Looking for NAT VPS // Small VPS
Looking for cheap NAT VPS // Small VPS can be KVM or OpenVZ.
I will just use it as a TCP forwarder for my system.
Preffered Location : Singapore, Tokyo
Budget : $7-$20 yrly (depends on BW and specs)
BW : 500GB-1TB (more better)
DDoS Protection is a bonus, but atleast some protection is required.
I will just install haproxy on it. I will take from multiple provider and can be the same provider but must be deployed on different nodes. Thanks.
P.S : I already have a few from Gullo and WebHorizon but they just have limited nodes. I prefer different hosts/nodes for failover so if someone isnt working the other works.
--I always need help..pff
