Im looking for test ips to ping to check latency on different ovh datacenters, but cannot find anything useful. I can find network status and speedtests and stuff, but i need the ping tests. Does anyone have services with ovh that i can ping?
@xreann20 said:
You can use lg.ovh.net There you can see the prefixes like sgp//sbg//rbx etc..then just ping the hostnames example sgp.lg.ovh.net .. easy as that!
Thats what i found out too right after posting this, thank you!
Turns out my UK ovh has 5ms more ping than Frankfurt, so im not gonna bother changing location. Not worth the effort.
It doesn't seem to be documented anywhere, but it's
sbg.proof.ovh.net
,gra.proof.ovh.net
,rbx.proof.ovh.net
, etc...— Michael
--I always need help..pff
