Share your most valued AMD EPYC/RYZEN VPS / Dedicated
This is the AMD powerhouse, show us what you got.
Was lucky to grab one of this during BF from AlphaVPS:
4 vCPU
3GB DDR4
45GB NVMe
3TB @ 1gbps
LAX
EUR 45/year
Performance has been smashing since half a year now.
load is either very well managed or I'm on a friendly node.
[root@cybertech ~]# curl -sL yabs.sh | bash -s -- -4 # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-12-29 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sun May 2 12:29:08 +08 2021 Basic System Information: --------------------------------- Processor : AMD Ryzen 9 3900X 12-Core Processor CPU cores : 4 @ 3792.874 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 2.9 GiB Swap : 64.0 MiB Disk : 44.9 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 329.66 MB/s (82.4k) | 1.22 GB/s (19.2k) Write | 330.53 MB/s (82.6k) | 1.23 GB/s (19.3k) Total | 660.20 MB/s (165.0k) | 2.46 GB/s (38.5k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.37 GB/s (2.6k) | 1.36 GB/s (1.3k) Write | 1.44 GB/s (2.8k) | 1.45 GB/s (1.4k) Total | 2.82 GB/s (5.5k) | 2.81 GB/s (2.7k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 840 Mbits/sec | 839 Mbits/sec Online.net | Paris, FR (10G) | 821 Mbits/sec | 790 Mbits/sec WorldStream | The Netherlands (10G) | 814 Mbits/sec | 845 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 735 Mbits/sec | 253 Mbits/sec Clouvider | NYC, NY, US (10G) | 903 Mbits/sec | 903 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 887 Mbits/sec | 877 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 931 Mbits/sec | 934 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 789 Mbits/sec | 633 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 5236 Multi Core | 14844 Full Test | https://browser.geekbench.com/v4/cpu/16151746
---------------------------------------------------------------------- CPU Model : AMD Ryzen 9 3900X 12-Core Processor CPU Cores : 4 CPU Frequency : 3792.874 MHz CPU Cache : 512 KB Total Disk : 45.0 GB (8.2 GB Used) Total Mem : 2985 MB (544 MB Used) Total Swap : 63 MB (63 MB Used) System uptime : 14 days, 2 hour 34 min Load average : 0.32, 0.46, 0.23 OS : CentOS Linux release 8.3.2011 Arch : x86_64 (64 Bit) Kernel : 5.11.15-1.el8.elrepo.x86_64 TCP CC : bbr Virtualization : KVM Organization : AS18450 WebNX, Inc. Location : Los Angeles / US Region : California ---------------------------------------------------------------------- I/O Speed(1st run) : 2.3 GB/s I/O Speed(2nd run) : 2.4 GB/s I/O Speed(3rd run) : 2.3 GB/s Average I/O speed : 2389.3 MB/s ---------------------------------------------------------------------- Node Name Upload Speed Download Speed Latency Speedtest.net 840.97 Mbps 670.65 Mbps 1.45 ms Beijing CU 549.21 Mbps 636.42 Mbps 144.57 ms Shanghai CT 195.39 Mbps 921.24 Mbps 253.01 ms Shanghai CU 521.37 Mbps 953.25 Mbps 147.88 ms Guangzhou CT 311.48 Mbps 935.65 Mbps 258.04 ms Shenzhen CU 416.59 Mbps 935.27 Mbps 180.74 ms Hongkong CN 418.04 Mbps 920.93 Mbps 177.65 ms Singapore SG 437.02 Mbps 869.67 Mbps 166.07 ms Tokyo JP 213.20 Mbps 5.60 Mbps 114.81 ms ---------------------------------------------------------------------
Ryzen dedi bench alllowed?
of course! would be even better
edited topic to include dedicated
Too bad it is running Windows and WSL doesn't want to run yabs
I was very lucky to get a Ryzen VPS from @DataIdeas during Black Friday. Their site was basically dead when it got posted. Will post a yabs later.
I believe the specs were:
Ryzen 9 3900X (1 vCore)
1GB Memory
10GB SSD Storage
1 IPv4 & 1 IPv6
Unmetered BW
$0.50/month (billed monthly)
Also got a nice Ryzen VPS from Nexril.
Ryzen 9 3950X (1 vCore)
1GB Memory
15GB SSD Storage
1 IPv4 & /64 IPv6
1TB Transfer
$1/month (billed yearly)
Both pretty solid, I used to run a website on the first one, but now it's just idling because I ended up having to move the website over to another VPS since it got popular. Both have been pretty solid so far, although DataIdeas has had some downtime lately.
I was lucky to got the following one from NaranjaTech
4 vCPU EPYC 7452
8GB DDR4
120GB NVMe
20TB @ 1gbps
AMS
EUR 80/year
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-12-29 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed 24 Mar 2021 05:10:11 PM EDT Basic System Information: --------------------------------- Processor : AMD EPYC 7452 32-Core Processor CPU cores : 4 @ 2349.992 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 7.8 GiB Swap : 255.0 MiB Disk : 117.8 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 258.91 MB/s (64.7k) | 3.00 GB/s (46.9k) Write | 259.60 MB/s (64.9k) | 3.02 GB/s (47.2k) Total | 518.51 MB/s (129.6k) | 6.02 GB/s (94.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 5.52 GB/s (10.7k) | 5.41 GB/s (5.2k) Write | 5.81 GB/s (11.3k) | 5.77 GB/s (5.6k) Total | 11.33 GB/s (22.1k) | 11.18 GB/s (10.9k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 933 Mbits/sec | 935 Mbits/sec Online.net | Paris, FR (10G) | 930 Mbits/sec | 772 Mbits/sec WorldStream | The Netherlands (10G) | 925 Mbits/sec | 938 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 511 Mbits/sec | 181 Mbits/sec Clouvider | NYC, NY, US (10G) | 393 Mbits/sec | 262 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 687 Mbits/sec | 440 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 415 Mbits/sec | 160 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 282 Mbits/sec | 177 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 911 Mbits/sec | 922 Mbits/sec Online.net | Paris, FR (10G) | 912 Mbits/sec | 845 Mbits/sec WorldStream | The Netherlands (10G) | 896 Mbits/sec | 921 Mbits/sec Clouvider | NYC, NY, US (10G) | 786 Mbits/sec | 286 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 487 Mbits/sec | 182 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 940 Multi Core | 3644 Full Test | https://browser.geekbench.com/v5/cpu/7106249Performance is solid becaue of no steal and good IO, and I can use up to 50% CPU on average:
Linux 4.19.0-5-amd64 (run1) 05/02/2021 _x86_64_ (4 CPU) avg-cpu: %user %nice %system %iowait %steal %idle 21.88 0.00 0.15 0.01 0.00 77.97wuuuuuut.....
Hi @cybertech
Hetzner AX101 Ryzen 9 5950X bare metal
root@Proxmox-VE ~ # curl -sL yabs.sh | bash -s -- -9 # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-12-29 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sun 02 May 2021 05:01:31 AM UTC Basic System Information: --------------------------------- Processor : AMD Ryzen 9 5950X 16-Core Processor CPU cores : 32 @ 2200.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 125.8 GiB Swap : 16.0 GiB Disk : 3.4 TiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 662.15 MB/s (165.5k) | 1.46 GB/s (22.9k) Write | 663.90 MB/s (165.9k) | 1.47 GB/s (23.0k) Total | 1.32 GB/s (331.5k) | 2.94 GB/s (45.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.48 GB/s (2.8k) | 1.49 GB/s (1.4k) Write | 1.56 GB/s (3.0k) | 1.59 GB/s (1.5k) Total | 3.04 GB/s (5.9k) | 3.09 GB/s (3.0k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 931 Mbits/sec | 927 Mbits/sec Online.net | Paris, FR (10G) | 936 Mbits/sec | 936 Mbits/sec WorldStream | The Netherlands (10G) | busy | 937 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 735 Mbits/sec | 316 Mbits/sec Clouvider | NYC, NY, US (10G) | 885 Mbits/sec | 530 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 857 Mbits/sec | 455 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 839 Mbits/sec | 471 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 919 Mbits/sec | 917 Mbits/sec Online.net | Paris, FR (10G) | 923 Mbits/sec | 924 Mbits/sec WorldStream | The Netherlands (10G) | 921 Mbits/sec | 924 Mbits/sec Clouvider | NYC, NY, US (10G) | 872 Mbits/sec | 418 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 824 Mbits/sec | 330 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 7051 Multi Core | 62187 Full Test | https://browser.geekbench.com/v4/cpu/16151777 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1661 Multi Core | 14117 Full Test | https://browser.geekbench.com/v5/cpu/7687675 root@Proxmox-VE ~ #Tom. 穆坦然. Not Oles. Happy New York City guy visiting Mexico! How is your 文言文?
There was a thread about Slackware on HN a couple of days ago. The original HN poster mentioned in a comment that in the Slackware changelog for April 12 and February 15, Patrick Volkerding had referred to a beta for Slackware 15. So I had to go grab Slackware current and install it inside a KVM. I will set up IPv6 too, of course.
Slackware seems to have a minimal KVM virtualization penalty on Geekbench 5: Single Core score 1687 vs. 1661 on bare metal. I've seen the bare metal higher, 1673, 1719, and 1725.
root@slack:~# uname -a Linux slack.metalvps.com 5.10.33 #1 SMP Wed Apr 28 12:55:31 CDT 2021 x86_64 AMD Ryzen 9 5950X 16-Core Processor AuthenticAMD GNU/Linux root@slack:~# wget -qO- yabs.sh | bash # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-12-29 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sun May 2 04:00:57 UTC 2021 Basic System Information: --------------------------------- Processor : AMD Ryzen 9 5950X 16-Core Processor CPU cores : 8 @ 3393.624 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 7.8 GiB Swap : 4.0 GiB Disk : 191.9 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 371.54 MB/s (92.8k) | 1.47 GB/s (23.1k) Write | 372.52 MB/s (93.1k) | 1.48 GB/s (23.2k) Total | 744.06 MB/s (186.0k) | 2.96 GB/s (46.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.50 GB/s (2.9k) | 1.46 GB/s (1.4k) Write | 1.58 GB/s (3.0k) | 1.55 GB/s (1.5k) Total | 3.08 GB/s (6.0k) | 3.01 GB/s (2.9k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 938 Mbits/sec | 928 Mbits/sec Online.net | Paris, FR (10G) | 936 Mbits/sec | 937 Mbits/sec WorldStream | The Netherlands (10G) | 933 Mbits/sec | 937 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 760 Mbits/sec | 245 Mbits/sec Clouvider | NYC, NY, US (10G) | 898 Mbits/sec | 381 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 857 Mbits/sec | 467 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 841 Mbits/sec | 359 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1687 Multi Core | 8290 Full Test | https://browser.geekbench.com/v5/cpu/7687105 root@slack:~#Tom. 穆坦然. Not Oles. Happy New York City guy visiting Mexico! How is your 文言文?
Okay, here is the Slackware KVM with IPv6 now enabled:
root@slack:~# curl -sL yabs.sh | bash -s -- -9 # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-12-29 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon May 3 02:49:42 UTC 2021 Basic System Information: --------------------------------- Processor : AMD Ryzen 9 5950X 16-Core Processor CPU cores : 8 @ 3393.624 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 7.8 GiB Swap : 4.0 GiB Disk : 191.9 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 382.46 MB/s (95.6k) | 1.45 GB/s (22.7k) Write | 383.47 MB/s (95.8k) | 1.46 GB/s (22.8k) Total | 765.94 MB/s (191.4k) | 2.91 GB/s (45.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.48 GB/s (2.8k) | 1.48 GB/s (1.4k) Write | 1.56 GB/s (3.0k) | 1.58 GB/s (1.5k) Total | 3.04 GB/s (5.9k) | 3.06 GB/s (2.9k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 945 Mbits/sec | 926 Mbits/sec Online.net | Paris, FR (10G) | 936 Mbits/sec | 937 Mbits/sec WorldStream | The Netherlands (10G) | 934 Mbits/sec | 937 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 761 Mbits/sec | 207 Mbits/sec Clouvider | NYC, NY, US (10G) | 892 Mbits/sec | 376 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 856 Mbits/sec | 524 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 836 Mbits/sec | 445 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 934 Mbits/sec | 920 Mbits/sec Online.net | Paris, FR (10G) | 933 Mbits/sec | 924 Mbits/sec WorldStream | The Netherlands (10G) | 921 Mbits/sec | 924 Mbits/sec Clouvider | NYC, NY, US (10G) | 882 Mbits/sec | 321 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 821 Mbits/sec | 278 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 6284 Multi Core | 34458 Full Test | https://browser.geekbench.com/v4/cpu/16153174 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1669 Multi Core | 8291 Full Test | https://browser.geekbench.com/v5/cpu/7701369 root@slack:~#Tom. 穆坦然. Not Oles. Happy New York City guy visiting Mexico! How is your 文言文?
Your IO are exceptionally good
@Mason Do you mind making yabs for Windows
? I hope you would love to do that
Last I tried, it worked perfectly fine using WIndows Subsystem Linux, beyond that I probably won't pursue Windows compatibility.
Humble janitor of LES
Proud papa of YABS
Well probably it just doesnt work for me lol
Mon May 3 14:53:27 CEST 2021 Basic System Information: ... (output cutted out) fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 0.00 KB/s (0) | 0.00 KB/s (0) Write | 0.00 KB/s (0) | 0.00 KB/s (0) Total | 0.00 KB/s (0) | 0.00 KB/s (0) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 0.00 KB/s (0) | 0.00 KB/s (0) Write | 0.00 KB/s (0) | 0.00 KB/s (0) Total | 0.00 KB/s (0) | 0.00 KB/s (0) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | busy | busy Online.net | Paris, FR (10G) | busy | busy WorldStream | The Netherlands (10G) | busy | busy Biznet | Jakarta, Indonesia (1G) | busy | busy Clouvider | NYC, NY, US (10G) | busy | busy Velocity Online | Tallahassee, FL, US (10G) | busy | busy Clouvider | Los Angeles, CA, US (10G) | busy | busy Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy ... (Geekbench output cutted out)here's mine on naranjatech too. top stuff.
EPYC 1 vCore
2GB Ram
30GB NVMe Disk
5TB BW
20 €/year (+vat if applicable)
@valkyrie WSL 1 or 2?
Github
WSL 2 and it should really run as I ran one on my test rig at home and it ran fine, maybe a buggy installation I guess
