how to add network route while in debian install
2»
  • @yoursunny said:
    @miu said:
    and for checking of gateway i use also these commands route -n ; netstat -rn ; ip route show
    route and netstat are deprecated and no longer installed in newer systems.
    Use ip route and ss instead.
    While that is true, I still keep netstat around because I consider the way ss formats its output awful; especially when you use the -p option. You can get the old tools back by installing the net-tools package, btw; at least in Debian 10 that is still the case.
    Thanked by (1)miu
