     USA, New York (Optimum)        269.26 Mbit/s    623.60 Mbit/s    65.403 ms
     USA, Chicago (Windstream)      343.40 Mbit/s    916.51 Mbit/s    50.026 ms
     USA, Dallas (Frontier)         471.62 Mbit/s    1366.54 Mbit/s   31.424 ms
     USA, Miami (Frontier)          319.25 Mbit/s    829.94 Mbit/s    58.959 ms
     USA, Los Angeles (Windstream)  410.33 Mbit/s    772.38 Mbit/s    46.924 ms
     UK, London (toob Ltd)          40.01 Mbit/s     340.07 Mbit/s   121.200 ms
     France, Lyon (SFR)             64.83 Mbit/s     328.43 Mbit/s   145.930 ms
     Germany, Berlin (DNS:NET)      124.47 Mbit/s    301.41 Mbit/s   152.583 ms
     Spain, Madrid (MasMovil)       126.33 Mbit/s    313.68 Mbit/s   153.910 ms
     Italy, Rome (Unidata)          116.18 Mbit/s    220.50 Mbit/s   170.895 ms
     Russia, Moscow (Rostelecom)    112.81 Mbit/s    260.75 Mbit/s   173.111 ms
     Israel, Haifa (013Netvision)   68.77 Mbit/s     157.58 Mbit/s   205.610 ms
     India, New Delhi (GIGATEL)     22.10 Mbit/s     87.71 Mbit/s    246.951 ms
     Singapore (FirstMedia)         68.72 Mbit/s     41.25 Mbit/s    168.307 ms
     Japan, Tsukuba (SoftEther)     144.04 Mbit/s    275.34 Mbit/s   134.070 ms
     Australia, Sydney (Optus)      114.73 Mbit/s    279.26 Mbit/s   174.584 ms
     RSA, Randburg (Cool Ideas)     20.02 Mbit/s     120.49 Mbit/s   294.916 ms
     Brazil, Sao Paulo (Criare)     110.61 Mbit/s    159.27 Mbit/s   175.364 ms
     Finished in : 15 min 12 sec
     Timestamp   : 2021-03-08 05:28:32 GMT
     Share results:
     - https://www.speedtest.net/result/11052781716.png
     - https://browser.geekbench.com/v4/cpu/16073860
     - https://clbin.com/8UuuH
    edited March 2021
    naranjatech
    KVM-NVME-2GB
    2 GB RAM
    1 CPU Core
    30 GB NVMe
    5 TB Traffic
    1 Gbps port speed
    1 IPv4
    /64 IPv6
    mindblown
     Virt/Kernel  : KVM / 5.11.4-1.el8.elrepo.x86_64
     CPU Model    : AMD EPYC 7452 32-Core Processor
     CPU Cores    : 1 @ 2349.992 MHz x86_64 512 KB Cache
     Load Average : 0.15, 0.06, 0.07
     Total Space  : 30G (1.9G ~7% used)
     Total RAM    : 1981 MB (149 MB + 291 MB Buff in use)
     Uptime       : 0 days 2:39
     ASN & ISP    : AS41608, NextGenWebs
     Organization :
      Single Core : 4668  (EXCELLENT)
       Multi Core : 4499
     ## IO Test
     CPU Speed:
        bzip2     : 130 MB/s
       sha256     :   1.0 GB/s
       md5sum     : 535 MB/s
     RAM Speed:
       Avg. write : 3072.0 MB/s
       Avg. read  : 8396.8 MB/s
     Disk Speed:
       1st run    : 2.3 GB/s
       2nd run    : 2.4 GB/s
       3rd run    : 2.4 GB/s
       Average    : 2423.5 MB/s
     Nearby                         384.61 Mbit/s    436.61 Mbit/s    36.384 ms
     USA, New York (Optimum)        231.09 Mbit/s    119.80 Mbit/s    76.041 ms
     USA, Chicago (Windstream)      195.60 Mbit/s    207.05 Mbit/s    89.136 ms
     USA, Dallas (Frontier)         144.39 Mbit/s    191.01 Mbit/s   113.208 ms
     USA, Miami (Frontier)          157.97 Mbit/s    156.74 Mbit/s   104.528 ms
     USA, Los Angeles (Windstream)  137.95 Mbit/s    110.99 Mbit/s   134.939 ms
     UK, London (toob Ltd)          512.61 Mbit/s    698.19 Mbit/s     9.323 ms
     France, Lyon (SFR)             503.32 Mbit/s    425.52 Mbit/s    20.238 ms
     Germany, Berlin (DNS:NET)      480.75 Mbit/s    469.46 Mbit/s    21.839 ms
     Spain, Madrid (MasMovil)       462.58 Mbit/s    254.07 Mbit/s    27.318 ms
     Italy, Rome (Unidata)          412.42 Mbit/s    325.28 Mbit/s    33.773 ms
     Russia, Moscow (Rostelecom)    356.56 Mbit/s    319.25 Mbit/s    40.527 ms
     Israel, Haifa (013Netvision)   207.46 Mbit/s    196.78 Mbit/s    80.772 ms
     India, New Delhi (GIGATEL)     103.48 Mbit/s    184.51 Mbit/s   151.962 ms
     Singapore (FirstMedia)         2.56 Mbit/s      17.62 Mbit/s    197.918 ms
     Japan, Tsukuba (SoftEther)     66.68 Mbit/s     32.52 Mbit/s    197.113 ms
     Australia, Sydney (Optus)      18.97 Mbit/s     43.91 Mbit/s    281.191 ms
     RSA, Randburg (Cool Ideas)     110.22 Mbit/s    221.45 Mbit/s   173.886 ms
     Brazil, Sao Paulo (Criare)     88.37 Mbit/s     159.03 Mbit/s   183.587 ms
     Finished in : 9 min 22 sec
     Timestamp   : 2021-03-08 12:13:20 GMT
     Share results:
     - https://www.speedtest.net/result/11054322944.png
     - https://browser.geekbench.com/v4/cpu/16074366
     - https://clbin.com/X ~]#
     Organization :
       Multi Core : 4499
     ## IO Test
     CPU Speed:
        bzip2     : 130 MB/s
       sha256     :   1.0 GB/s
       md5sum     : 535 MB/s
     RAM Speed:
     Disk Speed:
       1st run    : 2.3 GB/s
       2nd run    : 2.4 GB/s
       3rd run    : 2.4 GB/s
     Share results:
     - https://clbin.com/Xrk3C
    Thanked by (2)flips Abdullah
  • Racknerd 11.11 Special with additional 1 core upgrade.
     Region: USA  https://bench.monster v.1.5.5 2020-12-10
     Usage : curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -USA
     CPU Cores    : 4 @ 2799.998 MHz x86_64 16384 KB Cache
     Load Average : 0.04, 0.04, 0.05
     Total Space  : 55G (23G ~44% used)
     Total RAM    : 2845 MB (561 MB + 1492 MB Buff in use)
     Uptime       : 0 days 23:59
     Organization : NYC Metro
     Region       : District of Columbia
      Single Core : 2215  (FAIR)
       Multi Core : 5731
     ## IO Test
     CPU Speed:
        bzip2     :  59.4 MB/s
       sha256     : 133 MB/s
       md5sum     : 349 MB/s
     RAM Speed:
       Avg. write : 1051.3 MB/s
       Avg. read  : 2867.2 MB/s
     Disk Speed:
       1st run    : 665 MB/s
       2nd run    : 505 MB/s
       3rd run    : 544 MB/s
       Average    : 571.3 MB/s
     ## USA Speedtest.net
     Nearby                          279.60 Mbit/s    364.93 Mbit/s    43.052 ms
     USA, New York (Optimum)         417.28 Mbit/s    755.45 Mbit/s     7.512 ms
     USA, Boston (Starry, Inc.)      469.17 Mbit/s    647.34 Mbit/s    12.500 ms
     USA, Washington, DC (Sprint)    603.12 Mbit/s    791.53 Mbit/s     1.890 ms
     USA, Charlotte, NC (Windstream) 404.33 Mbit/s    540.53 Mbit/s    14.991 ms
     USA, Atlanta (Frontier)         204.95 Mbit/s    648.75 Mbit/s    31.872 ms
     USA, Miami (Frontier)           149.33 Mbit/s    635.74 Mbit/s    50.819 ms
     USA, Nashville (Sprint)         360.73 Mbit/s    584.19 Mbit/s    16.774 ms
     USA, Indianapolis (Metronet)    113.48 Mbit/s    470.39 Mbit/s    31.883 ms
     USA, Cleveland (CenturyLink)    374.71 Mbit/s    619.87 Mbit/s    20.612 ms
     USA, Chicago (Windstream)       263.94 Mbit/s    598.29 Mbit/s    23.170 ms
     USA, St. Louis (Elite Fiber)    359.28 Mbit/s    381.70 Mbit/s    29.117 ms
     USA, Minneapolis (US Internet)  376.42 Mbit/s    727.76 Mbit/s    24.279 ms
     USA, Kansas City (UPNfiber)     276.76 Mbit/s    525.16 Mbit/s    39.291 ms
     USA, Oklahoma City (OneNet)     150.39 Mbit/s    365.01 Mbit/s    34.610 ms
     USA, Dallas (Windstream)        230.07 Mbit/s    434.64 Mbit/s    29.248 ms
     USA, San Antonio, TX (Sprint)   212.89 Mbit/s    470.58 Mbit/s    33.502 ms
     USA, Denver (Vistabeam)         109.38 Mbit/s    146.14 Mbit/s    59.639 ms
     USA, Albuquerque (Plateau Tel)  149.31 Mbit/s    490.05 Mbit/s    58.392 ms
     USA, Phoenix (Cox)              224.65 Mbit/s    287.64 Mbit/s    71.475 ms
     USA, Salt Lake City (UTOPIA)    217.79 Mbit/s    225.53 Mbit/s    69.603 ms
     USA, Helena, MT (The Fusion)    212.85 Mbit/s    420.58 Mbit/s    48.273 ms
     USA, Las Vegas (LV.Net)         179.04 Mbit/s    239.32 Mbit/s    66.194 ms
     USA, Seattle (Bluespan)         146.12 Mbit/s    440.43 Mbit/s    75.077 ms
     USA, San Francisco (Wiline)     196.15 Mbit/s    252.33 Mbit/s    67.784 ms
     USA, Los Angeles (Windstream)   154.73 Mbit/s    314.94 Mbit/s    66.622 ms
     USA, Anchorage (Alaska Com)     148.91 Mbit/s    371.42 Mbit/s   115.077 ms
     USA, Honolulu (Hawaiian Telcom) 150.08 Mbit/s    121.29 Mbit/s   130.923 ms
     Finished in : 12 min 34 sec
     Timestamp   : 2021-03-25 02:24:21 GMT
     Share results:
     - https://www.speedtest.net/result/11151722443.png
     - https://browser.geekbench.com/v4/cpu/16098770
     - https://clbin.com/sKGzK
  • Hosterlabs Germany AMD 5
    Any Austrians here? Look at that (barely existing) latency towards Magenta/DTAG network! :#
     CPU Model    : Intel(R) Xeon(R) E-2174G CPU @ 3.80GHz
     CPU Cores    : 1 @ 3792.038 MHz x86_64 16384 KB Cache
     Load Average : 0.19, 0.23, 0.13
     Total Space  : 197G (1.4G ~1% used)
     Total RAM    : 3946 MB (62 MB + 320 MB Buff in use)
     Uptime       : 0 days 0:17
     ASN & ISP    : AS40994, Alwyzon
     Organization : Hohl IT e.U.
     Region       : Vienna
      Single Core : 5869  (EXCELLENT)
       Multi Core : 5622
     ## IO Test
     CPU Speed:
        bzip2     : 153 MB/s
       sha256     : 261 MB/s
       md5sum     : 708 MB/s
     RAM Speed:
       Avg. write : 5870.9 MB/s
       Avg. read  : 12185.6 MB/s
     Disk Speed:
       1st run    : 1.5 GB/s
       2nd run    : 1.4 GB/s
       3rd run    : 1.3 GB/s
       Average    : 1433.6 MB/s
     ## Europe Speedtest.net
     Nearby                           876.17 Mbit/s    889.93 Mbit/s    1.509 ms
     UK, London (toob Ltd)            375.87 Mbit/s    757.72 Mbit/s    24.740 ms
     Netherlands, Amsterdam (MaxiTEL) 568.98 Mbit/s    789.23 Mbit/s    18.962 ms
     Germany, Berlin (DNS:NET)        571.36 Mbit/s    714.48 Mbit/s    22.011 ms
     Germany, Munich (InterNetX)      580.43 Mbit/s    807.81 Mbit/s    16.974 ms
     Denmark, Copenhagen (Fiberby)    526.87 Mbit/s    689.94 Mbit/s    17.079 ms
     Sweden, Stockholm (SUNET)        275.77 Mbit/s    440.46 Mbit/s    43.931 ms
     Norway, Oslo (NextGenTel)        360.22 Mbit/s    606.75 Mbit/s    34.325 ms
     France, Lyon (SFR)               420.89 Mbit/s    720.12 Mbit/s    35.942 ms
     Spain, Madrid (MasMovil)         397.93 Mbit/s    544.63 Mbit/s    35.785 ms
     Italy, Rome (Unidata)            244.37 Mbit/s    355.54 Mbit/s    64.980 ms
     Czechia, Prague (Dial Telecom)   817.41 Mbit/s    918.18 Mbit/s     5.168 ms
     Austria, Vienna (Magenta)        891.49 Mbit/s    926.09 Mbit/s     0.882 ms
     Poland, Warsaw (Orange)          392.94 Mbit/s    512.22 Mbit/s    21.023 ms
     Ukraine, Kyiv (KyivStar)         364.41 Mbit/s    511.92 Mbit/s    40.147 ms
     Latvia, Riga (Bite)              327.51 Mbit/s    544.90 Mbit/s    37.038 ms
     Russia, Moscow (Rostelecom)      251.36 Mbit/s    396.94 Mbit/s    60.101 ms
     Greece, Athens (GRNET)           468.78 Mbit/s    638.24 Mbit/s    27.216 ms
     Turkey, Istanbul (Radore)        305.73 Mbit/s    669.54 Mbit/s    49.761 ms
     Finished in : 7 min 9 sec
     Timestamp   : 2021-03-20 08:16:14 GMT
     Share results:
     - https://www.speedtest.net/result/11124712732.png
     - https://browser.geekbench.com/v4/cpu/16090964
     - https://clbin.com/u69ut
    Now, if only Magenta would finally improve the latency of their own last mile… :D
  • Contabo VPS L SSD
     Virt/Kernel  : Dedicated / 4.19.0-13-amd64
     CPU Model    : AMD EPYC 7282 16-Core Processor
     CPU Cores    : 8 @ 2800.000 MHz x86_64 512 KB Cache
     Load Average : 0.82, 1.15, 1.03
     Total Space  : 815G (257G ~33% used)
     Total RAM    : 30153 MB (12304 MB + 3228 MB Buff in use)
     Total SWAP   : 4200 MB (2057 MB in use)
     Uptime       : 103 days 10:27
     ASN & ISP    : AS51167, Contabo GmbH
     Organization : Contabo GmbH
     Region       : Bavaria
      Single Core : 4085  (EXCELLENT)
       Multi Core : 18115
     ## IO Test
     CPU Speed:
        bzip2     :  89.3 MB/s
       sha256     : 196 MB/s
       md5sum     : 400 MB/s
     RAM Speed:
       Avg. write : 1543.9 MB/s
       Avg. read  : 4778.7 MB/s
     Disk Speed:
       1st run    : 584 MB/s
       2nd run    : 562 MB/s
       3rd run    : 562 MB/s
       Average    : 569.3 MB/s
     Nearby                           165.14 Mbit/s    580.46 Mbit/s    1.53 ms
     UK, London (toob Ltd)            34.98 Mbit/s     346.17 Mbit/s    22.876 ms
     Netherlands, Amsterdam (MaxiTEL) 397.54 Mbit/s    189.18 Mbit/s    16.224 ms
     Germany, Berlin (DNS:NET)        429.52 Mbit/s    239.32 Mbit/s    16.235 ms
     Germany, Munich (InterNetX)      459.32 Mbit/s    540.60 Mbit/s    11.698 ms
     Denmark, Copenhagen (Fiberby)    266.10 Mbit/s    85.90 Mbit/s     11.687 ms
     Sweden, Stockholm (SUNET)        135.67 Mbit/s    71.56 Mbit/s     35.077 ms
     Norway, Oslo (NextGenTel)        392.06 Mbit/s    315.06 Mbit/s    26.926 ms
     France, Lyon (SFR)               421.72 Mbit/s    182.56 Mbit/s    22.635 ms
     Spain, Madrid (MasMovil)         338.39 Mbit/s    178.12 Mbit/s    40.645 ms
     Italy, Rome (Unidata)            422.40 Mbit/s    320.70 Mbit/s    20.539 ms
     Czechia, Prague (Dial Telecom)   135.12 Mbit/s    244.67 Mbit/s    16.155 ms
     Austria, Vienna (Magenta)        224.81 Mbit/s    94.36 Mbit/s     20.608 ms
     Poland, Warsaw (Orange)          143.03 Mbit/s    228.41 Mbit/s    36.179 ms
     Ukraine, Kyiv (KyivStar)         131.43 Mbit/s    267.81 Mbit/s    37.944 ms
     Latvia, Riga (Bite)              266.31 Mbit/s    131.39 Mbit/s    47.314 ms
     Russia, Moscow (Rostelecom)      294.71 Mbit/s    97.15 Mbit/s     52.962 ms
     Greece, Athens (GRNET)           37.21 Mbit/s     47.27 Mbit/s     89.827 ms
     Turkey, Istanbul (Radore)        246.16 Mbit/s    134.46 Mbit/s    62.025 ms
     Finished in : 12 min 0 sec
     Timestamp   : 2021-03-25 07:34:59 GMT
     Share results:
     - https://www.speedtest.net/result/11152695909.png
     - https://browser.geekbench.com/v4/cpu/16099014
     - https://clbin.com/BmHk8
    Hostsolutions 1TB Storage VPS
     CPU Model    : Intel(R) Xeon(R) CPU E5-2450L 0 @ 1.80GHz
     CPU Cores    : 1 @ 1795.672 MHz x86_64 16384 KB Cache
     Load Average : 0.97, 0.46, 0.68
     Total Space  : 1008G (452G ~47% used)
     Total RAM    : 987 MB (204 MB + 157 MB Buff in use) q
     Total SWAP   : 8191 MB (630 MB in use)
     Uptime       : 7 days 0:40
     Region       : Bucharest
      Single Core : 1532  (POOR)
       Multi Core : 1486
     ## IO Test
     CPU Speed:
        bzip2     :  42.1 MB/s
       sha256     :  63.2 MB/s
       md5sum     : 226 MB/s
     RAM Speed:
       Avg. write : 749.0 MB/s
       Avg. read  : 1735.6 MB/s
     Disk Speed:
       1st run    : 245 MB/s
       2nd run    : 140 MB/s
       3rd run    : 145 MB/s
       Average    : 176.7 MB/s
     Nearby                           99.34 Mbit/s     169.92 Mbit/s    23.654 ms
     UK, London (toob Ltd)            77.44 Mbit/s     134.44 Mbit/s    49.673 ms
     Netherlands, Amsterdam (MaxiTEL) 80.13 Mbit/s     86.95 Mbit/s     41.897 ms
     Germany, Berlin (DNS:NET)        80.11 Mbit/s     148.08 Mbit/s    46.874 ms
     Germany, Munich (InterNetX)      104.05 Mbit/s    254.98 Mbit/s    24.197 ms
     Denmark, Copenhagen (Fiberby)    105.86 Mbit/s    199.48 Mbit/s    24.280 ms
     Sweden, Stockholm (SUNET)        81.43 Mbit/s     106.93 Mbit/s    54.129 ms
     Norway, Oslo (NextGenTel)        89.56 Mbit/s     188.39 Mbit/s    49.705 ms
     France, Lyon (SFR)               91.63 Mbit/s     181.05 Mbit/s    43.164 ms
     Spain, Madrid (MasMovil)         86.74 Mbit/s     141.61 Mbit/s    67.213 ms
     Italy, Rome (Unidata)            96.79 Mbit/s     196.23 Mbit/s    46.979 ms
     Czechia, Prague (Dial Telecom)   101.34 Mbit/s    222.62 Mbit/s    23.142 ms
     Austria, Vienna (Magenta)        83.29 Mbit/s     192.25 Mbit/s    23.831 ms
     Poland, Warsaw (Orange)          72.78 Mbit/s     173.41 Mbit/s    37.032 ms
     Ukraine, Kyiv (KyivStar)         67.88 Mbit/s     147.61 Mbit/s    43.553 ms
     Latvia, Riga (Bite)              72.99 Mbit/s     120.13 Mbit/s    70.771 ms
     Russia, Moscow (Rostelecom)      68.87 Mbit/s     82.95 Mbit/s     68.657 ms
     Greece, Athens (GRNET)           97.86 Mbit/s     173.30 Mbit/s    46.011 ms
     Turkey, Istanbul (Radore)        95.63 Mbit/s     228.78 Mbit/s    26.076 ms
     Finished in : 15 min 16 sec
     Timestamp   : 2021-03-25 07:53:19 GMT
     Share results:
     - https://www.speedtest.net/result/11152761369.png
     - https://browser.geekbench.com/v4/cpu/16099025
     - https://clbin.com/ATm4c
  • vyasvyas OGContent Writer
    edited April 2021
    WEbhosting24- SIngapore 2 GB. Ran it witi -in flag for India specific network speeds.
     OS           : Ubuntu 20.04 LTS (64 Bit)
     Virt/Kernel  : KVM / 5.4.0-29-generic
     CPU Cores    : 1 @ 3792.872 MHz x86_64 512 KB Cache
     Load Average : 0.07, 0.02, 0.00
     Total Space  : 30G (2.1G ~8% used)
     Total RAM    : 1987 MB (90 MB + 297 MB Buff in use)
     Uptime       : 0 days 0:30
     ASN & ISP    : AS34081, incubatec network
     Organization : Impulsiva
     Region       : Trentino-Alto Adige
      Single Core : 5538  (EXCELLENT)
       Multi Core : 5341
     ## IO Test
     CPU Speed:
        bzip2     : 140 MB/s
       sha256     : 172 MB/s
       md5sum     : 665 MB/s
     RAM Speed:
       Avg. write : 3481.6 MB/s
       Avg. read  : 10752.0 MB/s
     Disk Speed:
       1st run    : 754 MB/s
       2nd run    : 767 MB/s
       3rd run    : 754 MB/s
       Average    : 758.3 MB/s
     Nearby                          779.09 Mbit/s    855.76 Mbit/s    2.59 ms
     India, New Delhi (Weebo)        231.20 Mbit/s    599.79 Mbit/s    69.916 ms
     India, Mumbai (SevenStar)       151.99 Mbit/s    498.54 Mbit/s    68.381 ms
     India, Mumbai (OneBroadband)    216.33 Mbit/s    355.37 Mbit/s    62.954 ms
     India, Mumbai (SevenStar)       131.98 Mbit/s    533.23 Mbit/s    68.399 ms
     India, Bengaluru (I-ON)         316.67 Mbit/s    422.59 Mbit/s    39.531 ms
     India, Bengaluru (Activline)    265.48 Mbit/s    159.04 Mbit/s    39.510 ms
     Finished in : 6 min 7 sec
     Timestamp   : 2021-04-03 03:47:13 GMT
     Share results:
     - https://www.speedtest.net/result/11202207780.png
     - https://browser.geekbench.com/v4/cpu/16111360
     - https://clbin.com/Zi8JH
    For Asia:
     Nearby                           876.88 Mbit/s    931.52 Mbit/s    2.427 ms
     India, Mumbai (SevenStar)        214.00 Mbit/s    322.90 Mbit/s    68.438 ms
     India, Bengaluru (I-ON)          322.84 Mbit/s    487.67 Mbit/s    39.544 ms
     Sri Lanka, Colombo (Telecom PLC) 255.03 Mbit/s    393.38 Mbit/s    48.576 ms
     Pakistan, Islamabad (Telenor)    159.88 Mbit/s    384.14 Mbit/s   107.842 ms
     Mongolia, Ulaanbaatar (Mobicom)  148.78 Mbit/s    146.09 Mbit/s    92.782 ms
     Bhutan, Thimphu (Bhutan Telecom) 167.80 Mbit/s    434.08 Mbit/s    75.606 ms
     Myanmar, Mandalay (Ooredoo)      283.94 Mbit/s    319.38 Mbit/s    53.391 ms
     Laos, Vientaine (Mangkone)       372.17 Mbit/s    311.82 Mbit/s    40.204 ms
     Thailand, Bangkok (CAT Telecom)  434.73 Mbit/s    662.43 Mbit/s    27.470 ms
     Cambodia, Phnom Penh (Smart)     367.74 Mbit/s    304.75 Mbit/s    36.649 ms
     Vietnam, Hanoi (Viettel)         111.89 Mbit/s    603.31 Mbit/s    46.454 ms
     Malaysia, Kuala Lumpur (Extreme) 624.10 Mbit/s    804.43 Mbit/s     7.039 ms
     Singapore (PT FirstMedia)        876.90 Mbit/s    938.23 Mbit/s     1.101 ms
     Indonesia, Jakarta (Desnet)      323.65 Mbit/s    349.51 Mbit/s    13.091 ms
     Philippines, Manila (Globe Tel)  407.95 Mbit/s    474.20 Mbit/s    32.148 ms
     Hong Kong (fdcservers)           398.26 Mbit/s    446.86 Mbit/s    37.910 ms
     Taiwan, Taipei (TAIFO)           198.41 Mbit/s    379.21 Mbit/s    72.949 ms
     Japan, Tsukuba (SoftEther)       111.09 Mbit/s    358.21 Mbit/s    72.007 ms
    Thanked by (2)cybertech tomazu
  • Racknerd 1.5 GB Ryzen KVM VPS (USA Speedtest)
     Virt/Kernel  : KVM / 5.4.0-70-generic
     CPU Cores    : 1 @ 3792.874 MHz x86_64 512 KB Cache
     Load Average : 0.10, 0.04, 0.01
     Total Space  : 19G (3.1G ~18% used)
     Total RAM    : 1483 MB (240 MB + 1049 MB Buff in use)
     Total SWAP   : 1535 MB (0 MB in use)
     Uptime       : 1 days 3:15
     Organization : RackNerd LLC
     Region       : New York
      Single Core : 4860  (EXCELLENT)
       Multi Core : 4699
     ## IO Test
     CPU Speed:
        bzip2     : 127 MB/s
       sha256     : 240 MB/s
       md5sum     : 555 MB/s
     RAM Speed:
       Avg. read  : 7782.4 MB/s
     Disk Speed:
       1st run    : 1.2 GB/s
       2nd run    : 1.2 GB/s
       3rd run    : 1.2 GB/s
       Average    : 1228.8 MB/s
     Nearby                          342.58 Mbit/s    125.29 Mbit/s   * 82.838 ms
     USA, New York (Optimum)         597.37 Mbit/s    381.84 Mbit/s    11.352 ms
     USA, Boston (Starry, Inc.)      335.63 Mbit/s    428.04 Mbit/s    15.995 ms
     USA, Washington, DC (Sprint)    455.90 Mbit/s    602.22 Mbit/s    17.548 ms
     USA, Charlotte, NC (Windstream) 434.81 Mbit/s    320.28 Mbit/s    27.219 ms
     USA, Atlanta (Frontier)         332.23 Mbit/s    281.06 Mbit/s    36.765 ms
     USA, Miami (Frontier)           188.95 Mbit/s    351.63 Mbit/s    41.692 ms
     USA, Nashville (Sprint)         247.70 Mbit/s    436.73 Mbit/s    29.891 ms
     USA, Indianapolis (Metronet)    490.59 Mbit/s    574.79 Mbit/s    17.647 ms
     USA, Cleveland (CenturyLink)    432.98 Mbit/s    320.84 Mbit/s    22.064 ms
     USA, Chicago (Windstream)       571.09 Mbit/s    617.87 Mbit/s    10.625 ms
     USA, St. Louis (Elite Fiber)    475.77 Mbit/s    604.67 Mbit/s    19.793 ms
     USA, Minneapolis (US Internet)  468.76 Mbit/s    368.04 Mbit/s    22.184 ms
     USA, Kansas City (UPNfiber)     204.79 Mbit/s    140.89 Mbit/s    24.626 ms
     USA, Oklahoma City (OneNet)     237.13 Mbit/s    320.32 Mbit/s    36.224 ms
     USA, Dallas (Windstream)        304.45 Mbit/s    329.96 Mbit/s    36.103 ms
     USA, San Antonio, TX (Sprint)   180.90 Mbit/s    404.20 Mbit/s    40.841 ms
     USA, Denver (Vistabeam)         325.56 Mbit/s    272.08 Mbit/s    35.555 ms
     USA, Albuquerque (Plateau Tel)  242.76 Mbit/s    226.12 Mbit/s    43.417 ms
     USA, Phoenix (Cox)              171.06 Mbit/s    231.80 Mbit/s    80.111 ms
     USA, Salt Lake City (UTOPIA)    144.25 Mbit/s    99.05 Mbit/s     50.526 ms
     USA, Helena, MT (The Fusion)    220.76 Mbit/s    330.58 Mbit/s    42.031 ms
     USA, Las Vegas (LV.Net)         168.44 Mbit/s    212.91 Mbit/s    75.821 ms
     USA, Seattle (Bluespan)         153.05 Mbit/s    500.05 Mbit/s    65.382 ms
     USA, San Francisco (Wiline)     184.88 Mbit/s    223.73 Mbit/s    70.749 ms
     USA, Los Angeles (Windstream)   207.45 Mbit/s    313.78 Mbit/s    55.833 ms
     USA, Anchorage (Alaska Com)     144.92 Mbit/s    102.36 Mbit/s    88.701 ms
     USA, Honolulu (Hawaiian Telcom) 95.75 Mbit/s     98.65 Mbit/s    140.709 ms
     Finished in : 11 min 28 sec
     Timestamp   : 2021-04-03 10:06:50 GMT
     Share results:
     - https://www.speedtest.net/result/11203306855.png
     - https://browser.geekbench.com/v4/cpu/16111686
     - https://clbin.com/baSab
    edited April 2021
    Webhosting24 - Munich
    Click to view
    (gif screencapture)
    Edit: click to view. See comment below
    mate I can't see the results I wonder if my internet is slow
    The file is 81.6 MB in size. An 81.6 MB GIF.
