UK KVM 50% off - SSD cached - LIMITED Quantity
InceptionHosting
Hosting ProviderOG
The final BF offer from Inception Hosting
50% off on Quarterly, Semi-annual and Annual terms.
UK SSD cached KVM.
Nodes: E5-2640v4, DDR4, SAS Raid 10 (8 disk) + 2 x Samsung 960 Pro's in hardware cachecade (read+write cache)
Packages available:
- RAM: From 512mb to 6GB
- DISK: From 10GB to 120GB
- BW: 500GB to 4TB
Additional IP's = 1 Free on plans with 3GB Ram+
All plans benefit from DDOS protection and free Direct Admin licenses (on request)
Coupon Code: BF2019-KVMUK
Product Links: https://clients.inceptionhosting.com/cart.php?gid=27
Depending on the mix bought this could last a very short amount of time, it is limited quantity.
Am I doing something wrong?
Website: thomassen.sh
Discord: Decicus#0001
No, I set it to 0% discount, sorry my fault, should be ok now.
Arrgh, you got me! :-D Grabbed a 2G.
Can you change it to 0% payment please?
Thanks for the offer @AnthonySmith. Ordered another server to add to my growing Inception collection.
Bought a slightly beefier one. Hope it's just as reliable as the last one.
------------------------------------------------- nench.sh v2019.07.20 -- https://git.io/nench.sh benchmark timestamp: 2019-12-01 13:03:03 UTC ------------------------------------------------- Processor: Intel(R) Xeon(R) CPU E5-2640 v4 @ 2.40GHz CPU cores: 4 Frequency: 2399.996 MHz RAM: 3.9G Swap: 4.0G Kernel: Linux 3.10.0-1062.4.3.el7.x86_64 x86_64 Disks: vda 80G HDD CPU: SHA256-hashing 500 MB 2.569 seconds CPU: bzip2-compressing 500 MB CPU: AES-encrypting 500 MB 1.908 seconds ioping: seek rate min/avg/max/mdev = 74.4 us / 229.2 us / 299.9 ms / 2.45 ms ioping: sequential read speed generated 12.9 k requests in 5.00 s, 3.14 GiB, 2.57 k iops, 643.3 MiB/s dd: sequential write speed 1st run: 302.31 MiB/s 2nd run: 260.35 MiB/s 3rd run: 304.22 MiB/s average: 288.96 MiB/s IPv4 speedtests your IPv4: 185.187.154.xxxx Cachefly CDN: 106.53 MiB/s Leaseweb (NL): 68.84 MiB/s Softlayer DAL (US): 13.10 MiB/s Online.net (FR): 54.60 MiB/s OVH BHS (CA): 8.02 MiB/s IPv6 speedtests your IPv6: 2a04:92c7:e:xxxx Leaseweb (NL): 72.19 MiB/s Softlayer DAL (US): 6.68 MiB/s Online.net (FR): 63.42 MiB/s OVH BHS (CA): 9.20 MiB/s -------------------------------------------------The promotion code you entered has been applied to your cart but no items qualify for the discount yet - please check the promotion terms
It this promo code run out
P/S: change to quarterly period and DONE. Thanks!
Double Arrgh! Bought the wrong thing: somehow I chose UK-SSD-KVM-2048 instead of UK-KVM2048.
Feckin eejit!
(The "SSD cached" must've flung me off course
I live :-(
EDIT: @AnthonySmith cancellations/exchanges allowed? [Grasping at straws]
Thanks for fixing me up, Ant.
