@foxone said:
Can you tell more about the DDoS protection?
It is adequate in 999 cases out of 1000, the specific details of it are not made public though as knowing what you are up against can in itself assist in the attack.
For anything the complimentary mitigation does not handle a custom ruleset can be quoted for, to prevent particular specific attack types.
He posted one in his other deal: https://talk.lowendspirit.com/discussion/2936/20-uses-only-4gb-nl-plan-6-month-amsterdam-ddos-protection-free-da-free-cookies-kvm
NL
Hi, @InceptionHosting My Disk is a bit slow for Pure NVMe SSD, Can you do something about it?
We have a support department so I am sure we can yes,
It is worth checking the obvious first through, like that you are not using the ide drivers (manageable via the control panel)
ok. I will open a ticket. I checked the Disk Driver, my driver is virtio
